View Full Version : Discovery/LR3
  1. 00 disco leaking timing cover
  2. Discovery High Idle Problem
  3. Disco II Air conditioning
  4. Need help with unlocking radio
  5. recode or reprogram ecu
  6. Land Rover drivers are mechanically not gifted
  7. Changing the transmission fluid
  8. How to check codes
  9. Vacuum Line Diagram '94 Disco V8i
  10. Seeking owners with LR3 suspension failure for legal action
  11. Fuel Filter in 2001 Disco V8
  12. 97 Discovery missing/stalling
  13. Wind Shield Wipers have failed.
  14. Service Engine Soon LED Bulb
  15. Question Leaking gasket?
  16. NEED HELP, P0150 code AGAIN
  17. remote starter
  18. 95 Disco has water in oil
  19. 95 Disco has water in oil
  20. 95 Disco has water in oil
  21. 95 Disc Water in oil
  22. Cannot move 95 Discovery out of 'Park'
  23. 2004 Discovery with 31k for 19k?
  24. Front Axle - Vacuum Line Open
  25. Thinking of buying
  26. Discovery Sluggish When Cold
  27. 94 Disco Headlight Won't Turn Off !!!
  28. 97 discovery power seat
  29. Key Problem Discovery 3 TDV6SE
  30. 2000 Disco2 front brakes
  31. 4.0 engine out of wrecked Discovery
  32. Antilock, Traction control, and Hill decent lights on?
  33. HELP!!!! 94 Disco Stalling in Drive
  34. ODD vibration? grinding?
  35. Thinking Of Getting a 97 Disco
  36. Lucas alarm DiscoI
  37. Audio Problems
  38. 4.0 v8i engine
  39. lpg
  40. Power Window
  41. Two Questions
  42. 1996 land rover radio
  43. SAFETY RECALL News
  44. replacing starter
  45. Ignition Locked
  46. What to look for on used Discovery
  47. 95 disco headlight conversion
  48. 4x4 Photo Competition - win CASH prizes for photos of CB Equipment in your Disco !
  49. any known problems
  50. discovery questions
  51. Wheel Lugs
  52. help know nodda
  53. Rover discovery
  54. 95-99 The El-cheapos?
  55. 97 disco trans oil cooler repair
  56. 97 disco Trans Cooler leak
  57. ok there wasnt a LR3 form so this is as closest thing I could pick
  58. alternator-electrical problem-please help!
  59. Sweat switch problem
  60. lift kits
  61. 1998/1999/00 Disco...should I buy?
  62. removing squab and cushion knobs on seat switch cover
  63. Programming Keyless Remote
  64. Land Rover Discovery II Parts NEEDED!!!
  65. windshield wipers
  66. Help Please
  67. Fault Codes !?!?
  68. Swashing Water Sound in my Dash
  69. Washed engine, now runs rough
  70. 1999 Disco II
  71. studdering car and speedo probs
  72. whats the duribility after 100,000 miles???
  73. Check Engine amber problam/question
  74. Anyone from VT??
  75. tire air pressure question on disco II
  76. Sidebars?
  77. Weird Problem
  78. Rims/Tire question 1997 Disco?
  79. ignition hard to start
  80. Problem with running the discover
  81. Disc II: CD Change Problem
  82. starting problems
  83. difference between series 1 & 2
  84. Antenna
  85. 95 discovery window
  86. Discovery 1996 interior lights
  87. Transfer Noise
  88. Range Rover/Defender/Dicovery question (no Nonspecific Forum)
  89. Washer fluid leaking head light Washer
  90. Electric Question 1998 Disco
  91. Discovery Brake Pads
  92. Disco Bras?
  93. 95 disco problems
  94. 1996 land rover discovery
  95. costs to maintain
  96. condensation?
  97. 99-00 Discovery II Series
  98. Land Rover Electrical
  99. Disco Series II Brakes
  100. Tire Question.
  101. Clock Swap
  102. Any "Easy" Fixes for an exhaust leak?
  103. Low Brake
  104. 94 Disco "knocking" noise
  105. Remote Programming
  106. rangerover vogue se auto is it any good?
  107. Any way to get more power?? ('96 Disco)
  108. Squeeking From Drivers Side
  109. 96 Discovery...To buy or not to buy?
  110. 2000 Disco-What Do You Think?
  111. interior lights not working????
  112. Transmission Problem on Discovery I
  113. What have I done?
  114. The new Discovery 3
  115. Discos in New Mexico
  116. Anti lock light on!
  117. Help! Its this or a minivan (jump seats)
  118. shifting into 4 wheel Low??
  119. AM I Making A Mistake?
  120. Should We Buy!?!?!
  121. Head Lights
  122. alarm question -- need help please!!
  123. How do I fix these codes?
  124. CD Changer (aftermarket)
  125. Ignition Problems w/95 Land Rover...HELP!
  126. turning a car into offroad material?
  127. Boze Alloys
  128. Got Diesel??
  129. Some type of valvetrain problem
  130. Land Rovers 2003 NAIAS Stand
  131. Too many lights?
  132. Disco oppinion
  133. 96 Disc SE 7
  134. odd problem
  135. 2001 Discovery Towing Question
  136. Air Intake
  137. Gas
  138. workshop manuals and parts catalogue CD rom
  139. programing keyless entry on disco
  140. reset password for Land Rover
  141. strength & beauty
  142. 97 Discovery For Sale
  143. Whats better? Discovery or Grand Cherokee
