View Full Version : Cherokee
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. 5mpg
  2. 1988 Cherokee Pioneer Steering Box Q's...
  3. No 4x4
  4. need help with replacing radiator this weekend
  5. Front Loose
  6. '87 cherokee start stall problem
  7. 88 Cherokee ex manifold bolt
  8. 96 cherokee starts only w/ gas
  9. 350 in an xj
  10. Won't idle
  11. A/C blower motor intermittant
  12. Good code reader/scan Tool
  13. Wiring for a trailer
  14. front breaks screwed?
  15. 89 wagoneer limited problems
  16. 2000 Jeep Cherokee OVERHEATING HELP!!
  17. 200 Cherokee Sport Amber Engine Light
  18. Engine not starting, acts like dead battery
  19. head lights
  20. 89 cherokee wont start
  21. please help
  22. Interior lights stay on
  23. 87 jeep no start?!?
  24. bearings?
  25. 90 xj lift
  26. 2001 Cherokee Engine Light advice
  27. Noobz Question
  28. Need immediate help with white smoke/antifreeze leak
  29. Blower/HVAC problems
  30. Check engine light - an 01 Jeep Cherokee
  31. Gas Gauge on a 1992 cherokee
  32. Proud Owner of a 1989 Jeep Cherokee Sport
  33. has anyone had any experience with Auto RX Engine Cleaner
  34. NO START (no bus)
  35. Need help with 89 wiring
  36. Checking trouble codes???
  37. 88 Jeep Cherokee Vacuum Diagram.
  38. Newbie Needs Electrical Help
  39. Knock turning left
  40. Overhead console
  41. Heat Shield and Check Engine
  42. Anyone know about CSF Radiators from DPG Off Road?
  43. My 4 wheel drive wont engage. Any ideas?
  44. 1999 Jeep Cherokee Won't Start
  45. 93 Jeep Cherokee Idler Pulley Help!!!
  46. Coolant temperature question
  47. coolant spilling out cap
  48. steering loose
  49. Horrendous clacking noise while braking
  50. Dented exhaust pipe connecting to manifold
  51. Jeep towing
  52. Can almost start, squealling
  53. 1988 Jeep cherekee runs only iwhen the key is in the start position.
  54. Electric Fan 90 jeep
  55. No power to Radio and cigar lighter
  56. Wierd knock in rear
  57. 91 Sport blowing fuse
  58. Help with my Stick-o-matic
  59. 97 cherokee sport oxygen sensor voltage
  60. Does anyone else sound like a diesel?
  61. More power!
  62. Hot jeep
  63. Remote keyless entry
  64. Hills With 2000 Jeep Cherokee Sport
  65. OK. Now I've got some electrical gremlins...
  66. '99 Cherokee Stalls..
  67. Rear window issues
  68. Reverse Transmission Issue
  69. Oil gauge jumps when decelerating(1993 Grand Cherokee)
  70. 1993 Grand Cherokee 5.2L V8 Turbonater
  71. 86 Chrokee Running Problems
  72. shifting
  73. shifting problems
  74. 1999 Jeep Cherokee Loredo
  75. 91 cherokee knocking at idle
  76. 1991 cherokee transfer case problem
  77. 01 cherokee knocking
  78. overheating problem
  79. Leak under dash
  80. 1999 Jeep Cherokee turns over "very slow", shuts off when it idles
  81. Running Hot STILL AHHH
  82. Procedure for shifting into Low Four Wheel Drive
  83. Hypertech - Hypertech Power Programmer III
  84. Just Curious Engine Swap Question
  85. Surpentine Belt - Proper installation?
  86. Stalling, Squeeking, Overheating, & A/C
  87. A/C squeels on high - ideas?
  88. interchange engine
  89. help 98 4.0 cranks, no start
  90. 13 MPG (how bout you?)
  91. Stalling of Jeep Cherokee
  92. 1999 AC / Hesitation while accelerating
  93. 1999 Jeep cherokee air conditioning stops working
  94. Manual driver side mirror replacement (with remote)
  95. ignition switch red wire hot with blower on
  96. NO Headlights
  97. Jeep XJ Brake Adjustment
  98. 2001 Jeep Cherokee Spark Plugs
  99. Turn signal switch replacement
  100. 2001 Dome light bulb replacement
  101. Master Cylinder???
  102. how to lower jeepy
  103. Comanche 1988 bypass
  104. Can't turn ignition key on 90 Cherokee
  105. shimmy when i start to accelerate
  106. Air Conditioner Pricing Question
  107. 99 Cherokee with no Brake Lights
  108. engine computer changeout
  109. 1995 herokee country fuel injector control circuit problem
  110. 2001 Cherokee starting issues
  111. Electrical gremlins
  112. 99 Cherokee Rotors
  113. Cherokee no start
  114. No Reverse transmission
  115. Cherokee speedometer stops working
  116. Pinstriping Decal Kits?
  117. Clutch Stuck
  118. Temp Shows False Overheat??
  119. 99 cherokee sport air conditioning
  120. ABS Issues NO BRAKES! sometimes
  121. just got a cherokee
  122. need help deciding on parts
  123. gas gauge
  124. 01 fuel starvation problem
  125. 99 jeep cherokee sport...fuses
  126. 2000 cherokee sport fuel filter
  127. Wont start! Engine turns over then done.
  128. 96 XJ Replacement Rear End
  129. overheating at night
  130. shimmy at 55 mph
  131. Older '87 question
  132. Tire Advice
  133. rear wiper comes on when I brake
  134. Help!!! Overheating problem.
  135. 2000 Cherokee Classic - No Start Problem
  136. More detailed vin info for cherokee?
  137. CEl no work, now no start!! related?
  138. HELP! no CEL on dash, won't start!!
  139. 97 cherokee problem after mudding
  140. dash lights
  141. I love Electronics... Fuse keeps blowing.
  142. Transmission will not shift into 4th after adjusting the brake light switch
  143. My first Car!
  144. Need to adjust how much brake force goes to the front and back.
  145. 1998 Cherokee No Sound From Radio
  146. 89 Cherokee Power Steering Box
  147. cherokee or wagoneer
  148. Cruise Control Brake Switch?
  149. What may have happened?
  150. Slotted/ drilled brake rotors
  151. 1998 Jeep Cherokee vibration at 2200 RPM
  152. jeep cuts out at cruise
  153. cherokee overheating
  154. 1999 cherokee Ball Joints !!
  155. Instrument lights
  156. spark wire compatibility ??
  157. YJ brake line in rear? ##'s
  158. Cherokee 98 Exhaust Problem
  159. Wierd engine/exhaust problem !!
  160. Lower control arms: recommendations?
  161. 90 xj coolant tank mod help
  162. 1990 XJ Temp Sender at a slight angle
  163. Ambient Lighting
  164. Speedometer Not correct-- how can I fix??
  165. 96 Cherokee Sputters
  166. Selling 2001 jeep cherokee sport
  167. Just bought a Haynes
  168. "remodulating" the tach??
  169. Wider Tires on XJ
  170. drivers side door switches
  171. PLEASE HELP '96 jeep cherokee won't start
  172. exhaust threat?
  173. Headlight Problem 95 Cherokee
  174. 89 cherokee, hood left open in rain and wont start
  175. Jeep Instrument Cluster Replacement Odometer Fix?
  176. removing front axle to replace u-joints
  177. 95 Cherokee stalling
  178. Intake Modifications ?
  179. check engine light on and transmission seems weird
  180. New to XJ's - Problems
  181. Squeaking while moving
  182. Rear Differential question
  183. radiator removal
  184. tachometer false reading-500 hi- how to fix??
  185. chirp up front= miss or lope???
  186. 2.5" exhaust pip or not
  187. 85 cherokee chief we are selling or gonna scrap
  188. Stalling out
  189. tow points on 2000 Jeep Cherokee
  190. Can someone help with vin check?
  191. Exhaust manifold hardware
  192. Information needed: will be installing a 5.5" lift on my 96' cherokee
  193. creeeak,Bushings front and rear..rrrrrrrr
  194. 96 Jeep Cherokee 4 cyl Standard Trans
  195. 1999 jeep wont start...loud, rapid clicking noise
  196. 2000 Cheroke Evaporator
  197. 1995 Jeep Cherokee speedometer not working
  198. Windshield Washer Hard to Fill - 99 Cherokee Sport
  199. no transfer case fluid change ever
  200. 95 Cherokee Help
  201. Nu Finish polish/wax. Any good?
  202. 88 Jeep Cherokee Pioneer won't start
  203. 94 country ac leak
  204. 10 W 30 or 10 W 40?
  205. jeep cherokee .... safari doors?
  206. 99 Cherokee Wont Start
  207. Installing Hitch Reciever?
  208. 1999 Jeep Cherokee Alternator issue
  209. Exhaust noise question
  210. '96 Sport sometimes stalls at low RPMs
  211. Transmission question
  212. window repair ??
  213. 2000 Cherokee O2 sensor problem
  214. 1990 XJ Instrument Cluster Upgrade Help
  215. 1990 XJ Steering Click
  216. Need new shocks
  217. 93 Cherokee will not stop running
  218. All right guys... Help! lol
  219. 1996 Cherokee Air Conditioning
  220. wiring harness
  221. 97 Cherokee Issues
  222. 99 cherokee needs suggestions
  223. power door locks
  224. cherokee lifts
  225. Cherokee passenger door question 01 Cherokee
  226. 01 Cherokee question
  227. 97 xj lift
  228. charging problem 1987 cherokee
  229. throwout bearing noise?
  230. 89 cherokee 4.0 4X4 wont move
  231. Cherokee Thrashing Video
  232. Transmission shift problem
  233. 98 XJ Gas Tank gasket?
  234. 01 cherokee tinted glass
  235. slave cylinder or master cylinder
  236. 1992 Cherokee, Engine knock
  237. 1995 Jeep Cherokee reverse light problem
  238. 2001 Sport price
  239. This wagoneer doesn't exist
  240. Steering Wheel will not lock when key is removed
  241. Blinker flasher location?
  242. Headlights
  243. LCA's Squeeak when disco'd
  244. 1992 Cherokee engine swap
  245. Odometer question
  246. Looking to make the Wipers go faster???
  247. Rear Sag
  248. FSM Advice???
  249. Transmission problem.....grinding noise
  250. Help, running rough *cough*
