View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21
  1. 1993 Jeep Cherokee Speedometer and Gas gauge out!
  2. 89 blowing black smoke, idling rough, etc
  3. 1998 Cherokee problems
  4. Stubborn Rear Main Seal
  5. Intake manifold swap
  6. I'm thinking timing belt . . .
  7. 89 comanche starts but won't run
  8. Rear "rumble" type noise when stopped in DRIVE |
  9. air intake system on 98 sport
  10. 94 jeep Cherokee SE Lo Beam Problems
  11. car won't idle
  12. blinkers not working
  13. keyless entry conversion??
  14. If you were to lift your XJ 3" what would you buy?
  15. buying 1990 cherokee
  16. 94 sport won't start
  17. ignition lock
  18. buying a cherokee
  19. Smells like gas?
  20. 2000 Cherokee Sport
  21. radio problems
  22. Fuel Pump????
  23. Bull Bar
  24. trouble starting
  25. 92 Cherokee E-Brake light stayong on
  26. 1987 Cherokee Laredo
  27. Headlight stay on!
  28. Spark plug prob
  29. 92 Jeep Starting Issue
  30. Loud clunking in 4WD
  31. 99 cherokee rad. fan short cycling
  32. 86 Jeep Cherokee, 2.8L, "PHOTO" needed to identify Vacuum components
  33. Throttle cable stuck on 90 Cherokee
  34. 86 Jeep Cherokee, 2.8L, Vacuum Hose PHOTO needed
  35. 89' Jeep Cherokee aircare/stalling problem
  36. hose from valve cover to air cleaner.
  37. newbie with radio problem on 88 cherokee
  38. frame brackets??
  39. Kill switch on 98 Cherokee
  40. 1998 Jeep
  41. Jeep doesnt run PLEASE HELP
  42. Engine knocking
  43. Push Button Start
  44. 1994 jeep cherokee SE serpentine belt
  45. 92 Cherokee Starting Issues
  46. starter button
  47. replacing rear seal on transmission
  48. Fuel Pump Problem?
  49. electrical problem
  50. 98 jeep cherokee transmission sensors
  51. Jeep runs in start position and dies in run position.
  52. 1995 Sport Cherokee Won't Start - Not Coil
  53. Friends 90 Jeep Cherokee
  54. 89 stalls/dies after warming up
  55. Death Wobble?
  56. How do I calculate speed with Bigger tires?
  57. Suspension question
  58. brake lights
  59. Heater hack 89 xj
  60. 89 Cherokee help
  61. Axle upgrade
  62. 87 w/ whine...what did I do?
  63. Windshield wiper problems
  64. Meet & Greet in Pinellas County
  65. Fuel Injectors
  66. Transmission doesnt shift right
  67. 5-Speed makes noise under load, maybe bearings?
  68. Loud knock in 4Low
  69. Axles?
  70. over heating
  71. Cherokee new stereo
  72. 88 Jeep Experts Help...Lock/Unlock Relays
  73. lifters questions
  74. 95 Cherokee starting problems
  75. Tires
  76. Can't remove transmission hose from radiator
  77. relay
  78. Loud shacky noise when running
  79. Confused...temp sender in rad + another in lower rad hose?
  80. runs and then doesn't
  81. need help!!!!!! jeep screwed!!!
  82. auto into manual
  83. Wiring Question - CD Player & Dome Lights
  84. 93 Cherokee fuse box layout query
  85. Won't go into gear
  86. 98 cherokee trans range sensor malfunction
  87. Best Intake
  88. suspension spacers
  89. jeeps not starting well & won't run for more than 3 seconds
  90. Idle Air Controller giving me fits
  91. RHD Vs. LHD
  92. 90 Cherokee stalls when in neutral rolling to a stop after freeway speeds.
  93. Aftermarket temp guage/burping recommendations?
  94. HELP Jeep wont stay running
  95. 1989 cherokee hard starting
  96. Looking for a few jeep cherokee parts!
  97. Turn Signal Issue
  98. when Ball joints go bad
  99. jeeps are not bear resistant
  100. key stuck in ignition
  101. V6 exchange for I6???? will it work
  102. HELP! Diesel in my cherokee!!
  103. electrical problems on a 1998 cherokee
  104. 1999 Jeep Cherokee No Bus/guages drop out
  105. 1991 cherokee limited?
  106. mild shifting problem
  107. 86 Cherokee w/ 2.8L Where do I connect to diagnostics?
  108. Really funky electrical problems
  109. header question..
  110. 87 pioneer hissing from reservoir cap???
  111. 1988 Jeep Cheroke
  112. 1989 XJ newbie cooling issue : What to do 1st?
  113. ABS brakes
  114. 89 cherokee lost all lights/radio/AC
  115. Slippery!? Or is it just me!?
  116. broken window regulator.
  117. Slow cranking and stalling
  118. just dies?!
  119. Lift?
  120. Speedometer off due to large tires?
  121. Emissions Help
  122. overheating 91, 4 litre- complete battery discharge
  123. stumped,won't start
  124. 89 jeep cherokee
  125. is it the starter?
  126. Start
  127. Knocking Noise
  128. Jeep Patriot
  129. 1998 cherokk classic questions
  130. stroking tips
  131. 4.0 block 1988 cherokee jerkin
  132. Blower motor quits when running excessively
  133. Clutch pedal stuck up can't depress it
  134. Extra Temp Probe
  135. Neutral Safety Switch...Girl asking
  136. Does the following even exist?
  137. 93 XJ aftermarket/replacment bodyparts
  138. '93 Cherokee Sport 4.0 for sale
  139. 94 cherokee sport diagnostic codes
  140. 1997 cherokee sport 4.0 engine change
  141. Crankshaft Pulley Seperated
  142. engine overhaul kit????
  143. 1989 Jeep Cherokee egr vacuum solenoid operation and wiring
  144. 1990 cherokee; looking for transmission fluid filter
  145. Back pressure
  146. Engine Swap
  147. won't start when cold
  148. auto tranny not shifting
  149. 88 Jeep brake light switch connections
  150. check engine light
  151. 88 4.0 vacuum picture
  152. 96 Cherokee Radiator question
  153. 96 xl Seats any aftermarket seats ?
  154. 2000 Cherokee brake lights
  155. Newbie/ Headlights...
  156. this is kind of weird.
  157. 86 jeep electrical help
  158. compression test -results
  159. Bolt size for electric window regulator on 88 XJ?
  160. Need new seats for 1992 Laredo...ouch!
  161. Looking for a wiring diagram...
  162. best way to get best MPG?
  163. 88 Cherokee loses power, backfires, stalls
  164. 87 5speed tranny, which one is it?
  165. 91 cherokee horn
  166. 1998 Voyager, starts intermittantly
  167. Catalytic Converter support bracket
  168. 88 4.0 timing
  169. Dashboard Gauges work intermittenly
  170. No Spark 86 Cherokee
  171. Temp gauge & Hazard lights
  172. stuck water coolent temp sensor
  173. dropping the tranny pan
  174. 93 Jeep XJ
  175. just became a jeep owner
  176. 97 cherokee bad idle
  177. neutral safety switch
  178. Ran out of gas know won't start
  179. How I replace the fan clutch in 96 4.0L
  180. jeep takes forever to start...
  181. Jeep Radio
  182. Can Someone Help Me out With Some ECU Codes?
  183. reattach front diff vent hose
  184. 98 Cherokee Power Door Lock switches not working
  185. Roof Rack Mounting
  186. Knocking Noise 88 Cherokee
  187. Alternator replacement-97
  188. starting woes
  189. 1989 jeep cherokee limited edition
  190. 1990 cherokee won't stay running
  191. To Buy, or Not to Buy
  192. 2000 Jeep Cherokee - Check Gauge Light
  193. window gets stuck in down position
  194. A/C compressor noise
  195. '96 cherokee 2WD front bearing / hub replacement - need help
  196. Trans oil pan?
  197. 97 cherokee read check engine w/o scan tool?
  198. gas
  199. 2001 Jeep Cherokee Spark plugs
  200. 95 cherokee 4.0 no spark
  201. 2000 Cherokee Neutral Safety Switch
  202. 1989 Jeep Won't turn over
  203. steering column needs putting back togethor
  204. 4.0 block 1988 cherokee
  205. 85 v6 to 4.0
  206. Buying a 2000 Jeep Cherokee XJ
  207. Jeep Service Manual Question
  208. Cables and linkage
  209. Trans ID
  210. power window shot...
  211. Stumped with the wifes jeep
  212. 2000 Cherokee code P0740 torque converter
  213. Electric Fan Question
  214. Replacing Heater Core Jeep Cherokee '00
  215. A/C problem in 99 Jeep Cherokee.....
  216. Replacing Battery Cables
  217. 2000 Jeep Cherokee 4.0L overheating
  218. Aftermarket Camshaft
  219. Idle problem -- IAC motor
  220. need new seats for 88 jeep cherokee
  221. 88 cherokee,no spark
  222. reverse lights not coming on...
  223. stupid issues????
  224. trouble codes????
  225. overheating, found problem. now new one!
  226. 95 Jeep Grand Cherokee won't start
  227. Carpet Resources Anyone???
  228. sensor question
  229. 88' overheet jeep
  230. AC Fuse
  231. Jeep won't start with the key
  232. Temp gauge acting NUTS
  233. 1989 Cherokee runs like crap!
  234. 1999 Jeep Cherokee Turn Signal Problem
  235. 88' cherokee tranny
  236. wider wheels?
  237. Narrowed down noise still ??? PLS HELP
  238. Hood Release Cable Broke!
  239. Heater Hose Routing
  240. 89 model for 95 engine swap
  241. 96 not charging
  242. Engine Noise-Taping valves
  243. 92 running hot, loses power, codes 21, 52
  244. NoX not Good
  245. a/c turns on and off
  246. fender trimming
  247. cannot pass emissions any suggestions?
  248. Torque Converter Clicking?
  249. heater/ac
  250. Coolant Bottle/Tank burst! Why?
