View Full Version : Cherokee
Pages :
1 2 3 4 5 6 7 8 9 10 [ 11]
12 13 14 15 16 17 18 19 20 21
- 2.8L spewing oil
- Front Door Hinge---Pin worn out
- lost keys
- running rough 97 cherokee
- Fuel Smell/Leak - 95 Cherokee
- Install power lock on rear door
- 87 grand am se 3L starter problem? maybe?
- Now THAT's a Full Size Jeep!
- Jeep just dies!?!?
- Information needed on the two fans 1999 JGC
- 98 cherokee starting problems
- Front end noise
- 01 Cherokee Sport feedback please
- 92 4.0L Overheating like crazy
- 4WD high and low problems
- 89 cherokee dash and tail lights
- Crankshaft or Bearing noise?
- Fault Code
- Exhaust Headers
- Instrumental Cluster conversion
- Power windows and lock problem 97 Cherokee
- Even the dealer mechanics are puzzled
- 99 Cherokee "no bus" Error
- jeep problems again
- Cherokee no start
- Door Lock Stuck in Unlock Position
- power window help 99 cherokee
- Thermostat and hard starting
- Overhead Console Help
- Radiator Drain Plues
- 95 jeep won't start
- 2000 cherokee fan control
- electronic control module??
- engine knock
- 97 Jeep Cherokee Grand
- 89 cherokee with fan clutch
- Pt 4wd
- higher ratio rockers?
- fuse locations
- Help!!! Noise from rear!!!!
- Throttle Position Sensor - '92 4.0L 6 Cyl Auto Trans
- 87 Cherokee - air in radiator
- Spare parts available
- Tranny revs high
- Steering--won't go back to center
- blower motor
- 1986 Jeep Cherokee
- Engine miss at operating speed
- grinding brakes
- 1999 XJ Wheels (Compatibility?)
- Parting With '92 XJ
- xj problems
- 2000 Jeep Cherokee Sport - Engine Noise
- Ignition Switch, 88 & 89 Cherokees
- no fuse diagram for 2000 jepp cherokee classic
- Front hubs not disengaging?
- won't shift
- Violent shake from front end!!!!
- Headlamp
- Installing Shocks on 99 Cherokee Sport
- stuck power window
- Engine Problems in a 2001
- R12/R134 conversion
- 1996 Cherokee Sport for sale
- lift for an 89
- Fuel and starting problem
- A/C blows hot air only??
- Bleeder valve for 1991 Cherokee
- Ive got a coolant leak!
- 95 Jgc
- yet another A/C problem (with good reason)
- 1995 Cherokee fuse diagram
- 1994 Cherokee Country keeps blowing fuse #2
- Shock removal and air hammer
- check engine light
- AC problems
- won't start sometimes
- high oil pressure
- Trans/Power switch
- 89 cherokee won't crank
- 88 Cherokee Blower
- Turning the steering wheel = Noisy problems...
- oil in air filter fix
- exhaust/lift
- ac blows out of defrost only
- 96 Cherokee Won't Start
- Wing windows
- Coolant leak...1990 ???
- leaf springs
- headlights won't turn off
- Now THIS is an A/C problem
- Drivers door problem
- Experienced the Death Wobble this morning!
- A\c Works For 30 Mins
- Ignition locked up.
- 2.8l 2.5l question
- Motor Broke - Fix, Replace, or Dump Car?
- 2.8l cruising speed question
- remove key lock cylinder 92 charokee
- Transmission Issues
- Front end noise
- 89 Jeep Help
- Shocks for 93 Cherokee
- Jeep died while I was away ???
- Power Windows no stopping
- Cherokee A/C leak
- AEV 570 Hemi Jeep
- Looking for information
- '97 Cherokee Question
- cant locate radiator drainplug on my cherokee
- A cheap lift for '89 Cherokee
- brakes
- Fan Clutch/Running Hot
- Another tailgate question...
- installing window channel on 91 cherokee
- Tire size question
- Tailgate Latch Won't Open
- Emissions vs grade of gas ?
- High gas pressure!!! Please help!!
- high idle
- Electric Mayhem
- Adding louvers
- Air conditioning blows!!!
- Wife's 1992 Cherokee 4.0L Just Quits - Help!
- what differential
- NOX of luck
- Cherokee Manifold replacment Part II
- battery getting weaker
- Dumped wifes jeep in mud hole
- 1991 Cherokee over heating!
- 1988 jeep cherokee laredo
- trans line issue.
- jeep tranny not shifting
- 31's, Stock Lift?
- 2.8L Needs More Power!!!
- 94 Cherokee Sport Temp Gauge
- 87 xj needs man. trani fluid change?!?!?!
- engine light on
- Draining coolant system in a 98 Cherokee
- Please Help. Refilling A/C with R-134a 94 Jeep Cherokee Country
- how to reset the ecu?
- '95 Cerokee won't start!!!
- Electric Fan
- 1991 Cherokee Rotor Disc Removal
- 89 cherokee with issues...
- 1991 Cherokee won't start???
- '01 Spark Plug Replacement?
- Fuses and what they protect?
- A/C Hi-pressure sensor?
- A/C freon level
- a\c Clutch/ Low pressure switch
- Removing venture?
- What I did this weekend
- window replacement
- 96 xj how can i make it run cooler?
- 97 Cherokee A/C fault
- Loss of Power on hills
- fuel filter and spark plugs
- Electric Fan '92 XJ
- Brake Shoe size?
- clacking noise in engine
- Clutch
- 1999 Cherokee Needs Air Freshening
- air conditioner not blowing cool air
- 1988 jeep 2.5l and 2.8l questions 1988
- better gas mileage?!?!?
- Coolant leak!
- want to buy 1990 jeep, what to look out for?
- blower motor
- burn't piston
- Electric Fan motor
- power window motor
- Speedometer
- wont start checkin for spark, etc
- swaping a jeep engine
- 1996 Cherokee Sport keyless remote wiring
- 00' Cherokee - Rear lights, dash lights, clock light out, brake light works
- crazy shake
- Black ball thingy
- What are the chances of a rock busting out the headlight?
- Manuel to Auto tranny?
- HELP! She's broke!
- 01 cherokee a/c problem
- 1999 Cherokee Sport long cold start
- Power Windows and Power Locks problem...
- Strange overheating
- Wheel bearings-97 Cheerokee
- Eletric problem with my '96 cherokee
- 93 Cherokee- Replacing Rocker Panels ?
- a/c clutch doesn't engage when hot
- 86 2.5 oil leak
- thinking about buying a jeep
- 96 cherokee sport radio wiring
- durabanks coating
- shifting problem
- 90 cherokee makes beep noise
- rear end noise
- Parts swap?
- power steering fluid
- 92 sport a/c/ compressor problems
- 86 cherokee major problems
- V-8 Swap
- No power going to the coil, can I jump it to the battery??
- Tranny Flush??? Yes or no.
- Squealing front console - arrrggghhh!
- steering question
- 88 cherokee stalls a lot
- 95 cherokee keyless entry remotes?
- Odd Electrical Problem
- wasting away 15x6 steel whls (8) $32
- wrong side?
- idle prob?
- 90 cherokee stuck in 4wd
- '88 XJ...no wipers
- 87 cherokee power mirror wiring diagram?
- Marvel Mystrey Oil
- wiring diagram for a jeep cherokee laradeo 4x4 for the radio
- Ah...no start and complete dying '01 XJ
- A/C Heater Vents
- A/C Heater Vents
- 1990 Cherokee,need help identifying relays
- 90' XJ want stay running/stalls in park
- Synthetic Oil qiestion
- How to test the power window motor?
- bad oil leak (not rear main seal)
- 97 jeep cherokee questions
- 90 Cherokee Dead!
- 96 jeep has no fire to the distributor or coil HELP
- 96 Cherokee 6 cyl Starts and Dies
- O-ring seals on oil-filter assembly
- 98 Fuel Intake/Stalling issues . . .
- 1992 Cherokee Laredo - Auxilary Fan Keeps Blowing Fuse
- No a/c at operating temperature
- 96 crank no start
- removable doors
- Remote Entry for 98 Jeep
- High RPM at 60mph. HELP!
- 94 Cherokee heater valve? Can I bypass it?
- right side power windows
- Newbie ? about engine swap.
- Where to get new flares.
- Gauges just died in 2000 Cherokee
- Front Speaker Wire colors?
- Can someone help me with this turn signal issue??
- engine misfire?
- Rear "rumble" type noise when stopped in DRIVE
- Wheel Paint
- Radiator Drain
