View Full Version : Accent/Verna
Pages : [1] 2 3
  1. Spped Sensor
  2. Trouble gasing up!!!
  3. Nut size????
  4. 00' Accent wont revv past 3k
  5. Hard to get started
  6. Dim Headlight Problem
  7. Engine Stalls
  8. car won't start/sensor making buzzing noise
  9. 2007 Accent hatchback power door lock problems
  10. Accent transmission question....
  11. 00 accent ecm wiring
  12. Starting/stall Issue Since Changing Fuel Filter
  13. Free Hyundai Accent service manual
  14. 2001 Accent Transmission Oil Plug location
  15. Need help with wheel baring ?????
  16. I hate the Accent 95-99
  17. Accent 2003 4 th gear cylinoid location
  18. accent flooding
  19. 04 accent fuel filter location
  20. increasing power steering pressure
  21. disc brake overheating
  22. Hyundai Accent Parasitic Drain. Please Help.
  23. Changing front brake pads.....
  24. Question on 1996 Accent
  25. Can Anyone Find A Trunk Cover?
  26. 1999 Accent Sputtering
  27. Long to warm up
  28. Looking for a manuel
  29. (uk) accent 1.3LSi starting problems
  30. piston compression - accent coupe
  31. Burning oil.... but how???
  32. 2000 Hyundai accent console removal
  33. 2002 hyundai accent GS alternator
  34. cvvt setting on a accent 2006
  35. 2001 hyundai accent no acceleration
  36. '01 Accent dies while driving
  37. How can I replace the license plate bulb
  38. Accent Dies while driving
  39. How to change wheel barings??????
  40. Bad vibrations....???
  41. 2002 Hyundai Accent PO734
  42. Hesitation question....??????
  43. Hyundai Cars are Junk!!!
  44. no chime sound when I forget the light
  45. '00 Accent P1128
  46. brake work
  47. >>Vacuum hose problem???
  48. HYUNDAI cars are WORTHLESS!
  49. **'01 fuel filter Question ??????
  50. 00 accent auto trans
  51. 95-96 clutch problems/tranmission problem
  52. Test
  53. I need help with a problem
  54. Replacing the door handle
  55. 2008 Accent Radio Question
  56. Changing tranny fluid????
  57. power washed my engine, fried ECU -99 accent
  58. replacing radiator on '99 accent. Is it simple or complicated
  59. *2002 Accent Emission Codes Help Needed*
  60. sunpro 7906 tach installation 2000 accent 3 dr mt
  61. Someone please help
  62. Bake drum brake problem?????
  63. HYUNDAI ACCENT E coupe 1.3I 1999 brake problems
  64. Crankcase pully removal 1.5L SOHC
  65. Hyundai Accent 1.3i Coupe Ball Joint
  66. HYUNDAI ACCENT E coupe 1.3I 1999 T PLATE
  67. Hyundai Accent 1.3i Coupe 1999 T Plate
  68. Hyundai Accent 1.3i Coupe 1999 T Plate
  69. 99 accent trans question
  70. car overheating and no heat from heater
  71. 97Accent turnover but wont start,if pushstarted it will start, HELP!!!
  72. tranny interchanges
  73. Battery
  74. 97 accent tranny problem
  75. Horn not working
  76. 2002 accent wiring issues
  77. 1998 Hyundai accent low power consumption/car stereo shuts off when lights are on
  78. Accent starts sometimes, and wont turnover others???
  79. Timing belt replacement problem
  80. Timing belt replacement problem
  81. Timing belt replacement problem
  82. Timing belt replacement problem
  83. Timing belt replacement problem
  84. Timing belt replacement problem
  85. '98 hyundai accent check engine light
  86. exhaust questions.
  87. p1128 quandry
  88. hyndai accent 2004 radio replacement
  89. problem while filling fuel in the tank
  90. Can anyone offer assistance with my brake problems
  91. 97 Accent Rear Drums?
  92. Body Kit
  93. Sensor Location?????
  94. My wippers won't work!!!!
  95. Car Jerks at Red Lights
  96. Gas Gauge Not Working
  97. 2000 3dr towing possibility
  98. 2007 Accent mileage very low
  99. 2000 accent stalls
  100. Purge Valve Connector
  101. vibration?
  102. Diesel Accent
  103. Strange acting transmission
  104. 2000 Accent heater blower problem
  105. 2000 accent hard to start
  106. Need to prevent car from starting
  107. Blinkers
  108. 2004 Hyundai Accent Trans or wiring problem?
  109. fuel pump replacement
  110. Help!!
  111. Hyundia Mvi
  112. Stereo help!!!
  113. Fast car?....
  114. car jerks
  115. 2001 Accent-- Broken seal
  116. 1997 hyundai electrical problem
  117. 2007 Accent-No cruise control??
  118. Squeaky Spark Plugs??
  119. Shorted out door poppers???
  120. 2002 accent wet brakes
  121. 1996 accent wheel problems
  122. Thinking of buying a Hyundai Accent
  123. Interested in purchasing a 2001-2003 Accent....
  124. 01 Accent Hatch Light
  125. gas mileage sucks!!!
  126. won't start! help
  127. Avante Steering Problem
  128. aftermarket hood
  129. Question regarding the ECU on a 2002 Accent
  130. cfm question on a 2000 accent
  131. Freezing Transmission Problem
  132. front wheel bearing change
  133. gearlinkage cable help
  134. 2002 Accent
  135. Test connector location?
  136. 1997 Hyundai Accent
  137. Reverse Lights stay on
  138. Accent Instrument Panel Light
  139. 96 Accent HELP!!
  140. timing belt
  141. 02 accent help please!!!
  142. Dropping a 4G63T into a 2007 Accent
  143. Coolant Temperature Sensor
  144. ecu codes
  145. 2000 Accent dies after starting
  146. codes ?
  147. 01 accent will not shift into overdrive
  148. '95 Accent (General) Transmission Question
  149. Installing Transaxle in 2000 Hydundai
  150. 1998 hyundai accent gear/transmission problem.. *downsifted at 5 mph from 3rd to 1st"
  151. HOW DO I TEST IGNITION COILS 02 accent?
  152. 2002 Hyundai accent HELP!!!
  153. 96 accent missfire
  154. Help!!! Gas Pedal Is Resistant!
  155. suspension
  156. Questions about motor specs
  157. 2000 Accent transaxle gear oil change to Redline MTL & MT90
  158. 1996 Accent - low rpm hesitation
  159. 2001 Accent not going into Overdrive
  160. locked keys in car
  161. Anyone know were i can find Euro tail lights for my 2003 hyundai accent
  162. need hep fast 96 accent how many 02 sensors does it have?
  163. I need help really bad with a 2004 Accent
  164. Is it worth fixing and keeping?
  165. p0422 code
  166. 96 accent 3rd & 4gear GONE help 5speed
  167. 2002 Accent idle throttle problems help plz!!!
  168. Ruff Idle and loss of power
  169. Front Wheel Bearing
  170. 2002 Accent Wheel noise.
  171. smoking battery
  172. Got an Accent gave to me....
  173. Parts needed...need help to find
  174. Accent acceleration problem
  175. Been looking at another 95 Accent
  176. Is The Excel Sprint 2 Cars In 1 ?
  177. Exterior Handle
  178. O2 Sensor or what?
  179. 98 accent
  180. standard 2 gear
  181. Air??
  182. How good?
  183. 01' Hyundai Accent
  184. How much is a 95 Accent worth?
  185. 2000 accent code 1128 and 1123
  186. flex pipe problems
  187. accent codes P1529, P0740
  188. 1998 Accent Transmission Problems
  189. When they do an alignment, can they see other things wrong
  190. changing oil pan
  191. VIN decoding?
  192. 2002 Accent Right Front Window Regulator
  193. 2002 Accent P0444 code
  194. reverse lights not working
  195. battery ?
  196. Dash light doesnt work 96 accent
  197. Cheap easy turbo for an Accent? No BS
  198. 2002 Accent GS Wont start need help...
  199. 95 accent horn
  200. 96 Accent Headlight Low Beams are out
  201. Accent 01 Body Kits
  202. 96 accent smell gas on start up
  203. 96 accent.. sloppy stickshift and steering?
  204. i need quick fast help plsss
  205. 99 Accent Speed Sensor
  206. engine and ecu codes
  207. ruff idle? any ideas?
  208. Whining noise from gas tank area
  209. where is the ecu located??
  210. Are accents good cars?
  211. Antenna Jack
  212. i hear clicks when i turn
  213. 96 accent overheated wont start
  214. can anybody lend a helping hand?
  215. a bad ass pic of my hyundai!
  216. My 01 Accent's engine purrs too loud..
  217. window handle ???
  218. 96 accent scaner port
  219. Good article on the Accent
  220. help 96 accent brakes
  221. 2003 Accent loud squealing when turning
  222. Transmission Problems
  223. Shifting Cable
  224. hyundai accent need help
  225. Accent runs good when cold - after 40 minutes engine races 4K and transmission slips
  226. Engine Code P0133 Oxygen Sensor slow to respond
  227. transmission troubles, please can anybody help?
  228. Hyunday Accent ATF type
  229. Blown Engine, 1.6L, how to swap out?
  230. 2005 Accent - Mileage sucks - Advise
  231. transmission slip bettween second and third
  232. Help w/ Cigarette Lighter !!!!!
  233. 2005/2006 Accents
  234. 2001 Accent 1.5 Fuel Filter
  235. PO11 O2 Sensor responding slow
  236. Hyundai Accent Overdrive Problem & Solution
  237. Air Filter '95 Accent
  238. accent 60k mile service
  239. Transmission troubles
  240. Check engine, misfiring, high idle..
  241. setting the time
  242. New and with questions
  243. what a friggin LEMON 01 accent
  244. OMG 99 accent problems??
  245. 97 Accent "Economy Button"
  246. shark racing
  247. Hi Bro i need help>
  248. 98 accent CAN'T REMOVE ROTORS
  249. Brake problems - low break pedal.
  250. Radio Install Help for 2005 Accent
