View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. 99 center console rattle while idling
  2. Towing my eclipse with my 01 jeep cherokee sport help!!!!
  3. Water in center console
  4. 15 yr old son Needs 94 Cherokee Drivers Door, etc
  5. Violent jerking and vibes
  6. 2000 Jeep Cherokee, no brake lights.
  7. Burnout in Cherokee
  8. Fuel Tank Replacement
  9. '85 Cherokee starter installation
  10. i have fuel pressure and spark still wont start
  11. 92 cherokee wont start
  12. 4.0 and 4.0 HO, whats the difference?
  13. frustrating fuel filter
  14. Jeep Wheels?
  15. busted transfer case ?????
  16. stumbles and hesitates
  17. knocking underneath
  18. 2000 shuts off at low speeds or idle
  19. 4wd won't engage
  20. Rebuild or Replace
  21. 96 xj acceleration chatter
  22. Oil leak in the strange place
  23. 87 Jeep Cherokee Inline 6, REALLY bad blow by
  24. 4wd intermitant
  25. need some help
  26. neutral column switch
  27. 2000 Cherokee Sport Brakes
  28. Show Me Your Bumpers!
  29. 96 xj Wont start HELP!!!
  30. 96 xj Wont start HELP!!!
  31. Remove Head on 4.0 HO
  32. 1996 Jeep Cherokee squeaks while turning
  33. A/C Comp just kicks on... Why? 01 XJ
  34. howdy
  35. 98 xj On-board air
  36. Need Cherokee buying advice
  37. Tick tick tick tick tick grrrrrr
  38. Really dumb question...
  39. 93 Cherokee Sport Wiring Harness
  40. 95 Cherokee, wipers, radio, A/C
  41. 87 Cherokee 2.5ltr constant stalling
  42. aw4 jeep cherokee tranny problems
  43. Repair theft damage?
  44. 93 4.0 HO swap to a 88 4.0 non high output questions
  45. Need help replacing alternator!!!
  46. 98 remote starter question
  47. Stupid Transfer Case question......
  48. Installing a Car Stereo.
  49. Cherokee Sport Question
  50. 1989 Jeep Cherokee Hard or no start in rain
  51. 98 xj console
  52. Not so grand Cherokee
  53. Whats the difference?
  54. Removing carbon deposits inside intake manifold
  55. 1987 Cherokee inline 6 starter
  56. Brake Light Problem
  57. 96 xj tie rod install
  58. NEED FLOOR PANS! for my 92 XJ
  59. Transmission problems?
  60. 2000 Jeep Cherokee Classic Stalling Problem
  61. Bought a 93 XJ
  62. 1988 Jeep Cherokee shakes violently
  63. Jeep Cherokee heating driving me mad!
  64. 89 jeep cherokee oil in aire filter I know what your thinking replace the hoses etc
  65. 87 Jeep key switch problems
  66. 96 cherokee overheating all ofa sudden!
  67. heater core
  68. is my a/c condenser squeeking?
  69. after driving 93 wont restart
  70. starter
  71. 4wd part time and full time?
  72. 96 Cherokee electrical gremlins
  73. Help. My interior lights won't shut off
  74. opinions please
  75. 97 XJ Intermittent Start
  76. Ignition lock problem
  77. Ignition lock problem
  78. Buying 2002 Jeep Cherokee
  79. Stumbling at Idle and accelleration
  80. lift kits
  81. Starter Spin
  82. 99 jeep trouble shooting question!
  83. dashboard swap
  84. Rear seatbelt retractor
  85. Cherokee 2.5 stumble at cruising & 1/8 throttle
  86. Dome light/ CD player problems
  87. Seeking 1991 carburetor for 2.5 litre gas Cherokee
  88. 87 Cherokee replaced column and lost tail lights
  89. Ignition Removal
  90. Leaking Tranny Cooler
  91. New Suspension Lift
  92. Yoke installation on Pinion Gear
  93. engine swap
  94. 2000 cherokee ride height
  95. Changed Blower Motor & Fuse - Still not working
  96. 200,000 miles on original engine
  97. No Pvc????
  98. gas gauge trouble and more
  99. transmission??? PLEASE HELP
  100. 90 laredo P windows + wipers & locks
  101. 1996 Cherokee SE 4.0 6Cyl Blower Mtr Blew
  102. Number 2 cylinder has sporatic misfire??
  103. Number 2 cylinder has sporatic misfire??
  104. Cherokee fuel mileage
  105. crank no start inter.
  106. cranking/ flooding problems
  107. tail lights, too
  108. Brrr it's cold
  109. Replacing 04 Cherokee Headlight Bulbs
  110. Humming/Buzzing Noise At Speeds 20-40 MPH
  111. Water on floor board
  112. front differential
  113. Possible Oil Pressure Prob?
  114. 90 Cherokee Laredo gas smell
  115. 1987 jeep cherokee 6cyl 4.0 4x4
  116. 1987 Jeep Cherokee - Running lights / Instrument lights
  117. 96 Cherokee transfer case exploded
  118. jack
  119. Acetone and gas
  120. 89 Cold start problem
  121. 1993 Cherokee 9" rear brake problem
  122. NSS... Is it necessary?
  123. 99 cherokee squeaking
  124. 89 cherokee 4.0 hard starting...
  125. 4.0 mpg
  126. compressor clutch came apart
  127. GEN light on dash and smoke
  128. Shimmy that wont go away!!!
  129. '88 4.0L power loss...
  130. 92 cherokee front door window mod
  131. Oil Consumption sadness... :(
  132. Can i change the Donut for a full spare?
  133. automatic windows - not so automatic!
  134. 98 XJ Up Country aux trans cooler line routing
  135. 1996 cherokee sport
  136. Engine dies
  137. Jerky steering wheel issue.
  138. no spark
  139. oil oil everywhere-89 cherokee 4 ltr
  140. shift on the fly
  141. 97 cherokee sport - stalls turning left
  142. fan shroud
  143. Power windows
  144. Removing 4.0 Litre With Tranny
  145. 93 windshield wipers dont work
  146. redish-pink fluid leak
  147. replys to old treads
  148. abs change over to reg brakes
  149. Urethane Bushings
  150. dim charge light when heater on
  151. Thermostat Problems
  152. Trans fluid change
  153. FS: 1988 Jeep Cherokee
  154. 4.0 to 4.0 HO?
  155. changin belts
  156. Add Power Windows & Locks for 96 Sport
  157. Mushy brake pedal on 89 Cherokee
  158. Dashboard Lights
  159. Dashboard Lights
  160. Jeep won't turn off
  161. Where is the coolant leaking from?
  162. Ignition switch Problems
  163. engine light
  164. 87 XJ questions
  165. Backscape Decals...
  166. 4.0L Reg or HO?
  167. Screwed up trans issue....
  168. torque converter solenoid
  169. Correct Nuts & Bolts?
  170. Dimming headlights
  171. 1995 Jeep XJ Cherokee
  172. 90 JC, Horn wont work
  173. transfer case
  174. Jerking at high speeds....
  175. Troubleshoot w/o MIL Light...
  176. rear wiper
  177. feels weird
  178. sounds weird
  179. where can i get little pieces that are driving me crazy
  180. rear wiper
  181. cherokee
  182. crazy guages
  183. 01 Cherokee electrical madness!!
  184. What to Put
  185. 93 cherokee fuses
  186. AC Upgrade...
  187. My '88 XJ...
  188. Neutral Safety Switch Help
  189. Transfer Case...
  190. 98 Cherokee Dash Removal problems, Need Help!!
  191. Need help finding the right amplifier
  192. clutch plate or master & slave?
  193. Radiator replacement 95 w/tow pkg
  194. stereo amplifiers
  195. Engine Control Fuse Keeps Blowing
  196. what diffs?
  197. freewheel transmission?
  198. Side marker light and turn signal
  199. 89 4L auto wont start
  200. Slow To Start
  201. 1988 cherokee wont start
  202. 180 Deg Thermostat...
  203. MIL Light...
  204. temp light test 1996 cherokee 4.0L
  205. Hooking up a system
  206. 92 cherokee sport not cranking
  207. No Radio
  208. 1985 Jeep Cherokee
  209. starter soelinoid on an 87 jeep cherokee laredo
  210. 86 Cherokee
  211. It Runs !!!
  212. 97 Cherokee having no hot air
  213. Acceleration Problem
  214. Rear Pass Window Depth...
  215. running rough
  216. Camshaft Position Sensor
  217. brake and backup lights out
  218. Key Fob Programming
  219. synthetic or not
  220. Hatch Prob...
  221. Disconnecting Battery...
  222. 90 Cherokee..thumping when breaks are on
  223. New Ground...
  224. Thumping Noise From Left Rear?
  225. condensator
  226. 1995 cherokee transmission dipstick
  227. Cps Sensor Down
  228. charging system
  229. More XJ Q's...
  230. *scratches head
  231. Crank Position Sensor
  232. XJ Q's...
  233. 1997 jeep cherokee air bag module?
  234. Radiator Hose Q...
  235. Chrome Bumpers 4-Sale...
  236. Locate fuse seat heater
  237. Trac-loc?
  238. 88 Jeep Juice to positive wire(Red)/Need your help plz
  239. 1996 Cherokee Classic - No start
  240. 4.0 Fuel injected engine needed
  241. PLease Help, BIZZARE no start !!!!
  242. What Size Connector?
  243. 1990 Jeep Cherokee Laredo
  244. 99' Cherokee Limited
  245. Radiator and More 4-Sale...
  246. Alternator Bracket...
  247. My power locks are draining the battery.
  248. Stock 15inch Rims for sale with tires only $100
  249. Stuck Key and Control Arm Bolts...
  250. Stock 15" Rims 4sale
