View Full Version : Cougar
Pages : 1 [2] 3 4 5
  1. building power
  2. Spoiler Help
  3. ahh..blower resistor replaced
  4. clunking noise
  5. 95 cougar 4.6 bogs down
  6. 1994 XR7 Electronic Transmission Prob
  7. 1994 XR7 Electronic Transmission Prob
  8. Owners manuel
  9. ac/heater stopped working
  10. how do i make my 1997 cougar lighter?
  11. 99 Cougar Transaxle Light
  12. No Battery Power
  13. 91 cougar trans?
  14. no vaccum
  15. 95 Cougar crankshaft position sensor
  16. Question about my gas gauge!
  17. 1993 sputtering??
  18. 1979 CLuster Gauge
  19. 94 Cougar Xr7 Fuel Problem
  20. 99 cougar V6 Break switch
  21. Instrument cluster LED...or...fuse?
  22. Excessive EGR code
  23. 1990 digital dash Problem!
  24. 91' Cougar, Losing Anti-Freeze
  25. 96 Cougar, EGR valve?
  26. 3.0L Duratec Boring and Stroking
  27. Attenuator
  28. V6 5spd '02 Cougar -- Best Course for Power Upgrades
  29. 94 Cougar console
  30. 94 Cougar fuel filter
  31. 94 Couger
  32. Charging problems
  33. grille
  34. 2001 COugar Lightbulb Replacement
  35. stater swap?
  36. 99 Cougar headlights dimming
  37. 89 wont start, fuel gauge says CO
  38. 99 Cougar Brake Lights
  39. 1999 Cougar Wont run in cold weather
  40. '99 cougar-heat not blowing very hot air
  41. '96 Cougar XR-7 odometer stopped working
  42. 93 cougar engine swap
  43. Rear Spoiler
  44. Odometer display out
  45. 96 Cougar original battery!!!
  46. oil change counter
  47. 90 cougar dash/radio
  48. '99 Cougar Speedometer
  49. 8.5 inch 4.11 posi?
  50. lug nuts
  51. check engine light
  52. 95 cougar stalling
  53. Alarm?
  54. what year cougar should i get
  55. having problem with my check engine light
  56. 99 Cougar 2.5 v6 5 speed will not crank
  57. 99 cougar changing alt
  58. "Lost years" Cougar needs help
  59. see ya!! my cougar is gone!!! yea
  60. see ya!! my cougar is gone!!! yea
  61. 1994 Cougar XR7 3.8 V-6 exhaust leaks, easiest way to fix?
  62. Help!..Blower Motor Controller!
  63. HELP! Mystery Cyl #1 & #5 Misfire...
  64. 99 2.0L engine
  65. How to know???
  66. Heater problems with '01 Cougar
  67. 99 Cougar brakes growl in reverse.
  68. I need help with my 90 cougar
  69. 96 mercury cougar
  70. 99 cougar 2.0 won't start
  71. 1993 XR7 NOX high
  72. one more problem
  73. 96 cai?
  74. 97' cougar shaking...
  75. 1993 Mercury Cougar not starting.
  76. More power to my 1981 Cougar XR7
  77. HELP with odometer problem 94 cougar 4.6
  78. dfarr
  79. electiccl problem
  80. FREE somebody please take these parts off my hands 77-79 cougar FREE
  81. New owner
  82. What is wrong?????
  83. Transmission Range Sensor P0708
  84. overdrive problem
  85. Idle Problem
  86. 1992 cougar/tranny won't shift
  87. 99 Mercury cougar starting problem
  88. 94 cougar v8 smoke? gas smell? shaking? loss of power?
  89. 67 Cougar
  90. Oil smell
  91. 99 cougar idle problem
  92. 96 Cougar help
  93. 95 cougar electrical problem
  94. 1990 Cougar V6 3.8 running problem
  95. 1995 cougar stereo installation Help!
  96. 1986 cougar xr7 2.3L turbo wheel/rim offset
  97. 1999 cougar stuck in gear
  98. Has anyone replaced a heat/ac switch in their Cougar?
  99. back lights don't work.....
  100. 1994 Mercury Cougar Fuse box diagram
  101. oil filter problems
  102. 97cougar whines in first gear
  103. 2001 Cougar Stereo Wiring
  104. 2001 cougar???
  105. 99 Cougar Brake Job
  106. Wining sound while driving my 2000 Cougar
  107. Trans finally shifts around 7,000 rpm
  108. 1997 Mounts above raditao?
  109. 1992 Cougar Idle Question
  110. Bezel Help??
  111. 00 Cougar odometer problems
  112. '00 Cellphone in Vent
  113. on the road, alt dying/dead?
  114. transmission leak
  115. HELP!!! Keyless remote probs
  116. Should Mercury make a new Cougar?
  117. 1968 Cougar Project Car
  118. Clutch/Transmission Question
  119. Parting Out 91 Mercury Cougar LS
  120. Cougar/T-bird car show!
  121. 1997 cougar keys
  122. 91 Cougar LS 3.8, Headlights off and on
  123. 95 Cougar XR7 v8 idle control motor location
  124. '93 Cougar XR7 Problems
  125. 1999 cougar
  126. 1994 Cougar Tranny Question
  127. 99 cougar fuse problems
  128. CEL P0401 - DPFE Sensor?
  129. Oil Pan
  130. 2000 Cougar transmission range sensor
  131. Starts Sometimes, Doesn't Others '99 Cougar
  132. 99 Cougar ALT
  133. 99 Cougar No Climate Control or gauges
  134. 2001 Cougar Service Manual
  135. 95 steering column
  136. 1995 Cougar Fault Code
  137. resister pack for the blower motor
  138. 99 Cougar - Catalytic Converter?
  139. Interior Panels
  140. 2001 cougar battery light
  141. 1997 Cougar XR-7 V6 Wipers Don't Park
  142. 94 Going To Junkyard!!!!(help!!!)
  143. changing rear speakers...
  144. '94 cougar xr-7 -- ignition
  145. 96 3.8na enigne issues
  146. 96 XR7 Brake lights wont go on
  147. 2001 Cougar won't come out of PARK
  148. Need help with Cougar Electrical Problem
  149. Trunk leaks in my 2000 Cougar
  150. Better Engine?
  151. Hoses????
  152. 92 cougar/changeable years
  153. Help Please!!! :-)
  154. stupid cougar like a dead cat
  155. 99 Cougar alternator
  156. 99 codes. shifting and rev problems
  157. Cat Jam '06
  158. 96 Cougar head bolts
  159. In-Line Spout Connector 91' 3.8
  160. Can anybody help me!!!
  161. New to me 95 xr-7
  162. Shuddering and won't idle 94 XR-7 4.6 V8
  163. 1999 cougar radio fuse?
  164. 73 xr-7 fender question
  165. Engine Ticking noise
  166. My first car!
  167. What Engine Could I Swap???
  168. 99 cougar electrical problems
  169. Change over
  170. Change over
  171. Swapable Intake manifolds
  172. Rear Wheel Bearings on 99
  173. 95 XR7 4.6L Cougar Battery Drain
  174. 92 Mercury Cougar (should I buy?)
  175. Keyless Entry Fobs
  176. 1977-79 parts
  177. 79 XR7 - 2 questions- Plastic Roof panels and Tali Lights
  178. 95 cougar shifting problem
  179. engine noise / oil in throttlebody.
  180. help re reprogramming fobs, alarm,etc!
  181. oil filter problems
  182. Shifting Probs
  183. Spedometer/Trans Problem
  184. 1996 cougar charging problems
  185. cougar and t-bird parts
  186. Euro Taillights
  187. 99 cougar died; now will still crank but not start
  188. 99 cougar coolant problem
  189. Are 2002 cougars reliable?
  190. 1992 cougar and 1996 t-bird
  191. O/D Wires
  192. 99 Cougar codes? P0420 P1151 P0171 P0174 All Related?????????????????????????????????
  193. Problems with 01 Cougar
  194. Cougar Codes???
  195. LF fender removal 94 XR7
  196. '01 Cougar - Spits gas out of tank when filling!
  197. same engine in other cars?
  198. Charging System Fuse
  199. Vent Problem
  200. Running Cooling Fans 99'
  201. front wheel bearing on a 99 cougar
  202. looking to buy a 74 cougar any one selling
  203. Need Help 90 Cougar LS
  204. 99 Cougar idles down Real slow
  205. Need help with a 92' please
  206. 99 Mercury Cougar P0401 P0171 P0174
  207. Trouble shooting cougar
  208. '90 Cougar = Transmission Slipping?
  209. 1986 XR7 intercooler
  210. Exhaust
  211. 93'xr-7 dash lights out
  212. Gas Leak
  213. 2000 rotor replace
  214. 2000 cougar front wheel grind help
  215. 12v power access
  216. Reverse Glow Gauges Installation
  217. Common Issues?
  218. Heater core removal-97 cougar
  219. Headlight Knob Removal......
  220. 1999 cup holder
  221. Cougar speed pt#2
  222. need fuse box diagram, 91 couger
  223. Cougar Dies when cold problem
  224. 30th Edition Cougar
  225. Possible Major Problem. Automatic Transmission. 00 Cougar
  226. Cougar speed
  227. Electrical Issue
  228. Shuddering & Won't Idle on a 99' Cougar
  229. 92 Cougar Audio Installation......
  230. Auto to Manual Conversion
  231. coolant loss
  232. Convert Auto to Man 96 xr7????
  233. 2002 Mercury Cougar Speaker Problems
  234. 1999 Cougar Questions
  235. Lighter Problems
  236. Heater assembly
  237. 99 cougar fuel pump access hole
  238. 92 Cougar Suggestions anyone?..............
  239. problems with front,....
  240. 1992 Cougar Door Panel?
  241. Frustrated with my 2000 Cougar-Help!
  242. ford cougar 2000
  243. 1999 cougar problem
  244. 94 Cougar smelling antifreeze but can't find the leak
  245. 93 cougar xr7 radio problem
  246. Radio fuse problem on Cougar 2000
  247. Oil in Throttle Body
  248. 2000 Cougar
  249. 1994 Mercury Cougar - Location of EGR Valve
  250. Need advice about replacing an EGR valve
