View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21
  1. need help... Front Hub assemblies and U-joints
  2. 4x4 Not Getting To Axel
  3. problem starting 93 cherokee sport
  4. Problems Starting 90 Cherokee
  5. No accessories in run position
  6. manual lockers
  7. 4x4 won't engage
  8. cherokee radio
  9. Can I exchange my Cherokee Country 4.0 liter engine w 96 4.0 liter grand cherokee eng
  10. 87 cherokee , 3 water pumps blown in 2 months???
  11. Rough Country 3in
  12. My Jeep died help me please
  13. Missing - gas shortage when at cruise
  14. T-case fluid blues
  15. front drive shaft
  16. Electric choke
  17. 97 Cherokee starts then wont start
  18. Transmission Issues
  19. Cherokee 4.0L Misfiring and Decarbonizing
  20. transfercase
  21. 4.0 idle issue
  22. Problema Starting jeep GC
  23. possesed and squeeky electric fan
  24. colling
  25. 15X8 on a stock cherokee
  26. 85 xj running issues
  27. front drive shaft
  28. were is my horn ? limited 89
  29. Ohms for CPS
  30. stalled 1989
  31. 4wd problems
  32. Shocks?
  33. 1986 Cherokee Laredo Doors Won't Lock
  34. abs brakes to manual
  35. 3 or 4.5 lift kit and what is involved with putting on on
  36. Power Window switch module removal 97XJ
  37. 99 Jeep Cherokee Stalling
  38. 1990 Cherokee ABS: No pedal pressure
  39. 3 inch lift
  40. Oil Smells
  41. Oil filter housing
  42. 1999 Main Rear Engine seal leaking??
  43. fuel injector?
  44. AW4 Trans?
  45. clutch fluid loss
  46. Idling issues
  47. engine vibration(im a newbie)
  48. voltage problems
  49. 96 Cherokee sqeaking after oil change
  50. Command trac vs select trac
  51. Ignition cherokee sport 97
  52. vacuum lines?
  53. Where to find '98 Cherokee sport console latch
  54. how to remove stereo?
  55. trans oil
  56. 99 Cherokee Sport Rear Defrost Not Working
  57. Turn signals
  58. Trans Flush
  59. trans oil
  60. blower motor??
  61. Reverse gear blown?
  62. jeep cherokee sport guages
  63. Cherokee Tranny
  64. Unidentifiable knocking
  65. Jeep XD
  66. 88 Cherokee Mirror fuse location
  67. 3 or 4" lift
  68. new owner- 86 wiring and parts questions
  69. lifter noise
  70. Average Lifespan of a Jeep xj
  71. Electric door locks--no unlocking?
  72. service engine soon light on 88 cherokee
  73. spark plug wires
  74. fuse diagram
  75. 1997 jeep master cyl on ebay
  76. 1989 shuts off when i brake
  77. Jeep Running TOO Cold
  78. Gauge Cluster Replacement
  79. 89 Pioneer for 91 Briarwood?
  80. Why no K&N kits for 00 and 01's
  81. Rear Main Seal 96 Ch. Sport
  82. 1995 Jeep Cherokee
  83. Shake in slow hard turns
  84. Comanche - Exhaust
  85. 99 Jeep; clunk felt and herd under initial load from stop to start.
  86. Blower motor and high oil pressure problem
  87. Two Nitpicks
  88. '89 Cherokee aux. fan relay location?
  89. Need help identifying this lift!
  90. How much of the dash HAS to come out to get to the heater core?
  91. 1999 Chrokee Sport stalling when cold
  92. 1997 cherokee radio wiring Help !!!
  93. Window and lock problems
  94. Air Time...
  95. Bang noise when in 4x4
  96. Why?
  97. heating problem
  98. 94 Grand Cherokee no 4x4
  99. Whats this box?
  100. elec door locks
  101. Turning when 4+4 is engaged?
  102. Hesitation Issues
  103. Need tow hooks
  104. windows
  105. Bled the clutch
  106. 1991 cherokee limited power Seat wiring
  107. need help with 1999 cherokee sport
  108. cherokee laredo
  109. Replacing parts for a 6' lift and tires
  110. 2000 Jeep Cherokee Stalling Problem
  111. Lightswitch Install??
  112. Gas Mileage story
  113. clutch-problem shifting
  114. Overheating '92 XJ
  115. factory suspension upgrade
  116. radiator
  117. '92 2WD Rear End
  118. Help! My Jeep Is Moaning!
  119. Total loss, what next?
  120. New motor - no oil pressure!?!?!?!?!
  121. Oil on the air filter.........Whaa???
  122. 4x4 and Starting Problem-90 Laredo
  123. Whinning noise normal
  124. valve train noise
  125. oil presure gauge went crazy
  126. jeep service manual
  127. transmission
  128. wiper fuse location...91 cherokee ltd
  129. Clunking along in 4x4
  130. 2" Lift on '92 2WD
  131. Reprograming remote for 2000 Jeep Cherokee
  132. 99 Cherokee rear end knocks when stopping
  133. charging problem
  134. were can i find a used 6cl?
  135. 1991 jeep cherokee laredo
  136. '96 Cherokee, no blinkers or brake lights
  137. wiring diagram
  138. 2000 cherokee #4 misfire
  139. Jeep Cherokee RHD 1999 running rough on mail route
  140. 96 Jeep Stops taking gas around 3000RPMS
  141. Camshaft
  142. Jeep Cranks but won't Start
  143. Electrical problem / alarm won't turn off
  144. 91 Jeep Cherokee; Random Stalling, Please Help
  145. erratic wiper behavior
  146. Where to buy molding gards
  147. New Jeep Owner
  148. 92 Cherokee NSS
  149. '96 Cherokee. No fuel at rail...
  150. 2000 cherokee #4 misfire
  151. 96 jeep cherokee sport NSS
  152. Length of shocks...Thinking air shocks
  153. 99 Cherokee Strange issue!
  154. no start 1996 chrokee sport
  155. Cherokee Sport: 2X to 4X?
  156. 4 wheel drive in snow
  157. 88 cherokee chief Emis/Maint light
  158. 89 Rear Wiper Replacement
  159. Gas Gauge Reads Backwards
  160. ODD electrical problem with 89 'cherokee laredo
  161. Tires for 3" Lift
  162. 1986 Cherokee stalling
  163. rear end trouble ? (Have 3 days to return)
  164. 95 cherokee starting problems
  165. Cherokee brake extention cables
  166. 89 Jeep Cherokee Wont Start
  167. 86 Cherokee Laredo
  168. Jeep Brake Cable Extension
  169. dash lights, i cant see at night
  170. 89 Cherokee 4x4 won't engage
  171. 1992 Cherokee Sport - Hard starting
  172. no heat / over heating
  173. Synthetic Oil ?
  174. Help!!!!! 99 Cherokee won't start
  175. 93 jeep cherokee has problem with stalling
  176. Simple mods made to your jeep ?
  177. Cherokee Lift
  178. Tire Talk
  179. 88 Cherokee clutch?
  180. overdrive.....interesting ride
  181. 99 Cherokee Rear Wiper Motor Replacement
  182. 97 cherokee start/stall fuel filter question
  183. 90 cherokee blows lukewarm air from heater
  184. 92 laredo clutch problems
  185. Faulty spark plug wires hurt computer?
  186. Drum
  187. cherokee starts then dies
  188. How can I test/bypass my NSS switch
  189. What Kind Of Axle??
  190. power windows aftermarket
  191. "Part Time" Dash Light
  192. 93 cherokee heater fan
  193. Cherry red exhaust, still not good
  194. airbag light
  195. 2 batteries, new alternator.... still dying
  196. Help!!! Radiator fluid in floor.....99 Chief 2.5
  197. Stock Roof Rack
  198. 99 Cherokee heater fan switch
  199. Vaccum Trouble +
  200. Air conditioning
  201. Where is the Neutral Safety Switch?
  202. Idoling Probs For 90' Cherokee
  203. Fuse Diagram Needed
  204. Fuel system?? Help
  205. 89 Cherokee "Part time" 4WD?
  206. 2000 Cherokee wiper motor installation
  207. 95 xj remote start installation problem
  208. 93 4.0 - Gas on Intake - Help!
  209. what to do when changing out infiniti speakers
  210. jeep factor stero wiring
  211. Mystery Wiring ??
  212. several problems 94 GC LTD. Keyless,antenna and cruise.
  213. air bag light stays on on instrument panel
  214. Cruise Control Vaccum Tank
  215. 80 cherokee trans fluid pouring out ?
  216. Jeep Cherokee 89' Turns Over but dies, eventually starts and dies while driving.
  217. 96 jeep labors at start
  218. Power steering
  219. Mystery Vibration on Cold Engine
  220. Roof Rack?
  221. noise when front left wheel fully turned?
  222. Starter
  223. Replacing a left front axle U joint
  224. 99 cherokee 4x4 electrical
  225. Fuel Injector Upgrades?
  226. Radiator for conversion
  227. loud ticking sound
  228. when can i use 4WD Hi
  229. 1994 fsm
  230. 94' cherokee transfer case
  231. Installing 242 Transfer Case '88 Cherk 6cyl
  232. every week i have to add fluid
  233. Cherry-red exhaust
  234. Help I've got a 4WD problem
  235. Problems with Jeep cherokee-someone help!
  236. Need Help Plz Cherokee starts and then OFF
  237. Serious problem!!!! Electrical !!!! 92 cherokee. got nothing
  238. Vacum prob keeps car from running
  239. 1990 Cherokee: Mystery stalling
  240. Front suspension clunking
  241. 95 xj sport tranny problems
  242. blower makes whirling screeching sound?
  243. would like to be able to post attachments
  244. 93 Cherokee with oil/transmission troubles (first post ever)
  245. Ignition Timing
  246. Rattle-Rattle and a cloud of smoke!
  247. Newbie with newly acquired 92 Cherokee
  248. free mods
  249. Map sensor i think HELP!
  250. Power Windows, Radio go out...................
