View Full Version : Cherokee
- 1990 Cherokee - Clicking no start.
- looking for help
- tires
- Distributor replacement
- No power to radio or cluster in 2000 Cherokee?
- Temp Knob won't turn to cool
- 99 Jeep Cherokee Brake lights
- cost???????
- Large evap leak, beeping from gas tank
- 96 XJ won't turn over
- 1999 Jeep Cherokee Classic PROBLEM!
- 1989 cherokee fuel pump stays on with key off
- Just bought a 1999 Cherokee
- 96 Cherokee Died while driving and won't start
- Steering Wheel will twitch when i make turns
- 1998 Engine issues...
- 1999 Throttle hanging up.
- wont go into drive, need help plz!
- What are the odds?
- transfer case
- Tiny hole @ Y in header. Suggestions??
- 1996 jeep alternator repair
- 1990 Cherokee Lock up torque converter not locking up .
- Noise in tranny after fluid change worsens
- what tha?
- locknut w/wo washer for thermal clutch?
- turn signal fails to turn off-Cherokee 1997
- Neutral Safety Switch- 1997 Cherokee Sport 4x4
- oil pump prime
- swapping tranny
- Flex plate?
- XJ battery & rpm gauge not working!
- Starter bolts
- Did my mechanic rip me off?
- Temp Gauge never moves
- I got a BDS lift . anyone else? pros cons?
- Did I screw my bushings up?
- Fcc Number
- Brake sieze problem
- 96xj 4.0 Spark plug gap
- What does this button on the shifter do???
- Trans. fluid change 96 XJ
- Line-X ed Jeep Pictures
- computer codes on 89 jeep cherokee
- helppppp!
- Computer not sending signal to solinoid
- Light problem...any imput helpful
- '96 Hub removal, strange fasteners
- starts, just for a second
- smog issues
- I have raised suspension about 2 inches. How much it will cost me to get it back...
- Suspect Gasket - Clatter on acceleration
- How much can 4.0L 4*4, Man tr. Cherokee tow?
- mech. fan thermo clutch test?? Any way ?
- rattle in OD and when it drops to 4th on hills
- If you replaced timing chain on 4.0 engine why did you do that and what mileage did..
- removing overhead console
- Scanner
- 98 Cherokee sport Transfer case swap
- 1988 Jeep cherokee Vacuum switch diagnostics
- 1997 jeep cherokee won't start????????????
- 89 cherokee cold air intake
- Why would a switch be added?
- no acceleration lots of backfireing
- New catalytic convertor necessary?
- Shaking Steering Wheel when exiting freeway
- 2000 JCS no start, voltmeter high
- No Air Coming From Vents
- 2000 Cherokee fuse diagram
- No Power and overheating !!!
- Electrical Problem...Plz HELP!!!!
- cherokee door handles
- Turn Signal Problems
- 1998 Cherokee Rear End Noise Help
- 98 cherokee "death wobble"
- Rear main seal
- lack of cooling...not very cool.
- Coolant level
- child safety locks
- 91 Jeep ABS pump wont turn off!!!
- windshield crack repair kit
- oil pan for an Xj and grand cherokee
- Possibly Running Hot ?
- 99 Cherokee Sport won't start
- check engine code
- 1997 cherokee electric cooling fan wont work
- AW4 Transmission shift problem
- 1989 Cherokee hard start
- 98 cherokee sport idle surge
- xj for student car?
- 92 cherokee fuse diagram
- front end parts
- A short? Bad battery? Alternator problem?
- How to glue/join hood latch rods
- Troublesome XJ, Any ideas appreciated.
- 92 cherokee electrical problems
- jeep starts but wont stay running help!!
- door buzzer 1996 cherokee
- WIndshield 1996 Cherokee sport
- Abs Mod!
- Cherokee wont start
- Replacing Ignition Switch
- Not getting gas?
- Installing a chevy 350 in a 94' cherokee
- Help!!
- Major Transmission Problems on 95 Automatic
- Help before I shoot this dam% jeep
- 4.0 Motor swap
- 2000 Sport Brake Rotor **HELP**
- need some help
- Need owners manual for 95 jeep cherokee sport
- liftgate adjustment????
- Name This Jeep !
- headlights activate rear wipers and washer
- 97 CHEROKEE 4.0 MANUAL WON'T START (details inside)
- How to open stuck tailgate - lift gate on 99 Jeep Cherokee XJ
- wierd idle
- 4.0L engine component name needed
- door lock
- Back window seal
- Knocking noise
- clicking noise while driving
- Total exhaust replacement
- 1989 Transmission? Problem
- HELP!!! My XJ is dying!!
- '95 4.0 knocking noise
- cleaning power steering fluid from front end
- Check Engine Light in 95 Jeep Cherokee Sport
- Econo carb 360 ci '78 Cherokee
- knocking/clicking noise under acceleration
- fuel injectors?
- 96 Cherokee wont start - weird cause
- 97 no hot air
- 88 Jeep Cherokee Bad MPG
- 84 cherokee rough idle, rough while driving
- 2001 Cherokee - Full Size Spare?
- 1993 Jeep Windshield Wiper Not Working
- key broken in driver door
- Shameless pics of my newly lifted XJ.
- Some people don't deserve a jeep
- A/C troubleshooting question
- 89 cherokee laredo wont start
- Parking Lights
- new parts still no start
- Biggest tires on Factory Jeep?
- Thank god for jeep owners!
- Need seatbelts for 95 Cherokee
- 2001 Cherokee Engine Surge
- Lift Kit Questions
- Thanks!
- shiftin problems
- transmission slip question
- suspension help--how to get the smoothest ride?
- rear heat output low
- Muffler / Exhaust
- 1993 4.0 Oil Leak at Oil Filter
- Loss Of Power
- new parts no start
- 95 Jeep - How Do I Use 4 Wheel Drive?
- Starting Problems 1991 Cherokee
- electrical sadness
- knocking noise
- power steering leak
- 1992 Jeep Cherokee sometimes has no power to starter
- 94 cherokee front diff swap
- Best lift kit
- '091 no start 4.0
- Suspension lift
- fuse diagram of 97 jeep cherokee
- 2001 Cherokee "cricket"
- engine for 2001 cherokee sport
- No Gap Spark plugs, are they worth it?
- Is there supposed to be a light behind the heater controls?
- Front End
- Cherokee Sport/WEIRD overheating problem
- Body Lift
- 96 xj 4.0 200k when do you R/R engine
- 91 Cherokee fuel pump buzzing.
- clutch help
- 99 Jeep Cherokee Sport won't start
- Shiftlinkage for 4X4?
- 4 wheel drive
- 92 xj coil replacements
- Electrical Problem in 87 Jeep Cherokee?
- 89 Jeep Cherokee 4.0 4wd oil pump
- 2004 7/70 Powertrain warranty question
- '96 Jeep Cherokee sport won't start
- 1993 Jeep Cherokee
- Cherokee starts but then dies...
- Jeep cuts off
- looking at a 2000 Cherokee
- 91 Jeep Cherokee wont stay running
- 4x4 light on?
- Trans fluid change stumped question??
- No heat in seats
- pinpointing front axel trouble
- Does anybody know...
- 4wd wont work hubs not lockin need help
- help please
- Broken bit nightmare
- wont' start nor turn over, ahhhh
- Replacing rocker panels 1996 Cherokee sport
- Misc Jeep Transfer Cases FYI
- 85 Cherokee not starting
- Heater blower resistor location
- A few problems on a 96 Cherokee Ltd
- shock
- full time 4low
- reverse lights
- 94 cherokee back up light switch
- Airbag light on, no gages- 98' Cherokee
- No Overdrive, delayed shift 98' Cherokee 4.0L
- Starting Problem: B+ Latch relay not the culprit.
- Uncommanded 4-3 downshift
- Transfer case won't go into 4 wheel low
- What is a "B+ latch relay"?
- Need a part
- Question about transmission fluid change
- 94 cherokee tranny
- 1996 jeep cherokee sport headlights "?"
- 1987 Cherokee Pioneer MPI injector issues
- Won't shift into overdrive
- Broken/Bent pushrods
- 350 News
- 1995 jeep cherokee part time 4wd light
- Starting problems, different this time
- 96 xj 4.0 How many 02Sensors?
- 1996 Jeep Cherokee door handle (rear)
- Heater Problem
- 1990 Jeep Cherokee Larado-Heater problem
- Bypassing Ignition/Neutral switches
- Gas Leak Dash Lights
- 1996 Jeep CHerokee oil pan
- 95 Cherokee Sport Running Like Crap
- On XJ Overheating
- 88 Cherokee will not stay started
- Coil Mount Broken
- 89 jeep charokee
- Hang Transmission Shifting Cherokee Sport
- 88 Cherokee stalling fixed
- 87 cherokee problem
- 96 Cherokee 4.0 Liter- High Idel/low Idel- And Electrical "growl"
- Water Kills
- Mystery noise
- map senso issues
- 1987 Jeep Cherokee Pioneer lock cylinder
- 4.0 noise
- back passenger window install...... :(
- front axel question.
- XJ Electrical Problems
