Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mazda
> 626/Capella/Capella Wagon |
View Full Version :
Web
AF
Pages :
1
2
3
4
high idle
'93 626 Manuel stucking in gears.
Cannot shift into Park - problem with lock-release button
No Cold Start Mazda626/86
Where is the thermostat located 2001 626 ?
tcs warning lights
97 Mazda internal wiring problems
Scheduled Maintanence-waterpump w/ timing belt
maZDA spaRKS
Squelling Noise?
03-05 Mazda 6 wheels on a 93-97 626?
Engine Temp Gauge went to hot today
transmission or cv joint?
2000 626 brake pad installation
626-auto swap to stick...problem
Is there a way to bring the back windows fully down?
Check Engine Light
Help! Need to program new key for 1998 626
Cruise Control For 626
idiling rough and stalling 88 Maxda 626 turbo
Alternator Replacement
'93 626 Parts for sale
How do you time a distributor?
Mazda 626 2000 owner's manual
vacuum chambers
Problem finding 93' 626 fuel filter on engien.
heatercore door 91, 626
Dashboard lights not working.
2001 626 - Windows Won't Work
Help Car Stall At 3,500 While Driving
My 94 died on the interstate & won't start.
differential bearing
Problems filling fuel tank
Aaarhg... I dropped the freeze plug in the block
One more question about knocking or misfire?
16" OEM wheel to fit 1999 mazda 626?
Where do I get a key made (that works)?
Where is the fuel pump relay?
Heater core 91 Mazda 626
90 626 engine codes
After driven for about 5-10 mins my car wont reverse
M plate 626- gearbox scrap?
87/88 626 2.0Diesel temperature problem?
98 626 won't start
89 626 turbo performance parts? Where?
1989 626 turbo, anyone know these cars well?
Trouble pulling cv axel
Possible Tachometer Problem
A/C problem
low voltage on rear running lights
97-626-2.5-Timing Mark on Left Camshaft???
trans change
A Soldier's story (trans out)
94 626 trans linkage problem
93 626 timing diagram
no rear running lights
1996 a/c problem
Knocking when slowing
Weird headlight
98 Mazda 626 Gas, Spark Plug, Idle Issues
91 passenger door problems
Mazda familia
1993 626 stalls when stoped, and a/c blow hot air
'91 Mazda 626, engine rebuild needed?
'97 Coolant Problems
1999 Mazda 626 keyless remote programming instructions
i really need all the help i can get
Error Codes
626 O/D off and engine light on
Harmonic Balancer
626 tranny search
93 mazda 626 hold light flashing....please help
98 Mazda 626 automatic; low idle and AC problem
please help
Mazda 626 GT 2.0 that will not start
taking out the dash
91 626 taillight problem
I need some help
84 Mazda 626: Fuel Gauge Not working
check engine code 23,24
how to program used remote control for my 2000 Mazda 626 LX
Headlight adjustment screws
2000 626 performance modifications
low idle
tranny code help ?
fuel gauge
suspension question
1999 626 2 liter gas mileage
Backflushing
transmission cooler
keep or sell?
93 626 engine problem
mazda 626 cronos head bolt torques
rear cailpers will not compress
1996 626 alternator belt
1993 626 distributor parts?
car shakes when you brake
1990 626 2.2 block interchange?
AC woes
looking for fiberglass hood for 1993 626
Dohc question mazda
driver side mirror assembly
check engine light, malfunction
temp sensor
Mazda 626 Transmission or Engine Mounts
93 626 For Sale
my list of fast, cheap, used cars with performance data
I want a Bosal performance Cat-Back for my 94' 626 ES V6 (part# 112-201)
AC Compressor making racket
1991 valve cover gasket
Buick vs. Mazda
97 626LX 4cyl - Computer probs
anyone know where to get a manual window regulator
high nox wont pass emissions
Starting
Steering Wheel Adjustment
Car overheats when AC is on (1999 Mazda 626 LXv6)
engine problem? please help!
early 626 help
Timing Belt Replacement
performance fule injectors and fuel rail
636 transmission diffult to shift into 3rd
belt????
Replacing Transmission Filter in a 626
top speed 91 N/A auto
Broken radio
spark plug firing order
Transmission
97 626 trans rebuild kits???
p-flow for 626
Demons in headlights
Idle low, sometimes stalls
626 Transmission issues "HELP"
98 626 air cond belt squeal
2000 626 squeaks at start up
99 mazda 626 security key blinking no start!
radiator removal 626
Speed alarm in 93 Mazda 626
FREE 626 steel rims
626?
'98 626 Major Oil Consumption ????
'94 Coil springs & shock/strut
ecm codes
plug gap?
95 2.0L engine ticking from injectors?
'93 626 brake light - panel
'95 - '96 Cronos
water pump replacement 86 626
Water leak advice
4 cyl rough idle and check engine lite
97 Mazda 626 LX 4cylinder
Annoying Sound
Please Help!!! I Need My Car... :(
'91 mazda 626
Need help... engine toggles between 2000-3000rpm
Newbie Question
idle problem
Antifreeze pouring out of car! Major! Help!
91 626 oil filter
power light is on
My 626
99 GXI Estate remote locking problems
Transmission valve Body
mazda 626
EGR Valve
1993, changed transmission filter, hold light comes on and it won't shift into third
’94 Mazda 626 Airbag Dash board light?
2000 626 Keyless Entry System install?
'99 626 Running very rough
Emergency Please, Please Help!!!
Firing Order - Spark Plug Wire Set
program key 98 626
Oxygen Sensor(s)???
transmission problems
please help-looking for programming for 97 626 keyless remote
Capella / 626 trans "Hold" issues
Strut replacement
626 hesates in 1st and 2nd
Wont start part 2 ( Please Help Desperate)
Headlights
91 blower not working
B&M shifter
Engine code P0708
Mazda worth fixing?
No Spark
2000 626 sputters and nearly stalls at idle
1996 Mazda 626 anyone with this car can help me Fuse Panel
89 Mazda
1991 626 fuel pump problem
wanna get a 99 626
crank pulley broke off my 98' 626es
air conditioning
98 Mazda 626 AC or Engine problem. Please help
Car will not start 3
Car will not start 2
Car will not start
problems getting out stock radio on a 96
Intermittent Check Engine Light - 94 4cyl 626 A/T
1991 626-Wants to change GASKET, how? Anyone got a diagram of the engine?
gauges lights stay on even when the switch is off
Problem with Installed CD Receiver - Please HELP
help!!! abnormal transmisson leak
Removing tape deck for repair/replacement
99 626 hu install
97-V6 2.5 Water Pump R&R Procedure
Mazda IHI Turbo
Mazda smoking
97 626 V6 Eating Coolant
93 Mazda 626
93 626 front headlights
1996 Mazda 626/ Sputtering and stalling during acceleration. HELP!
1996 Mazda 626/ Rattling in front passenger side tire when braking
I need help please.
98 626 engine light on
95 mazda 626
98 626 EGR Valve
626 tail lights
considering buying '01 i4 - please send recommendations
1998 626 specs for horsepower
OWNERS OF 626's PLEASE READ!
626 security system - 1997
Overheating-weird problem
2000 Ponitac Grand Am
Hey Need Help BIGGG TIME
Tornado in air intake related to check engine light?
For Sale: 626 Gauges
loss of power, regain it in 15 min.
Battery charge light comes on intermittently
Reversing / Fog lights on 98 626 SW
immobilizer module - where is it?
96 626 LX Running ruff
Ok guys, clueless girl question, be gentle with me ;)
Manuel Window problems
Air Conditioning problems PLEASE HELP
Mazda 626 Tire /road noise
Speedopmeter and Fuel Gauge
1996 Mazda 626 - Gas odour
1996 - 626 Cornos- Not starting
1999 626 Vacuum hose
2000 626 Tapping/Rattle When Hitting Bumps
won't start
FOR SALE: KLZE KL31 Cams
transmission noise
Radiator Flush
need torque specs bad!
mazda626 overheating and steering becomes hard
Anybody have a similar problem: 1990 626 - No heat
headlight alignment 1998 mazda 626
body modifications
Major hesitation under accleration
Web
AF
