Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mazda
> 626/Capella/Capella Wagon |
View Full Version :
Web
AF
Pages :
1
2
3
4
PCV valve check
Engine "Hum" between 59MPH-64MPH
Help 97 626 check engine light
'95 626 Automatc Transmission Shift Lever Problem?
oil in radiator
1991 Mazda 626 - Check engine & washer fluid lights
91 Mazda & Some Needed Advice
Replacing Heater Core?
626 for sale
98 mazda 626 need help w/ modifications
1989 Mazda 626 2.2L Non-Turbo Problem
Please help 95 626 EX Manual
what is a cronos
1999 626 heater wont work
Are there any mazda websites?? -Please Read-
Stuck CD
Mazda Speed?
my 626 - what model is it?
FS: 19" Diablo 7Hart & 23" KMC V2 w/Pirelli Rubber!
1998 Mazda 626 (Need Advice.. Thx U)
mazda turbo
High speed vibrations
Mazda 626 GT 2,5 V6 - engine running bad
Beginner mods...
MAZDA 626 gc POWER STEERING HELP!
crack in the exhaust system
1995 626 keyless entry reprogramming?
626 wont get in reverse help
1993 626 ES Flashing Air Bag Light
Oil leak, hardley any power to the car, and now my brakes are not really braking!!
Power Seatbelts work and sometimes don't work
reverse lights will not come on
Air Condition Charging A/C
Holy crap deisel!
1997 Mazda 626 Check Engine Light On.
Help! Anyone's Opinion!!
performance parts for mazda 626
Desperately need timing diagram - 626 2.0 Twin Cam 1987
need torques
alternator help
Automatic Seat Belts dead
94-95 computer for sale
90 626gt upgrades
Plastic part on the undercarriege?
Short shifter
FS: my 92 626
95 Mazda 626 transmission
Mazda 626 1993
tranny swap?
crankshaft position sensor
need 626 modification help
1989 Mazda 626 Hatchback: Performance help
car alarm won't turn off
error code 0441 "Evaporative Emission Control System Malfunction"
Changing rear brakes
my car won't start
overheating
99' 626 Part Out!
2.5 litre ??????
stereo and speakers not working...sound goes on and off
Rims
level of difficulty of changing trans on 98
86 626 problem starting after overheat
97 626 dead spot, hesitation & low Power
Newb
89 Cruise
86-87 Mazda 626
97 626 hesitation on acceleration
Help with stereo Install
93 & 94 Mazda Parts................
Cold Air intakes, Cams, oil breathers, ect..
Air Condition and Idling
How/Where to sell used MAZDA parts? Please help.
Do you need and MAZDA 626 parts? Check this out.
97 mazda check engine light - HELP!!
'94 626 Shut down problems!
is that the problem of battery?
86 Motor Block
Grinding rumbling noise during startup
95 626 for sale
possible 89 626 engine swap
hesitation under heavy acceleration
What do you think about my little car?
mazda 6
'89 Mazda 626 - No Spark
Check Engine Light
Alternator vs Battery Problem
93 maz 626 4-cyl, install starter
626 deisel
pls help: rough idle (ODB II Error code inside)
Air Conditioning
Flame Thrower kit
Turbo Converion
Where can i get
1990 626 tail lights wanted
My 626 doesn't start sometimes, but sometimes it does!?!?!
wiring diagram for '87 mazda 626
any1 done auto to manual conversion(89 626)
headlights
I Need a Harmonic balancer( crank pulley)
98 626 engine swap
Normal running temp?
horsepower question
too kool
Anyone Know Any Performance Sites?
Mazdas are junk....oil pump.
89' 626 reverse glow guages
Transmission stopped engaging/hold light flashing
Is There A Guru Here? Need 200+bhp
p/s grinding noise cold weather
1997 Mazda 626 keyless entry programing???
93 Mazda 626 transmission prob
anyone intrested in a 88-92 front strut bar?
94 626 2.0L (4cly)to 2.5L (6cly)engine swap
For Sale:ngk Laser Platinum Plugs, Free S+h
626 Anti-Theft system question....
"HOLD" keeps blinking? what doe sit mean?
set clock on 1999 626 (no manual)
I have some problems, think you can help?
91 626 runs now but not right
Computer (PCM) protocol for 1997 626?
87 mazda, little help here please
brake pedal goes to far before engaging
engine doesn't start after replacing timing belt
91 Mazda 626 Cranks But Wont start
97 mazada/95 probe gt/engine swap
starting problems
01' 626 and 02'protege5
AEM cold air intake
short throw shifter
headlight problems
Rookie mazda user that needs help
87 mazda... wont start.. please post anything that may help
No spark
Changed air cleaner now wont start!
95 626 ingition
91 626 for sale
1997 626 Mods?
just picked out a 626
trans problem....suprise, suprise
I need help in modifing my 626 ES
Where can i get a body kit?
91 mazda 626 custom body kit
1995 mazda 626 for sale
vacum leak??
air flow meter calibrating
mazda transmissions question!
Muffler Replacement
chassis wiring
86 mazda 626 wont start., Starter motor ground problem?
Exhaust pipe size needed.
Noise while starting engine
96' 626-malfunction indicator light
speaker size for 98 626
1994 626 engine troubles
1985 Turbo conversion
'95 Mazda 626 Stereo- Front Spkrs Dont Work
'95 626 Remote Car Starter
Alternator & Right Front Axle
Blown headgasket - brainstorming
Brake booster and master cylinder for sale CHEAP!
1991 626: plastic air box ex/imploded--worth fixing?
91 626 battery drain problem
90 626 not starting...Help please...
white smoke
626 dies but not in reverse
93 Washed engine - now won't start.... help
center channel for 92 audio system???
surging/hunting 91 626 mazda in Drive...ok in rvrs
Looking for front lip for 95' 626
'93 626 mazda owners manual help
93 626 Transmission Problem
how do i program keyless remote on 1999 mazda 626
lookin` for`91 626 detailed engine specs
lil 626 help
86 problem
Parting out 1987 Mazda 626
Failed Emissions test.
626 basic question-3 catalytic convertors?
626 problems need help
Tranny won't shift from park
91 Mazda LX 626 Power Window Problems
O/D off light?
overheating problem??
Tranny in the 626
93 Mazda 626 Valve Adjustment
bought 94 626
92 Mazda 626; extreme rpm's
ROOM fuse???
crank position sensor question????????????????
1987 626 "Koni Shocks" for sale
Break chatter limilar to ABS brake system kicking in.
1991 Mazda 626 -- won't start
car won't start
Body Kits for 86 626 i4
98 626 will not start when engine hot.....HELP
88 626 turbo CEL 16 & 42: What are they??
1995 mazada 626 fuel problems..help!
Optima battery alternatives
what is the firing order for a '93 626 2.0 4cyl
Burn smell and CV boots
help with probably purchase of 93 626
Programing a Keyless Remote for a 98
mazda 4 banger jdm cams wanted n.e. info?
HELP!: 1981 Mazda 626 Modifications
check engine light
Stupid Question?
gearshift stuck in 4th gear
Automatic Transmission Issue 96/626
93-97 626 .PDF factory service manual
lack of power
Number One Cylinder
Water Leaking into car
1998 V6 Check Engine Light
1989 2.2L MX-6 turbo engine put into a 1996 Mazda 626 LX. Is it possible?
turn signal not blinking
Air Intake
Turn signal not blinking
parting out 1985 626 4-auto fwd
Laptop to OBD?
Tranny Prob
performance brake pads for 98 626.. any?
Wiring Diagram
Turbo
Cd player w/o harness
brake lights stay on and drain battery
Greddy Evo Exhaust Mx-6 Brand New
fuel pump relay location for 95 626
Ford Telstar TX5 2L DHOC Into 626 Wagon
Seeking feedback on 98 626
Cold Air Intake for 98 + 626s (it's here!!)
Mazda 626 rpm shoot to over 30k
Lhr Siezed Caliper
99-02 aftermarket 626 sites?
headers
Did the dealer screw up with wrong size tires?
WILL a header for a 95 626 fit on a 98 626
1980's Mazda 626 specs
4cylinder mazda 626 - need more power
Smoke :(((
can ne one tell me...
Looking to buy a 626...Weird Noise!!!
Online Mazda parts stores??
My Mazda
Small Accident Need New Headlight Please Help
Will a 626 2.0ltr engine bolt into a 323
Suggestions??
CV Axle
lumpy running
Web
AF
