View Full Version : Cherokee
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. brake question
  2. Please help alternator covered w/ tranny fliud
  3. 93 cherokee elctrical brake/hazards out
  4. 1990 selec trac question
  5. 88 Cherokee Pioneer Ignition/Idle issue
  6. jeep
  7. Cut n fold rear bumper
  8. Help heated seats not working
  9. 88 Cherokee 4WD Transfer Case rebuild or replace?
  10. '89 Cherokee problems.
  11. Need Help!
  12. 1990 Cherokee No Start
  13. I'm stumped
  14. Body Part Question
  15. cant start my 86 cherokee 2.5l
  16. 1998 cherokee limited heater
  17. changing cherokee serpentine belt
  18. Axle bearings-2000 Cherokee Sport
  19. Connector location?
  20. What year ?
  21. 4WD instructions
  22. I think I bit off more than I could chew!
  23. Weird Tranny Problems
  24. 96 cherokee sputtering backfire
  25. Clutch Fluid Leaking Out !
  26. Help!!! Overheating
  27. Best 4 WHD driff for a 88 Cherokee Pioneer
  28. Major oil leak, any ideas?
  29. Need 2 Put A 88 Intake On A 96 Motor
  30. Security alarm problem with a 91 Jeep Cherokee?
  31. 89 4.0 jeep cherokee runs rough help!!!
  32. what are the extra gears for?
  33. Vacuum Actuator 4WD Front Axle ?
  34. How hard is it.....?
  35. Will it work?!
  36. electrical fan won't shut off
  37. '87 Floating steering?
  38. help i cant have fun!!!!!!!!
  39. Starter Wheezing!??
  40. 91 Cherokee Trans problem or electrical???
  41. jeep will not start in cold unless ign held in start pos!
  42. Small question
  43. fourwheel drive jeep cherokee
  44. No 4x4 light or 4x4 front axle
  45. Steering in 4wd?????
  46. Electrical help please
  47. 95 Cherokee really wierd starting
  48. Grinding Sound
  49. Heater Problems
  50. Being proactive?????
  51. Rpm"s
  52. 94 Cherokee Rather Wierd Problem
  53. Wrong Fluid!
  54. 97 cherokee heater issue
  55. Street legality between XJ and YJ/TJ/CJ's
  56. Can a 97 Cherokee be timed?
  57. Miss on "tip in" (accelerating)
  58. Light Switch????????
  59. Electrical problem w/94 cherokee sport, HELP!!!
  60. cherokee 2000 speed problem
  61. 97 Cherokee AX-15 tranny stuck in reverse
  62. xj 90 Fire+Fuel - Start Idle problem
  63. 2001 Cherokee - no heat & it's cold outside
  64. 88 Jeep CHerokee Pioneer MSD Q's?
  65. '92 XJ Cherokee--is it time to say goodbye?
  66. 1990 cherokee cruise control
  67. 95 cherokee wont start
  68. what should my temp be
  69. 1994 Jeep Cherokee 4X4 Front Axle Vacuum Line Question
  70. '87 Cherokee extended crank when cold
  71. serpentine belt ?
  72. 96 Jeep Cherokee Country 4.0 Squeek!
  73. 92 jeep cherokee stereo wire harness
  74. 1991 Cherokee 4x4 front windshield wipers.
  75. 97 Cherokee will not turn on anything
  76. Digg!?
  77. Want To Buy Audio System
  78. New Purchase Advise Please.
  79. lock problems
  80. 96 Cherokee - Missing, backfire only on initial start
  81. 94 jeep cherokee sport electrical ghost
  82. Crap... Death Wobble.
  83. coolant loss
  84. 95 Cherokee AT problem
  85. Testing an '01 Alternator
  86. 1994 Cherokee,headlight relay location
  87. Waterproofing idea
  88. No power mirrors/window locks in '97 Cherokee
  89. Im exhausted :)
  90. Blowing fuses after battery change
  91. 87 pioneer
  92. Cranking problem
  93. A/C problem
  94. 1991 Jeep Cherokee Laredo drop in gas mileage
  95. it broke!!
  96. 1990 xj tumbler
  97. 95 Cherokee..4.0..........No Start
  98. Merry Christmas to me!
  99. Serpentine belt tension 4.0 cherokee
  100. Post 4WD Steering weirdness
  101. some times wont start
  102. Steering issues.....
  103. how to loosen harmonic balancer bolt ? (crankshaft pulley)
  104. stalling issue
  105. 1993 Jeep Cherokee whistling...
  106. 1987 jeep pioneer
  107. 90 cherokee laredo 4.0 water pump .. noises
  108. 99 Cherokee Sport....LUV it
  109. Front caliper bolt??????????
  110. starting problem
  111. 91 4x4 sometimes works? no part-time light
  112. getting loose
  113. Door latches
  114. 87 Cherokee Laredo 4WD Manual 4.0L cranks, but won't fire.
  115. Tires? Wheel beraings? HELP!!
  116. 2.5 engine swap?
  117. 1990 cherokee
  118. 1990 cherokee door seals
  119. rough idle all of a sudden
  120. 1984 cherokee 2.5 vaccum diagram
  121. 1988 Jeep Cherokee high idle
  122. 1987 jeep cherokee laredo
  123. '94 Jeep Cherokee tire problem...
  124. Starting ??????????
  125. Plug wires????????
  126. new xj, old issues
  127. 89 Cherokee Erratic Idle
  128. Front drivers window "acts" stuck
  129. An Interesting Conundrum...
  130. HOW DO YOU ADUST a TPS Throttle position sensor?
  131. Jeep Cherokee not shifting properly
  132. Asking for an opinion....
  133. Exhaust system
  134. Site Search Turned Up Little !
  135. NSS cleaning
  136. Door mounting
  137. Please Help! 89 Jeep Wont Start! Cold weather
  138. changing back to full roof rack
  139. 94 Jeep Cherokee Overheating!
  140. 89 jeep cherokee
  141. Haha!! Lol!
  142. wipers won't park in normal position
  143. 1996 cherokee charging system
  144. Clutch Fluid???
  145. 96 Cherokee radio + lighting problem
  146. How to test my 4x4
  147. fluids
  148. fuel pump timer?
  149. stalls after 10 minutes of driving
  150. any ideas on getting a cheap windshield?
  151. Getting to the cps?????
  152. Exhaust Fumes in Passenger Compartment
  153. Bigger Tires
  154. changing injectors
  155. 1990 Cherokee 4.0L Auto Not starting
  156. oil smells like gas
  157. 92 cherokee speedo
  158. 92 Cherokee 4.0 speedo no work
  159. 91 cherokee 4.0 Intermittent stumble when cold
  160. 97 Jeep Cherokee/starts sometimes/other times no.
  161. What are they thinking???
  162. Rattle from oil pan area
  163. Oil Pressure or Indicator problem?
  164. Bad censor????
  165. ? on 98 Cherokee Cooling System
  166. 4 Whell Drive Issues????
  167. Location Gas Pump Relay 88 Cherokee
  168. Bushwacker Fender Flares?
  169. O2 Sensor or MAP Sensor
  170. High Idle Problem
  171. 1996 Jeep CHerokee
  172. Idiot Lights
  173. 01 Cherokee serpentine belt squeal
  174. Cruise Control Problems 95 Jeep Cherokee
  175. Jeep Total..changing threads
  176. Is it possible?
  177. Shifting Problems 4wd
  178. 92 cherokee clutch
  179. 1987 Jeep Cherokee Chief starting problem
  180. 2000 Cherokee No Fan For Heat
  181. 2001 Turn Signal Issues
  182. 1994 Cherokee radio fuse?
  183. Shock advice
  184. Tapping when cold, stops suddenly when engine is warm
  185. 1996 Cherokee Xj a/c condenser
  186. 1996 Cherokee Xj transmission lines
  187. New AC Compressor
  188. 1991 No brake lights!?!?! Confused
  189. disabled mom needs QUICK advice!! PLEASE?
  190. Where are the engine lift brackets?
  191. Transmission Problems please help!
  192. Can i go higher??
  193. Sun visors
  194. tcc stuck locked!!! help
  195. 1987 Cherokee Brakes deep concern
  196. pics of my 99 xj
  197. Changing Windshield Washer Pumps on 97 Cherokee
  198. Timing Belt ?
  199. 1993 jeep cherokee sport issue
  200. Stalling when drives slow !!
  201. Help Engine Knock 4.0L
  202. Replaced the Fuel Filter and the Stalling is way worse
  203. How much Lift???????
  204. 96 Cherokee Country Dash lights
  205. humming noise coming from the back of my 89 cherokee
  206. What wheels will fit?
  207. 89 Cherokee Pioneer Cooling System conversion
  208. 95 jeep cherokee 4.0
  209. 1992 Cherokee Laredo
  210. Jeep tranny acting up
  211. Need Help. 89 Cherokee Overheated now Loud Clacking noise when Accelerating
  212. '96 with '98 trans, How to???
  213. jeep barely stops
  214. 254,914 miles
  215. Jeep 92 - just won't start
  216. Ignition key wont turn plus...
  217. 99 Jeep Cherokee Runs Rough When Cold
  218. 150,000 mile inspection
  219. Paint
  220. 99 cherokee sport with difficult engine start
  221. question on differential fluid exchange
  222. No BU or running lights or
  223. oil in my air filter
  224. Dome Light
  225. Problem with idling
  226. Front axles seals on '86 Cherokee
  227. i have 4 problems my jeep i need advice
  228. 1998 cherokee 4.0 missing at idel no stall
  229. 1998 cherokee 4.0 missing at idel no stall
  230. Overheating?
  231. Lift For 1987 Cherokee????????
  232. need some serious help-lift coils
  233. Loose gas gauge
  234. np231 swap for np242?
  235. Keyless entry
  236. Door panels
  237. How to change headlight switch
  238. Popping sound from front of XJ
  239. backspacing??
  240. 98 cherokee stumbling and going dead (cleaned NSS)
  241. Popping in front steering
  242. Comanche
  243. Pop When Turning Gone !
  244. 2001 Jeep Cherokee speedometer acting strange
  245. 304 help
  246. Lifting the steering column
  247. cherokee high rpm knock- only in acceleration
  248. Power steering issues
  249. Clutch Problems
  250. 5mpg
