View Full Version : Cherokee
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. 99 Cherokee Black Smoke
  2. radio removal
  3. carpet removal 96 xj
  4. 1990 Cherokee Front Differential Replace/Rebuild
  5. Need More Power
  6. 97 fender flares ona 96
  7. Newbie Here Command-Trac Question
  8. just installed 4.5 inch lift and now wheels toe in towards top
  9. 3rd Times a charm (start problems)
  10. Throttle body spacer
  11. 1996 Jeep Cherokee sport 4.0 liter steering
  12. Death Wobble Problems
  13. Worth keeping?
  14. door lock wiring driving me insane
  15. cracked block diagnosis
  16. Beginner Question Command-trac
  17. Fuel Pump?
  18. 2001 jeep cherokee sport blower motor
  19. really high idle
  20. 93 jeep cherokee i6 hard start in mornings
  21. Beginner,s OFF/ROAD website
  22. Paint hood nicks
  23. 01 Cherokee Sport, Dash flashing Code
  24. No drilling....No welding.....
  25. blower motor
  26. Quick Question about Steering parts/trouble
  27. Grill question.....
  28. Wheel Vibration at Varying speeds
  29. power steering box leak, how do i remove??
  30. '98 throwing code P0306 after being submerged in water, rough idle and hesitiation
  31. brakes locked up ?
  32. Need some advice? Reality Check!!
  33. 1999 Cherokee Sport Steering Trouble
  34. What kind of tranny fluid to use?
  35. 1992 cher ltd i6 4.0 - HUGE MPG Swing
  36. budget boost
  37. Engine cooling problem, questions and theories abound
  38. Ball Joints
  39. Alternator Woes
  40. Tranny problem?
  41. ac problem
  42. 2000 Cherokee power problem
  43. running too cold?
  44. 2000 Cherokee Crank Sensor?????
  45. 1995 Cherokee Sport I-6 PCM Problems?
  46. 1993 Jeep Cherokee engine stall-surge
  47. 1993 Jeep Cherokee engine stall-surge
  48. lack of power
  49. low idle speed
  50. part time 4wd=locked diffs?
  51. 95 cherokee
  52. 98 Cherokee Sport-Problem with Gauges
  53. 1988 Cherokee Pioneer lift kits?
  54. 1988 Cherokee Pioneer
  55. No Power Sometimes
  56. Driveline noise when decelerating down hill
  57. 96 has no spark at coil
  58. 2000 jeep won't start HELP!
  59. timing cherokee
  60. detroit track-lock
  61. what does it weigh?
  62. Overdrive Band
  63. Grand Cherokee History
  64. Towing capacity of 1992 cherokee larado?
  65. Another fog light question
  66. 96 SE coolant leak!!!HELP!!!
  67. Recharging A/C
  68. Power Window Controls Driver Side 2000 model
  69. fog lights
  70. need help, with jeep wiring
  71. 4wd clunks under pressure...
  72. tire noise
  73. Rear leaf spring question
  74. 97 Cherokee ignition key won't turn
  75. ABS on a 1992 cherokee Larado?
  76. starting problem
  77. Liftgate lock malfunction
  78. power loss during acceleration
  79. What might be causing this?
  80. engine cleaning
  81. 96 cherokee tranny fluid
  82. 1990 Xj seat problem......
  83. 96 sport fuel filter and cs install
  84. 96 jeep cherookee sport question
  85. 1987 Cherokee Pioneer front axle
  86. Questions about differentials, gearing ect
  87. Fuel Pump...or CPS??
  88. '95 Cherokee Sport A/c
  89. Gas In Oil????
  90. 1992 4.0 6cyl. - Won't start & no power
  91. 1984 cherokee 2.5L
  92. 98 Cherokee overheat after many fixes
  93. Serpentine Belt Broke
  94. 1992 cherokee problems
  95. 90 JC, Shifting problem! PLEASE HELP!
  96. Seems like an unrelated problem
  97. Gas milage in the city
  98. 95 Cherokee Stalling
  99. Suspension problems...
  100. overheating
  101. 1500 RPM & no more
  102. 97 Cherokee Country I6 4WD
  103. 95 Cherokee Country
  104. 89 inline six water pump pulley?
  105. dead jeep
  106. 2000 Jeep Cherokee Sport overheating
  107. 1997 Cherokee, fuel filter location?
  108. h.o. head on non h.o. engine?
  109. 96 power door locks
  110. engine swap
  111. Instrument display
  112. Door Locking Problems
  113. Cherokee HELL-P!!
  114. My jeep only has defrost
  115. 96 Jeep Cherokee Help
  116. Serious Brake Promblems
  117. engine problems
  118. Got a stumper for ya'll
  119. 89 jeep with messed up vaccum lines. 4.0 cherokee 4x4
  120. Good Or Bad?
  121. AC recharged,working. now over heats. Fan Clutch?
  122. 4.0 liter --> V8 Engine swap
  123. NO FIRE all of a sudden?? please help me..
  124. 2000 Jeep Grand Cherokee Transfer Case; Types And Fluids
  125. 1999 Cherokee AC/Blower Issues
  126. 2000 laredo speed sensor question.. help!!
  127. 97 Cherokee Issues
  128. 91 cherokee a/c question
  129. 1989 Cherokee cooling system
  130. 1989 cherokee overheat issues *help*
  131. Back Door Lock buzzing
  132. 2000 cherokee cranking but not starting till second crank
  133. Brake Booster problems, I think!!!!! PLEASE HELP ME
  134. steering coulmn
  135. Starting/Stalling Problem - Bad CPS???
  136. 89 cherokee ball joints
  137. 01 xj clicking felt on evaporative system
  138. balancer gone bad?
  139. For those who think you know Jeeps, Try to figure this out...
  140. Welding the rear differential?? Help
  141. 97 Cherokee Country 4x4
  142. 97 Cherokee Problems
  143. 97 Cherokee Problems
  144. Oil leaks only when engine running
  145. Driveline/Slip Yoke Eliminator Questions...
  146. Need opinion on Bendix rotors and pads
  147. I think I just killed my Jeep!
  148. crankshaft position sensor
  149. major coolant leak
  150. 92 Jeep Cherokee overheats at idle...
  151. 92 Jeep Ch still over heating at idle after work
  152. Jeep Camp 2006
  153. 99 fog light switch
  154. Confused about 4wd
  155. Rear captain seats/throttle body
  156. electric fan running
  157. '89 Repair/Shop Manual
  158. Distributor Wobble
  159. 1988 Jeep Cheerokee
  160. 98 jeep gas mileage
  161. new purchase
  162. Oxygen sensor disconnected
  163. Track Bar removal
  164. 1999 Cherokee Sport signal/flasher problem
  165. 91 Engine Stalling
  166. lift kit for sale
  167. Who makes this tire rack?
  168. Replaced head gasket Now low compression.
  169. Cherokee limited signal lights not working.
  170. Signal lights on cherokee limited not working
  171. 1994 Cherokee SE - Hi Idle Speed
  172. Grinding noise in park or neutral
  173. Older cherokee - Hard starting, high oil pressure
  174. Auto to Manual?
  175. Brake and Dash lights
  176. Wont Start
  177. '96 air-con control panel lights
  178. New Front Bumper
  179. Distributor Problem
  180. Compatible seat belts for 1995 Cherokee
  181. thanks guys
  182. Jeep trans issue - please help
  183. Engine Power Loss
  184. Woah
  185. 96 Jeep xj problems please read
  186. Are all Jeeps 4x4?
  187. Sonny Boy's 94 Cherokee Has Marginal A/C
  188. 200,000 miles +
  189. Moving on over
  190. Fog light madness
  191. 92 cherokee bucking while passing
  192. pontiac 350 in cherokee
  193. 93' Cherokee Radio Fuse
  194. Tie Rod End Question
  195. Unknown Warning Light Bus 5
  196. Help - unidentified warning signal on dash
  197. 2000 Sport multiple cylinder misfire
  198. 1987 Cherokee Sat for awhile now won't start cranks !!
  199. clicking in the stearing????
  200. '93 Cherokee I need ideas on what code 11 could be
  201. 97 cherokee running around 1500 rpms.What should I do?
  202. low oil pressure & chatter
  203. Back Up Lights / Keyless Entry
  204. Help! Sonny Boy has broken Leaf Spring and Oil Leak on '94
  205. 93 cherokee motor i6
  206. JEEP seat belts
  207. 1992 Cherokee "Clanging" from Below
  208. 95 cherokee motor
  209. Fluid Question
  210. 94 Grand Cherokee V8 fuel problem
  211. I-6 to V8?
  212. Oem Radio Question
  213. Tranny slams into gear and gas peddle sticks after hard turn. need help plz.
  214. Help forJeep 99 Cherokee Sport Acceleration
  215. Rusted Wheel Question
  216. 01 Cherokee Gauge Failure - Please Help!
  217. 86 Cherokee 4wd clutch slave problem
  218. leaking 4 auto
  219. Does Death Wobble only happen On Lifted Jeeps?
  220. Death wobble?
  221. Looking to buy a jeep
  222. Door locks on 1990 2dr
  223. Poo on my trans....
  224. electric cooling fan wont come on 4.0L
  225. Tranny Problems?
  226. Stalling !!!!
  227. Possible condensation in gas tank causes car to shut off?
  228. Next step
  229. Auxilary/electric fan problems 4.0L
  230. auxilary/electric fan problems 4.0
  231. Suspension...Death or doable?
  232. 99 Cherokee Sport - A/C question
  233. Loud POP when turning left
  234. Tire size advice
  235. Need More Power!!!
  236. what's the difference?
  237. 99 Cherokee Sport - Driver Side Seat Belt
  238. fog light rewiring...dangerous
  239. Suspension issue...I think
  240. 97 manual cherokee sport wont start
  241. High Idle Madness!
  242. Help With Tranny Pls ! ! !
  243. Anybody ever done this
  244. Power steering WTF issue....
  245. AX-15 Manual Tranny help needed
  246. Articles on how to replcae crankshaft sensor?
  247. Articles on how to replcae crankshaft sensor?
  248. Articles on how to replcae crankshaft sensor?
  249. It's a SMOKER!
  250. Lift kits
