View Full Version : Spectra/Cerato/Cerato Euro/Mentor
  1. 2002 KIA Spectra
  2. What transmission
  3. Dashboard
  4. Transmission flush on a 2003 Spectra
  5. Timing Belt on a 2003 Spectra
  6. KIA Spectra Problems
  7. Keyless Remote Programming
  8. Shock/strut
  9. 2001 kia spectra transmission won't engage after the half shaft was replaced
  10. Rattle and Slosh
  11. High RPM at idle normal?
  12. 2002 Spectra heater and a/c Drain ???
  13. Spectra Engine Problems after Wash
  14. Location of throttle position sensor in a 2002 Kia Spectra
  15. Smelling fuel inside car
  16. 2010 Kia Forte
  17. Codes po422 and po460
  18. Gauges stopped working on 2001 Kia Spectra
  19. removing rear tail lights
  20. 03 Spectra with 78k jolting
  21. Just picked up a new 08 Spectra5
  22. 02' Spectra Auto Trans Shifter replacement:HOW-TO
  23. Spectra5 or Hyundai Elantra SE
  24. 2003 Spectra- Misfire on Cylinder 1
  25. P1404 on a 2003 Kia Spectra
  26. 01 Spectra motor oil - which one?
  27. Shaky 05 Spectra.
  28. 2009 Kia Spectra spy shots
  29. 2002 kia spectra
  30. 03 spectra leaking brake fluid
  31. Aftermarket A/C
  32. FS: 05-Current Kia Spectra Strut bar!
  33. Very interesting KIA trivia.
  34. Rattling Noise
  35. '03 Kia Sprectra Code P0325 - knock Sensor mal
  36. 05 airbags
  37. Wierd PS fluid and Tranny fluid.
  38. 2004 Spectra rear brakes
  39. Sloshing noise
  40. 2001 Spectra clutch repacement
  41. PCV HELP? 02 Spectra
  42. Help! Oil on Spark Plug!
  43. Fuel Tank access
  44. windshield wipers wont work...2003 specta
  45. oil
  46. Spectra V. rio
  47. '06 Spectra5 wiper problems
  48. 03 kia spectra
  49. How do you prime a fuel pump for a 2003 Kia Spectra?
  50. Rear Wiper Blade
  51. 03 Kia Spectra CD Player help
  52. Towing capacity for 2002 Spectra GS?
  53. 2003 Spectra Help
  54. What is the optimal tire size for 01 5door spectra
  55. AM/FM Cassette Audio Adjustments?
  56. Oil wrench size
  57. Help Timing Belt
  58. A/C complete meltdown
  59. emission issue and drive cycle
  60. 3rd brake light
  61. Best place for Aftermarket parts?
  62. Replacing tailight bulbs on a 2001 Spectra
  63. Spectra brake pads
  64. V4?
  65. rear brake going bad
  66. rear calipers
  67. Spectra Modifications
  68. 2004.5 Kia Sepctra Keyless Entry
  69. High RPM issues
  70. literally frozen ignition
  71. My heat doesnt work
  72. Help
  73. Kia body parts
  74. Automatic Shift Problem
  75. Turn signal question - 01 Spectra
  76. Navigation
  77. 2003 Kia Spectra Check Engine light
  78. Kia Spectra Maintanence
  79. 2003 Kia Spectra Radio help
  80. 2002 Spectral Problems or Not?
  81. Ark Performance - Looking For Spectra5 2005 for exhaust test fit
  82. help
  83. remote keyless sensor
  84. Make it shift?
  85. 2002 Kia Raido Codes
  86. Prostart remote starter
  87. bad sensor?
  88. spectra timing
  89. Changing the radio station on a 2002 kia spectra
  90. need assistance
  91. Check out this new Specta5 - .
  92. Who knew a kia could sound like this!
  93. hmm
  94. new here
  95. Interested in a Kia Spectra
  96. Kia misfire in Cylinder 1
  97. 2005 Spectra
  98. New headlights
  99. new board
  100. Prostart Car Starter
  101. change the spark plugs
  102. I have had great luck with my Spectra
  103. Thinking of a Spectra ...
  104. Kia Spectra Jackson Racing Project Spectral K
  105. Spectra Owners Group
  106. 2000 Kia Spectra GSX
