View Full Version : Accent/Verna
Pages : [1] 2 3
  1. Transmission help and
  2. Spped Sensor
  3. Trouble gasing up!!!
  4. Nut size????
  5. 00' Accent wont revv past 3k
  6. Hard to get started
  7. Dim Headlight Problem
  8. Engine Stalls
  9. car won't start/sensor making buzzing noise
  10. 2007 Accent hatchback power door lock problems
  11. Accent transmission question....
  12. 00 accent ecm wiring
  13. Starting/stall Issue Since Changing Fuel Filter
  14. Free Hyundai Accent service manual
  15. 2001 Accent Transmission Oil Plug location
  16. Need help with wheel baring ?????
  17. I hate the Accent 95-99
  18. Accent 2003 4 th gear cylinoid location
  19. accent flooding
  20. 04 accent fuel filter location
  21. increasing power steering pressure
  22. disc brake overheating
  23. Hyundai Accent Parasitic Drain. Please Help.
  24. Changing front brake pads.....
  25. Question on 1996 Accent
  26. Can Anyone Find A Trunk Cover?
  27. 1999 Accent Sputtering
  28. Long to warm up
  29. Looking for a manuel
  30. (uk) accent 1.3LSi starting problems
  31. piston compression - accent coupe
  32. Burning oil.... but how???
  33. 2000 Hyundai accent console removal
  34. 2002 hyundai accent GS alternator
  35. cvvt setting on a accent 2006
  36. 2001 hyundai accent no acceleration
  37. '01 Accent dies while driving
  38. How can I replace the license plate bulb
  39. Accent Dies while driving
  40. How to change wheel barings??????
  41. Bad vibrations....???
  42. 2002 Hyundai Accent PO734
  43. Hesitation question....??????
  44. Hyundai Cars are Junk!!!
  45. no chime sound when I forget the light
  46. '00 Accent P1128
  47. brake work
  48. >>Vacuum hose problem???
  49. HYUNDAI cars are WORTHLESS!
  50. **'01 fuel filter Question ??????
  51. 00 accent auto trans
  52. 95-96 clutch problems/tranmission problem
  53. Test
  54. I need help with a problem
  55. Replacing the door handle
  56. 2008 Accent Radio Question
  57. Changing tranny fluid????
  58. power washed my engine, fried ECU -99 accent
  59. replacing radiator on '99 accent. Is it simple or complicated
  60. *2002 Accent Emission Codes Help Needed*
  61. sunpro 7906 tach installation 2000 accent 3 dr mt
  62. Someone please help
  63. Bake drum brake problem?????
  64. HYUNDAI ACCENT E coupe 1.3I 1999 brake problems
  65. Crankcase pully removal 1.5L SOHC
  66. Hyundai Accent 1.3i Coupe Ball Joint
  67. HYUNDAI ACCENT E coupe 1.3I 1999 T PLATE
  68. Hyundai Accent 1.3i Coupe 1999 T Plate
  69. Hyundai Accent 1.3i Coupe 1999 T Plate
  70. 99 accent trans question
  71. car overheating and no heat from heater
  72. 97Accent turnover but wont start,if pushstarted it will start, HELP!!!
  73. tranny interchanges
  74. Battery
  75. 97 accent tranny problem
  76. Horn not working
  77. 2002 accent wiring issues
  78. 1998 Hyundai accent low power consumption/car stereo shuts off when lights are on
  79. Accent starts sometimes, and wont turnover others???
  80. Timing belt replacement problem
  81. Timing belt replacement problem
  82. Timing belt replacement problem
  83. Timing belt replacement problem
  84. Timing belt replacement problem
  85. Timing belt replacement problem
  86. '98 hyundai accent check engine light
  87. exhaust questions.
  88. p1128 quandry
  89. hyndai accent 2004 radio replacement
  90. problem while filling fuel in the tank
  91. Can anyone offer assistance with my brake problems
  92. 97 Accent Rear Drums?
  93. Body Kit
  94. Sensor Location?????
  95. My wippers won't work!!!!
  96. Car Jerks at Red Lights
  97. Gas Gauge Not Working
  98. 2000 3dr towing possibility
  99. 2007 Accent mileage very low
  100. 2000 accent stalls
  101. Purge Valve Connector
  102. vibration?
  103. Diesel Accent
  104. Strange acting transmission
  105. 2000 Accent heater blower problem
  106. 2000 accent hard to start
  107. Need to prevent car from starting
  108. Blinkers
  109. 2004 Hyundai Accent Trans or wiring problem?
  110. fuel pump replacement
  111. Help!!
  112. Hyundia Mvi
  113. Stereo help!!!
  114. Fast car?....
  115. car jerks
  116. 2001 Accent-- Broken seal
  117. 1997 hyundai electrical problem
  118. 2007 Accent-No cruise control??
  119. Squeaky Spark Plugs??
  120. Shorted out door poppers???
  121. 2002 accent wet brakes
  122. 1996 accent wheel problems
  123. Thinking of buying a Hyundai Accent
  124. Interested in purchasing a 2001-2003 Accent....
  125. 01 Accent Hatch Light
  126. gas mileage sucks!!!
  127. won't start! help
  128. Avante Steering Problem
  129. aftermarket hood
  130. Question regarding the ECU on a 2002 Accent
  131. cfm question on a 2000 accent
  132. Freezing Transmission Problem
  133. front wheel bearing change
  134. gearlinkage cable help
  135. 2002 Accent
  136. Test connector location?
  137. 1997 Hyundai Accent
  138. Reverse Lights stay on
  139. Accent Instrument Panel Light
  140. 96 Accent HELP!!
  141. timing belt
  142. 02 accent help please!!!
  143. Dropping a 4G63T into a 2007 Accent
  144. Coolant Temperature Sensor
  145. ecu codes
  146. 2000 Accent dies after starting
  147. codes ?
  148. 01 accent will not shift into overdrive
  149. '95 Accent (General) Transmission Question
  150. Installing Transaxle in 2000 Hydundai
  151. 1998 hyundai accent gear/transmission problem.. *downsifted at 5 mph from 3rd to 1st"
  152. HOW DO I TEST IGNITION COILS 02 accent?
  153. 2002 Hyundai accent HELP!!!
  154. 96 accent missfire
  155. Help!!! Gas Pedal Is Resistant!
  156. suspension
  157. Questions about motor specs
  158. 2000 Accent transaxle gear oil change to Redline MTL & MT90
  159. 1996 Accent - low rpm hesitation
  160. 2001 Accent not going into Overdrive
  161. locked keys in car
  162. Anyone know were i can find Euro tail lights for my 2003 hyundai accent
  163. need hep fast 96 accent how many 02 sensors does it have?
  164. I need help really bad with a 2004 Accent
  165. Is it worth fixing and keeping?
  166. p0422 code
  167. 96 accent 3rd & 4gear GONE help 5speed
  168. 2002 Accent idle throttle problems help plz!!!
  169. Ruff Idle and loss of power
  170. Front Wheel Bearing
  171. 2002 Accent Wheel noise.
  172. smoking battery
  173. Got an Accent gave to me....
  174. Parts needed...need help to find
  175. Accent acceleration problem
  176. Been looking at another 95 Accent
  177. Is The Excel Sprint 2 Cars In 1 ?
  178. Exterior Handle
  179. O2 Sensor or what?
  180. 98 accent
  181. standard 2 gear
  182. Air??
  183. How good?
  184. 01' Hyundai Accent
  185. How much is a 95 Accent worth?
  186. 2000 accent code 1128 and 1123
  187. flex pipe problems
  188. accent codes P1529, P0740
  189. 1998 Accent Transmission Problems
  190. When they do an alignment, can they see other things wrong
  191. changing oil pan
  192. VIN decoding?
  193. 2002 Accent Right Front Window Regulator
  194. 2002 Accent P0444 code
  195. reverse lights not working
  196. battery ?
  197. Dash light doesnt work 96 accent
  198. Cheap easy turbo for an Accent? No BS
  199. 2002 Accent GS Wont start need help...
  200. 95 accent horn
  201. 96 Accent Headlight Low Beams are out
  202. Accent 01 Body Kits
  203. 96 accent smell gas on start up
  204. 96 accent.. sloppy stickshift and steering?
  205. i need quick fast help plsss
  206. 99 Accent Speed Sensor
  207. engine and ecu codes
  208. ruff idle? any ideas?
  209. Whining noise from gas tank area
  210. where is the ecu located??
  211. Are accents good cars?
  212. Antenna Jack
  213. i hear clicks when i turn
  214. 96 accent overheated wont start
  215. can anybody lend a helping hand?
  216. a bad ass pic of my hyundai!
  217. My 01 Accent's engine purrs too loud..
  218. window handle ???
  219. 96 accent scaner port
  220. Good article on the Accent
  221. help 96 accent brakes
  222. 2003 Accent loud squealing when turning
  223. Transmission Problems
  224. Shifting Cable
  225. hyundai accent need help
  226. Accent runs good when cold - after 40 minutes engine races 4K and transmission slips
  227. Engine Code P0133 Oxygen Sensor slow to respond
  228. transmission troubles, please can anybody help?
  229. Hyunday Accent ATF type
  230. Blown Engine, 1.6L, how to swap out?
  231. 2005 Accent - Mileage sucks - Advise
  232. transmission slip bettween second and third
  233. Help w/ Cigarette Lighter !!!!!
  234. 2005/2006 Accents
  235. 2001 Accent 1.5 Fuel Filter
  236. PO11 O2 Sensor responding slow
  237. Hyundai Accent Overdrive Problem & Solution
  238. Air Filter '95 Accent
  239. accent 60k mile service
  240. Transmission troubles
  241. Check engine, misfiring, high idle..
  242. setting the time
  243. New and with questions
  244. what a friggin LEMON 01 accent
  245. OMG 99 accent problems??
  246. 97 Accent "Economy Button"
  247. shark racing
  248. Hi Bro i need help>
  249. 98 accent CAN'T REMOVE ROTORS
  250. Brake problems - low break pedal.
