View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21
  1. XJ Engine Needed
  2. My jeep Was stolen :(
  3. 1993 Power Window Fuse - Which one is it?
  4. one headlight brighter than other
  5. 1991 cherokee won't start
  6. Front end "POPS" when i turn left????
  7. Egr Valve...
  8. Troubleshoot Seat Heater Cherokee Limited
  9. Fuel Injectors...
  10. 89 Jeep Cherokee-Frost plugs popped out and probably a bad starter?
  11. 2000 Cherokee Sport ??
  12. 4.0 air intake system
  13. 89 cherokee H-lights,radio,horn intermittent
  14. Heating Issues
  15. Size does matter
  16. Best made
  17. Emissions...
  18. Rear differential rubber drain plug
  19. 1991 with 4.0 putting 1989 4.0
  20. Other heating problems
  21. Thermostat...
  22. Power Window and Door Lock Probs...
  23. 87 jeep cherokee starting problems after swap
  24. How to...
  25. Fan Switch...
  26. Thermostat Good?
  27. What’s better off-road, a Cherokee or a Blazer
  28. 88 4.0 Upgrade
  29. looking for a 6cld for my 78 jeep mail truck
  30. 1984 jeep cherkee 4x4 stick truck
  31. 1987 cherokee 6cyl serpentine belt installatioon
  32. Power Door Locks SLOW
  33. '93 Jeep Cherokee 4wd problems
  34. 99 jeep
  35. 88 XJ Cherokee Laredo Q's...
  36. 95 Cherokee gate supports
  37. Temp Sending Unit Replacement HELP!!!
  38. 95 Cherokee brake pads
  39. Front end noise
  40. 1999 jeep cherokee vibration and humming
  41. 2001 Cherokee serpentine belt
  42. 94 cherokee won't start, help.
  43. 88 jeep cold start problem
  44. Engine keeps flooding
  45. Engine Swap for xj?
  46. Weird starting problems.
  47. 98 cherokee radical missfire while driving
  48. 88 Comanche 4.0
  49. auto tranny nightmare
  50. Where are the plugs
  51. 88 Cherokee 4.0, Fuel Injected, Stalling
  52. 1993 Cherokee 4.0 quits (not cps)
  53. Blowin' Fuses For Signals
  54. No Luck...Thanks any way.
  55. bad steering in my cherokee
  56. Windsheild washer pump
  57. Dana rear question
  58. Block heater on my cherokee???
  59. Heating Problem!?
  60. Column replaced and Windshield wipers don't work
  61. Rear Wiper Help! 99
  62. Electrical Short - Dome Circuit - 91 Laredo
  63. starting trouble
  64. Small Lift Suggestions
  65. heater blower
  66. No heat 96 Jeep Cherokee 4.0
  67. 89 Comanche Stalls hot won't restart
  68. blower motor on high speed only
  69. Overheating-90 Cherokee
  70. lots o miles
  71. can't get in
  72. 97 jeep cherokee won't idle on its own
  73. Hydraulic Clutch Slave Cylinder-88 Cherokee
  74. 1991 jeep cherokee Limited keeps stalling
  75. Technical service manual?
  76. 2003 requiring new valves and cam shaft
  77. 1991 Cherokee Laredo Dashboard problem
  78. Start problem
  79. oil leak
  80. No tail lights, dash lights
  81. Intake manifold
  82. 95 cherokee leaking heater valve
  83. 95 Cherokee, Lack Of Power
  84. overcooling???
  85. XJ killed!
  86. track bar install
  87. Engine died when sitting at idiol, No spark
  88. Headlight Problems!!
  89. Tire size
  90. Problem Starting, No Fire...
  91. evo sensor for steering control
  92. Tramission blows fluid from dip stick
  93. have to fight my jeep like crazy to keep straight???
  94. Manual window regulator
  95. Won't start in cold!
  96. No horn
  97. have to fight my jeep like crazy to keep straight???
  98. Won't start in cold
  99. ??Bump Steer?? -Searched
  100. Stock HP for 98 Cherokee Classic
  101. Heating *wierd*
  102. Control Arm Bushings
  103. Distributor 1992/1996 both 4.0
  104. 1990 Cherokee rebuilt transmission problems
  105. Temperrature problem?
  106. subwoofer help
  107. posi or detroit locker?
  108. Temp sending unit broke
  109. Is there a certain oil i need to buy or will any do?
  110. I have an electrical problem.(i think)
  111. 95 starter issues
  112. Power Steering Pulley Installation
  113. Omg!!
  114. neutral start/back-up light switch
  115. 1996 Jeep Cherokee 4wd Indicator light not working
  116. Need JEEP/EAGLE ADAPTER For DRBII
  117. Somebody Help Me!
  118. Desert Heat
  119. 92 jeep cherokee
  120. Please Help!!
  121. Rear differential
  122. running over ricers
  123. dynamic dampener
  124. Problem with A/C, blinkers, radio and windshield wipers
  125. 89 cher ltd right signal arrow getting stuck
  126. Leakage
  127. Purge solenoid ticking
  128. Speedometer Intermittent / Dead
  129. Emiss maint Light
  130. new starter, won't start
  131. Gap bridging on spark plugs
  132. Crank shaft replacment
  133. "low wiper fluid light always ON!"
  134. Brakes just wont work tried everything
  135. Parking Lights
  136. Need Adive on Cherokee add-ons
  137. Engine Mods?
  138. 2000 jeep cherokee sport blower fan switch
  139. Help--Heating issue
  140. 1988 cherokee 4.0
  141. Heater core replacement
  142. Whining noise above 35
  143. wont start
  144. Battery gauge dropping
  145. driving lights question
  146. trouble code retreival
  147. Looking for advice on 1995 Sport
  148. 88 jeep cherokee std trans shifter prob.
  149. whats the best performance mod.-4.0
  150. Hesitation & Stalling
  151. looking for leaks
  152. 95 Cherokee high NOX
  153. code reader for xj 90 and before
  154. 89xj rear left door will not open from driver control armrest
  155. rear disc brakes
  156. Should I Sue In Small Claims?
  157. jeep cherokee damaged computer
  158. 96 jeep cherokee = fried computer - HELP
  159. Cold Air Intake Question!!!!!
  160. having problems when turning tothe right shuts off
  161. 89xjlimited no status light on dash--HELP!
  162. where to look for oil leaks
  163. No More OVERHEATING!!!! YEAH! Biggie UP for BC BLues
  164. question about fog lights on jeep
  165. 160000-too many miles on a cherokee?
  166. Help, no power!!
  167. More weird electrical problems
  168. 89 xj limited horn does not work
  169. Weird electical/starter problems in '90 Cherokee
  170. Parking Brake Button 98 Cherokee
  171. Clank Clank Clank
  172. Fuel gauge goes crazy
  173. 89 fuel pump or pressure regulator?
  174. rear main seal
  175. Bump...Stop (running that is)
  176. 94 Cherokee EGR
  177. Eng Ctrl fuse blowout.
  178. 88 cherokee transmission issue
  179. jeep cherokee sport
  180. jeep 2000 electrical questions
  181. 99 jeep cherokee rumbles
  182. 93 cherokee not starting
  183. 2000 Cherokee liftgate problem
  184. MAINT REQD Light
  185. fuses
  186. passenger manual window wont roll up
  187. rpms fluctuating
  188. broken firewall
  189. Brake Lights on 1989 Jeep Cherokee wiring
  190. No spark
  191. need lift for my 90' limited
  192. liberty wheels fit cherokee?
  193. 700 & 705 Codes
  194. Ignition Switch
  195. 2000 Cherokee Sport
  196. somethings not right Part II....
  197. turn off Check engine light
  198. Leaf Springs
  199. flowmaster exhaust on a cherokee?
  200. Eng Ctrl fuse blowout.
  201. Jeep Cherokee headlights
  202. Jeep Wont Start
  203. What is this hose out of my firewall
  204. debris in clutch fluid
  205. Having gauge problems? heres the answer
  206. UP COUNTRY Suspension?
  207. stearing collum was pealed
  208. will any other leaf springs work on 89 xj lift?
  209. clutch problem
  210. help
  211. overheating ?
  212. 1999 jeep just quit
  213. Jeep thumping
  214. Cherokee Cold Air Intake ?
  215. Door stuck closed & locked.
  216. 95 jeep troubles
  217. Starter turns but engine doesn't crank
  218. 1999 Jeep Grand Cherokee - Need advice on replacing a blown dash speaker.
  219. V-8 swap
  220. somethings not right...
  221. 1989 Cherokee Backfires
  222. Shifter I.d.
  223. intermittent short circuit
  224. 89 4.0 that wont stay running
  225. Jeep Cherokee DASH
  226. Differential Fluid Additive?
  227. 1996 Jeep transmission problems
  228. Front hub/axle removal
  229. Clunking and tranny whine
  230. alternator or what
  231. Clutch Problems
  232. Spark plugs?
  233. leafsprings
  234. Jeep Cherokee Sport Door Speakers
  235. fuel injectors
  236. Jeep Cherokee Bench Seat
  237. remove and install radio 1992 jeep cherokee
  238. No Heat, HELP!!!!
  239. Hard Starting
  240. 85 cherokee slave cylinder
  241. Jeep won't start
  242. O2 Sensor Heater Trouble
  243. Groaning Noise
  244. overheating question
  245. 89 cherokee transmission problem
  246. 89 cherokee fuel injecting no 12 v power
  247. Cherokee Side Moldings Anyone?
  248. Chrankshaft Position sensor removal
  249. 89 cherokee hatch area leaking
  250. 89 limited leaking sunroof
