View Full Version : Diamante
- 92-95 Mitsubishi Diamante K&N Air Filter for Sale
- 93 diamante intermittent heat
- Starter grinds and won't engage
- Diamante Turns Over, Won't Start
- Mitsubishi diamante trouble codes?
- replacing a serpentine belt
- 1997 diamante ls (headligh problem)
- Warning: 'lmi turbos'
- Engine knocking need help!!
- Headlight Assembly
- 93 diamante overdrive problem
- 93 diamante exhaust
- 6g74
- 1992 diamante manual
- 1995 Diamante crankshaft pulley removal
- fuel tank leak?
- Diamante Manual
- 97 Diamante, wont spin or start
- 02 VRX Power Steering Belt Problem
- 03 radio replacement/ code
- Looking for a 1998 Mitsubishi Diamante Bumper Cover
- white smoke that smells like fuel
- 92 Diamante, no spark
- Need Some Help - 2001 Diamante - P0431, P0401, P0403
- 93 diamante exhaust smoke
- looking to purchace
- Harmonic Balancer
- window wipers on 99
- 2003 mitsu diamonte
- 1999 3.0 smokes after 5 minutes of idling
- Need help on Oxygen sensor
- 1992 Diamante lack of power
- Anyone Else Have This Problem?
- 95 Diamante LS 6cyl smoke & OBD code
- Mitsubishi 2.5l 6G73 Severe sag/hesitation
- 2002 VRX Timing belt replacement any ideas?
- Contstant click dependant on revs.
- 1995 diamante-brake adjuster
- foot brake
- sleeper
- Going through antifreeze....
- Changing Head Gasket
- Diamante/Magna/Sigma/Verada Hood
- Engine Knock (or tapping)
- 96 Possible Tranny Problems? Maybe a Sensor?
- Problem with engine-Hope you people can help.
- Strange Event While Cruising!
- tapping lifters, 94 diamante SW
- 2001 Diamante Fuel Consumption, A/C Settings, Alarm, Headlight Intensity and More
- 97 mitsibushi
- 1999 Diamante - oil burns too fast
- 2001 Diamante AC - no air from center ventss
- My '95 wagon. Pics.
- 2002 Key Fob Programming
- Diamante Sei ABS problem
- '94 Diamante Stalling
- Adding Video to MMCS
- Idle problem with 95 wagon
- Exclamation mark?
- 92 diamante TCM
- help
- Parking Brake Action
- Audio System & Bumper Guard
- 2000 diamantels or 2000 galant es
- Heater Fan delayed operation
- 2002 Diamante LS left headlamp assembly
- 1993 Diamante- No Spark
- Diamante radio lights
- How hard is it to replace cv joints
- Too high RPM
- 1992 diamante no voltage at fuel pump
- Synthetic Engine Oil
- Program Keyless entery - Diamante 2000 LS
- Clear rear lights
- 1992 diamante * tcl *
- Battery? starter? or Altnator or what
- 93' Diamante hesitate to speed up from 30 miles
- 2001 Diamante Muffler Replacement
- 1999 Diamante loud ticking sound
- Gas Mileage???
- 97 diamante ac compressor winding noise
- diamante 92 air conditioning problem
- Where to get heads?
- Exporting Cars to the US
- 1992 mitsubishi diamante
- 93 Sohc To Dohc Swap
- Transmission Filter located??
- WTB Diamante 3L V6 Upper Intake - Cheap
- Cheap Fix for Heater Core and 3000GT
- Air Conditioning Problem
- SRS lamp will not go out after dead battery
- trouble getting axle out
- engine oil consumption
- Strut Problem???
- Data Link Connector
- HELP! Transmission Problem & High idle @ 1300
- Diamante 2001 dies
- 2001 diamante keyless remote programming
- 1990 3.0v (Cruise Control)
- 92 Diamante won't start no spark
- 1992 Diamante won't start.
- Antilock light on
- need to program remotes for 2k diamante
- My 1st thread!!!
- Electrical? Alternator? Battery?
- window problem
- Radio went out
- 92 Diamante won't stay running
- how do i get to 3rd brake light???
- New User - Car trouble
- Front-End Problem
- Electrical problem
- Power Window jammed
- Radio Buzzing on 2003
- Modifications
- Problems with power windows on a '93 Diamante
- Diamante / Magna
- WHATS THAT "TCL" BUTTON FOR?
- 4 indash monitors, what is best location the top den or the bottom den?
- Anyone Ridin Spinners Yet?
- How Do Yall Make Those Chrome Grills???
- Start Up, Then A Clickin Sound??
- Fogg Lights Wont Work.......
- Flex pipe Leak, shop says it's the motor mounts?
- just seeing whats out there
- pcm
- looking for diamantes TCM TRANS CONTROL MODUAL
- What's that SMELL!?!??!
- Rear Brakes (98)
- Where to get online Diamante Manual?
- How do i remove back 3 spark plugs?
- EGR valve modification
- Locks '93 LS
- '93 Diamante alarm problem
- Japanese Touch-screen Display?
- transmission question
- 93 diamante motor
- TCL blinking/ESC not working
- Car Dies
- Where can i post parts for sale
- Spark Plugs...
- Sputter/hesitation on hard acceleration
- Diamante Engine Performance Parts
- Trip counter stuck!
- turbos
- Factory Alarm
- Diamante ECU Codes
- FS: Axxis Metal Master brake pads for Diamonte
- Blowing Oil
- Homecoming ?
- Does anyone post here?
- Try a real Diamante Forum
- The Real Shiz
- DragginWagon
- Se-RiousB13
- Glad To Be Out of Hell
- smoke problems
- www.777recon.com
- computer trouble with diamante
- D God
- Where you guys from?
- Whatup
- has anyone else had this problem w/their 93?
- aftermarket suspension parts?
- How to program keyless entry for 1993 mitsubishi diamante wagon!!!!
- radio code
- reseting my radio
- Transponder Key programing
- Sweet! a diamante forum!
- wheels and tires
- 1997 Diamante Body Kit
- Diamante performance parts
- Does anyone have a suped up Diamante?
- RPW Online for Performance products
- squealing belt when AC is on
- Diamante Accessories
- any pics
- Blinkers Don't Work
- wheels
- 2002 Diamante VR-X ???
- DUBs?
- 2002 ls
- anyone here
- Factory Alarm
- Diamante Question
- First thread..
Automotive Network, Inc., Copyright ©2012
