Our Community is 705,000 Strong. Join Us.
Mazda
> MX-6
View Full Version :
MX-6
Pages :
1
2
moose5
requires a locksmith my car door locks
Need Help my Check Engine light..
03 premacy clutch scraping sound please help
stock fuel capabilites?
93 MX6 2.0 wiring problem
what does open or closed maf mean?
replacing clutch... question
93 mazda mx6 power windows not working
steering wheel hub
Help!!!
93 MX6 won't shift into 3rd gear
how do u know if the engine is a klze?
intermiten CEL???
how much boost can be safely run on a stock block.
Rear Disc Conversion
Stuck Inner CV Axle - 93 MX6 - Help Please!
rpm drops to zero
O2 Inversion Error!?
KL-ZE Building
Blinking hold light messing with my Transmission
4cyl to V6
mx6 starting problem
Idles too high
clutch replacement guide
Mazda89mx6
need help plz comment
88 MX 6, 2nd Slave Clutch-teenage driver
Please Help!! Please Read!!! Please Help!!
intermittent overheating???
motors?????
1993 Mazda Mx-6 v6 wont crank
somebody help...........
MX6 Rear Suspension Parts
need help w/89 mazda mx6
O6 Maz 6 V6 6 speed Automatic
where are the cylinoid identification sensors a&b located for my 89mazdamx6 w/turbo
CV half shaft replacement
FS motor and tranny
Hi guys Im a Mazda MX-6 GURU!!!!!!!!!
Uh-Oh
To buy or not to buy?
The MX-6 build
Mazda anti-sway bar, rear suspension parts
Adding gear oil
F/s 93 Mazda Mx6 2.5l J-spec Swap Done.
Mx-6 For Sale
fs. enkei racing s 2pc lightweight wheels tires
1995 Mx6 V6
new engine
ac problem
1993 need help
94 mazda mx6 NEED HELP
info
Mazda National Day – Orlando, Fl – Jul/28/2007
Ignition Problems
Ignitor Module
Cigarette lighter fuse location
OBD 2 Reader
Ec-at
96 mx6 throttle position sensor
what transaxle is in 93 MX6
Mazda MX6 Wiring Harness Please Help
mx-6 halfshaft
mx-6 halfshaft
Unknown Problem
looking into an mx6
Wiring Harness
HOLD light blinking
Looking at Getting an MX^
need lights
engin noise
lookin for input
95 mx6 - ignition fuse keeps blowing out
grinding gears? :( need help asap
96 MX6 Engine noise/knock help
stock internal//engine management capabilities, ????
88 Mazda MX6 Turbo
New Mx-6/Probe site
Tenzo R seats and brackets
Help: Buying an MX 6 Mystere
i need to find picture of how to assemble ignition coil
engine questions??
94 mx6 will turn but won't start
mx-6 turbo interference motor?
Looking for Body kits
Prospective owner with questions: HELP!!!
Best kind of engine for a swap?
89 MX6 GT turbo for sale cheap
93 Stalls while driving and at idle.
Help Please!!! Car Really Broken
Light question
Clutch problems
1993 MX-6 Mystere
a newbie to mx-6 have some ?'s
FS: Mazda 626 IHI RHB5 Turbo & Downpipe
89 mx-6 gt turbo?
looking for supra tails
fixing up my mx6??
Mx6 Warning Light
problem with mx6 please help
carbon fiber
SRS Code 52
MX-6 Stuck in park
Wont Start
Mx-6 for SALE!!!!! 1993 LOOK LOOK
Mx6 Water Pump And Right Drive Tranny Seal
mx-6 problems???
1991 6 Tranny
rx7 parts
Inertia Switch
oil in the cooling system
4 sale
alarm on the car
Automatic Transmission Problems - Help
Selling 2 Mx-6s
clutch replacement
Also selling my 3" mandrel exhaust
Turbo pipes MX6 $600
How do you time a distributor?
Replacing Stock Motor with JDM KLZE
Sub wiring
Died & won't start
Stru Bars
radio wiring
Intermitent Starter (MX-6 90 Turbo)
KLZE legal in cali?
89 MX-6 CV Boot Replacement
93 mystery problem with transmission
Mx-3 swap engine HELP!
Ball Joints, Bushings, Control Arms...
should i buy one?
i need jdm projectors!!
stupid question..please help
Best Exhaust?
Expansion Valve replacement
I need a bodykit.
93 mx6 automatic to manual
egr valve replacement
running problems 93 mx-6 V6 5sp
Wrecked My Baby!
Buying 95 MX-6 4 cyl w/auto trans PLEASE
Looking for a racing club
radio
radio
inertia switch?
cai install
looking to maybe sell my Mx6
Engine manual
Newbie needs help
Turboing a second gen mx-6
An MX-6 For Racing?
Stuck in 2nd gear
Shaking at 30-40 mph
I need help on my auto trans......
i need a mx-6 engine!!
Looking 4 a moonroof panel
Needed a working power antenna
Is there a idle adjustment on these mx-6's?
fuse cover diagram
problem starting
How to repair chipping clear coat?
So I've been having problems with my car...perhaps you could shed some insight.
93 Cluster
im parting out my mx6
93 inner tie rods?
help me look
Alternator
For Sale: Please Read!!!!
low price turbo kits
tachometer cable
shifter moves upon accell.....
turbo mx6
3rd brake light
door locks on my 93 mx6
engine problems
1976 Jeep Cj For Sale Fiberglass Body Finish My Project
Parts!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
looking for parts!! 93 mx6
Need Help!!!! Misfire Problem!!!
looking for high performance cams
i got this 93mx6 with 110k miles on it for sale
Can you get one?
Do i need a new clutch?
problem with lights
door
Fs: 93mx6 $2000!!!!!!!!!!!!!!!!!
egr valve
1997 MX-6 problem
cheap klze
warning lights
Pricey??
Back-up light switch
88 Cassette Deck Help Needed
Fs: 1995 Mazda Mx6
???performance???
Car will not start...help!!
Polyurethane
Need Your Help Please
FOR SALE: KLZE KL31 Cams
Mx6 Engine Problem
flashing chk engine light - stuttering idle/engine response
idle surge
Help Help
Need marker left side light for '94 mx6
mx-6 idle rpm messed up and overheat
klze ?
Tranny swap
Squeaky suspension
Exhaust
cigarette lighter
blinkin o\d light
Rear warning light on
Check engine light
HELP PLease
dodge avenger vs. mazda mx6 both 2.5 v6
Anyone have programming info for Mazda MX-6 Keyless Entry Remote?
Beef Up My Ride
Standard CD player
Mazda Injector CC's???
MX6 vs LUDE vs Jetta turbo
FS 1989 Mazda MX-6 in NYC/NJ Area
93 MX6 Tail Light Lens Replacement
help!
Automatic Transmission question
5.0 drop in mx-6
MX6 parts anyone?!?!?!
Mx-6 questions
Rough idle, What gives??
Mx6 turbo for sale
short shifter
89' MX6 GT, 5-speed???
Starting Problem
Exhaust
Good sounding mods
Brake Lights Gone Crazy
steering vibration at stop
'96 MX6 error codes
rear tail light
Transmission problems
are mx-6's good road racing cars
Fuse box Mapping
1993 MX-6 relay box Map
need parts?
240 sx vs mx-6
Dual Gauge Pod???
Oil pressure gauge install?
HELP! What's a Disc Modulator for a 1993 MX6
Automotive Network, Inc., Copyright ©2013
