View Full Version : Cherokee
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [ 19]
20 21
- 1990 steering problem...Help
- 1996 Cherokee won't start
- Just rebuilt engine, car won't start
- need more slack from speedometer cable
- Pre 92 Cherokee Radiator Conversion
- Jeep has sat for two years un-started...What to do to help the engine before startin?
- 1999 Wont Start, Going Nutz HELP ASAP PLEASE
- Rear Brakes
- Throttle position sensor
- pressireized air
- 1990 Jeep Cherokee Laredo Cruise Control
- wheels
- headlights quit 94 cherokee
- Rear Crankshaft Seal $
- 96 Cherokee w/ Suspension Issues - Help
- UPGRADE ?'s On MY 87' Jeep Chero Pioneer
- springs/coils
- Removing Rear Panel.. How?
- Older model Jeep Cherokee (1990)
- water from the tail pipe
- How do you BURP! the cooling system??
- Cannot open rear door
- Replacing speakers, a few general questions
- 87' Jeep Chero Pioneer Water Pump and Nocking Noise Problems
- wiring diagram.....
- Oil sending unit issues????
- Where is a/c fuse located for 90 jeep cherokee laredo
- no 4wd low
- oil pressure
- Engine dies when warm
- wheels/ thumping
- windshield wipers not working properly
- Hellllllllllllp!!!!!!!!!!!!!!!!!!!!!!!!!!
- 88 cherokee won't heat up!!
- 92 Chero Laredo-body/frame question
- Fuel pressure drops when I turn off the motor
- tires/lift/dilemna
- Tire size on Jeep
- u joint installation
- Instrument panel lights 1991 Cherokee
- 95 Cherokee... overheats on highway
- Newbie,with some questions
- '84 cherokee wont idle when cold and blows black smoke
- Looking for parts jeep
- Want to Buy Seat
- if your cherokee wont run it's probably your ground wires
- Bad News for my T-case
- 88 Cherokee clutch problems
- 87 jeep cherokee 4.0l oil in air filter
- Air Filter has OIL ON IT!?!?! What's wrong??
- erratic oil pressure
- 1996 Cherokee Sport Power Windows dead
- AIR Intake
- 88 Cherokee Gas Guage not working???
- local 4x4 shop in TN?
- Jeep with 20's
- oil pressure
- Interested in Leather?
- Will A Tach Cluster fit in a Pioneer with no modifications?
- 87' Cherokee OverHeat During Idle
- aftermarket tach
- do i have a blown headgasket?
- Electrical Problem
- no parking lamps
- Tach, Speed, Gas Guage
- i need help on underhood relays
- Chrome grill shell
- gauges not working....please help
- Resistance across fuel sending unit?
- Need 2001 XJ sport wiring diagram
- Custom Wheels for JEEPS
- idleing problems... please help
- 1988 Cherokee Pioneer, electrical problems, turn/S, blower, radio, wipers.
- 88 comanche chief hard vibration
- Custom Leather Seats
- 2000 Cherokee Sport-Vibrations-Shaking in Steering-Trans Problems?
- J8s-800 2.1td/1991
- oil pressure?
- Transfer case swap in '84 Cherokee
- 20" rims 4 sale
- New Leather Seats for my Cherokee
- rear main seal
- 1991 jeep cherokee cutting out
- Fan not kicking in
- Transmission cooler 2000 cherokee
- wont turn over
- red brake light with a timer like noise???
- Cold air intake for a 90 Cherokee
- Replacing blinker switch
- Help setting clock...
- clunking under the hood
- engine missfires and backfires
- Stereo wiring and harnnesses
- 82 Cherokee Chief V8 - engine cuts out
- passenger door lock
- Charcoal Gray Leather Seats
- A/C compressor only works sometimes
- Oil getting in my air filter
- Heating problem
- 4 x 4 problems
- 89 Jeep seems to be Frozen?
- Jeep Cherokee 2000 transmission trouble
- Electric Fan Not Running
- 2001 Cherokee Classic engine starting issues
- Elecrical problem Instrument cluster
- FWD electrical problems
- Tail Lights...Short? HELP
- '99 Jeep Cherokee high oil pressure
- Another overheating Jeep
- 1992 cherokee stalls
- POWER vs. COMFORT
- 1990 xj laredo missing something !!PLEASE HELP
- 89 jeep bout to cause divorce please help
- air conditioner conversion
- Sending unit for water temp
- Thermostat housing gasket info??
- GAS Mileage?.?
- 91 Cherokee Bucking under smallest load
- 86 Cherokee Tranny needed!
- 1990 jeep missing or stalling???
- turn signal problems
- Auxilliary fan runs for 30 min after parking
- Check Engine Light (MIL) - Need your input
- 2000 Cherokee Cruise Control On/Off Button
- Cherokee vs Blazer
- 4 wheel drive noise
- correct trans fluid for 88 2wd auto
- 98 Cherokee Power Windows
- Full Size spare rack 2001 Cherokee
- 5 speed Cherokee Manual Transmission
- guages,blinkers,heater fan
- 1999 Jeep fuse panel
- 93 sport clattering! HEEELP!
- cherokee tilt steering adjustment
- Radio wiring harness color code
- 94 cherokee sw
- Rear differential noise in reverse
- XJ lift???
- 87 jeep ECM
- 95 Wrangler,clutch question
- Rookie - 94 Cherokee 4wd Questions
- Comatose Jeep!
- 1995 Jeep Cherokee headlight relay
- low heat...
- 95 Cherokee Sport, NO HEAT, Help!
- Help! '98 Cherokee - interior lights staying on!
- front end knocking!?
- 2000 Sport rear sagging, HELP
- 1994 cherokee sport parting out
- 89 cherokee: starter and more.
- 1994 Alternator removal
- 1991 Jeep Cherokee Questions
- Rocker Arm Cover (aka Valve cover)
- 1998 cherkee sport keyless entry
- 1999 Jeep Cruise Control
- 1988 Laredo
- 87 Cherokee Auto Tranny wont Engage??
- OPINION on Clutch Brands
- Tow Hooks
- Like some 93 help on door-locks&pwr windows
- 90 4.0L No power, no rev past 1400 rpm
- To Lift or not to Lift...???
- Won't Start?
- Neutral Safety Switch Location
- Radio Antenna
- 89 Cherokee Chief 4.0 won't start backfires flames from injector
- 92 Cherokee overheating and no heat
- Manual trans removal on 91 2 wheel drive
- Newbie Here needs Help Please
- Complete Wiring Harness
- 1996 cherokee headlight switch
- 1990 Testdrive noise
- hornless xj
- body lift or not
- new speakers 2000 Cherokee Sport
- Power windows wiring problems
- 1990 jeep cherokee
- correct motor mount install
- UPDATE: Missfiring and backfiring on 89 cherokee 4.0
- Abs problems!
- E-brake light
- Turn signal light
- Fuel Regulator 1987 Pioneer
- Help w/Replacing Fuel Pump in 99 Cherokee
- neutral safety switch
- steering problem
- 89 xj idle problem
- '98 4.0 Coolant Color
- Headlight switch
- 1999 won't start, idle air intake problem
- Noise behind dash.
- A couple of questions
- Back-up Light Switch
- Power Windows and the amazing mystery
- 88 Cherokee stalls out sporadically
- 94 cherokee mods
- 96 cherokee no crank, then runs, then no crank
- cup holder for 94 sport
- several questions about 94 cherokee sport
- 89 Jeep Cherokee
- Spark Plugs?? Advice please....
- fuse panel for 90 cherokee
- Airbag Light/Starting/Speakers
- lug diameter
- 1988 Jeep Cherokee Electrical Problem
- question about 4wheel lo / hi
- Electical problem
- Advice Needed: MIL
- xj
- Help 1994 Cherokee Will Crank Won't Start
- Brakes at 20,000 miles?
- differential fluid change/trans fluid change
- Aftermarket jeep parts for sale
- 1996 Cherokee driving me nuts.
- 1995 Cherokee Sport Clutch Problem?
- Brake Lights Won't work...Help!!!
- parting out 89 xj
- Cherokee Problems. Starts, not a key issue, but won't run occasionally.
- coolant cap hiss/coolant dribble from same
- Cherokee Racing!
- '90 Comanche 2.5
- Cherokee model chronology
- 1991 Cooling Problems
- Need help wiring my head unit
- 1995 jeep cherokee sport
- Help!!!jeep Starts But Won't Run
- 1990 Cherokee Electrical Issues - Starting - Charging
- 1996 Cherokee--Reverse lights work when they want to..
- 1988 Jeep Cherokee Pioneer 4WD light on dash display
- Hard first start of day
- 18x8 masitaly wheels w/toyo tires FOR SALE!!!
- 96 XJ Rear Retracting Seatbelt
- 2000 Cherokee Rear Main Seal
- 1989 XJ stalls after warmup suspected fuel pump
- Bump after braking
- headlights
- trouble codes
- Jeep wont start when warm
- 95 Cherokee Sport - leaking Fuel Pump?
- Update: 89 Cherokee/Poor Mileage
- valve cover gasket replacement/motor mounts
- Select-Trac & ABS
- suspension lift ?
- what is an xj
- 4wd aftermath
- interchagable years
- rear hatch
