Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Jeep
> Cherokee |
View Full Version :
Cherokee
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
Weird noise associated with bumps
2000 JGC HVAC blower resister
99 cherokee steering / turning trouble
88 cherokee starts with HIGH RPM's????????
TGISSEL...question on seat-belts.
LED XJ tail lights
Fuse Diagram!!!
These Cherokee threads are awesome!
Transmission Leak
getting rear bumper off
Problems getting it started
rear door
Replace or rebuild?
HELP! Rear End Clunk after shifting & removing foot from clutch
clutch adjustment
thanks
transmission flush?
WTB: Fuel Injectors for '89 4.0L
Rear Leaf Spring Replacement
blinkers
Leakage problem
Would you buy it?
96 Cherokee Country 4.0 Automatic Ignition problem
regular maintenance
manual shifting noise
Tranny filter replacement question
93 jeep starter problem? ...yes another thread
96 cherokee classic 2wd
To buy or not to buy?value of 91 cherokee sport
'88 Cherokee radio problem
transmissoin fluid replacement
89 auto trans problem
Closed or open??
What fits?!
Has anyone installed air bag helper springs?
problem with my 4X4 transfer case
93 Cherokee tries to stall, but never stalls out completey.
99 cherokee helppp!! (I have dynamite ready)
performance
Speedometer doesn't work
Crazy Starting 91 Cherokee Need Help
Broken power window cable
88 cherokke 4.0 hard to start
Stuck in Part Time 4WD
So about that crushed spot in the exhaust?
Tow hooks
what is the biggest tire i could fit on a 87 cherokee
2000 Cherokee tire size
I need advice on TIRE sizes.
stalling and more, need help for fellow jeeper.
Can you get brake pad spacers...?
'87 Cherokee running problem
Jeep Cherokee Window Fuse
1996 Cherokee se whinning sound during acceleration
1994 Jeep Cherokee Sport Overheating issue
starter or electrical problem??
1990 4.0, transmission "hunts"
More MPG for a Jeep?
NSS overhaul for '88 Cherokee
Theres alot of play in my steering.
Idle vibration
dana 30 Front diff
Clean Catalytic Converter?
"Honk" lock confirmation not sounding?
'93 dead - CPS? Help I am stuck at school on Friday
No inst. pnl. lites (Still)
trouble code
HELP! Cracking sound in front axle!
wants to stall
vibration (not death wobble)
Grinding noise during hard accelaration - 87 4.0L 4x4
hood latch cherokee
Distributor
99 Cherokee Dash Removal Question
Horn Keeps Beeping in 94 Cherokee
suddenly it stalls while driving
Brakes?!
90 cherokee limited 4x4 won't start
clutch or throwout bearing?
Adding rear sholder belts to a pre-91 Cherokee
Tranny Noise ???
87 4.0L Whining / Poor Gas Mileage / Cruse Control
'97 steering stabilizer replacement
93 cherokee parts for sale
Cooling Fan Relay: Location
1992 Cherokee blower motor
Stuck!
XJ Running HOT? Change your Stat!
NSS on a '88?
'88 Jeep radio schematic
95 cherokee 2 wheel conversion to 4x4
Fuel pump sounding noisy on 90 cherokee
90 xj abs pump...
help
1997 Cherokee Electrical Problem
87 4x4 manual transmission how can i tell what model
91 4.0 Too many cranks to start?????
cherokee 2000 engine light on
Splitted tail pipes
Unibody vs Frame
key won't turn
disabling air bags 96 cherokee
Jeep staying idled up
egr testing 88 4.0 cherokee
My XJ hates me... Stalling problems.
1992 Jeep Cherokee LMTD Cruise Control
Preventitive MAintenance?
Best place to buy new front hub assembly for my 99 cherokee??
Jeep shaking badly need advice!
Battery good, but NOTHING at start
Electrical Gauge in red
1990 Jeep 4.0 Run Problem
90 cherokee cold and damp running problem
Service Manual?
obdII failure
94 Temp Gauge
Clutch Master Cylinder
Help, 1994 Cherokee clickins sound and
no dash lights
87 XJ Tranny / T-case noise??
can i have 31's
tranny problem?
Slow start....
No Lights in the Radio
94 Cherekee dies
Book time of wheel cyclinder replacement?
A new problem
89 chrokee limited transmission problems
clicking rear end
Another speedometer problem
Fuse for Tail Light 94 Jeep Cherokee
98 Power Window Connection
No Heat...
4.0 stalls intermittantly, but starts right up
91 cherokee-help jeep bretheren
DEATH WOBBLE 98 cherokee
Transmission Removal
93 JC Sport won't start....
Vacuum Diagram- 89 4.0?
Pop when take off
89 jeep xj problems
Sluggish backfiring cherokee
Pwr Locks and Windows??
1997 Cherokee Key problems
Blue smoke
Accesorie, but no on!!!!
Gas Smell coming from Heater?
ignition starter problem!><! help please
89 electrical problems
'98 coolant temp sending unit
Vibration Need Help
a different overheating problem
question about the radio
2000 Jeep Cherokee 4WD problem
4.0 I6 breather grommet
Cooling mods for a 98. Any ideas?
clutch adjustment?
radio acc wire and hot wire makes dome lights work again hum
4.0 will not shift into drive
Cruise control
Electrical Problem??
Guages, door locks, dome light Just Quit
1988 cherokee shift problems
What is a resonable Labor $$ to change brakes?
Wont start after changing head 4.7
Serpintine Belt
sensors quastions in my cherokee 2000
MaXXing Performance
Better Braking
Noisy @ High Revs
aftermarket coolant sengin unit
driver side power window stuck down
oil pressure gauge question
jeep seats
Steering column loose
92 Cherokee rebuild
Jeep hesitation @ startup
Hard Start and fast Idle?
blower motor not working
front brake question
00' Hazard flasher switch
Tranny Hose Connection
Turn signal / hazards problem
Kits for350 chev in jeep? How? Where? HELP!!!
Check Engine Light
New Jeep owner
95 jeep cherokee sport engine/crank
'90 Cherokee - "The Sky is Falling"
Cherokee 95 engine whine
No Speedo
anyone need radiator for 89?
95 cherokee sport clutch
88 Cherokee Cooling System
Lift-gate lock sbolt?
retro radiator install
My Cherokee 2000 Engine light is on
jeep cherokee 1988
A/C or something?
Power steering squealing whining sound... Please help!!!
87 Cherokee want to get bigger tires but dont know if they will FIT
1993 Jeep Cherokee No Start
2001 Jeep Cherokee Sport
93 jeep Out of Blinker fluid
Ballast resistor
1995 jeep overheats
'98 XJ w/possible clutch problems?!?!
Odd electrical problem
blinkers 99 cherokee
wiring problem? window problem?
Up Country Package Question
Bad idle and whining fuel pump
Shocks and Rubber bumper (rear)
Engine smokes after 30 mins
HELP PLEASE> loud knocking from engine
1996 Cherokee stalls after 20 min.
cherokee 1990 fuel pumpm relay
clunk clunk noise when driving
HELP Installing a Distributor/Engine Rotated
91 Cherokee ABS problem after replacing rotors & pads
96 sport starting problem
88 cherokee> knocking from the engine
Selling 89 cherokee - New York
'85 cherokee pioneer/4x4 indicator light stays on...
Fitting jeep engines
were to buy to cherokee engines
2000 Cherokee Sport Trailer Lights not working
Loose Steering
Car acting funny...please help!
93 cherokee engine swap
Antenna motor
no power to power windows and power seats
People in the Miami fl area
Huge dent...need body work
Anti-theft system 93 problems
rear brakes stick
2000 Cherokee Power Window Problems
1992 4.0 HO issues
cherokee 89 code readings
89 jeep cherokee won't start of course
Keyless Remote Entry - Panic Button - 99 Cherokee
Random Problems
'97 Jeep SERIOUS Electrical Probs
99 Cherokee engine light P1494
Spark knock
Over Heating
'90 Cherokee -- Low Rider
Window Washer Problem
'90 Cherokee front axle leak
Falling Flat 91 4.0 liter Laredo
Web
AF
