View Full Version : Rodeo/Passport
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Stubborn shocks
  2. A few minor, but annoying issues...
  3. Rod Knock?
  4. 96 rodeo 3.2 SOHC 2wd problems
  5. How to clean egr passage in 2000 Honda Passport
  6. Throwout bearing question
  7. 5 spd... how stout?
  8. Crank shaft position sensor
  9. Idle/ECU Problems
  10. Spindle/Knuckle axle seals? Help
  11. 1999 Rodeo V6
  12. Rebuild or replace?
  13. Isuzu Repair manual
  14. 1999 Rodeo
  15. Looks like my H2O pump is leaking at 45K
  16. 971/2 Passport
  17. Wierd issue that effects startup and Idle
  18. key will not turn in lock
  19. 1998 Isuzu Rodeo wont start
  20. Souping up?
  21. Timing Belt/Water Pump Change Out
  22. Replace Front Rotors for 97 Rodeo with 4wd
  23. 2000 Rodeo 3.2V6 blown?
  24. EGR Tube diameter?
  25. 1998 Isuzu Rodeo ECU Location ????
  26. ELECTRIC WINDOWS/ 95.5rodeo
  27. half shaft removal
  28. 93 rodeo wont restart! 23 auto shop owners are stumped!
  29. help please
  30. Manual locking hubs
  31. Truck changes lanes on its own....
  32. Blue Devil Head Gasket Sealant
  33. Thud...check trans, cruise control?
  34. RBS/BRAKE lights
  35. Help - Possible bad head gasket?
  36. Crankshaft pulley removal
  37. 96 Rodeo Auto No Reverse
  38. 94 Passport Won't Start
  39. what fluid does my rearend take? 2001
  40. 2000 Isuzu Rodeo "Hissing"
  41. Winshield Wiper Issue
  42. the horrid rodeo lifters tick!
  43. My transmission hesitates
  44. if your lookin to buy fuel pressure gauge FYI
  45. crank pulley slipping????
  46. 2001 Rodeo blower works 1, 2 and 3 only
  47. 2000 Isuzu Rodeo
  48. 1995.5 Isuzi Rodeo New Owner Needs Help ASAP PLEASE!!
  49. 2001 rodeo
  50. Anyone ever buy a Carter fuel pump?
  51. 95 rodeo cruise control
  52. Need help on fuel gauge
  53. 97 Valve Cover gasket
  54. 96 Rodeo Radio Problems
  55. 99 Rodeo will not go shift into park or reverse
  56. 95 Rodeo gas blow back when filling tank?
  57. blowing white smoke
  58. 1997 runs like crap
  59. Denso spark plug price
  60. 97 1/2 to 2000 Rodeo
  61. Is a radiator flush on an older Rodeo OK?
  62. Successful Starter Removal on '01 Passport 4WD 3.2
  63. 1997 blowing ignition fuse
  64. Help! What did I fry
  65. I am, I am new to this forum
  66. 02 sensor questions
  67. 99 RODEO Front Speaker
  68. How to tighten crankshaft bolt
  69. Can't get rear gate to lock
  70. Trouble Code P0341
  71. Sluggish start
  72. power window problem
  73. How tight should timing belt be?
  74. Error Codes 1997 Rodeo 4ze1 efi
  75. exhaust gasket
  76. transfer case fluid fill??94 rodeo m/t
  77. 1996 Rodeo trans fluid drain fill / replace
  78. manual trans 94 rodeo transfer case???
  79. 95 rodeo/ 2000 passport engine compatibility
  80. Farewell 1998 Rodeo LS
  81. 95 rodeo
  82. 03 Rodeo replacement engine
  83. Whistling @ 2500 RPM
  84. help diagnosing sound
  85. Help! Surging and frequent stalling when A/C is on!
  86. Squeaking front end driving me nuts!!
  87. sluggish acceleration
  88. 1992 rodeo bad fuel pump
  89. transmission removal/transfer case 94 rodeo M/T
  90. 1995 Honda passport stuck in 4wd
  91. Re:Sounds like marbles in motor when I accelerate
  92. '96 Rodeo brake and ABS lights constant
  93. Running hot, AC cuts off
  94. finding a bad gas leak
  95. Lean on Both Banks
  96. How much Seafoam?
  97. '95 Rodeo 4cyl./5sp. random stalling
  98. 99 4WD Rodeo LSE ABS lights up driving over 70mph.
  99. 96 Rodeo, Won't Charge Properly
  100. P0442 code- purge solenoid need help
  101. 94 isuzu transfer case help
  102. Leaking valve cover ...
  103. Fixing it the Old Fashioned Way
  104. 1997 Left Rear Window Regulator
  105. Want to change Rodeo trans fluid?
  106. ABS sensor problems
  107. '93 Rodeo 4WD right front wheel noise
  108. CEL p0442 Can an exhaust leak cause this code?
  109. 2004 Rodeo burns 1qt oil in 3K miles
  110. Error code P1403 Rodeo 2002
  111. 92 Died and won't start
  112. Please help with my dumb transmission!
  113. 2001 Rodeo Reduced Power Light
  114. trans fluid-flush it or change it.
  115. suspension/handling recommendation
  116. brakes again.
  117. Stopped on Hwy and won't start
  118. new engine codes for me
  119. Starter??
  120. Air Conditioning
  121. Engine ig fuse keeps popping
  122. Speedometer-wacko
  123. 98 Rodeo Starter Issues
  124. Intake manifold
  125. 01 Rodeo fan belt replacement
  126. 1995 Passport sounds like a diesel
  127. map sensor
  128. 1996 Rodeo factory am-fm cassette
  129. Safety check before I try to add trans fluid
  130. Teeny Tiny light bulbs
  131. FOB Issues
  132. transfer case/transmission
  133. transfer case pull/install? 94 rodeo 3.2
  134. Stripped EGR bolt hole
  135. Radio problems
  136. 1999 Rodeo LS V6 spark plug/coil diagram?
  137. 92 with starter problems
  138. To buy or not to buy transmission
  139. Fuel Injector o-rings
  140. low compression on rebuilt 4ze1 motor
  141. 1999 Isuzu Rodeo - Won't Start After Long Distance Driving
  142. rodeo efi 4ze1 motor kicks but wont start
  143. 1996 Passport, battery crosswired
  144. rodeo 4ze1 efi kicks but wont start
  145. Fuel Gas Sending Unit Rodeo 1998-2002
  146. Thunking when turning
  147. P0440 continous -Solenoids good
  148. 1999 Isuzu Rodeo, bad knocking noise
  149. Parking/E-brake
  150. Will GM 6 lug wheels fit my 92 rodeo
  151. Crankshaft wont turn
  152. 94 Psprt 3.2L4x4 diesel swap, wasting my time?
  153. Audio help?
  154. 2000 Rodeo - Knocking, Rough idle, misfires, surging
  155. Fuel pump problem
  156. Rear cam plug leaks...
  157. Cracked block?
  158. 1997 Rodeo Suspension
  159. transfer case issues???
  160. Wix Oil Filter
  161. #6 coil
  162. Radio change question.
  163. running rough- fuel filter/pump/system?
  164. Looking to buy
  165. My "new" Rodeo is finally ready!
  166. Isuzu Rodeo and Honda Passport same?
  167. random misfire code
  168. decarbonize?
  169. Fan in front of radiator in 97 passport
  170. First time doing a larger job successful :)
  171. computer system
  172. Electrical connections to 94 Passport 5 speed
  173. 93 Rodeo cranks but won't idle. Help!
  174. Blower not working
  175. 95 Rodeo, 1st gear will not kick in....
  176. Hello friends of the rodeo isuzu engine is so noisy?
  177. hello my freinds i from guadalajara mex. I need your help to find the harness that co
  178. power steering fluid leak
  179. 1995.5 3.2L V6 Engine
  180. 1997 Honda Passport Timing Belt Issue
  181. Transmission Control Module
  182. 1999 rodeo..wobbing sound while driveing slow
  183. Can the 3.5 replace the 3.2 in a 2001 Rodeo sport?
  184. Can 3.2 replace the 2.2 in a 2001 Rodeo Sport?
  185. 2004 Rodeo with 3.5L DI CEL ALERT
  186. TIMING belt and tensioner
  187. 2001 4 cylinder dead after oil change/ flush
  188. new img: now high idle.
  189. ticking like its nearly out of oil
  190. CEL Help
  191. 01 Isuzu Rodeo, Clicks Once, Won't Start
  192. Engine noise
  193. CEL is flashing, HELP!
  194. Engine pull update.
  195. 01 Isuzu Rodeo 15a ECM Fuse
  196. accumulator Piston Cover.
  197. check engine light and reduced power light
  198. help needed-bizarre electrical short on 99 passport.
  199. Misfire causes?
  200. 2nd Gen Intake Manifold Gasket
  201. bleeding 2000 rodeo ABS modulator... Help!
  202. Code P1171
  203. WHOA. not what bucking snorting backfire
  204. Negative / Positive Speaker Wire , 01 Rodeo
  205. Rear Diff Maintenance
  206. Thanks from a lurker!
  207. Running out of ideas, 95 Rodeo
  208. what is the tank size?
  209. Axel/CV Boot
  210. '97 w/ headlights but no parking lights??
  211. 95.5 air bag
  212. 99 rodeo rear wheel lugs
  213. '99 2.2L p0301/idle help
  214. Engine Rev in Park
  215. 95.5 rodeo pcv valve / grommet 3.2
  216. Camber kit
  217. loose steering wheel.
  218. Time for a new exhaust...
  219. Engine swap possible w/ GM 4.3 V6
  220. Rodeo body lift
  221. 96 Rodeo Losing Power
  222. manually open sunroof--2003 Isuzu Rodeo
  223. where can I find a 98 rodeo relay diagram?
  224. I almost sold my Rodeo, continued....
  225. i need this A.S.A.P
  226. point me in the right direction
  227. Replacing IMG
  228. 98 3.2 4x4 engine stalls
  229. Alignment Issue
  230. another problem
  231. *UPDATE on "EGR P0401 that won't go away"
  232. 98 rodeo wiring problem
  233. Can I do these myself?
  234. 1994 passenger side door
  235. Transmission Question.
  236. After warm up
  237. Alternator
  238. 1997 Rodeo idling problem update
  239. 97 Rodeo Issues
  240. 1997 rodeo sensor problem
  241. Knocking noise at speed
  242. H e l p
  243. High output alternator?
  244. passport coolant o-ring size
  245. Rawl fuse
  246. Key stuck in ignition...again!?!
  247. '99 Passport not firing on passenger cyl bank
  248. roof rack cross bars how to install
  249. rear noise
  250. 1994 Rodeo Thermostat Housing
