Kia
> Sportage
View Full Version :
Sportage
Pages :
1
2
3
2000 kia sportage dont run HELP
some problems w/2000 sportage 4x4
Newbie With Question
Possible Fuel Pump Problems.
1997 Kia Sportage
2000 Kia Sportage
spark plucgs
Timing Belt Slips / Plug Failure
dohc head
dohc head
4WD trouble...AGAIN
Another HUB question
hold light is flashing
Removing fuel filter on 2000 kia sportage
Stock wheels chrome finish is peeling
Mud Flaps
Kai theft deterrent system problem
Sportage revs high unexpectedly
Stereo wiring harness for 2005 Sportage?
POWER vs. ECON Button
2001 Sportage Convertible- Multiple Problems
Diagnostic Code Identification
2000 Kia Sportage won't run
Sportage 2000 TD 4wd problem
song from kia sportage commercial?
2000 kia
Power Steering Hose
Sportage Stalling when slowing
engine code
can a remote immobiliser be disconnected?
fuel pressure
spark plugs
Air Bag Light and Other Problems
Dodge problems help please?
Replacement of vacuum hubs with Warn mechanical
Rough Idle
Timing belt
Looking for an engine code for a Kia sportage
Leaking brake fluid...
bad baterey?
fuel pump relay
Steering problem
New User
changing trans fluid
turns over.. wont start ..after changing battary
Engine Computer
looking for Front Grille
leaking oil
For Sale, 96 Kia Sportage
sensor
1998 Sportage over heating
O2 sensor location
Check This Out
Rough Idle, stall, And oil leak
Sportage inmobilizer problem.
1998 KIA Sportage HUB ???
acorns in the blower
Emmissions NOT READY after replacing O2 Sensors
Considering a 2000 Sportage HELP
Died while driving on I35
2001 Sportage 4wd
Loosing power on accelaration
Sportage Manual
Sportage Blower Motor Resistor
removing spare tire
Another Clicking Start Question... Have new battery
kia that pops
Clicking / ticking Noise from engine HELP!!!!!!
Manual Gear box - won't change gear in cold weather!!
2000 kia sportage Doesn't always start but turnsover all the time!
No Tail Lights!
passenger windows dont move?!
Keyless Entry System
wheel interchangability
Unable to drive straight
Whistling noise and loss of power
Keys are $10.00 EACH
body kits
2002 Sportage Keyless Entry Programming
defective hub due to corrosion
blower resistor
1999 Kia Sportage
Grinding noise
New Sportage
over heating
sPORTAGE RUNNING ON 2 CYLS! hELP
pads and rotor change. How?
ABS Light
Kia Sportage...MAJOR Stalling/Jerking Problems
Engine Startup Problems, Lots of Clicking!
squealing noise?
Help!!!!!
Wipers stopped in 1999 Sportage, but can still hear motor
Trouble starting when hot out.
2000 Kia Sportage Soft Top
Looked all over the net for horn relay switch
Please buy my Kia Sportage!!!!!!
Horn doesn't work..how do i?
Do You Need "Free Manuals, specs, etc, for KIA?
My brakes are gone
A/c Problems With 97 Kia Sportage
firing order of a Kia sportage
Truck Only Starts When Cold after having Work Done
fan... heater-a/c problem
Changing to 4WD
Swing Arm Latch
sportage cv joints
timing belt
4wd Not Working
new board
97 sportage temp guage
3 Kia Sportage Service Manuals
For Sale: 3 Volumes Of Sportage Service Manual!
Fuel Economy Problem
Lookin for sportage info?
'01 sportage code PO13, what is it?
Kia Sportage Center Cap
Hold Button??
Dash Lights (and Other Things)
98 kia Sportage Airbag Problem
smell?
spare tire latch
KIA Sportage Routine Maintenance
new kia
Problem with Limited Slip Differential
Owner Manual Kia Sportage 1994
Excessive Play in steering
Removing Dash Unit
I Need Professional Help With My Kia Sportage
Testing
