View Full Version : Cherokee
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. 2001 Jeep Cherokee A/C
  2. 2001 Jeep Cherokee A/C
  3. 2001 Jeep Cherokee A/C
  4. 1998 Jeep Cherokee Classic - Electric Window Issues
  5. 93 Jeep Cherokee Running Rough
  6. 1988 chero. tv cable
  7. Point me in the right direction?
  8. 1996 jeep hard shifting
  9. jerky and non-shifting transmission
  10. middle console stopped working
  11. 2001 XJ 4x4 4.0l question about a noise
  12. 1993 Cherokee Sport
  13. Trouble Starting Cold
  14. 2wd to 4wd swap. will it work?
  15. 1996 jeep cherokee starter
  16. Shorter Serpentine Belt possibility
  17. 97/98 2.5 petrol Sport - lumpy running
  18. Starter just clicks how to get to it?
  19. front wheel bearing (2001 XJ)
  20. 1992 limited drivers seat
  21. led turn signal arrows
  22. 1996 cherokee 5.2LEFI, Trans problem...
  23. three cut tubes!!!!
  24. bad MAP sensor?
  25. Regarding the NP-231 sticky in this forum..
  26. 2001 ZJ clunk when you turn
  27. What'd I break this time...?
  28. 03 grand cherokee wont shift into last gear
  29. 03 grand cherokee wont shift into last gear
  30. wipers acting wierd
  31. '92 Cherokee Laredo 4.0 stalling
  32. Preferred plugs?
  33. trouble grabbin gears
  34. XJ Rear Leaf Spring Swap Problems
  35. 93 Cherokee Frnt end shaking/clicking
  36. 1998 Cherokee NO start
  37. cam and crank position senser?
  38. It's a jeep thing and I don't understand
  39. 2001 cherokee rough idle when hot
  40. 95 Cherokee Turns over but wont fire up.
  41. Jeep runs rough when warm
  42. NP 231 / 242 How they work
  43. Radiator Fan not turning
  44. Upcoming Weekend Projects - '98
  45. Slop in the front sterring and some vibration
  46. 98 XJ drivetrain? u-joints? flexplate? problem
  47. Front brakes lock and grind on rainy days.
  48. Still having turn signal problems
  49. 4WD shimmy and shake
  50. 96 cherokee - won't crank
  51. Wheelin' question
  52. 96 cherokee distributor replacement
  53. More sagging rear ends
  54. Under belly protection
  55. DIY LED tail lights help!!!
  56. rough running 4.0
  57. 1999 Cherokee Front Brakes left & Right hand pads
  58. 1998 cherokee
  59. Need some help!!!
  60. need some guided advise please
  61. Cherokee rear end sag
  62. Broken Flexplate
  63. 94 jeep manual transmission 4cly 4W needed
  64. looking for performance exhaust for 01 xj
  65. 94 cherrokee 4sp automatic wont shift out of 1st gear
  66. Battery Keeps on Dying
  67. Buying an old Cherokee, and making it reliable
  68. t-case or tranny?
  69. 1996 Cherokee electric door locks not working
  70. 89 Jeep gas in oil and exhaust
  71. Help!! Timing Chain or torque convertor problem?
  72. Transmission
  73. Dead ECU?
  74. 4.0 hard starting
  75. 98 Cherokee Starting Problems
  76. 98 Cherokee Starting Problems
  77. 1996 Jeep turns signal do not work
  78. bad fuel pump? buzzing sound
  79. If your Jeep won't start....
  80. 1993 Jeep G.Cherokee Upper and Lower Idler pulley torque specs
  81. 1988 jeep cherokee -idle issues
  82. Please help!!!
  83. help fuse keeps blowing
  84. help fuse keeps blowing
  85. power window 97 cherokee
  86. 1998 Jeep Cherokee limited Gearbox knocking sound
  87. Tires - important
  88. Cold Engine = Rough Running 90 Laredo 4.0L
  89. 01 not blowing hot air
  90. My jeep acts like it runs on 2 or 3 cyl Help plz
  91. Fog lights not working
  92. help me
  93. heater problem
  94. Axles on Jeep Cherokee
  95. Tires--what kind are best and where to get them?
  96. really weird radio problem
  97. 1989 Cherokee wanders
  98. engine for sale
  99. O2 sensor trouble code needs fix
  100. 1988 cps
  101. replaced cps, still no start!! help!
  102. 96 2wd auto wanting to put transfer case on it
  103. 2001 xj intake manifold question
  104. weird drive train problem
  105. heat prob for expert not heat have checked a lot
  106. 87 xj cherokee fuel pump trouble
  107. 99 jeep cherokee oil sensor
  108. Turn key and nothing. no dash lights or response from the key turn at all.
  109. 01 XJ charging issue
  110. blowing cool air
  111. '96 Cherokee Sport Temp Control Issues
  112. turn signals
  113. a few cherokee questions
  114. emissions control unit '01 XJ
  115. 95 Jeep Cherokee Has Problems Starting
  116. 1996 jeep
  117. 1996 jeep dont run good
  118. 92 abs problem
  119. 2000 Cherokee sport Dealer Manual
  120. 2000 Jeep Cherokee stalling at idle
  121. 02 Grand Cherokee
  122. oil pressure
  123. 2000 Jeep cherokee sport ticks when accelerating
  124. 99 xj overheating
  125. pressure release valve question
  126. 95 cherokee T-case
  127. 95 cheokee oil filter adaptor
  128. 1991 Jeep Cherokee Engine Problem
  129. Marc
  130. interior lights wont turn off
  131. wipers wont turn off
  132. transmission slips in all gears..car won't move.
  133. Fuel problems?
  134. 95 Cherokee weird electrical problems
  135. Can't open back door (hatch back)
  136. Leaking coolant, but on days it wasn't run
  137. 0331 Heads dont break!!!!
  138. Another Cherokee Cooling Issue!!
  139. 98 cherokee. fuel pump not running
  140. Jeep XJ 4.0l heads question
  141. Extra lift 87 Cherokee???
  142. idles normal than cuts out.
  143. 00 Cherokee Sport 4x4 dies out but stays running
  144. 97 jeep grand cherokee larado
  145. Electric-Vaccum booster swap.
  146. 2002 Anti theft
  147. Cooling Fan won't shut off
  148. my jeep doesnt run like it should
  149. Buzz sound from transmission area
  150. Looking for a rebiuld kit for a 2001 xj 4.0l engine
  151. Looking for a rebiuld kit for a 2001 xj 4.0l engine
  152. 94 Jeep Cherokee Automatic Door Locks Dome Light NOT THE FUSES
  153. 88 Cherokee Valve Cover Gasket Replacement
  154. 97 Cherokee Serpentine Belt Tension?
  155. 90 cherokee won't start after replaceing fuel pump
  156. New Oil Pressure Switch
  157. 90 Jeep Cherokee, headlamps won't turn off after shutdown.
  158. Recommended Oil? 1994
  159. 91 cherokee brake accumulator?
  160. 2001 XJ weird sound
  161. my jeep blows black smoke and doesnt idle right..
  162. 2000 Jeep Cherokee Headlights Blinking
  163. 1994 jeep grand cherokee
  164. Throttle Body Adjustment
  165. 2003 Grand Cherokee, no crank, key symbol on
  166. True-trac??
  167. Fuel system issue?
  168. 96 Cherokee won't crank
  169. High Idle at Start?
  170. 1996 jeep cherokee
  171. timeing issue
  172. High RPM's starting up...? Pedal loose...?
  173. fuel pump???
  174. no sound from stereo
  175. 90 cherokee 4.0 need help !!!!
  176. Wobble
  177. How do you open the hood when the Hood Latch Cable Broke.? 1994 Cherokee
  178. jeep grand chrokee
  179. anyone with a 4.0L: need help with wiring plug connections and wire colors
  180. lifter is stuck
  181. 01 Jeep Cherokee intermittant oil leak
  182. Bumper swap
  183. instrument cluster swap
  184. XJ Parts available
  185. takes twice to start
  186. 92 Jeep Cherokee won't start.. HELP!!
  187. engine swap
  188. Lift questions
  189. snorkel
  190. 1988 Jeep Cherokee Idle's VERY low
  191. jeep grand chrokee
  192. 99 Cherokee Sport - opinions?
  193. 1988 cherokee 4.0L hgih idle/engine tick
  194. 8.25 trac-loc clutch pacs
  195. '01 cherokee engine replacement
  196. Jeep 4.0 6 cyl freeze plugs
  197. cherokee fuse# 11
  198. 90 cherokee laredo hard brake pedal
  199. battery dying
  200. Inside rhino line
  201. 1984 jeep problem help
  202. Can freeze plug be replaced with engine in car?
  203. electrical gremlins, please help!
  204. 94 cherokee overheating but coolant not hot
  205. 95 lots of blow by and detonation hothttp://www.automotiveforums.com/vbulletin/images
  206. 1996 Jeep Cherokee Won't Start
  207. 2001 Jeep Cherokee check engine light
  208. 2001 Jeep Cherokee AC Fan
  209. 1990 cherokee stalling
  210. corrosion on brake lines
  211. Is it possible they turned back odometer
  212. HELP!!! Stalling at idle
  213. AC problem
  214. Surging
  215. AC / Heater Fan speed Switch
  216. AC questions
  217. My Jeep Cherokee '98 dies while running-dire need of assistance!
  218. First time Jeep buyer.....
  219. '00 3 speed tranny (30rh?)
  220. 2001 Cherokee Turns over but will not start
  221. Lucas Fuel Additive
  222. '96 Cherokee Sport
  223. 92 Jeep Cherokee Laredo, intermittent start
  224. 96 grand cherokee limited 5.2 - won't stay on
  225. Engine Smoking
  226. '94 Cherokee battery problem
  227. No ac
  228. Turn signal problem
  229. 1990 4.0L Cherokee No-Start
  230. Cherokee Oil pressure problem
  231. AC Cooling Fan not turning on....
  232. Let's play name that connector!
  233. "Spring" clean-out!
  234. Wobble
  235. Window came off tracks
  236. 1999 Cherokee Left Turn Stall (Full Tank) HELP!!
  237. 1998 grand cherokee limited blinking windshield display
  238. R.i.p
  239. What kind of transmission fluid 1986
  240. 1986 Cherokee, 4wd problems.
  241. 90 Jeep Cherokee Electrical Problem
  242. 99 Jeep Grand Cherokee, stalling
  243. 88 jeep wagoneer wont start
  244. 92 cherokee not shifting
  245. 1978 jeep cherokee
  246. How to fix a "p1694" code?????
  247. 93 cherokee possible fuel injector issue
  248. Engine dies when throttle let go.
  249. how do you fix rear gears?
  250. Connector
