View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21
  1. M/T wheels...help please!
  2. Stereo Help
  3. 90 Wagoneer overheating
  4. 88 cherokee stuck in 2nd gear
  5. compass,temp display
  6. changed clutch pedal
  7. Parts
  8. Noob Question Time Again
  9. OEM Radio Wiring Info
  10. New Jeep Or New engine?
  11. antifreeze smell
  12. Interchangable jeep manual/book ?
  13. Jeep Cherokee Mk 1 Skid Plates
  14. better MPG and mods what next?
  15. Idle Problem
  16. front axle!?!
  17. 98 Grand v8 front springs on 89 Cherokee
  18. 93 jeep cherokee overheats
  19. 89 Jeep Cherokee
  20. Cherokee Headlight problems
  21. 1992 Cherokee Limited Overhead Console problem
  22. 86 Cherokee Engine ??
  23. FS: 36" Spare Tires
  24. FS: 36" Spare Tires
  25. Engine Knocking at idle when cold
  26. Two Cherokees
  27. 88 Cherokee Brake booster
  28. Help! Left Key On all day - Now No Spark
  29. What else do I need ?
  30. 1995 Jeep Cherokee towing capacity
  31. Sensors different for different dash clusters?
  32. sorry 4 double post
  33. What would u do????
  34. What would u do?????
  35. 89 Cherokee 4.0 Fuel rail leak ...
  36. please I need owners manual cherokee 99
  37. Transfer case drops out of gear
  38. engine swap
  39. a/c controls help in cherokee 99
  40. Caster - Camber Adjustment / Ball Joint Replacement
  41. Audio problem ??
  42. 1985 cherokee engine swap???
  43. Jumping NEedles
  44. over heating jeep
  45. 1995 Cherokee Country quit while going down the highway.
  46. what switch and where?
  47. 87 Cherokee won't start
  48. #2 misfire
  49. helping a friend
  50. Sagging headliner
  51. '95 cherokee won't start
  52. radio trouble!
  53. Lifters replaced, still strong clicking noise
  54. 1998 4.0L wants to die on freeway
  55. A Scary Night in Northern Idaho...
  56. exhuast help
  57. is oil pressure ok??
  58. '94 Tranny/clutch probs - need suggestions
  59. return spring 88 Cherokee
  60. Blower motor location? 01 cherokee
  61. brake grinding noise
  62. adding more lift
  63. Front Left Speaker No Working
  64. Turn signal lever replacement
  65. new tire carrier on back door?
  66. when installing injectors
  67. A/C Compressor not cycling ??
  68. Water in blow by tube
  69. bushwacker flares
  70. Skipping, stalling, OBDII 45, or P0705. clean you NSS
  71. horn not working wan to rewire it
  72. Keys
  73. loud noise coming from driver side door
  74. 93 jeep keyless reciever
  75. Best Shocks?
  76. self tooting horn
  77. Top speed in 4H
  78. Rubbing noise
  79. 88 cherokee won't start (sometimes)
  80. main seal leaking
  81. Wet carpet and Towing
  82. Fender Flare Hardware
  83. Locking gas cap or door?
  84. Blue Vacuum
  85. 2000 Cherokee / Blown Head Gasket !
  86. fuel filter(s)?
  87. a/c issue
  88. gauges/interior lights dont work
  89. Cherokee Performance Upgrades
  90. yet another starting problem - 1996 4.0
  91. window lock on 2000 cherokee
  92. 2000 jeep cherokee 4.0L
  93. 1998 Cherokee Gas Gauge shows empty
  94. Are HO engines better?
  95. rear ends
  96. speaker size
  97. need tc help
  98. 86 Cherokee 2.8L tranny probs
  99. Up Country suspention
  100. 96 Grand Cherokee motor, into a 1989?!?
  101. Rear Locker Question
  102. Fender Flare change reasons from pre97 to newer
  103. clutch pedal diagram
  104. clutch pedal
  105. 88 closed cooloing system question
  106. Tempature Sensor/Dash Gauge
  107. Please Help with headlights
  108. 89 cherokee blinkers, clock, & dome lights all stopped working???
  109. ???? 2.5 liter to 4.3 liter engine swap ????
  110. need help fast
  111. A/C troubleshooting
  112. long cranking before start
  113. acceleration problem???
  114. Can anyone tell me where the Reverse light switch is
  115. Seprentine Belt Squeaks with A/C On
  116. gearing after lifted jeep
  117. Car Show In Ct
  118. stalling and starting issues with 89 Cherokee
  119. clunk/bump in suspension?
  120. Vacuum line location
  121. I saw something horrible today
  122. Location of Backup Switch
  123. trans slipping
  124. 1989 Jeep Cherokee Laredo - Door Locks
  125. Power steering leak
  126. Cherokee 2 Door... Rare?
  127. Auxiliary fan vibration '01 XJ
  128. 1997 Jeep Grand Cherokee Engine Stalling
  129. dual fuel....
  130. different lift kits...
  131. 1995 Jeep Cherokee sport
  132. vacuum canister?
  133. Radiator problem?
  134. Fuel Pump fuse
  135. 6.5" or 8" Rock Krawler Severe Duty Lift
  136. No more oil leak?
  137. 1999 Cherokee overheating?
  138. air bags available for 92 Cherokee Sport?
  139. '92 with Death Wobble
  140. Engine fell
  141. How to get better gas mileage?
  142. Put a 2" lift now i have a problem
  143. Squeaky Clutch
  144. 90 Cherokee wiper blades
  145. 00 Cherokee vs 05 Grand Cherokee
  146. 88 Cherokee Clutch Slave
  147. which lift kit
  148. Brake lines after lift kit
  149. 98 Classic Cherokee w/ Transmission Issues
  150. Stalling Solved - May Can Help You
  151. Cherokee 88 4.0,radiator Replacement
  152. window electric regulator
  153. FS: nice seats!
  154. 1996 Jeep Ch/Sport 6 Cyl, Replace Computer?
  155. 2000 cherokee center console removal
  156. Clunking
  157. Degreased 4.0, now tranny not engaging past 2nd
  158. Put a diaper on it
  159. death woble
  160. Sunday is lift kit day... Hints & Tips???
  161. 92 Power Steering
  162. no charge getting to battery
  163. '94 Cherokee TCM problem?
  164. high beam dont go on
  165. having jeep problem and need help
  166. Scramblers
  167. A day at the dealership or Cherokee vs Wrangler
  168. 93 Cherokee Sport tranny fluid line - HELP please
  169. Quick question about fuse box
  170. dyno max cat back ordering
  171. 2001 Cherokee Sport MIL Light On
  172. Tires in the desert
  173. Classified Forum?
  174. 94 cherokee stalls
  175. carb/intake question...
  176. temperature gauge fluctuating
  177. Airbag light and dash gauges
  178. need info 89 Cherokee Ltd.
  179. 94 Cherokee Headlight
  180. 94 Cherokee Headlight
  181. 2006 Jeep Cherokee
  182. thanx for the info
  183. spark plug help
  184. Problem with 4 low 98 cherokee
  185. oil pressure
  186. Cherokee dies
  187. Plastic Surgery
  188. Foglights
  189. 86 Jeep Cherokee wont crank
  190. '98 Classic 4.0 Stalls when turning
  191. Fuel sending Unit?
  192. piston slap?? please explain
  193. idle, stalling problems 2000 cherokee
  194. Over heating
  195. Cycling A/C compressor
  196. Leaking Oil
  197. What Brand of Spark Plugs?
  198. auction possibility
  199. Continued Problems! 1990 Cherokee LTD 4.0L
  200. 86 Jeep v6 (2.8)
  201. Slave Cylinder/Clutch Return Cylinder Problem
  202. Tranny problem
  203. jeep flag
  204. 1990 jeep laredo wont even click !
  205. Help! 1997 Cherokee 4.0L
  206. BFG MT's or Goodyear MT/R's
  207. When do you upgrade the Altenator???
  208. 87-90 A/C Relay Location
  209. 89 cherokee problems
  210. Power door locks and windows
  211. Dome lights stay on - drains battery
  212. engine
  213. 88 cherokee starting/stalling problem
  214. broken bolts/ Lug nuts
  215. leaky slave unit
  216. 97 cherokee, ALTERNATOR????
  217. Desert runner
  218. Lifting My Jeep
  219. Patience dear, patience. Cherokee still hates me...
  220. 86 Cherokee engine Vibration
  221. FOR SALE: 90 XJ in new jersey
  222. Morning Drive
  223. daylight module cherokee 91
  224. lift gate lock
  225. High rev when starting
  226. no headlights
  227. SALE; 1990 Factory TSM 2 book-set.
  228. Distributor Cap And Rotor Kit
  229. 89 cherokee hesitation problems
  230. what transmission do I have?
  231. neutral safety switch - help!
  232. Trottle Body adjustment - 1989
  233. 1991 Cherokee Lardeo Questions
  234. Roof Racks
  235. Steering shock question
  236. Brake problems
  237. Rear Brake Rebuild..
  238. 2000 Cherokee Stalls
  239. 1992 Cherokee bounces all over the road
  240. Tire Bump When Turning
  241. 88 Cherokee HVAC Lights
  242. Wet air filter
  243. What is this sensor?
  244. Fuel Injectors...
  245. general maitenance
  246. Instrument lights blink with turn signal/electrical problems
  247. 99 cherokee starting problem, stalling, no idle !!!!
  248. brake lights don't work
  249. 89 Cherokee starting problem
  250. Strange Coolant Loss - 2000 Cherokee
