View Full Version : XJ6
  1. Need advice on buying '94 XJ6
  2. 1995 XJ6 repair info needed
  3. 1996 xj6 will not start with key
  4. New website feauring Jaguar parts
  5. Need Jaguar JEPC AND JAGUAR SOFT
  6. Grey smoke when starting.
  7. Knocking noise on 1994 xj6
  8. 93 XJ6.. sometimes starts.. sometime dont.
  9. manufacture's recommended fluids
  10. 89' xj6 alternater problem HELP ME PLZ!!
  11. 1993 Soveriegn - O2 sensor wiring - tracing
  12. 89' XJ6 Jag Electrical Prbs Need Info/Help
  13. advice on a xj6
  14. 1995 Jaguar XJ6 Door lock problem
  15. Fuel lines in trunk. 85 XJ6
  16. 95 xj6 fuel line to filter
  17. over riding radio security
  18. underhood relays 1994 xj6
  19. I just bought a 1987 XJ6
  20. 96 Electrical problem
  21. Fluctuating oil pressure
  22. 1993 XJ6 Dashboard light question
  23. 1975 XJ6 Repairs!
  24. dash info needed please:)
  25. how to clean wire wheels
  26. 83 xj6 heat/ac question
  27. timing belt or chain
  28. 91 Sovereign (xj6) Fuel Pump
  29. xj6
  30. auxillary fan function
  31. 1990 Sovereign console cover
  32. 1994 Jaguar XJ6 - No Start - No Ground to Relay
  33. rusted frame at control arm
  34. 1989 XJ6 Need help
  35. 1990-1996 Jaguar XJ6
  36. 91 Jaguar XJ6 Sovereign
  37. 1987 XJ6 engine running rough
  38. 1989 XJ6 Where do I start?
  39. xj6 window winders
  40. HELP!DFW tx alternator?newbattery!
  41. Fuel Vapors and possible leaks
  42. 1996 XJ6 misses at idle!
  43. What warning lights mean what
  44. Shop Manual
  45. Power Locks/Interior lights
  46. Heat on floor and rear, not along dash?? Please help!!
  47. Jaguar xj6 electrical
  48. Question on Display screens
  49. 1994 Jag xj6 vdp Fuel pump? starting problems
  50. No fuel past fuel pressure regulator
  51. Loud 88 Xj6
  52. 1971 XJ6 trunk
  53. Xj-6 91
  54. 88 XJ40 - fuel odor in boot
  55. Transmission Light Question
  56. Water Damage- Please Help!
  57. parting out
  58. Engine Troubles - Please help!
  59. Check Engine light/other
  60. 1987 XJ6 production totals
  61. 87 XJ6 wheels
  62. problem starting 1988 xj6
  63. 76 XJ6 Heater/AC Work
  64. 1989 XJ6 How do I know if
  65. 90 xj6 for sale
  66. XJ6 1995 misses over 3000RPM
  67. Engine swap on 1989 xj6
  68. Need help to program remote xj6 1993
  69. 1986 Xj6..to sell or not to sell
  70. 1988 XJ6 reverse going going gone
  71. 1986 xj6 body kit?
  72. xj6 1991 radio
  73. No oil pressure at low RPMs
  74. F/s 91 Xj6 Front End
  75. 1995 xj6 Starting issues Help please
  76. conversion FORD 4.6 DOHC
  77. 1984 xj6 questions
  78. XJ6 starts and Cuts off when in gear
  79. engine swap
  80. 1992 Remote programming
  81. XJ6 ?s
  82. Daimler soverign V Jaguar XJ6
  83. Slow crankin starter
  84. FS: winter tires + rims
  85. 1989 XJ6 Brake actuator?
  86. 1997 Xj6 Good Car
  87. 1990 XJ6 Problem hoping to find some answers
  88. Heat turned on -strange smeel - no heat
  89. 1989 XJ6 Loping
  90. 1997 front disc brakes
  91. check engine code reads multiple miss fires.
  92. Starting Issues (Sensor?)
  93. parting a 84 xj6
  94. xj6 modifications
  95. XJ6 starting problem
  96. Headlights on - Dashlights go out?
  97. Need advice on '83 XJ6
  98. 1991 XJ6 won't fire- any suggestions????
  99. Dash Lighting
  100. Selling 84 XJ6 with approx 45,000 miles!!
  101. ceased engine
  102. Shock Bushings?
  103. Wanting an XJ6 for Fiancee
  104. Starter relay
  105. Janspeed Jaguar conversion help
  106. XJ 40 Diagrams
  107. Questons on XJ6..
  108. XJ6 with 22" Wheels
  109. xj6 water in gas tank
  110. '83 Jaguar XJ6 headlights in an '85 cougar
  111. Programming sequence for automatic door lock
  112. supercharger for xj6
  113. 1997 XJ6 Radio Problem
  114. Northwest Jaguar XJ6 Vanden Plas For Sale
  115. My baby!
  116. How much
  117. PLEASE HELP Instrument Gauge cluster DEAD
  118. Pic of my 1996 XJ6
  119. How do I remove head rests in a 1980 XJ6?
  120. Keyless entry programming question
  121. XJ6 Nightmare
  122. I now have two XJ6s...
  123. Buying an '89 XJ6
  124. Looking at a 1988 XJ6
  125. Wanted: Jag XJ6 in new england area
  126. What is this switch for??
  127. 1984
  128. Wake up XJ6 forum!
