Our Community is 662,000 Strong. Join Us.
View Full Version : Rodeo | Passport | MU
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 2001 Honda Passport Front Brake issues.
  2. 2001 Rodeo Transmission
  3. 2000 isuzu rodeo shift indicator problems
  4. Couple of non-normal ideas... can I do'em?
  5. Where to get a C-clip for my rear axle?
  6. where to get cheapest ignition coil?
  7. Low rpm chug
  8. Transmission accumulator M.I.A.
  9. Ticking noise and weight of oil
  10. 2001 Rodeo Sport V-6 occasional stall
  11. 97 Rodeo Ocassional Starting Problem
  12. tranny perplexing problem
  13. new IMG, still hissing
  14. horn stopped working
  15. Replacing starter solenoid contacts
  16. 2001 Isuzu Rodeo with automatic 4x4...tranny issues?
  17. 2 BROKEN BOLTS when trying to change exhaust manifold gasket :( PLEASE help!
  18. Power steering hose???
  19. 96 Isuzu rodeo
  20. Rodeo spark plug question
  21. Tps ?
  22. 01 Rodeo 2.2L - Manual - P0301 code that WONT go away. Help or ideas?
  23. 99 Rodeo Transmission Issue
  24. cooling issues
  25. stalls when put into reverse
  26. I need an Isuzu WIZARD!! Rodeo 2.2l - 4cyl - P0301 ...NEED HELP, meh...please!! :(
  27. !996 Passport 3.2 Alternator dying?
  28. 2000 Rodeo 4L30E, 3.2 V-6
  29. Coil Pack Question
  30. Key won't turn in ignition
  31. New '97 Rodeo LS
  32. 1996 Rodeo heatercore plastic pipes broke
  33. 99 4cyl coolant leaking out of reservoir vent tube
  34. Where to purchase a heater core?
  35. Major Decision - Fix Tranny or Get rid of Car
  36. 01 Rodeo start problem but good battery
  37. 2001 Isuzu Rodeo oil pressure indicator
  38. 01 Rodeo Stiff door handle
  39. whats wrong with my tranni!
  40. honda passport shifts hard
  41. Fuel Pressure Regulator Removal 97 3.2
  42. How to adjust wipers
  43. 1999 rodeo
  44. 97 rodeo random misfire cylinder 5 & 6 misfire po101 & po102
  45. 1999 rodeo
  46. Radio wiring diagram
  47. Power steering pump belt adjustment
  48. Windshield Wiper Trouble - 00' Rodeo
  49. Clicking noise when turning right
  50. Power seat issue 2004 Rodeo
  51. How to get rid of the chat on the
  52. No power to OBDII code reader
  53. anyone know?
  54. Thanks for being here and ? about shocks
  55. 2001 Rodeo - Need Help Identifying Issue
  56. head gaskets will not seal
  57. 95 Rodeo 3.2L V6...long crank/start times
  58. Aligning timing belt on 97 Rodeo 3.2L
  59. Check Engine and Reduced Power Lights
  60. Sunroof /Moonroof Crank
  61. Hit 200,000 miles today
  62. Overheating problems with 1994 Honda Passport
  63. Rear end question?
  64. auotlite iridium plugs OK?
  65. '96 2.6L Idles fine, misses and dies @1600 RPM
  66. 91 Rodeo Brake Light
  67. 96 rodeo lost electric power on bumping road
  68. 2000 rodeo fuil pump
  69. 91 Rodeo clicking clutch pedal
  70. 200 Rodeo hard brake pedal
  71. 2000 rodeo wont start
  72. 96 Electrical Problem
  73. Spark plugs for 99 Rodeo
  74. timing belt issues on 99 rodeo
  75. Having starting issues after new head install
  76. 95 Isuzu Rodeo...a/c will not shut off
  77. 1995 Rodeo LS...power windows issue
  78. Whining when first started.....
  79. What did I get myself into?!
  80. 97 Rodeo 2.6l P0441 code
  81. Hitch for sale 98-01 rodeo, passport
  82. passport trans problems
  83. Check engine light blinking 2001 Rodeo
  84. is this normal
  85. 99 rodeo with light knock after warm up
  86. So long and thanks for all the tips.
  87. replacing burnt "alarm control unit" now horn wont work
  88. 94 LS 4x4 210k dead auto needs to go
  89. 97 Rodeo Intermittent Starting Problem
  90. Rodeo Sport Transmission Question
  91. isuzu rodeo 2001 scrapped for recall
  92. Rough start, ignition noise
  93. 2001 isuzu transmission problem
  94. 2001 Rodeo Sport Fuel Sender Question
  95. 1994 Isuzu Rodeo 3.2 Liter SOHC High Idle Problem!
  96. Alarm turn on by itself
  97. Where to buy parts?
  98. K&N Air Filter 1998 Honda Passport
  99. Transmission Click Sound
  100. 1998 Honda Passport Transmission Cooler
  101. Bumping/thumping noise underneath the dashboard
  102. 2002 Rodeo noise behind the glove box
  103. Never had a problem...now it's making a weird noise :(
  104. creeking sound
  105. New-used 97 Rodeo
  106. Spark plugs...?
  107. Freaking sound from the rodeo
  108. Made in Japan or USA?
  109. Honda Passport '94 V-6 3.2L
  110. 1998 Passport part out
  111. 1999 passport shocks
  112. passport issues
  113. New and have a rodeo problem
  114. 4 wheel drive doesn't stay engaged 97 Rodeo
  115. Frame swap on Rodeo
  116. FS: 98 Rodeo parts
  117. VIN to Tell Difference Between 95 and 95.5?
  118. All Kinds of issues
  119. The mysterious disappearing coolant saga...
  120. transmission loud between 1st and 2nd
  121. 1996 Honda Passport EGR question
  122. Need another key, 97 Rodeo
  123. 4x4 Front End Not Pulling
  124. Timing belt replacement
  125. 2001 Isuzu questions
  126. Rodeo 92 3.1L MAP Sensor
  127. 200 Rodeo trans again
  128. Rodeo photos
  129. 98 Rodeo bumper fix
  130. Thank you for a great forum
  131. Steamy exhaust?
  132. 98 Passport - Rear wiper acting weird
  133. I'm BACK!!! With a 97 Rodeo and ?s
  134. Isuzu Rodeo and Axiom Recall Letter
  135. Water pump
  136. parting out 2001 rodeo.
  137. Change or just drain and fill on Rodeo
  138. What is this? Help appreciated!
  139. Shift lock doesn't unlock despite foot on brake pedal
  140. rodeo 2004 aisin ATF pan plug size
  141. iat sensor 95 isuzu 3.2 v6 4x4
  142. 95 Isuzu Rodeo No Powersteering At Idle
  143. Replacement Windshield Washer Reservoir for 95 Rodeo
  144. Weird Starting Problem
  145. wanted-rodeo wiring harness/fusebox
  146. 99 passport check engine light
  147. rodeo blues
  148. Oil Substance in wheel well
  149. check transmission again
  150. 2001 Isuzu Rodeo Car Alarm Program Code
  151. 2001 Isuzu Rodeo Car Alarm Program Code
  152. Hood Stuck Closed
  153. Just picked up my first Rodeo, No Reverse?
  154. 95.5 Isuzu Rodeo running rich
  155. FLUIDS and stuff
  156. it sputters and dies
  157. Brake Pad Set Replacement
  158. The cursed P0401 EGR Flow Insufficient
  159. Replacing heater core - '95 Rodeo
  160. 95 rodeo vibration
  161. 98 Passport 3.2 speedo quit and tach flutters
  162. Leaking antifreeze!!!
  163. IM FRUSTRATED!!!!!! 1999 Rodeo 3.2l
  164. 2000 Pass Intermittent Stutter
  165. Atf change
  166. 2000 honda passport/isuzu rodeo v6 auto
  167. What is this!?!?!?!? '99 Rodeo
  168. 2001 Isuzu Rodeo p0463
  169. Rodeo ODB code 446
  170. 97 Rodeo Blower Not working
  171. 01 Rodeo Overheating - Opinions?
  172. 01 Rodeo Thermostat Install - Which Way?
  173. pics of 99 isuzu rodeo engiine bay
  174. 1995.5 Rodeo oil pressure and electrical problems
  175. Shift Indicator Problems on Automatic Honda Passport
  176. 2000 rodeo trans question.
  177. Recall issued for Rodeo frames!
  178. possible oil presure problem
  179. PO420, P0171 Need Help Please
  180. 2000 Rodeo Spark Plugs
  181. 99 Rodeo wiring harness
  182. 3.2l rodeo chatters!!!
  183. "CatFuzz"" DO you still have??
  184. Engine Fan, related...
  185. 97 rodeo "no dash lights"
  186. egr
  187. Coil Overs to replace stock coils and shocks 99 4WD Rodeo
  188. any idea?
  189. rear windshield wiper
  190. Isuzu Rodeo 2000 Engine wanted
  191. Rear differential Seal Leak?
  192. rodeo 2004 3.2L transmission fluid
  193. rodeo 2004 front rotors
  194. P1153 on 98 V6 Isuzu Rodeo manual speed
  195. Achilles Tires
  196. 2000 Isuzu Rodeo Parts Needed!
  197. Moonroof Drainage holes clogged?
  198. 2000 trnsmission leak
  199. transmission fluid
  200. Tailgate Lock Actuator
  201. 93 Rodeo power steering V-BELT tensioner assy
  202. Disappearing CEL
  203. 10yrs or 120k ... 10yrs for me ...
  204. 2001 Rodeo speeds up while driving
  205. 1996 rodeo 4 speed auto tran problem
  206. Looking to Buy 2000 Passport
  207. 2002 Rodeo - Clicking - Won't Turn Over - All Lights On
  208. Detailed help needed with IMG replacement on '99 Rodeo 3.2L
  209. Replacing thermostat On 1999
  210. '94 rodeo 3.2L no spark
  211. 98 Rodeo center cap spring washers ???
  212. 2001 Passport A/C Low Side Pressure Question.
  213. EGR clean the large hole that supplies exhaust flow
  214. Heres is a really weird problem.....Can anyone help??....please!!
  215. Need a keyless
  216. A Couple of issues with my 2001 Passport
  217. GPS Map Update
  218. cylinder is filling with water
  219. 2001 Passport
  220. 2000-2001 rodeo swap
  221. Just got a rodeo
  222. Whirring sound in Drivetrain... somewhere.. I think.
  223. Loose Skid Plate...
  224. Range mode sensor?????
  225. 99 rodeo camshaft position sensor where is it
  226. Isuzu Rodeo will not shut off
  227. Isuzu Rodeo Runs HOt
  228. 200k!
  229. My 2000 rodeo is slipping?
  230. 2001 Rodeo A/C clicking
  231. Isuzu gauge problem
  232. '93 Rodeo - Intermittently working during summer in 90+ temps
  233. It just clicks-98 rodeo
  234. 99 rodeo fuel pressure
  235. Adding New ATF fluid - Leaky Servo Cup
  236. isuzu rodeo clutch slave cylinder
  237. 00 trans question
  238. What fluid goes in the transfer case?? Feel stupid for asking, lol!!
  239. 01 Rodeo Misbehaving
  240. Car engine racing while on idle
  241. Connecting rods
  242. Where online do I buy a range mode sensor?
  243. Water Boiling "IN" Radiator (not out)
  244. 96 rodeo engine swap with a 99 rodeo
  245. 2000 Rodeo - no pwr windows, rear wiper, ac/heat, turn signals, ...
  246. Crankshaft broken?!?!
  247. 2000 Passport lighter/ACC socket no power
  248. Lights dim when braking
  249. 1997 rodeo ac problem
  250. My First 100k ...
