View Full Version : Sportage
- 2000 Kia Sportage Died And Won't Start, Help
- Problems with my 2001 Kia Sportage
- 2002 Sportage RKE button??!!
- Head gasket? and Door remote problems
- 2001 Clutch Slipping
- Squeeky belts
- 2000 kia sportage
- fan blower switch
- Miracle needed Kia sportage
- 2000 kia sportage
- 2001 sportage loss of power while at 60up
- Fuel filter fittings
- Dead '95 Sportage
- Replaced IAC but still stutters at idle
- help help
- Kia Sportage 1997 transmission PROBLEM
- sudden power loss - 2001
- 1997 2WD Sportage Problem
- car starts but cant move or it stalls, HELP!
- starts but cant move or it stalls, HELP!
- 2000 Kia Sportage
- Brake light and battery light come on intermittently.
- Trans fluid change
- dying sportage needs help
- I love my KIA Sportage
- 2002 sportage making squealling noise in front driver side tire
- Blown Fuses
- New stereo
- Towing Advice
- 2000 Sportage Check Engine light
- idle problems on sportage
- Less power and pinging down low
- Water leaking IN the rider side floor board.
- Car unlocked on its own
- loose wheel
- Sportage with Overheating issues
- Genuine vs aftermarket.
- fuse problems on my KIA Sportage 2001
- Kia Information Needed
- Not sure what to do.
- Need help
- I need help
- 2001 sportage stalling/codes
- 2000 Sportage Engine Squeals, Help
- what years are cross compatible for the spare tire carrier?
- HELP! my 2001 Sportage DIED on Hwy 99
- 98 Kia Sportage Key Stuck in Ignition
- Changed motor wont start now
- transmisions
- Leaking AC Unit
- Timming belt fix
- Front brake fix
- Some Sportage information here
- Please Help!
- 2001 Sportage 4x4 -Check Engine Light won't go off
- $4000 to repair blown gasket?
- Help Changing Spark Plugs Please
- the screws that seal the air cleaner
- Strange smell on 99 Kia convertable
- ICV Valve Fixed 99 Kia problem now blinking hold
- 2000 Kia Sportage Double Din Installation:
- AC is leaking onto the floor board.
- P440 Error code problem
- abs light
- Sportage 97 Big problem. HELP!
- 99 sportage alternator
- heatercore
- sportage overheating
- warn auto locking hubs?
- Universal Cup Holder for Sportage?
- Tranny problems???????
- replacing pitman arm?
- Another hub question . . .
- Tranny fluid in manifold journal??
- Surges whilst driving.
- 01 sportage big gas problem
- neeeddd heeelppp!!!!!
- Squeaky Belts won't go away!
- I Give Up! Need Help! P0326 Knock Sensor
- Is it the timing belt?
- Frustrated Technician - 2+3 Misfire 2001 4wd
- '01 Kia stutters in idle and jumps
- Fuses? Please help!
- Kia Sportage 97
- Kia Sportage '96
- engine problems
- 99 sportage no signal lights
- Grinding nose in the front end
- 97 sportage starter removal, whats the trick ?
- Normal gas mileage check
- 2000 Kia Sportage
- '95 Kia Sportage with leaky gas tank
- Sportage maintenance question
- Yet another timing belt question
- Ruff start after gas up
- A/C Heat vent on Kia Sportage etc HELP!
- 2000 Sportage Problems with Heat/Starting
- 99 sportage heater core where do i start
- 2000 Sportage Engine Design and control
- i need timing belt specs
- low pressure fuel filter attached to fuel pump
- What's REALLY needed at 30,000 miles??
- HELP - Urgent! O2 sensors/running rich/ cat problem
- 1998 Kia Sportage. Hard to Crank/Start
- Need Help
- 98 Kia Sportage EX leaking by oil filter area
- 1999 sportage in dominican republic
- Sportage overheats and temp gauge reads normal
- start problems
- 1999 Kia Sportage
- 2000 sportage running rough
- spark plug coils
- 1999 sportage engine start but wont stay on
- Radio/CD clock reset question
- 2000 Kia Sportage Rear Hatch Problem
- 2001 Sportage Rear Main Leak
- 99 Sportage EX/Sudden stalling
- timing belt broke
- Sportage Missing and not pulling
- LED turn signal headlights and mirrors?
- 2001 sportage w/ fuel smell in cab
- 2001 Kia Sportage catalytic converter problem?
- Still waiting on a wire hareness
- 4WD trouble on '95 Sportage
- obdII p0453
- i need help fuel pump problem
- 98 4 whel drive
- 2001 Kia Sportage Bezel radio removel
- Fuel Pump vs. Wire Harness?
- driver window failure
- 2001 Sportage - Should I buy one?
- ABS and Warning Light Appear for few seconds
- 2001 Sportage cd/cass/radio
- A/C and temp meter problem
- Flashing hold light!
- No Heat
- 1997 sportage oil leak
- 2000 Sportage - Losing power & understandig codes
- Sportage Trans.overdrive
- fuel tank leak
- ADVICE ON 99 SPORTAGE - Do they go over 89,000 of the engine?
- Low Fuel Warning Light?
- 1999 Kia sportage problem
- HELP!! Radio Blown Fuse
- Power steering belt
- 2002 sportage AC compressor pulley
- Loss of power
- 1993 sportage dlc location
- 1999 Sportage keyless remote
- Front wheel bearing adjustment
- switch on the dashboard question
- Help. Website needed
- fuel injectors
- detachable faceplate for the radio cd player
- Rod Knock
- Gas Cap Door
- Engine studders when it is cold
- Airbag Light Question.......
- alternator/battery/charging problems
- 2005 oil drain plug
- What could be wrong?
- Thinking of Purchasing a cheap Sportage, input wanted.
- 1999 Sportage problem
- Knocking Sensor
- '95 Sportage misfiring badly
- 2000 sportage runs but verry hard to start, HELP
- 2002 Kia replacement battery
- 2000 Sportage Aftermarket parts
- a few questions wiper prob/ and a studder
- Excessive auto tranny shifting
- Car not starting I unplug batery wait 60 sec it starts Help
- 2000 kia sportage dont run HELP
- some problems w/2000 sportage 4x4
- Newbie With Question
- Possible Fuel Pump Problems.
- 1997 Kia Sportage
- 2000 Kia Sportage
- spark plucgs
- Timing Belt Slips / Plug Failure
- dohc head
- dohc head
- 4WD trouble...AGAIN
- Another HUB question
- hold light is flashing
- Removing fuel filter on 2000 kia sportage
- Stock wheels chrome finish is peeling
- Mud Flaps
- Kai theft deterrent system problem
- Sportage revs high unexpectedly
- Stereo wiring harness for 2005 Sportage?
- POWER vs. ECON Button
- 2001 Sportage Convertible- Multiple Problems
- Diagnostic Code Identification
- 2000 Kia Sportage won't run
- Sportage 2000 TD 4wd problem
- song from kia sportage commercial?
- 2000 kia
- Power Steering Hose
- Sportage Stalling when slowing
- engine code
- can a remote immobiliser be disconnected?
- fuel pressure
- spark plugs
- Air Bag Light and Other Problems
- Dodge problems help please?
- Replacement of vacuum hubs with Warn mechanical
- Rough Idle
- Timing belt
- Looking for an engine code for a Kia sportage
- Leaking brake fluid...
- bad baterey?
- fuel pump relay
- Steering problem
- New User
- changing trans fluid
- turns over.. wont start ..after changing battary
- Engine Computer
- looking for Front Grille
- leaking oil
- For Sale, 96 Kia Sportage
- sensor
- 1998 Sportage over heating
- O2 sensor location
- Check This Out
- Rough Idle, stall, And oil leak
- Sportage inmobilizer problem.
- 1998 KIA Sportage HUB ???
- acorns in the blower
- Emmissions NOT READY after replacing O2 Sensors
- Considering a 2000 Sportage HELP
- Died while driving on I35
- 2001 Sportage 4wd
- Loosing power on accelaration
- Sportage Manual
- Sportage Blower Motor Resistor
- removing spare tire
- Another Clicking Start Question... Have new battery
- kia that pops
- Clicking / ticking Noise from engine HELP!!!!!!
- Manual Gear box - won't change gear in cold weather!!
- 2000 kia sportage Doesn't always start but turnsover all the time!
- No Tail Lights!
- passenger windows dont move?!
- Keyless Entry System
- wheel interchangability
- Unable to drive straight
- Whistling noise and loss of power
- Keys are $10.00 EACH
- body kits
