View Full Version : Cherokee
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [ 18]
19 20 21
- 1988 Cherokee REAR WIPER DOESN'T WORK
- What's wrong with this !@#$% thing?
- 1989 Cherokee Laredo; fuel problem
- frontend noise
- installing automatic locks ??
- Problem Fixed
- Need Help On A Idle Problem!
- EAZ-E-LIFT Trailer Hitch FOR SALE !!!!!!
- 96 Cherokee - CV Joint????
- 99 Cherokee AC Cycling Problem
- Idle 'miss' - 88 Cherokee
- high idlel
- 1990 Jeep Cherokee takes forever to start
- EAZ-E-LIFT V5 Trailer Hitch FOR SALE !!!!
- Steering/track bar problem?
- 1988 Cherokee BUZZER WON'T SHUT OFF
- Electrical Problem on AC compressor
- Front End Problems
- Thermostat with or without Jiggle Valve!?
- f/s 01 jeep cherokee limited
- Fuse Diagram for 00' cherokee
- Steering
- Help Headlights
- What is that thing above rear view mirror?
- 97 doors on a 96
- What Degree of shims do I need?
- speedometer not working
- Which Spark Plug to Buy!?
- Cracked exhaust manifold - 1986 2.5L
- Sputtering,Stalling,Slow accel. 1986 2.5L
- Air Conditioning Cherokee
- Steering Issues
- Left Turn Signal Rapid Blink
- Drum To disc conversion
- Transmission / Modulator Valve Problem in '89 Pioneer
- Crankshaft Position Sensor?
- Jeep Cherokee Code.
- 1994 cherokee key lock cylinder
- 4WD No Longer Engages
- Cooling Fan Relay
- clunking noise
- fuel
- Dana Identification
- 1991 Jeep Cherokee 4.0L 4WD Thermostat problem?!?
- 1992 Cherokee Ltd, 105k , wont stay started, alarm prob?
- Starts, Stall Quickly.......
- clicking noise in tranny
- VERY STRANGE electrical probs, 98 sport
- Info on Jeep Cherokee...
- 2000 Cherokee Trailer Brake Wiring
- I am in need of a little bit of help !!!!!!
- Low Clutch
- 4.0 Engine Rebuild for 89
- What is it worth?
- 98 Jeep Cherokee Leaking Oil
- Urgent help needed with injector problem
- inertia switch 90' laredo
- engine parts vendors???
- check engine codes
- 92 cherokee cruise control
- 92 cherokee speedometer failure
- '90 jeep cherokee lerado won't start
- Another TPS question (1995 Cherokee)
- 88 Laredo Dies When Hot
- Transmission cooler hose leaking '97 Sport
- Cruise control never used now its coming on and using and abusing me!
- 1988 jeep cherokee cutting out
- good buy?
- Heater Problem - Resistor for Blower motor overheating
- FS: 2002 Jeep Grand Cherokee 17" alloys
- Crankshaft position sensor ? 94 Cherokee
- I still cant figure out the problem?
- 93GC Problems ANYONE?
- Cherokee tranny problems
- Lincon locker
- Late model Jeep rims on older Cherokee?
- 1996 cherokee sport radio removal
- Electrical problems (99 Cherokee)
- 5.0 ford conversions in cherokees anyone?
- ABS sensor
- Fuel Injector Leaks
- Bad ABS sensor?????
- Got some wiring done on overhead console but need help!!!!
- bearing(?) noise & rebuild question
- Upgrading wires and grounds on 1990 Cherokee.
- jeep wont break 2500-3000 rpms
- Acceleration?
- Jeep Shakes at highway speeds
- Replacing crankshaft positioning censor
- 1988 XJ heating/AC vents not working
- 96 Cherokee water pump
- Power Steering Leak
- Cluster Question and Directions for Oil Pump Installation... HELP
- Battery keeps draining
- Component Location
- My Jeep Want Start 1990 Cherokee
- ((...95 JEEP Cherokee Radiator/Gasket/Engine problem...))
- Need Help Fast !!!
- Wiring up overhead console
- anyone know how to hotwire a 1990 jeep cherokee
- Keyless entry/ key fob for
- 1990 jeep cherokee ignition is locked
- Help! I need points ignition for my 2.5
- Big Bucks on '89 Cherokee?
- left side running lights
- bucking problem with 96' cherokee
- wiring diagrams for Cherokee
- 91 --> 96 4.0L HO Swap
- 2000 XJ - MIL, heated seat, cruise control
- Successful driver seat repair?
- how do I test the a/c clutch relay?
- 1988 Jeep Cherokee Coolant leaks
- Alarm/Door Lock Problem - 91 Cherokee
- rear hatch
- 99 Cherokee Tranny Noise
- DIY Jeep Repair
- Huge sucess changing axle universals!
- corvette engine (327) or 4.0L
- Modulator valve on 98 cherokee?
- 1999 door panel removal
- Shudder at Hwy speed, NOT unbalanced tire
- 1989 Jeep Cherokee 4.0 Rough Idle Problem
- what causes auto tranny to shift? computer?
- 88 intermittent misses / dies
- Fuel Pump Quagmire
- 97 Cherokee Head Gasket Problem?
- changing front axle uni's (Hey Dale!!! you out there?)
- 76 cherokee 4wd
- carburated points distributor is there such a thing?
- Good Times changing the oil
- Replaced everything...what am I overlooking?
- Transmission Troubles
- My jeep starts runs for 5-10 sec then stalls
- 94 Cherokee Electric Seats Dead
- Problems on my 87 XJ w/ 470K Miles
- In the Jeep Market
- Rough country lift review?
- 1995 Cherokee wont start
- 89 cherokee auto trans won't shift!
- Common stall problem in Cherokee Sports?
- Core plug problem
- Wiper problems
- PLEASE HELP !!!! MANY Problems !!!!
- '98 Cherokee's headlights
- 99 Jeep Cherokee Sport Fan Sticks On
- Need a solution for mushy weak brakes
- transmission Concern
- Transfer case leak
- 1991 keyless remote
- Coolant Disappearing
- Door locks and latch lock troubles
- my jeep is history
- 94 Cherokee NO SPARK
- 87 Jeep Cherokee Idle and Rev Prob...
- transmission and lift questions 96 xj
- cylinder head torque settings
- Where is the Crank Sensor
- 88 Jeep Cherokee specs HELP
- help wit 01 chrekee limited
- '96 xj overheating prob
- death wobble
- Please need HELP with 96 cherokee sport
- Lost all oil in a 1998 Cherokee
- Shifting Problems!!!Please Any Help???
- Help...metal on metal grinding noise
- Oversized Tires
- 91 Electrical Problem
- 93 jeep cherokee stereo wiring code
- Help Jeep runs like crap and dies when I turn on the headlights?
- coolant leak...
- can i bypass the ac compressor?
- I Need Help !!! Quick!
- 89 Cherokee overheating...and overheating...
- prostart remote starter won't work
- Looking for a Cherokee Overhead Console
- Ignition Switch Compatibility
- Valve Cover
- All JEEP parts for sale (new from dealer)
- Won't hold oil pressure
- Rear brakes
- Ticking noise
- 1995 Cherokee cuts out on idle
- engine turns over but doesnt start Help Please
- Power Window makes noise when fully up
- Speed tach and fuel gauges out
- 98 XJ 2.5 I4- Need Power
- Help Problem with my 1988 cherokee cooling
- Cherokee sounds like a jet
- Transmission knocks when warm
- 1998 Cherokee electrical problems
- Headlamp switch? Bare wire? HELP!
- 1991 Cherokee ABS Light
- striped power window
- Busted U-Joint
- 2000-2001 Jeep Cherokee Rough Idle / Multiple Cylinder Misfire
- EGR System problems!?
- 2001 Cherokee Check Engine Light
- Cherokee/ Grand Cherokee
- Wont Start when warmed up
- NEWBIE here!
- OIL LEAK search HELP!
- transmission light on
- checking the quadro 1987
- 97 Cherokee w/ rear end vibration when decelerating
- Leak in transmission???
- Leakage on the return line for automatic transmission, how to connect?
- 1989 Cherokee 6cyl shuts off while driving
- How Big Is Yours???lol
- 18" rims and tires FOR SALE
- Please help me fix my Jeep so my girlfriend won't make me sell it!
- just another lift question
- 95 Cherokee brakelight burnout
- More motor mount stuff
- How Big Is Big Enough?
- up country suspention
- 1990 4.0 passenger side motor mount
- No thermosthat
- 2000 power window issues
- rear end thumping and grinding
- Please Help, Axle Shift Motor?
- Speaking of Harmonic Balancers...
- 98 Cherokee Transmission smoking
- 87 4.0 cherokee overheating
- 85 Cherokee High beam & blinker indicators
- Installing keyless entry, lil' help?
- buying a jeep
- jeep that revs at idol
- 1992 cherokee wont stay running
- programing car remote
- sounds like jeeps going to turn off when inreverse
- EGR Valve Question
- stuck in 4wd
- Any Good Sites On Cherokee Parts Installation
- any ideas would be helpful
- 1988 XJ 4.0L serpentine belt replacement
- Power door locks on 89 cherokee
- knocking 4.0
- Hard to start 1990 Jeep Laredo
- Keyless Remote Programming?????
- Window crank - Does it come off!!!
- Please Help With 89 Cherokee
- Why all the Giggles????
- 89 cherokee & 91 bronco parts swap
- Jeep (Chrysler) Svc Manuals Contact Info
- tranfer case specs
- Electric window motors
- Where to mount cd changer in Cherokee???
- New water pump, new stat still overheats
- 1990 steering problem...Help
