Jeep
> Cherokee
View Full Version :
Cherokee
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
liftgate won't open...
lower ball joint grease fitting
95 cherokee trans/tranfer swap with 98
Difference between 99 and 00 and 01 engines
Engine Removal With T-case?
VIN definitions
Fouled Plugs
electric fan override
head lights won't turn on
87 Cherokee braking problems
Replacing alternator 92 cherokee
Need Advice!
fuel filter location 91 jeep cherokee
1990 jeep cherokee limited specs?
Factory Service Manuals (fsm)
no pressure in clutch pedal
About neutral safety switch
92 cherokee stalling problem
1988 jeep pionner parting out
No compression in 1 cylinder
lights
Vaccum diagram and "part time"
89 Cherokee no fuel.
Anyone Needs These?
jeep 4.0 engine parts
My jeep is leaking water whenever it rains!!!
front axel (left side) leaking diff. oil
tail,parking,and intrument pannel lights
Reverse Lights not working on 1996 Cherokee Country
2000 Cherokee Sport won't start
Intermintent Overheating
4x4 and fuel gauge problem
Flat or Roller Lifters on a 2000 4.0?
No Power to Ingnition switch
Rear Wiper Question
cherokee + turbo = whp?
93 cherokee low spark
problem with ignition/transmission?
tranny fluid change?
Cherokee Sport Hesitating
Freeze plugs?
clicking valves?
Tire size and rim question
convert command trac to selec tracl??
not enough heat
rough idle
Will it fit?
head light problem
stalls on left turns????
$120. good price?(rear shocks/mounting)
a/c and electric issue
1989 cherokee no spark?
MY 1990 quit while cruising on the highway
changing oils
factory stereo
Injectors question
2000 Cherokee Sport fan switch
front axels
94 stereo wiring problem
intermittant wipers
94 jeep grand cheokee ran out of gas
1989 Jeep Cherokee won't start
FS: 1990 Lifted XJ - South Jersey
Stalling jeep!
Help,4x4 is making a clicking noise
89 cherokee won't stay running!
Lift kits- what do I need?
Hitch Needed 1989 Cherokee Pioneer 4X4
Front Differential
Difference between '00 and '01 XJ
steering wheel picture
New Rocker Panels
Check Engine Light on
1990 Jeep Cherokee 4.0 5-speed SOMETIMES won’t start.
steering bump
throttle body vs multiport
tire size differences?
Need Vaccum Diagram
lifted, coils on front still compressed?
Tow hitch
Forum questions
1994 Transfer Case Shift Sequence
89 Cherokee Not Starting
for the woodys
1989 Emmiss Maint Light @ 50K
right rear power window won't go up
Knocking Lifter
fog light install
86 Cherokee
Coolant Block Drain Plug
valve cover gasket
Blown Engine?
2001 XJ Service Manual?
Part-time light on, but no 4WD...removed
AutoTransmission Fluid Change 1989 4.0L
1998 rear hatch lock Jeep Cherokee Sport
Pulling my hair out
Computer Chip in Keys
can I use 6 1/2 speaker
HELP Wiring Diagram for Cherokee 97 TD sport 2,5
$$... is it going to cost alot?
synthetic oil
Special Edition??
parts
2 or 3 inch lift?
does motor need to be rebuilt
Rear Wiper Bezel removal
power windows problem...
Cherokee Country Bearings
Exhaust manifold replacement
How to recognize command trac from select trac?
my heat is broken and im really cold
Emission light stays on...UGGHHH!!
Is it possible to clean my injectors?
Selling my 86' XJ
1999 Jeep Cherokee Gas Gauge Stopped Working
need help on water pump
Factory Jeep Tech-service manual; 2 books 1990
"Dying turkey" sound in 01' Limited engine
CPS questions
just bought 93 Cherokee
Brake line screw rusted into wheel cylinder
1996 jeep cherokee wont start
1990 jeep cherokee limited making humming noise
4wd
Stalled 1998
Cherokee Freedom edition????
Transmission Fluid Leak
Selling XJ
need help... Front Hub assemblies and U-joints
4x4 Not Getting To Axel
problem starting 93 cherokee sport
Problems Starting 90 Cherokee
No accessories in run position
manual lockers
4x4 won't engage
cherokee radio
Can I exchange my Cherokee Country 4.0 liter engine w 96 4.0 liter grand cherokee eng
87 cherokee , 3 water pumps blown in 2 months???
Rough Country 3in
My Jeep died help me please
Missing - gas shortage when at cruise
T-case fluid blues
front drive shaft
Electric choke
97 Cherokee starts then wont start
Transmission Issues
Cherokee 4.0L Misfiring and Decarbonizing
transfercase
4.0 idle issue
Problema Starting jeep GC
possesed and squeeky electric fan
colling
15X8 on a stock cherokee
85 xj running issues
front drive shaft
were is my horn ? limited 89
Ohms for CPS
stalled 1989
4wd problems
Shocks?
1986 Cherokee Laredo Doors Won't Lock
abs brakes to manual
3 or 4.5 lift kit and what is involved with putting on on
Power Window switch module removal 97XJ
99 Jeep Cherokee Stalling
1990 Cherokee ABS: No pedal pressure
3 inch lift
Oil Smells
Oil filter housing
1999 Main Rear Engine seal leaking??
fuel injector?
AW4 Trans?
clutch fluid loss
Idling issues
engine vibration(im a newbie)
voltage problems
96 Cherokee sqeaking after oil change
Command trac vs select trac
Ignition cherokee sport 97
vacuum lines?
Where to find '98 Cherokee sport console latch
how to remove stereo?
trans oil
99 Cherokee Sport Rear Defrost Not Working
Turn signals
Trans Flush
trans oil
blower motor??
Reverse gear blown?
jeep cherokee sport guages
Cherokee Tranny
Unidentifiable knocking
Jeep XD
88 Cherokee Mirror fuse location
3 or 4" lift
new owner- 86 wiring and parts questions
lifter noise
Average Lifespan of a Jeep xj
Electric door locks--no unlocking?
service engine soon light on 88 cherokee
spark plug wires
fuse diagram
1997 jeep master cyl on ebay
1989 shuts off when i brake
Jeep Running TOO Cold
Gauge Cluster Replacement
89 Pioneer for 91 Briarwood?
Why no K&N kits for 00 and 01's
Rear Main Seal 96 Ch. Sport
1995 Jeep Cherokee
Shake in slow hard turns
Comanche - Exhaust
99 Jeep; clunk felt and herd under initial load from stop to start.
Blower motor and high oil pressure problem
Two Nitpicks
'89 Cherokee aux. fan relay location?
Need help identifying this lift!
How much of the dash HAS to come out to get to the heater core?
1999 Chrokee Sport stalling when cold
1997 cherokee radio wiring Help !!!
Window and lock problems
Air Time...
Bang noise when in 4x4
Why?
heating problem
94 Grand Cherokee no 4x4
Whats this box?
elec door locks
Turning when 4+4 is engaged?
Hesitation Issues
Need tow hooks
windows
Bled the clutch
1991 cherokee limited power Seat wiring
need help with 1999 cherokee sport
cherokee laredo
Replacing parts for a 6' lift and tires
2000 Jeep Cherokee Stalling Problem
Lightswitch Install??
Gas Mileage story
clutch-problem shifting
Overheating '92 XJ
factory suspension upgrade
radiator
'92 2WD Rear End
Help! My Jeep Is Moaning!
Total loss, what next?
New motor - no oil pressure!?!?!?!?!
Oil on the air filter.........Whaa???
