Our Community is 662,000 Strong. Join Us.
View Full Version : 626/Capella/Capella Wagon
Pages : [1] 2 3 4
  1. WTF? when i weld car locks and lights turn on
  2. looking into buying a new (99) 626
  3. Ignition Key with chip
  4. 02 626 2.0 auto no start what sends the signal to turn the fuel pump on??
  5. 2002 626 2.0 coil question?
  6. turn key on/off mutliple times before it starts
  7. 88 front spindle
  8. No charge
  9. 1999 626 Won't start when it is hot but will after cool down.
  10. brakes
  11. Sunroof Adjustment
  12. 98 626 2.0l shifting problems
  13. Mazda 626 Front Suspension
  14. 2000 Mazda 626 Jerks While Driving
  15. 98 626 clutch loses pressure
  16. 1996 626 V6: Need to replace head gasket...help!
  17. 93 mazda won't start sometimes
  18. Whistling noise at highway speeds.
  19. mazda 626 runs on R, 1, 2 but not D?
  20. CV axles replaced, still popping
  21. Check engine light, code P1633
  22. 97 626 wont start
  23. Hood painting on 1995 Mazda 626
  24. 88 mazda 626 engine/trany swap
  25. 02 626 random misfire
  26. 2000 626 with ABS light on
  27. 2000 4cy 626 Mazda Transmission stuck
  28. Where is the EGR valve on a 1996 626 V6?
  29. 1999 Mazda 626LX 2.5L - A/C problem
  30. 2000 mazda 626 Catayltic Converter or o2?
  31. Clutch Trouble
  32. 1994 Mazda 626 Air Bag light codes
  33. 99 626 Hard shift in 2nd with 3 transmissions
  34. Semi simple question...
  35. 2001 mazda alarm goes off
  36. Thinking of buying a 2000 626
  37. 96 626 Auto Tanny problem
  38. frame damage
  39. 1991 626
  40. 86 626 turbo starts runs but cuts out
  41. Trans Issue 94 626
  42. 1994 O2 Sensor location
  43. Frozen fuel line? Give me your opinions.
  44. i have worked on this car for 3 weeks urg
  45. 2001 626 4cyl no cool air
  46. 97 626 Radiator Support
  47. battery wont charge in a 94 626
  48. '95 626 water pump replacement question
  49. 1990 Mazda 626 will not start
  50. Check Engine Light Pops On After Being Turned On And Off About 5 Times Over 12 Hrs
  51. Will 95 auto tranny work with 98 626?
  52. 2001 Mazda 626
  53. 99 626 trans slips
  54. 1993 Mazda 626 cronos V6 2.5 ltrs HEATER no hot air
  55. 92 Mazda 626 Fuel Pressure
  56. 2001 626 White Smoke, Awful Smell Not Overheating
  57. Ticking noise in rear drum brakes on fast stopping and downhill
  58. 97 626 LX pass. side half-shaft removal from case?
  59. Do I Need to replace my automatic transmission?
  60. looking for mazda 626
  61. '97 626-What is this broken piece?
  62. 1996 626 V6 automatic transaxle problem
  63. 88 mazda 626
  64. Mazda 626 Transmission??
  65. down to business
  66. hi
  67. 2000 626 2.5 help needed
  68. 88 626 2.2 timing & gages issues
  69. transmission won't engage
  70. 98 626 V6 ABS TCS TCSoff lights on
  71. Throttle Position Sensor
  72. '92 model 626....HELP
  73. 2000 626 Hesitation
  74. '90 626 with tranny, brake issues
  75. heater issue on 88' 626
  76. Automatic Transaxle problems
  77. A/C Problem.
  78. Alternator problem?
  79. EGR Flow Fault?
  80. Headlight problem
  81. Mazda 626 2.0L 2000 model Alternator supply voltage
  82. 2000 626 Cabin Air Filter
  83. question for 1995 mazda 626
  84. 91 626 idleing problem?? help?!
  85. 84 mazda626 fuses
  86. '94 626 Fuel Filter
  87. moon roof seal
  88. Water Pump replacement 626 4Cylinder 1997
  89. 1994 Water Pump Pulley 2.5L
  90. Radiator
  91. Christmas Present=crazy 626 problems
  92. Mazda 626 Outside Mirror replacement
  93. 1994 626 2.0 flooding
  94. Constant vibration at all speeds in front
  95. Power surges... resulting in damage in mazda 626
  96. 91 626 considering purchase
  97. 1989 2 dooor turbo
  98. Hesitation after a 'pop' during acceleration
  99. 1994 Mazda 626 Sputtering on Start
  100. 1991 Mazda 626 Smoking blue in mornings
  101. Program a keyless remote to the car
  102. 95 626 water pump
  103. 86 626 Rear Drums to Disc Brakes
  104. 1991 626 REAR light on dash on
  105. please help!!!!!!mazda 626
  106. 86 Mazda 626 LX Turbo 4 dr.
  107. 93 626 brake lines
  108. Strange Fuel Gauge Issue
  109. Black stuff blowing out of vents
  110. 97 626 Rain Gutters?
  111. Rusty oil pan
  112. Do We have to Live with Hard Shifting? 99 626
  113. 98 Mazda 626 Altenator Question
  114. 98 mazda 626 egr and o2 sensor
  115. Mazda 626 O2 dilemma
  116. Alternator light flickers
  117. intake?
  118. Distributor Install
  119. Flashing lights
  120. engine shaking on 91 626
  121. 91 mazda shifter is loose
  122. ignition short
  123. Stalling while in gear
  124. P0421 (emissions leak small) and P0176 (running rich)
  125. Engine thumps lightly while idling
  126. 96 Mazda 626 Check Engine Light
  127. HELP - 626 Alternator Replacement
  128. Clicking Noise
  129. Oil on Spark Plugs
  130. 2002 626 will not shift into gear
  131. 1994 Mazda 626 Won't Start
  132. Immobilizer problem ?
  133. Car Always at 1900-2000 RPM!!!
  134. Mazda National Day – Orlando, Fl – Jul/28/2007
  135. dash light out on climate control unit
  136. 626 Break Problem
  137. M3 style mirrors for 626
  138. lowering a 91 626
  139. Parts compatibilty 94 626 vs 91 626 (2.0L)
  140. 95 MAZDA 626 Idle problem
  141. Cuts off in drive
  142. 97 626 tranny wiring diagram needed.
  143. hey juss wondering if this happened to u..
  144. Mazda buyers, specifically 626.....BEWARE!
  145. Primium fuel
  146. Rear Speakers
  147. Another dumb question...distributor issues.
  148. 2000 626LX Trans Line Pressure Port
  149. turbo?
  150. windshield wiper spray
  151. please help asap
  152. heater core??
  153. 91 Mazda 626 M3 Mirrors
  154. 626 turbo manifold
  155. '94 626 quick questions
  156. 1999 mazda 626 transmission filter location
  157. Check Engine Light - P0461
  158. '97 2.0 automatic/626 smokes at start-up?
  159. Wire under dash disconnected, can you identify? '98 .626
  160. Should I buy this Mazada626?
  161. 97 Mazda 626, MAF Sensor issues or something else???
  162. Cam bearings
  163. Check Enging Light P0740
  164. 626 V6 Auto Trans
  165. Just bought a 93 626 dx
  166. 2001 626LX No Brake Lights
  167. 626 headgasket and comression need some help please
  168. 96 626 injection problem?
  169. Mazda 626 Catalyst converter problem
  170. Can't get '94 626 to pass emissions.
  171. Airbag error code: 46
  172. Starter/Solenoid
  173. 93-mazda 626.. Cluster making noise speed of 120mph..
  174. '91 626 vibration at highway speed
  175. 98 Mazda 626 LX, 2.0L codes 0117 & 0421
  176. 02 626 engine light
  177. Mazda 89 brake booster
  178. CD4E Transmissions fixed by 2000?
  179. 1991 626 does not idle in neatrual
  180. MAZDASPEED MEET @ Tropical Park Miami
  181. 626 speed
  182. 1996 626 LX V6: Timing Belt
  183. Sound coming from Driver Side Rear Tire
  184. 97 626 with 2.0 16valve Transmission swap problem!!!
  185. 95 Mazda 626
  186. CV Joints Clicking in turns ?
  187. 89 626 temp guage not working
  188. Whats going on with my Car?
  189. '94 626 Defroster Problem
  190. 96 626 Shredded\Damaged Belts
  191. airconditioner compressor
  192. 1985 626 non-turbo
  193. 96 Mazda 626 Moon Roof repair
  194. 1988 626 2.2 4dr auto non turbo ignition radiator fan heater fan problem
  195. Stalls In Mid Driving 93 5 Speed
  196. 1998 .626, tranny or electrical problem?
  197. 1991 626 just wont start
  198. Engine noise when standing in drive or in reverse
  199. Taking the windows out
  200. 98 626 left front axle replacement
  201. Overheating
  202. Ignitor
  203. Tank separator??
  204. Pilot bearing Removal
  205. Transmission removal
  206. New to the 626
  207. timing belt advice? 96 4cyl
  208. 91 626, NO idle, hesitates at slow speed
  209. Windshield wiper arm
  210. 91 626 Noise when turning
  211. My 91 626 wont start
  212. clutch sticking to floor when held down.
  213. 2002 626 cams
  214. 91 626 Reverse Lights
  215. 91 626 problem
  216. 1997 Mazda 626 Idle Issues!
  217. Question about oil on a '92 626
  218. problem with my brothers 90 626
  219. a ton of questions, knockin em all out at once.
  220. nothing works! need help!!!
  221. 2000 battery cables
  222. 82 626 5 speed top speed
  223. Engine flooding on startup?
  224. Check Engine Light and trouble
  225. 91 626 Overheating
  226. Just bought this 2000 626..whaddya think?
  227. 91 mazda 626
  228. 2002 626 engine swap
  229. 2002 626
  230. Pls bear with - dumb blond 626 question
  231. O2 Sensor
  232. 93 Mada Cronos 225K Heater not always working.
  233. seat belt indicator light
  234. Timing belt contacts the front cover
  235. Can I tow a trailer?
  236. should i buy a 99 626? good car?
  237. Transmission fluid coming out of the transmission stick, Help??
  238. Weird Noise when I turn the steering wheel & Engine Light Woes
  239. ac problem
  240. 626 Tranny Problem?
  241. 1995 626 LX flashing o/d light
  242. Check Engine Light - jumper?
  243. possesed headlights 95'
  244. HELP...1997 v6cyl.....so many problems
  245. '91 lx 4 door body kit
  246. HELP...1997 v6cyl.....so many problems
  247. ProStart & New Transmission
  248. fuel filter location?
  249. 1996 626 Lx V6: P0170
  250. 87 626 conversion to manual
