View Full Version : Accent/Verna
Pages : 1 [2] 3
  1. beta swap
  2. tranny Problems?
  3. Replacing front rotors, 2000 Accent
  4. Wiring Kit for Radio/CD
  5. Power steering to -91 Pony
  6. transmission problem
  7. Is your Accent a little slow? Try this!
  8. 96 accent timing belt change
  9. 01 Accent Died, won't start
  10. Odd Electrical issues-Plz help!
  11. 96 accent using oil
  12. hyunday accent complain
  13. popping noise
  14. Hyundai Transmission No Reverse Help!!
  15. sticking brakes
  16. www.hmaservice.com website
  17. car wont start
  18. engine swap
  19. Hyundai has finally done it!
  20. Inside Diameter of intake tube.
  21. 02accent ground and wires
  22. Accent Diagnosis codes
  23. Few ?'s about 05 Accent
  24. 110 Volt Adapter for Cigarette Lighter - Alternator
  25. Any News on '06 Accent?
  26. cat
  27. Won't start after a short rest
  28. check engine light
  29. 2 MAF's and now transmisson slipping.
  30. The 2005 Hyundai Accent
  31. 99 Accent 66000 miles Check Engine Light
  32. info on exhaust system
  33. check engine light :(
  34. radio removal and installation
  35. making a beta rev to 9000 rpm???
  36. check this
  37. dashboard lights switched off randomly
  38. my 2005 accent
  39. Rattling sound...2000 Accent
  40. 1996 Accent - Intermittant stall
  41. check engine light is on....
  42. rear door wont open
  43. a/c
  44. I have an overheating problem
  45. 95 Hyundai Accent Spark Problem
  46. Help on getting first car
  47. Turbonator
  48. power loss in my 96 accent
  49. Accent 2000 bearing change
  50. 97 Accent Gas Tank
  51. 2000 accent runs like crap!!!!!!
  52. 2001 Accent Wipers
  53. 2000 Accent P1128
  54. Strange pulsating noise in front end.....
  55. mica or metallic
  56. worth modding
  57. Water Pump Leak
  58. Air bag
  59. O2 Sensor adapter wire colors?
  60. 1.8L Beta in LC2 and hi-revving
  61. Timing adjustment 2001 Accent
  62. 95 accent tranny shift problems
  63. How to install an aftermarket Tacho?
  64. Accent problems
  65. Where is my Fuel Filter on Accent 2000 GL
  66. Where is my fuel filter
  67. carburetor
  68. High Beams Stuck On
  69. Engine suddenly dies and doesn´t restart inmediatly
  70. How hard is it to Remove rear seats to get to speakers
  71. cd player removal? 2001 accent GSI
  72. 99 accent bucks, or jumps while driving
  73. Clutch Leaking Fluid
  74. lowering and wheels
  75. 1995 Starting Problem
  76. Engine noise
  77. ACCENT 01 brakes
  78. Auxiliary Emission Controls (P1403/P1402)
  79. P1128 Code
  80. summer tires
  81. sloppy shifter/rear struts
  82. Installing custom accent grill question
  83. Iat
  84. 2 or 1 oxygen sensors
  85. horn problems
  86. Accent low compression
  87. '98 Accent - Stutters after rain.
  88. Catalytic Conveter Cover
  89. where is fuel filter on 2001 accent 1.5
  90. Squeeky belt
  91. users experience
  92. 2001 Mysterious Brake Grinding
  93. 1999 Accent losing oil
  94. hub bearings and brakes
  95. 97 Accent Won't Start
  96. Help Check Engine Light
  97. Check eng. lt. P0138 P0141
  98. P0441 Check Engine Light
  99. bad fuel economy
  100. Accent 2004 ODB-II
  101. 1998 Accent - Removing Window Crank
  102. HELP! After reconnecting the battery, Accent won't start
  103. The Turbonator aaaaanyone
  104. 1999 Accent rust freckles
  105. where is my fuel filter
  106. Where is the Mass Air Flow sensor?
  107. electrical problem?
  108. engine swap
  109. Fuel Problem...can anybody help??
  110. heater/air vent problems
  111. 1997 hyundai accent body kits
  112. Performance 1.5L vs 1.6L
  113. Advice on buying a used Accent
  114. Accent quit shifting into overdrive
  115. Bad thermostat or vent problem?
  116. Tachometer
  117. clutch problems? please help!
  118. Check Engine Light
  119. P0303 Fix
  120. multiple misfire
  121. Wiper problem
  122. 96 Accent - transmission problem? help or advice?
  123. 1998 Hyundai accent Tranny problem
  124. Trouble Pumping Gas
  125. Check engine light-lean mixture code
  126. Brake problem?
  127. "Check Engine Light"
  128. where da e brake at......
  129. Brakes!!!!!!!!!!!1
  130. Rpm
  131. Making accent faster????
  132. Wiper problems..need help fast
  133. Buying a 1998 Accent - What should I get checked?
  134. Injection problem?? Please help
  135. 2000 Accent P1128 error code
  136. need help quick
  137. Removing Dash when installing deck in 05 Accent
  138. bigger brakes
  139. check engine light and air bag light are on!
  140. My Accent is slow
  141. 00 Accent - Wing Mirror Change
  142. Heater problem help please??
  143. I need help! 97 accent
  144. '98 Accent - Knock Sensor?
  145. Cargo Racks
  146. Strike 3 - Spark plug and wires question
  147. Fog lights
  148. 2002 accent gs- AIRBAG QUESTION
  149. Interrmittnet dies or no restart
  150. odd problem
  151. remote starter help
  152. Fuel Injector Cleaning
  153. body kit 4 sale and wheels
  154. Oil Change Question
  155. rev limiter?
  156. Overdrive Problem Automatic Trans
  157. Starting it up
  158. shifting hard
  159. TSB for Brake lights?
  160. Throwout bearing, how difficult?
  161. remote starter help
  162. 02 Accent Wont Start
  163. fuel filter location
  164. Accent interchange with Pontiac LeMans?
  165. motor try to stall, please help
  166. Check Engine Light
  167. tranny slipping to neutral
  168. Security codes?
  169. Misconcepions of Hyundai
  170. 02 accent for sale
  171. engine surging
  172. Woe is Me
  173. Radio Trouble
  174. breaks for an 02 accent
  175. 96 accent cheap, should i buy it?
  176. Obd II codes
  177. OBDll code
  178. OEM Timing Belt?
  179. window will not roll down?!
  180. window handle removal
  181. extended-life antifreeze
  182. My wipers won't work!!!
  183. Clutch Slipping at 69,000
  184. rims
  185. Auto Transmission Problem
  186. pushing the timing belt change
  187. Driving with Overdrive off or on?
  188. Catalytic convertor?
  189. engine swap
  190. Transmission Slip?
  191. Tiburon Motor?
  192. 02 accent and warrenty
  193. 96 accent speaker help?!
  194. Loud clicking/popping noise from rear brakes when slowing down...
  195. 95 Accent Bodykits
  196. CoverCraft Full Mask/Bra For Sale
  197. Rear Wheel Bearing Torque
  198. intermittent, rough, choppy, acceleration while shifting
  199. Honda Guy lookin for Hyundai feedback
  200. car wont start
  201. brake problems
  202. Air bag and Check Engine Light.
  203. timing belt/waterpump change
  204. 01 accent wheels
  205. Wipers Not Moving
  206. accent motor tuning
  207. air filter
  208. Blown Radio Fuse
  209. 99' accent voltage regulator
  210. remove steering wheel
  211. 2001 Accent- Where is the fuel filter located?
  212. A/C Installation
  213. Anyone with a 2002 Accent Parts car???
  214. 2001 accent gsi odur like burnt plastic?
  215. 1995 wheel bolt pattern
  216. Replacing front door speakers
  217. Sluggish
  218. Sub Install
  219. 01 accent drum removal?
  220. No spark
  221. selling/buying 01 Accent parts
  222. Hyundai Accent Heater Odor
  223. Any kind of parts for a 03 Accent
  224. Hyundai Accent Petition
  225. what are some body kits for the accent?
  226. cd display working/sound lost
  227. volume levles
  228. Rim Specs
  229. Motor Swap
  230. I need More Power
  231. Redline And Shift Points
  232. Mutual respect
  233. Slippin' Transmisson
  234. disc removal on a 99 accent
  235. Fuel Consumption
  236. Back into an Accent!
  237. Possible Alternator/Voltage Regulator Problem? Your Semi-pro Advice is Appreciated!
  238. questions from a newbie about 04 Accent GL
  239. New to mods
  240. 2002 Parts on a 2003 Accent L
  241. new board
  242. What to hook to, tow hook?
  243. need help ...what kind of engines do hyundai's have
  244. 99 Accent
  245. press gas pedal but no power help
  246. accent haters
  247. 2005 full redesign
  248. engine swap tips
  249. 99 accent head unit removal
  250. 2003 Accent A/C System
