View Full Version : Cherokee
- 4.0 noise
- back passenger window install...... :(
- front axel question.
- XJ Electrical Problems
- Ignition Key Problem
- twisted diff on axle housing
- Killing Batteries
- Didn't.....
- 95 jeep cherokee country
- Trans shifting to Fast, No down shft
- Front Driveshaft
- horn resistor
- 1990 Cherokee Power Steering Pump
- Anti Wrap
- where is fuel pump relay?
- 1990 Cherokee overheating need help
- Need help for my 1996 Jeep Cherokee...
- No can idle cold
- Strange clunking in front end
- wiring color code 89 limited
- High Oil Pressure
- 1999 Jeep Cherokee Check Engine Light
- slow shifting
- 1998 Cherokee Clunk In Front End
- 1999 Jeep Cherokee fuel rail
- Cherokee Limited Overhead Console problem
- Knocking when turning, please help
- '93 Cherokee Stalling...PLEASE HELP!
- 1990 jeep
- Jeeps Unlimited
- Fuse Box Passenger Compartment & Power Dist Box
- ABS Fuse Location 1996 Jeep Cherokee Country
- Crankshaft pulley / harmonic balancer
- front shock mount
- Location of Headlight Relay 1994 Cherokee?
- Toubleshooting a 3.5" Rubicon Express Lift
- vacume diagram 88 jeep pioneer please
- 1999 Jeep Cherokee Classic - Ignition?
- 99 cherokee classic problems.
- 98 cherokee sport suv
- 98 cherokee sport
- cherokee won't start when it's humid/rainy
- Steel Seal Head Gasket Fix
- 98 Jeep Head Gasket Fix
- 96 jeep cherokee(not for sale)
- Backfiring?!?
- Part name needed
- Overheat? In this weather??
- Fuel pressure tests
- 88 Cherokee EGR Valve Removal
- MyJeepSpace.com
- 96 jeep cherokee towing package lights not working
- 96 cherokee problems
- Just to help Forum users get answers
- New to Forum...Need help/info on '86 jeep Cherokee Chief V6 2.5liter
- HELP! Airbag light came on, all gauges went off!
- Think I need a new engine wiring harness....
- Need help with Temp Gauge sensor
- XJ Parts
- '92 4 wheel drive
- How to bypass neutral safety switch
- Leaf spring replacement?
- 93 Cherokee Fan Clutch help needed
- 1990 Fuel Injectors Please Help
- Got Links?
- Crappy Thread Content
- Engine noise, possible idler pully serp belt?
- Engine outline light on dash
- Jeep stalling problem
- 1992 Cherokee not accelerating rough idle getting worse
- 1995 Cherokee Sport loses power above 3000 rpm
- Need a hand with trac bar info
- Need help with my Jeep!!!
- 1996 Jeep cherokee rocker panel
- 96 Cherookee SE 2 dr 5 speed manual
- ADS fuse 2000 Cherokee
- Speed Sensor - 2nd time + Fuel Filter
- Repairing More Flood Damage
- 97 radiator fan keeps running...
- Starting problems
- Remote Starter Info
- Proper torque for 96 XJ
- cruise control fuse/mirrors
- Downshifting at highway speeds
- Running Lights not working
- 9 mpg! *kicks Jeep again*
- installing a factory chrysler nav. system
- help installing ignition lock cylinder please in a 1996 jeep cherokee
- Serpantine Belt Tensioner????
- smells like burnt rubber
- What is the gear ratio?
- Harness wiring diagram
- stalling jerking
- Rear Axle
- 1996 Jeep cherokee steering problem Still
- Air locks and guess work - help needed
- Planin For Moab
- Rear main.... *kicks jeep*
- Help soon - Washington State Requires Information
- diagnosis help: loud fan-like noise behind glove compartment
- Miss at cruise !!!
- 95 XJ What is this?
- Whinning/rattleing in 97 country 4wd 4.0
- Clutch help!
- 1991 cherokee runs rough sometimes dies backfires,hestitates ect.
- 2001 cherokee sport
- Wobble, shaking
- speaker wiring in rear hatch
- Jeep Cherokee knocking during idle
- Thermostat gauge fluctuating
- 96 XJ Flushing the Motor??
- noise?
- Brakes!!
- 97 Cherokee country 4.0 4wd
- Liftgate will not open
- coil, distributer, cps???
- 99 Grand Cheeroke Radio Fuse
- 95 Cherokee random knock
- 87 Cherokee dies when turning a corner
- 1988 Cherokee Pioneer Project
- Lots to do tommorow!
- transmission oil in differential
- Automatic Transmission Fluid
- 95 Cherokee rod torque and clearance
- 96 Cherokee Sport Noise
- wiring speakers rear hatch
- 1994 Cherokee Rough Acceleration
- parts breakdown
- Gas tank leak?
- how to put the fan belt on
- 1999 Jeep Power Steering Pump
- Help - Flood Damage
- Re: 88 cherokee transmission issue
- Thud when stopping or accelerating
- Fuel Pump
- Jeep randomly won't start
- Procomp 3" Lift kit ?
- Good Write Up On 4x4 Gearing Types
- Climbing Hills 2000 xj command trac trans.
- 88 Cherokee Pioneer...CAN YOU GUESS WHAT THIS STUFF IS FOR...???
- 1996 Cherokee 4.0 liter Dies after running very rough for 20 seconds
- 1999 4.0 with code P0455
- Estimated cost of repairs?
- Axle U-Joints 2000 Jep Cherokee Sport
- Lurker turned poster looking for a referral
- 96 xl popping noise
- Project 89 XJ
- Turn signal switch
- New Trans @ 177K
- 96 cherokee Noise
- Jerky Wipers 2000 Jeep Cherokee Sport
- 2000 sport electrical problems
- '87 transmission
- Twisted end off lower shock mount - GRRR!
- Transmission problem...???
- Renix Tb Spacer Or Not?
- New Fan Motor is possible Solution to no low or medium air blowing.
- conversion
- Engine cooling fan will not run
- Odd Electrical Problems
- 1999 cherokee cold starting problem
- Sonny Boy's '94 6 Cyl Oil Filter Adapter Leak fixed
- engine oil smells like gas
- cant find belt to fit 92 cherokee
- 2006 jeep grand cherokee 4x4 IS THE 4x4 always on
- major problem
- 97 XJ Power Lock Trouble
- 1999 Rear Main Deal
- 96 XJ hub replacement
- Jeep Jamboree in Snowshoe, WV
- Vibration only under heavy acceleration?
- Intermittent Ignition Trouble
- 99 Cherokee Problems..please give me some ideas
- Jeep Gone Bad
- 2001 front end noise?
- Trail rig!
- intermitten knocking
- 97 Jeep Cherokee Directional Auto Shut Off
- rear diff question
- key stuck in "on position." can't get key in off postion
- Jeep Hood Vent Question
- 1999 Jeep GCL P1494 Issue
- Sqeaky Breaks...Need Help
- Starting problems - '95 Cherokee
- Coolent system Leak
- Clunking on start when cold
- 1989 Jeep - Question that needs answered!!!
- 1987 Jeep Cherokee not starting, intermittent
- Jeep Cherokee electrical problem
- 1987 Cherokee= 4 cyl. vs. 6 cyl.???
- 94 Jeep Cherokee
- door panel removal?
- OH CONS fuse blows randomly
- best and worst years
- Cannot engage 4 wheel drive
- Rear lights out!
- check Guages light
- NP231 vs. NP242
- Transmission Rear Seal Leak
- towing capabilities
- Rear leafs finished, brakes dead, help please!
- Code 12 Won't start
- 2001 Jeep Cherokee Wiring Diagrams?
- Hissing sound
- mirror problems
- 1997 Cherokee-Doesn't like to work at Post Office
- Another no bus gage panel code HELP!!!
- Please confirm this is a CPS issue
- rebuilding transfer case...
- Buck at 65MPH, battery output of 17 AMPS
- Towing Jeep
- A/C Compressor Readings?
- I NEED HELP ANYONE PLEASE....1989 sputtering rattling hesitates is a manual
- 98 cherokee,key stuck in ignition...
- Operating temp
- 1988 no power to AC compressor
- 99 cherokee sport hesitation under acceleration
- Leather seats available anyone?
- 2001 Jeep Grand Cherokee OBD code P1494
- Dramatic Power Steering Failure
- u-joint
- No lights -in the dark
- 94 Seat Help
- NO BUS message on dash gauge, dead gauge PLEASE HELP!
- 95 won't start
- toggle switch for what?
- Help Fuel Tank Leak O-ring problems
- Would a CPS problem cause these issues?
- Right side front axle shaft removal
- Rpm Idle Read 2000 Jeep Cherokee Sport
- problems with radiator removal
- Additives for 4 liter/6 mtr.
- 2000 cherokee sport starter problems
- Another heating question
- Trouble with '89 Cherokee Trouble Codes...
- 89' XJ Brake question
- 1999 Sport - Rear Brake problem
- AdvanceAutoParts or AutoZone?
- Heat exchanger help 94 cherokee country
- 93 Jeep Cherokee Temp.
- Lots of problems help!
- simple tune up turns into $1000 PCM??!!?
- 96 Jeep Cherokee ...... how to increase MPG
- Is a $1,000 for my Power Steering Sound right?
- 1988 Cherokee Pioneer Catalytic Converter?
- fender removal XJ
- Headlight Bulbs Help
- Sparkplug question
