View Full Version : Sportage
Pages : [1] 2 3
  1. sportage drive cycle
  2. 2000 Sportage head bolt torque
  3. 2002 Sportage P0171 Code
  4. 1998 sportage front brakes
  5. 2001 Kia Sportage driveshaft problems
  6. 2007 Kia Sportage
  7. CEL on, then off, then on, then off....P0304&P0343
  8. please help! my 96 sportage died on the hwy and now it wont start...
  9. 2000 sportage
  10. 98 kia vibration
  11. Thumping in front end, tire feels loose
  12. 2001 kia power serge
  13. Alternator mounting bolt
  14. 2000 Kia Sportage died on fwy. Will Turn over but not start...HELP
  15. ecm
  16. No power when gas pedal pushed
  17. egr valve
  18. 00 KiA Sportage 4wd Locking Up on Turns
  19. Overheating 2001 sportage
  20. Where is the fuel filter on '99 KIA Sportage? PLEASE HELP!!
  21. Where is high pressure fuel filter '99?
  22. codes
  23. no power 97 sportage
  24. *URGENT* Need right rear backer plate for 95 Sportage!
  25. Washington and Jefferson Nat. Forest
  26. KIA Sportage OBD2 Problem
  27. Sneaky gas smell
  28. blower motor
  29. Ragtop -suitable replacement?
  30. 2000 Sportage Installing Glow Gauges
  31. 2000 kiad sportage no power
  32. 2000 kia sportage help no power
  33. 4wd dont work, only 2wd...
  34. 01 sportage busted timing belt
  35. question about alternators
  36. question about alternators
  37. had spark plugs changed ...now wont start
  38. 2001 Sportage died on highway and wont start...timing belt??? And How to replace it
  39. 1999 Kia Sportage won't start
  40. 97 Sportage 4wd and #2 misfire problems
  41. 2002 Sportage - in drive mode
  42. 98 Sportage Vibration
  43. engine light code reading help
  44. 2001 sportage weird vibration
  45. help with timing/head gasket
  46. 4 wheel drive making noise ONLY! HELP
  47. Kia 98
  48. kia sportage 2000 blows fuel inj fuse
  49. 2000 Kia Sportage WILL NOT start when it is cold outside..HELP!!!
  50. 2001 kia sportage cel code p0171
  51. 97 Sportage making loud noise!
  52. replaced water pump and t.b. won't start
  53. Best solution for 2001 Sportage 4x4 hub issues?
  54. where is the crankshaft position sensor
  55. extreme starting problems
  56. Dash Lites... no engine turnover
  57. fuel filter
  58. Brake issue, soft pedal - 01 Sportage
  59. Crankshaft for sale
  60. need engine for 2000 Sportage
  61. fuel pressure
  62. Hard to start when cold
  63. Help with O2 sensor
  64. help
  65. ABS sensor - replacement
  66. 07 Sportage-Can't find touch-up paint
  67. 98 sportage rear hatch help--
  68. car alarm 97 kia sportage
  69. trying to fix rear drifeshaft and carrier bearing
  70. Help PLS!
  71. gas cap
  72. Sportage remote failure , engine not start :|
  73. Intermittent starting problem KIA
  74. 2000 kia sportage engine wont start when hot
  75. engine don't start
  76. Hold button and 4th gear Help Please.
  77. Need maint manual for 01 Sportage
  78. Power loss after transmission replacement
  79. Changing fuel filter on 2000 Sportage
  80. 98 Sportage Fuel Tank
  81. 98 sportage speedometer not working
  82. 2000 sportage-difficulty starting when engine is hot
  83. 1998 Sporatge Knocks when braking
  84. Support Bracket Intake Manifold
  85. check engine light flashing
  86. kia the power to suprise
  87. 2001 Kia Sportage trouble starting
  88. HELP!!!! My 2001 Sportage wont start
  89. "Help" Sportage will not start!!!!
  90. Srs Light
  91. 2000 Kia Sportage - Timing Belt Problem?
  92. 97 sportage 2.0l ignition coils and spark plug wiring
  93. 2007 sportage water inside
  94. Squeeky belts when it rains-solved
  95. need help after changing sportage motor
  96. 2001 kia sportage 4x4 problem
  97. Transmission Problem
  98. 2001 Sportage with no power
  99. Vibration on Acceleration and Coasting in High Gear
  100. 2001 Sportage power lock problem
  101. P1795 code - 00 Kia Sportage
  102. 2000 sportage fuel gauge problem
  103. 96 manual transmission prolem
  104. help!!!
  105. No Start and OBD connector location?
  106. coils melted,still has miss
  107. 1998 Kia Sportage "NO POWER"
  108. Hub nut socket
  109. Fuel injectors
  110. kia sportage running fast
  111. Water Pump Question???
  112. Need advise on 2000 Sportage
  113. Repair Manual
  114. 1997 kia sportage timing belt
  115. Looking at buying a 97 Kia Sportage
  116. CEL light when it rains
  117. 2001 Kia Sportage Brake Warning Light
  118. 1999 kia sportage will not start
  119. timing belt
  120. 2000 Sportage: Won't shift out of park! HELP!
  121. need confirmation of marks?????
  122. 1999 SPortage warranty problems
  123. two questions in 94 sportage
  124. Transfer case shifts hard
  125. 2001 Kia Sportage starting problem.
  126. 2000 Sportage Starting Problems
  127. is this possible??? need a fix
  128. 98 kia sportage won't start?
  129. 2000 Kia Sportage Door Locks
  130. sportage airbag
  131. 99 sportage sloppy 5 speed shifter
  132. 2000 Sportage 2wd rear main leak
  133. 2000 sportage has me boggle read
  134. Blower motor
  135. 2000 Sportage Will Not Start ????
  136. 2000 Kia Sportage keeps blowing Meter Fuse
  137. 99 sportage 4x4 all or parts for sale
  138. fan bracket
  139. Cold weather starting problems
  140. non interference engine
  141. 1995 speedometer quit
  142. t-belt ?
  143. Cant change gears
  144. 2002 Sportange No 4WD Troubleshooting
  145. cranks but no start or intermittentstart
  146. 2002 Sportage no heat inside? Heater Coil?
  147. Fuel tank maintenance
  148. 1999 sportage overheating
  149. 2000 kia power loss just put new battery in whats up?
  150. Clutch replacing
  151. 99 Kia Sportage, AC, Windows, & Wipers quit
  152. 2001 Kia Sportage running rough after overheating
  153. 99 Sportage Tranny
  154. 1998 Kia Sportage OBD code P0264
  155. What Now??
  156. KIA Sportage – sputtering - misfire - no power - check engine – smoke - PO303
  157. HELP - 2001 Kia sportage 4x4 Power Steering problem
  158. removing rotor on 4wd
  159. heater core replacement
  160. 98 Sportage Won't Start After Fuel Filter Change
  161. New video brochure for Sportage shoppers
  162. need 5 speed for 01 sportage 2wd
  163. Kia Sportage Wheels
  164. Fuel Pump Issues
  165. 2001 kia sportage fuel injectors
  166. starting issue 2001 sportage
  167. 98 Sportage-clutch slipping
  168. Fuel tank differences 2dr/4 dr
  169. O2 sensor draining battery?
  170. 95 Sportage AC not working
  171. 2001 Kia Sportage oil filter leaking
  172. looking for reset button on 99 kia sportage
  173. driver side window just disappeared...
  174. 2001 Sportage engine smells and compartment feels hot
  175. 2000 Sportage overheating
  176. 2000 Kia after fixing 4 wheel drive problem
  177. 2000 sportage intermittant starting problem
  178. 1999 Kia Sportage code Po440
  179. blower moter issues on 2000 sportage
  180. Kia Sportage 2.0 TDI 07/2000 Engine does not start
  181. '99 Tportage transmission problem
  182. Hold Blinks, CEL on, codes: P0122, P1309, P1624, P0101 PLEASE HELP!!
  183. 1998 kia sportage
  184. 2002 Kia Sportage misfiring
  185. 2000 Kia Sportage 2wd misfire problem
  186. Corrosion
  187. Fuel tank/sender Corrosion
  188. Too much pressure in fuel line
  189. Trouble starting 99 Sportage
  190. Engine cranks but only starts when it wants to
  191. Shifting noise - 5spd
  192. problems starting Kia sportage 2000
  193. 2000 Sportages Flashers
  194. Location of the main computer for a 1998 Kia Sportage 4x4
  195. Cyl#2 missfire on 96 sportage
  196. Kia Sportage Recall
  197. help with 2001 sportage
  198. Help Please
  199. 2001 kia sportage P0171 error & rough idle
  200. 2001 Kia Sportage EGR valve location
  201. Any one have any use for a Sportage Tranny?
  202. Intake Manifold-Vacuum Line???
  203. 95 Sportage Stick Drop Link Shaft!!!!!
  204. starting prob.
  205. starting prob again
  206. From CAJUNHOPPER : problem with heater
  207. Problem with heater
  208. Another problem, flickering lights
  209. 98 Sportage overheating
  210. 2000 kia sportage
  211. Sportage won't start in wierd temperature range
  212. Kia rear axle help Bearings
  213. valve cover torque question
  214. air bag light.....
  215. codes and CEL
  216. allergic to gas
  217. starts but extremely rough
  218. 1999 Sportage won't restart
  219. Kia overheats / heavy gas fumes when cold
  220. wont start back up
  221. 2006 Sportage Fog Lights
  222. Fuel Tank INspection
  223. 2005 sportage
  224. kia sportage won't start
  225. got in 4 wheel drive-- but more problems...
  226. how to engage 4 wheel drive
  227. 2000 sportage reboot
  228. 2000 kia sportage engine issues
  229. 2001 Sportage Fuel Pump Relay ???
  230. '98: engine light on, hold blinking, what do the trouble codes mean?
  231. gas cap door release
  232. Error Code P422
  233. Hard to start when cold
  234. Changing bearings 2001 Kia Sportage 2WD.
  235. gqas dripping
  236. changing lub in front and rear universals
  237. The 2007 Kia Sportage - New set of wheels
  238. 1996 Sportage-temperature related idle problem
  239. 97 Kia Sportage Fuel Pump/ Fuse Problem
  240. 2000 Kia Sportage 2 Timing belts in 2 weeks
  241. HELP!!2001 sportage HELP!!!
  242. Battery Draining
  243. Raw Gasoline Smell Thru Heater Vent
  244. 2001 Heater Blower Died, How to test / troubleshoot?
  245. Ruff idle and slight shake !!!
  246. 2000 Sportage Misfire When Cold
  247. 2000 Kia Sportage
  248. flat tire caused damage to wiring harness?
  249. found what the problem was the hard way
  250. thinking of buying a kia
