View Full Version : Cherokee
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Engine knocking like a p'd off woodpecker
  2. Clutch & brake pedal assembly question
  3. tire wobbles
  4. funny sound comming out of engine compartment
  5. 91 Cherokee hesitation and low idle
  6. 1994 Jeep Cherokee Rear Wheel Bearings
  7. 2000 Jeep Cherokee grinding problem
  8. which fuel pump to purchase?
  9. Wont Start Please Help
  10. Air Conditioning
  11. "Cheap" upgrades?
  12. What tire size for 15x10's with 3.5 in backspace for Cherokee Sport
  13. 90 xj 4.0 engine light on when in 4wd
  14. temp. gage broken
  15. 96 cherokee sport. Miss after HG change.
  16. replace transmission mount
  17. Cherokee serpentine belt
  18. drop in voltage when blower fan on?
  19. 97 Cherokee gauges tach radio not working
  20. high pitched squeeling
  21. Food for thought!
  22. help me with my clutch?
  23. belt chirping noise
  24. no power to A/C Compressor
  25. Information Needed 2005 Grand Cherokee Loredo
  26. 87 Cherokee Pioneer Stalls
  27. driving without rear drive shaft
  28. Engine Revving/Transmission Disengaging
  29. Any good links for doing brakes on a 96 xj
  30. 1992 4.0 Jeep Cherokee Won't start in park when parked on inclines?
  31. 1992 4.0 Jeep Cherokee Laredo How to turn of maintenance required light?
  32. what kind of gas mileage do you get?
  33. want to put '97 doors on '96 xj
  34. 90 XJ electrical guru question
  35. 1997 Jeep Cherokee Sport - Won't start
  36. Header install
  37. 96 XJ having major issues
  38. 99 Cherokee Sport 4.0L - All gauges failure
  39. Jeep 2000 GCL, turn signals work intermittently, hazards work fine
  40. 89 xj idle problems
  41. 2001 jeep cherokee
  42. condensation water leaking on passenger floorboard
  43. hard to get into gear from park
  44. Sputters at take off
  45. AC recharge
  46. Transmission change
  47. 1993 Cherokee Ignition Switch
  48. 1999 Cherokee Parking lights stay on
  49. lookin at '96 cherokee, got random Q's
  50. 4.0l Engine block coolant draing plug- how to remove?
  51. 1992 jeep cherokee air conditioning blows out of defrost not vents
  52. No Brake Lights
  53. 89 Jeep Cherokee Idling Problems/gas smell
  54. Few questions about an idea I have... 99 XJ
  55. 99 JGC AC Compressor
  56. Opinion - 1998 Jeep Cherokee Sport Utility SE 4D 4x4 6cyl
  57. 99 Jeep Cherokee starting issue and gauges
  58. 1994 Jeep Cherokee 2.5l starter removal
  59. 01 Cherokee front brakes not releasing
  60. 97 Jeep Cherokee Sport squeeks when braking or turning??
  61. Rear Diff Questions.
  62. Jeep doesn't like starting
  63. need info on 90 xj cold air intake?
  64. Annoying squeeking sound
  65. Bizzare Jeep behavior- Wheel locking up at low speed?
  66. how to get brake rotor off
  67. axle
  68. Where is the radiator drain on a '96 Cherokee 4.0 HO ?
  69. 99 Cherokee 4WD Front Drive Shaft ?Repair?
  70. engine upgrade
  71. 87 Cherokee antenna
  72. Jeep tranny problem
  73. 1997 Jeep Cherokee Sport lost power
  74. Wierd problems.. I need help, please
  75. Electrical gremlin
  76. will an exhaust upgrade mess with TPS,CPS,MAP sensors.
  77. 2001 jeep ch sport tranny dipstick wont seperate
  78. 88 XJ Smoking Under the Hood
  79. 87 4.0 hard start when warm
  80. Brush Guard Problem
  81. Fuel Vapor Ldp Probs
  82. 99 Xj 4wd Engine Cuts Out While Driving,no Warning
  83. need help with TPS,CPS,MAP?
  84. will a dana 44 bolt directly to a 90 xj?
  85. 90 cherokee front axle leak?
  86. 90 xj 4.0L, stumble and hesitation during acceleration.
  87. Death wobble ?
  88. 95 Cherokee-Trans leak
  89. 87 jeep cherokee electrical problem
  90. Problem with Lights
  91. rear clicking
  92. 1990 cherokee 4.0 hard start
  93. 93 Jeep Cherokee Country
  94. 1989 Cherokee Laredo no spark
  95. Front driveshaft keeps aspinning
  96. 1996 Cherokee A/c Removal
  97. Pads, Rotors, and Calipers
  98. 2001 Cherokee fuel guage
  99. 91 jeep cherokee misfire
  100. Rear end
  101. 1989 XJ Idler Pulley Removal
  102. Dana 30 wheel bearing
  103. pugs out
  104. 99 Jeep Classic - Front End Rumble
  105. High Idle? ERB?
  106. O2 sensor wiring?
  107. Smoking squirrels
  108. 87 Cherokee water pump
  109. 4.0 and HO 4.0
  110. 98 cherokee grinding
  111. Center Console Removal
  112. Will a 92 Fuel sending Unit work in a 96
  113. RWD to 4WD
  114. HEad swap
  115. 92 Cherokee new engine runs rough
  116. Jittery Start
  117. 01 cherokee transmission problems
  118. '87 Cherokee L/F Hub stuck in steering knuckle
  119. Tranny Slipping
  120. Old 1984 2.5l Cherokee wont start
  121. grinding problems
  122. Torque sequence?????
  123. My jeep wont start
  124. heres info on troublshooting shorts in 90 cherokee.
  125. 90 jeep cherokee low idle problem
  126. I miss my cherrokee
  127. '94 Jeep Cherokee gas mpg drop
  128. brake light switch in 2000 cherokee sport
  129. Amp draw when accesories are on.
  130. Amp draw when accesories are on.
  131. instrument panel short
  132. Exhuast manifold.
  133. oil pan
  134. Replacing Head Gasket?????
  135. 88 Cherokee with yellowish-white on bottom of oil dipstick
  136. 91 Cherokee Rear Tail Lights Stay On
  137. 1976 Jeep Cherokee wiring diagram
  138. 88 Cherokee-Lash in tilt wheel
  139. Hard to start
  140. 4wd linkage issue.
  141. 1987 jeep pioneer-battery keeps going dead
  142. 91 wiper,radio,lighter,blower,turn signals
  143. need help! 1999 jeep Cher. When shifting into 4h or 4l the light on the dash does n
  144. something's not right
  145. 96 Cherokee Rich smelling exhaust
  146. Fias Idle?
  147. Cooling system problems 01 Cherokee
  148. Stupid but easy question
  149. HELP!!! 89 XJ wont start
  150. EGR VAlve missing.
  151. 91 Jeep Cherokee Limited Electrical Problems
  152. '86 jeep carb vacuum lines...Im lost!
  153. Knock After H/G Repair
  154. 4.o Knock after H/ G Repair
  155. front axle qs?
  156. 1989 models
  157. Temp sensor short?
  158. brake question
  159. Please help alternator covered w/ tranny fliud
  160. 93 cherokee elctrical brake/hazards out
  161. 1990 selec trac question
  162. 88 Cherokee Pioneer Ignition/Idle issue
  163. jeep
  164. Cut n fold rear bumper
  165. Help heated seats not working
  166. 88 Cherokee 4WD Transfer Case rebuild or replace?
  167. '89 Cherokee problems.
  168. Need Help!
  169. 1990 Cherokee No Start
  170. I'm stumped
  171. Body Part Question
  172. cant start my 86 cherokee 2.5l
  173. 1998 cherokee limited heater
  174. changing cherokee serpentine belt
  175. Axle bearings-2000 Cherokee Sport
  176. Connector location?
  177. What year ?
  178. 4WD instructions
  179. I think I bit off more than I could chew!
  180. Weird Tranny Problems
  181. 96 cherokee sputtering backfire
  182. Clutch Fluid Leaking Out !
  183. Help!!! Overheating
  184. Best 4 WHD driff for a 88 Cherokee Pioneer
  185. Major oil leak, any ideas?
  186. Need 2 Put A 88 Intake On A 96 Motor
  187. Security alarm problem with a 91 Jeep Cherokee?
  188. 89 4.0 jeep cherokee runs rough help!!!
  189. what are the extra gears for?
  190. Vacuum Actuator 4WD Front Axle ?
  191. How hard is it.....?
  192. Will it work?!
  193. electrical fan won't shut off
  194. '87 Floating steering?
  195. help i cant have fun!!!!!!!!
  196. Starter Wheezing!??
  197. 91 Cherokee Trans problem or electrical???
  198. jeep will not start in cold unless ign held in start pos!
  199. Small question
  200. fourwheel drive jeep cherokee
  201. No 4x4 light or 4x4 front axle
  202. Steering in 4wd?????
  203. Electrical help please
  204. 95 Cherokee really wierd starting
  205. Grinding Sound
  206. Heater Problems
  207. Being proactive?????
  208. Rpm"s
  209. 94 Cherokee Rather Wierd Problem
  210. Wrong Fluid!
  211. 97 cherokee heater issue
  212. Street legality between XJ and YJ/TJ/CJ's
  213. Can a 97 Cherokee be timed?
  214. Miss on "tip in" (accelerating)
  215. Light Switch????????
  216. Electrical problem w/94 cherokee sport, HELP!!!
  217. cherokee 2000 speed problem
  218. 97 Cherokee AX-15 tranny stuck in reverse
  219. xj 90 Fire+Fuel - Start Idle problem
  220. 2001 Cherokee - no heat & it's cold outside
  221. 88 Jeep CHerokee Pioneer MSD Q's?
  222. '92 XJ Cherokee--is it time to say goodbye?
  223. 1990 cherokee cruise control
  224. 95 cherokee wont start
  225. what should my temp be
  226. 1994 Jeep Cherokee 4X4 Front Axle Vacuum Line Question
  227. '87 Cherokee extended crank when cold
  228. serpentine belt ?
  229. 96 Jeep Cherokee Country 4.0 Squeek!
  230. 92 jeep cherokee stereo wire harness
  231. 1991 Cherokee 4x4 front windshield wipers.
  232. 97 Cherokee will not turn on anything
  233. Digg!?
  234. Want To Buy Audio System
  235. New Purchase Advise Please.
  236. lock problems
  237. 96 Cherokee - Missing, backfire only on initial start
  238. 94 jeep cherokee sport electrical ghost
  239. Crap... Death Wobble.
  240. coolant loss
  241. 95 Cherokee AT problem
  242. Testing an '01 Alternator
  243. 1994 Cherokee,headlight relay location
  244. Waterproofing idea
  245. No power mirrors/window locks in '97 Cherokee
  246. Im exhausted :)
  247. Blowing fuses after battery change
  248. 87 pioneer
  249. Cranking problem
  250. A/C problem
