View Full Version : Cherokee
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. '96 Jeep Cherokee
  2. engine swap
  3. weather drop=dramatic mpg drop-is it normal with cherokees???
  4. clunking noise when turning with 87 Cherokee
  5. Driveline wined up? Clunk, bang sound.
  6. Mystery shifting problem, big mpg drop, out of ideas.
  7. Engine wiring harness. 96 4.0 4x4
  8. Starter Relay
  9. 01 Jeep Cherokee Transfer Case issue
  10. bad alternator ?
  11. factory shocks and lift???
  12. Heater/AC fan control issue
  13. Running and Shifting Issue. Help Guys!!!
  14. xj fuel tank swap 98 to 89 -will it fit???
  15. fuse
  16. Brake line
  17. Need Help Stranded 88 Cherekee
  18. 88 XJ - Tranny slipping when cold outside
  19. How important are wheel weights?
  20. Question from a new Jeep owner.
  21. Flushing closed system and fan sensor help
  22. Bottoming out!
  23. mild 3" lift but...
  24. Ignition mystery
  25. 1990 Jeep Ignition Inigma
  26. High Flow H2O pump vs. louvers?
  27. Airbag light?
  28. heater hose pipe name?
  29. 89 xj runs, then.... it quits?!?!?!
  30. 95 Cherokee. Need Help! Stranded!!
  31. 89 cherokee fuel pump
  32. gas guage not working on 93 grand cherokee
  33. parting my 1993 jeep grand cherokee laredo
  34. Manual Transmission
  35. 1998 Jeep Cherokee
  36. pulled ABS fuses now brakes don't work
  37. rear main tourqe
  38. Command Trac & Select Trac
  39. Fender Flare Brackets
  40. Still no Mirrors
  41. Transfer case question
  42. 97 Jeep cherokee Clanking/Rattling sound on startup and idle
  43. need help on 1989 Cherokee Laredo
  44. need help on 1989 Cherokee Laredo
  45. transmission leak on a '98 ZJ 4x4
  46. 1988 Jeep cherokee 6cyl man. tran. clutch wont engage!
  47. auto to manual?
  48. jeep over heated and wont start
  49. Reman Head
  50. fault code 54?
  51. 1990 XJ "Neutral Slips"
  52. Why won't it work?
  53. keyless remote entry question
  54. keyless remote question
  55. Help
  56. clicking sound when accelerating in 2wd & 4wd
  57. No brake lights or hazzards
  58. Starter problems
  59. great beater
  60. limp mode
  61. Feil odor coming from engine
  62. '94 sport stumble
  63. child car seat/ cherokee2.5 diesel 60th anniversary edition
  64. 95 cherokee OEM cruise control
  65. 1997 Jeep Cherokee Country P700 Code
  66. 2000 Cherokee Sport Electrical Gremlin
  67. blowing fuses.
  68. electric fan & clutch fan
  69. Hard Brake Pedal 89 Cherokee
  70. textured grip oil filter!?
  71. Cherokee Cooling Issues
  72. 98 Cherokee Cruise Control issue
  73. HELP!!! Please its my bday
  74. 96 Cherokee. Tranny fuild boiled over.
  75. Love at first sight, now kicking the dang thing
  76. cherokee wheel spacers
  77. 93 cherokee ax-15 compatibility question.
  78. 2000 Speedometer & Tach Quit "no bus"
  79. 1988 Jeep Cherokee Air Intake Hose
  80. Need help! #16 Fuse doesnt work at all!
  81. 1998 jeep cherokee sport problem
  82. what are these parts??
  83. 88 XJ Stalling
  84. 94 sport rattling
  85. Idling High in everything but drive and reverse.
  86. Another hot jeep question
  87. How many Electric fans?
  88. 01 cherokee a/c compresser clutch replacement
  89. tranny flush Yes Or no?
  90. FS: 1989 Jeep Cherokee XJ
  91. ABS Trouble? I think
  92. Tried everything, still nothing
  93. 1999 cherokee fuel problem
  94. 88 4.0 Vacuum Diagram
  95. Windshield wiper motor on 89 Cherokee Laredo
  96. 88 cherokee has clicking sound
  97. truth about cleaning engine compartment
  98. Engine knocking like a p'd off woodpecker
  99. Clutch & brake pedal assembly question
  100. tire wobbles
  101. funny sound comming out of engine compartment
  102. 91 Cherokee hesitation and low idle
  103. 1994 Jeep Cherokee Rear Wheel Bearings
  104. 2000 Jeep Cherokee grinding problem
  105. which fuel pump to purchase?
  106. Wont Start Please Help
  107. Air Conditioning
  108. "Cheap" upgrades?
  109. What tire size for 15x10's with 3.5 in backspace for Cherokee Sport
  110. 90 xj 4.0 engine light on when in 4wd
  111. temp. gage broken
  112. 96 cherokee sport. Miss after HG change.
  113. replace transmission mount
  114. Cherokee serpentine belt
  115. drop in voltage when blower fan on?
  116. 97 Cherokee gauges tach radio not working
  117. high pitched squeeling
  118. Food for thought!
  119. help me with my clutch?
  120. belt chirping noise
  121. no power to A/C Compressor
  122. Information Needed 2005 Grand Cherokee Loredo
  123. 87 Cherokee Pioneer Stalls
  124. driving without rear drive shaft
  125. Engine Revving/Transmission Disengaging
  126. Any good links for doing brakes on a 96 xj
  127. 1992 4.0 Jeep Cherokee Won't start in park when parked on inclines?
  128. 1992 4.0 Jeep Cherokee Laredo How to turn of maintenance required light?
  129. what kind of gas mileage do you get?
  130. want to put '97 doors on '96 xj
  131. 90 XJ electrical guru question
  132. 1997 Jeep Cherokee Sport - Won't start
  133. Header install
  134. 96 XJ having major issues
  135. 99 Cherokee Sport 4.0L - All gauges failure
  136. Jeep 2000 GCL, turn signals work intermittently, hazards work fine
  137. 89 xj idle problems
  138. 2001 jeep cherokee
  139. condensation water leaking on passenger floorboard
  140. hard to get into gear from park
  141. Sputters at take off
  142. AC recharge
  143. Transmission change
  144. 1993 Cherokee Ignition Switch
  145. 1999 Cherokee Parking lights stay on
  146. lookin at '96 cherokee, got random Q's
  147. 4.0l Engine block coolant draing plug- how to remove?
  148. 1992 jeep cherokee air conditioning blows out of defrost not vents
  149. No Brake Lights
  150. 89 Jeep Cherokee Idling Problems/gas smell
  151. Few questions about an idea I have... 99 XJ
  152. 99 JGC AC Compressor
  153. Opinion - 1998 Jeep Cherokee Sport Utility SE 4D 4x4 6cyl
  154. 99 Jeep Cherokee starting issue and gauges
  155. 1994 Jeep Cherokee 2.5l starter removal
  156. 01 Cherokee front brakes not releasing
  157. 97 Jeep Cherokee Sport squeeks when braking or turning??
  158. Rear Diff Questions.
  159. Jeep doesn't like starting
  160. need info on 90 xj cold air intake?
  161. Annoying squeeking sound
  162. Bizzare Jeep behavior- Wheel locking up at low speed?
  163. how to get brake rotor off
  164. axle
  165. Where is the radiator drain on a '96 Cherokee 4.0 HO ?
  166. 99 Cherokee 4WD Front Drive Shaft ?Repair?
  167. engine upgrade
  168. 87 Cherokee antenna
  169. Jeep tranny problem
  170. 1997 Jeep Cherokee Sport lost power
  171. Wierd problems.. I need help, please
  172. Electrical gremlin
  173. will an exhaust upgrade mess with TPS,CPS,MAP sensors.
  174. 2001 jeep ch sport tranny dipstick wont seperate
  175. 88 XJ Smoking Under the Hood
  176. 87 4.0 hard start when warm
  177. Brush Guard Problem
  178. Fuel Vapor Ldp Probs
  179. 99 Xj 4wd Engine Cuts Out While Driving,no Warning
  180. need help with TPS,CPS,MAP?
  181. will a dana 44 bolt directly to a 90 xj?
  182. 90 cherokee front axle leak?
  183. 90 xj 4.0L, stumble and hesitation during acceleration.
  184. Death wobble ?
  185. 95 Cherokee-Trans leak
  186. 87 jeep cherokee electrical problem
  187. Problem with Lights
  188. rear clicking
  189. 1990 cherokee 4.0 hard start
  190. 93 Jeep Cherokee Country
  191. 1989 Cherokee Laredo no spark
  192. Front driveshaft keeps aspinning
  193. 1996 Cherokee A/c Removal
  194. Pads, Rotors, and Calipers
  195. 2001 Cherokee fuel guage
  196. 91 jeep cherokee misfire
  197. Rear end
  198. 1989 XJ Idler Pulley Removal
  199. Dana 30 wheel bearing
  200. pugs out
  201. 99 Jeep Classic - Front End Rumble
  202. High Idle? ERB?
  203. O2 sensor wiring?
  204. Smoking squirrels
  205. 87 Cherokee water pump
  206. 4.0 and HO 4.0
  207. 98 cherokee grinding
  208. Center Console Removal
  209. Will a 92 Fuel sending Unit work in a 96
  210. RWD to 4WD
  211. HEad swap
  212. 92 Cherokee new engine runs rough
  213. Jittery Start
  214. 01 cherokee transmission problems
  215. '87 Cherokee L/F Hub stuck in steering knuckle
  216. Tranny Slipping
  217. Old 1984 2.5l Cherokee wont start
  218. grinding problems
  219. Torque sequence?????
  220. My jeep wont start
  221. heres info on troublshooting shorts in 90 cherokee.
  222. 90 jeep cherokee low idle problem
  223. I miss my cherrokee
  224. '94 Jeep Cherokee gas mpg drop
  225. brake light switch in 2000 cherokee sport
  226. Amp draw when accesories are on.
  227. Amp draw when accesories are on.
  228. instrument panel short
  229. Exhuast manifold.
  230. oil pan
  231. Replacing Head Gasket?????
  232. 88 Cherokee with yellowish-white on bottom of oil dipstick
  233. 91 Cherokee Rear Tail Lights Stay On
  234. 1976 Jeep Cherokee wiring diagram
  235. 88 Cherokee-Lash in tilt wheel
  236. Hard to start
  237. 4wd linkage issue.
  238. 1987 jeep pioneer-battery keeps going dead
  239. 91 wiper,radio,lighter,blower,turn signals
  240. need help! 1999 jeep Cher. When shifting into 4h or 4l the light on the dash does n
  241. something's not right
  242. 96 Cherokee Rich smelling exhaust
  243. Fias Idle?
  244. Cooling system problems 01 Cherokee
  245. Stupid but easy question
  246. HELP!!! 89 XJ wont start
  247. EGR VAlve missing.
  248. 91 Jeep Cherokee Limited Electrical Problems
  249. '86 jeep carb vacuum lines...Im lost!
  250. Knock After H/G Repair
