View Full Version : Cherokee
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [ 17]
18 19 20 21
- Still can't find NSS
- ignition switch problems
- How much can my jeep pull?
- 1998 Grand Cherokee Laredo Neutral Safetly Switch
- What axle is in the front of this jeep?
- Minimum Lift for 32X11.5's?
- can i manually roll up a power window ?
- Cowl area water leak
- '93 cuts off after few minutes at ilde
- Wheels
- 87 cherokee wiper problems
- 98 Grand Cherokee Exterior door panel loose
- 88 Cherokee shook violently then died
- cant get key out of ignition
- Lost 25% of fuel mileage, possible solns?
- Clutch frustration
- 89-drive to reverse sounds
- Getting bolts inside frame rails
- 88 4.0 Cherokee dies out in higher RPM.
- Cruise Control
- 1986 XJ w/ 2.8l V6
- 87 Cherokee A/C
- 87 Cherokee death wobble
- OK, Who needs parts? 91 Cherokee
- heating/AC problem
- 97 cherokee-rear wiper fluid not coming out
- 96 Cherokee clutch pedal question
- is it worth the price?
- engine interchange
- New Power Booster and Master Cylinder, brakes still suck!!! :(
- 90 Cherokee I'd love to kick a few times
- 97 Cherokee problem
- Speaker issue - Drivers Side - 99 Cherokee
- 91 Jeep Cherokee. Feeling really bad!
- vacuum line diagram 88 cherokee
- Transfer Case Socket Size?
- 89 XJ - HELP! Engine is choking...?
- 1986 2.8l V6 won't run--HELP!
- Got new Brake Booster, How to test Master Cylinder?
- 89 Cherokee sport 2 door rocker panels
- 1994 Cherokee electrical problem
- Is this Death Wobble??
- Back firing 6 cylinder
- 88 cherokee won't start or turn over
- Final answer on Jerk and Hesitation!?
- 92 cherokee laredo terrible gas mileage
- Dash Lights
- motor revving high out of control...help!!!
- message consul says "bad coolant sensor"
- 1992 Chrerokee Speedometer and Cruise Problems
- Transmission Slipping
- 89 cherokee stalls turning corners!!
- Grinding sound in 1998 Grand Cherokee
- rearend gear oil recomondations
- For Sale NJ: Smittybilt Modular Nerf Bars (Black) 97-01 XJ
- Static!
- Transmittion Filter Replacement
- 86 Cherokee Acceleration @ low RPM
- 88 Cherokee Overheating badly - out of ideas
- front leaf springs?
- Electrical Problem Where do I start?
- 98 Cherokee won't idle at first.
- 1999 Cherokee - Check Gauges/High Temp Prob
- 1996 Jeep Cherokee Electrical Problem
- Heater Controls
- 94 Cherokee 2wd Transmission noise
- 87 cherokee wont stay running
- Body side mouldings
- 98 wont start after fuel pump install
- ac compressor bearing noise
- 92 Laredo, Battery Causes Engine To Die
- Slow to shift
- Please help find web link
- My 91's Ignition Is Locked - Help!!
- turn signal problem
- front bump stop removal
- I love my cherokee.....but.....
- 1995 Jeep Cherokee Cuts off w/o warning.
- Need power steering pulley
- 1992 Jeep Cherokee battery tray removal please advise!
- Starting Problems 1993 Cherokee
- 88 4.0L no fuel
- 98 Cherokee jerks from bumps
- 1995 jeep gc idle problem
- Starter Selinoid Wiring
- ash tray light
- Vibration
- Throttle Body
- performance parts
- Jeep Cheroke 95 blowing instrument fuses and park lights
- 1991 Jeep Cherokee Laredo Alarm System does not reset-cannot crank
- looking for rear springs
- 91 Cherokee Laredo dies when warm
- A/C odor
- 1991 Jeep Cherokee Fueling Problem!
- battery draining
- Buying a Jeep Plz Help me!
- Heavy Vibrating Noise (Near Dash ?)
- k and n intake system for 1987 cherokee 4.0
- Odb Ii
- No Cat?
- oil pressure problem (89 xj)
- webber carb and vac
- No Spark???
- liftgate compatibility
- Overhead console??
- Door Graphics
- stuck in 4 wheel drive
- Rear Reverse Lights stopped working
- Losing Fuel Pressure
- Spark plugs ...Double Platimun needed or harmful?
- Trans hoses leaking ... repaired for a buck !
- 96 cherokee stalls, sputters, and lost power
- No Headlights!
- Cruise control won't take control
- 93 cherokee wont start
- 1999 Overhead Console
- Electrical problem with 87 Cherokee
- 2000 Jeep cherokee sport
- '89 Cherokee - Spongy pushrods/runs poorly
- A/C Clutch Wiring
- 1993 radiator replacement
- 98 cherokee starting hard
- Overheating
- 92 wipers
- new to the threads
- 1987 cherokee air filter soaked w/ motor oil
- stuck in 4 wd
- 732K Miles ....... !!!! Need HELP !!!!
- Common Reason Why 87 - 92 Cherokee Won't Start
- Trans clunk
- Radiator replacement 97 Cherokee
- Throttle Body Spacers
- AC water in floorboard in of Jeep
- Simota Air Filter Setup... should I buy this?!
- 89 power window
- smoke out the back
- 91 Cherokee Fog Light Malfunction
- Blower motor runs on high speed only
- Transmission Fluid Flash???
- How many miles...
- Front U-jionts
- Cruise Control broken?
- 84 cherokee 2.5L, engine swap?
- 91 Jeep won't start
- Air Conditioning
- A/c
- Blown fuse?!?!?!
- Another water leak!!
- 1990 Cherokee will not turn over
- Fuel pump, or what?!!??!
- Unknown popping (clunk)
- 89 cherokee not starting
- new to forum
- 96 Cherokee stalled and will not start agian
- 89 cherokee- idle hight until i play with gas
- 96 jeep cherokee cranks not starting not the coil!!!
- Speedometer not working
- 94 XJ VERY slow cranking
- Water leaks into rear left panel
- 87 Jeep Cherokee w/ Horrid Jerking over 1500 RPM !?!
- interior lights linked to break light switch problem, any one had this happen
- knocking sound at idle
- Fuel sending unit
- No power to fuel pump
- A/C Problems !!!!!!
- 88 Cherokee Pioneer Help
- wiper problems
- hard steering
- Roller Rockers
- Idle stepper motor
- 89 cherokee - e-brake light on constantly
- 85 Jeep, drains battery overnight.
- 99 cherokee sport fuel gauge and pwr windows
- Cherokee Factory Accessories
- Service manual
- left front grinding noise
- tranny noise
- No power to AC clutch
- Solenoid, starter or ignition
- 92 running hot
- wont start
- How to Gain more HP??
- 96 Cherokee - Cranks, doesn't run...
- My door was falling off!
- Transfer case rebuild
- f150 coils?
- 95 Jeep Cherokee
- She does not blow...
- cps question?
- Major Engine Problems
- 87cherokee electrical problem
- Yet Another Starting Issue
- Do they make one?
- Doesn't accelerate well
- Turn Signal Wiring Problem
- needle valve in throttle body help?
- Upgrade injectors?
- 88 cherokee lack of power
- 1989 Cherokee shifts funny.
- trailer hitch
- HELP!4WDproblems(I think)
- K & N KIT
- Shaking
- I6 4.0 Serp belt squeek. Tried 2 brands.
- Front axle shaft seals
- recommended lift kits
- 89 cherokee hesitation
- loose steering
- Water leaking from floor heat vent 1999 Cherokee
- 1987 jeep cherokee oveheats
- 96 cherokee won't start PLEASE HELP!
- got a problem with my heep
- Move to NAXJA.
- Evaporative Control System
- pinion crush washer change giving me trouble
- 98 is starting sluggishly
- Any tips on refilling "closed" coolant system?
- Takes a while to start
- screaming rear end
- 89 Cherokee Shaking/Vibrating Please Help
- slow battery problem
- 1998 Cherokee electrical
- TPS or CPS?
- Jeep Cherokee Limited 1999
- jeep flooding
- check gauges light
- idle problems with 1997 Cherokee
- clunking in rear cherokee
- water pump
- dash bezel removal in 87 laredo
- How about this one?
- Fuel Pump ? - Cherokee
- high idel
- exhaust manifold
- Air conditioning conversion kits
- 4.0 Litre that knocks. I need your suggestions!!!
- PAINTING ISSUES .. maaco?
- 1994 Cherokee Sport
- swapping gas tank
- Getting off Factory Exhaust
- Change timing gears ?
- Intake for 1990 Cherokee
- Q on leaf spring bolts during lift kit install
- Rough Idle with A/C
- 1987 Jeep Cherokee Won't Turn to Start
- 1987 Jeep Cherokee Win't Turn or Start
- 2001 Cherokee P/s Noises
- Power Steering pump
