View Full Version : Cherokee
- Hello need some help
- 2000 Cherokee sport Dealer Manual
- 2000 Jeep Cherokee stalling at idle
- 02 Grand Cherokee
- oil pressure
- 2000 Jeep cherokee sport ticks when accelerating
- 99 xj overheating
- pressure release valve question
- 95 cherokee T-case
- 95 cheokee oil filter adaptor
- 1991 Jeep Cherokee Engine Problem
- Marc
- interior lights wont turn off
- wipers wont turn off
- transmission slips in all gears..car won't move.
- Fuel problems?
- 95 Cherokee weird electrical problems
- Can't open back door (hatch back)
- Leaking coolant, but on days it wasn't run
- 0331 Heads dont break!!!!
- Another Cherokee Cooling Issue!!
- 98 cherokee. fuel pump not running
- Jeep XJ 4.0l heads question
- Extra lift 87 Cherokee???
- idles normal than cuts out.
- 00 Cherokee Sport 4x4 dies out but stays running
- 97 jeep grand cherokee larado
- Electric-Vaccum booster swap.
- 2002 Anti theft
- Cooling Fan won't shut off
- my jeep doesnt run like it should
- Buzz sound from transmission area
- Looking for a rebiuld kit for a 2001 xj 4.0l engine
- 94 Jeep Cherokee Automatic Door Locks Dome Light NOT THE FUSES
- 88 Cherokee Valve Cover Gasket Replacement
- 97 Cherokee Serpentine Belt Tension?
- 90 cherokee won't start after replaceing fuel pump
- New Oil Pressure Switch
- 90 Jeep Cherokee, headlamps won't turn off after shutdown.
- Recommended Oil? 1994
- 91 cherokee brake accumulator?
- 2001 XJ weird sound
- my jeep blows black smoke and doesnt idle right..
- 2000 Jeep Cherokee Headlights Blinking
- 1994 jeep grand cherokee
- Throttle Body Adjustment
- 2003 Grand Cherokee, no crank, key symbol on
- True-trac??
- Fuel system issue?
- 96 Cherokee won't crank
- High Idle at Start?
- 1996 jeep cherokee
- timeing issue
- High RPM's starting up...? Pedal loose...?
- fuel pump???
- no sound from stereo
- 90 cherokee 4.0 need help !!!!
- Wobble
- How do you open the hood when the Hood Latch Cable Broke.? 1994 Cherokee
- jeep grand chrokee
- anyone with a 4.0L: need help with wiring plug connections and wire colors
- lifter is stuck
- 01 Jeep Cherokee intermittant oil leak
- Bumper swap
- instrument cluster swap
- XJ Parts available
- takes twice to start
- 92 Jeep Cherokee won't start.. HELP!!
- engine swap
- Lift questions
- snorkel
- 1988 Jeep Cherokee Idle's VERY low
- 99 Cherokee Sport - opinions?
- 1988 cherokee 4.0L hgih idle/engine tick
- 8.25 trac-loc clutch pacs
- '01 cherokee engine replacement
- Jeep 4.0 6 cyl freeze plugs
- cherokee fuse# 11
- 90 cherokee laredo hard brake pedal
- battery dying
- Inside rhino line
- 1984 jeep problem help
- Can freeze plug be replaced with engine in car?
- electrical gremlins, please help!
- 94 cherokee overheating but coolant not hot
- 95 lots of blow by and detonation hothttp://www.automotiveforums.com/vbulletin/images
- 1996 Jeep Cherokee Won't Start
- 2001 Jeep Cherokee check engine light
- 2001 Jeep Cherokee AC Fan
- 1990 cherokee stalling
- corrosion on brake lines
- Is it possible they turned back odometer
- HELP!!! Stalling at idle
- AC problem
- Surging
- AC / Heater Fan speed Switch
- AC questions
- My Jeep Cherokee '98 dies while running-dire need of assistance!
- First time Jeep buyer.....
- '00 3 speed tranny (30rh?)
- 2001 Cherokee Turns over but will not start
- Lucas Fuel Additive
- '96 Cherokee Sport
- 92 Jeep Cherokee Laredo, intermittent start
- 96 grand cherokee limited 5.2 - won't stay on
- Engine Smoking
- '94 Cherokee battery problem
- No ac
- Turn signal problem
- 1990 4.0L Cherokee No-Start
- Cherokee Oil pressure problem
- AC Cooling Fan not turning on....
- Let's play name that connector!
- "Spring" clean-out!
- Wobble
- Window came off tracks
- 1999 Cherokee Left Turn Stall (Full Tank) HELP!!
- 1998 grand cherokee limited blinking windshield display
- R.i.p
- What kind of transmission fluid 1986
- 1986 Cherokee, 4wd problems.
- 90 Jeep Cherokee Electrical Problem
- 99 Jeep Grand Cherokee, stalling
- 88 jeep wagoneer wont start
- 92 cherokee not shifting
- 1978 jeep cherokee
- How to fix a "p1694" code?????
- 93 cherokee possible fuel injector issue
- Engine dies when throttle let go.
- how do you fix rear gears?
- Connector
- cross member
- 1995 Jeep Cherokee stalls immediately after ignition released
- i need help
- 1991 laredo shifting probs on accel.
- 99 NSS switch HELP!!!
- Check engine light on 89 cherokee
- Whats with this my baby
- Not running well
- how tight
- Vibration on accel
- gonna take a look at cherokee tomorrow need advice
- stuck in 4wd 85 cherokee
- CD Player Mode disappeared - Please Help!
- i Need to change my tranny mount
- bypass air conditioner
- Weird Coolant leak
- Gas tank siphon question
- powerwindow switch pass side works intermittently
- 1997 4.0 bucking problems???
- 89 Cherokee Laredo fuel system problem?
- tps issues
- popping noise when i turn steering wheel
- don't know what this code means...
- 98 4.0 Trans. Trouble
- 1995 Grand Cherokee trans cooler line repair
- 1995 Grand Cherokee speed sensor o-ring
- Wet Floor on Driver's Side of 97 Laredo
- 93 5.2L JGC backfires at around 2000 RPM
- Shimmy at acceleration
- 95 jeep sport no reverse
- 97 cherokee wont idel
- 88 cherekee inline 6 4.0 L
- lean codes
- Idle Issues-intermittently
- Tilt steering broken
- 88 cherekee
- will not shift into drive
- 99 Jeep cherokee motor fan
- Cherokee Sport Won't Turn Over
- 98 2 door xj driver seat
- 1989 Jeep Cherokee - Hazard relay location?
- thrown rod--is it worth it to get new engine?
- 99' Laredo sputtering issue
- help noise after pressing gas pedal
- tranny question
- tranny question
- spiking engine temp, dropping voltage?
- turn signal, winshield wiper knob not working
- 96 xj tire size question
- Front passenger speaker not working
- 99 Grand Cherokee front end noise
- Transmission Problems
- 99jeep computer interface has no power
- Engine Cranks, no start
- 1988 Cherokee ticking
- auxiliary fan comes on at start up
- Cherokee Sport Shutting Off
- Tranny Slipping in OD
- 99' Grand Cherokee Laredo gas economy?
- Battery dies in cold temps
- start and then stops
- dissapearing heater...
- turn signals dont turn
- Pardon the dumb question: how do you put a 96 XJ in 4wd?
- 96 XJ strong gas fumes
- XJ will drive in reverse but not forward!
- jeep wont start
- 96 Jeep Starts sometimes
- Power Brake Problem
- Xj Transmission Problem
- 98 cherokee overcharging
- ccv orifice problem 93 jeep cherokee country
- 88 XJ Engine Grinding Noise
- cruise control?
- 93 jeep cherokee 4.0 HO/running rough
- 2000 Cherokee Link Add to No Start XJ
- 1995 xj 4.0 pin test
- Heater problems
- Shop Manual 2000 Cherokee
- serpentine belt tension .. broke the adjuster.. 1990 4.0 laredo
- oil in coolant 88 cherokee 4.0
- 2001 Cherokee Sport Window Problem
- 1999 Cherokee Cruise Control problems
- bigger gas tank for xj
- Keys, please
- Locked Wheels on Ice while Sliding and Gear Clicking Sound
- Oil level grows 99
- 98 Heater Problem
- One you don't hear too often
- Warranty extension '96-'99 Please read
- 97 xj wont stay on
- Problem with 4X4 Shifting on Selec-Trac
- 2001 Cherokee brake issue
- power window switches replacement?
- 1998 Jeep Cherokee Serpentine Belt Replacement 4.0 6 Cyl
- 1989 Jeep Ignition Nightmare
- Advice on plugs
- 231 J Transfer Case Swap
- More Flexplate Issues/maybe More
- bad cat or engine / sensors ?????? 4.0
- 99 Cherokee - Odd Electrical Problems
- 1998 Cherokee Running problems
- engine problems!
- replacement radiator question
- 87 Cherokee for parts
- 96 Cherokee 4.0 Intermittent idle problem.
- 89 Jeep Cherokee
- 2000XJ - Turn Signals
- 1990 jeep cherokee sport heater blower?
- Bad Squeaking When Thottled
- slow start and high idle(couple seconds) when cold
- Dashboard lights
- '96 Jeep Cherokee
- engine swap
- weather drop=dramatic mpg drop-is it normal with cherokees???
