View Full Version : Rodeo/Passport
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. 92 misfiring
  2. 2000 Honda Passport - Whine on Accel
  3. 95.5 rodeo
  4. Isuzu Rodoe timing
  5. 02 Rodeo Sluggish Accelerating
  6. 1999 rodeo
  7. 1992 Rodeo, 2WD, 4cyl, needs engine mounts, maybe clutch.
  8. Stubborn shocks
  9. A few minor, but annoying issues...
  10. Rod Knock?
  11. 96 rodeo 3.2 SOHC 2wd problems
  12. How to clean egr passage in 2000 Honda Passport
  13. Throwout bearing question
  14. 5 spd... how stout?
  15. Crank shaft position sensor
  16. Idle/ECU Problems
  17. Spindle/Knuckle axle seals? Help
  18. 1999 Rodeo V6
  19. Rebuild or replace?
  20. Isuzu Repair manual
  21. 1999 Rodeo
  22. Looks like my H2O pump is leaking at 45K
  23. 971/2 Passport
  24. Wierd issue that effects startup and Idle
  25. key will not turn in lock
  26. 1998 Isuzu Rodeo wont start
  27. Souping up?
  28. Timing Belt/Water Pump Change Out
  29. Replace Front Rotors for 97 Rodeo with 4wd
  30. 2000 Rodeo 3.2V6 blown?
  31. EGR Tube diameter?
  32. 1998 Isuzu Rodeo ECU Location ????
  33. ELECTRIC WINDOWS/ 95.5rodeo
  34. half shaft removal
  35. 93 rodeo wont restart! 23 auto shop owners are stumped!
  36. help please
  37. Manual locking hubs
  38. Truck changes lanes on its own....
  39. Blue Devil Head Gasket Sealant
  40. Thud...check trans, cruise control?
  41. RBS/BRAKE lights
  42. Help - Possible bad head gasket?
  43. Crankshaft pulley removal
  44. 96 Rodeo Auto No Reverse
  45. 94 Passport Won't Start
  46. what fluid does my rearend take? 2001
  47. 2000 Isuzu Rodeo "Hissing"
  48. Winshield Wiper Issue
  49. the horrid rodeo lifters tick!
  50. My transmission hesitates
  51. if your lookin to buy fuel pressure gauge FYI
  52. crank pulley slipping????
  53. 2001 Rodeo blower works 1, 2 and 3 only
  54. 2000 Isuzu Rodeo
  55. 1995.5 Isuzi Rodeo New Owner Needs Help ASAP PLEASE!!
  56. 2001 rodeo
  57. Anyone ever buy a Carter fuel pump?
  58. 95 rodeo cruise control
  59. Need help on fuel gauge
  60. 97 Valve Cover gasket
  61. 96 Rodeo Radio Problems
  62. 99 Rodeo will not go shift into park or reverse
  63. 95 Rodeo gas blow back when filling tank?
  64. blowing white smoke
  65. 1997 runs like crap
  66. Denso spark plug price
  67. 97 1/2 to 2000 Rodeo
  68. Is a radiator flush on an older Rodeo OK?
  69. Successful Starter Removal on '01 Passport 4WD 3.2
  70. 1997 blowing ignition fuse
  71. Help! What did I fry
  72. I am, I am new to this forum
  73. 02 sensor questions
  74. 99 RODEO Front Speaker
  75. How to tighten crankshaft bolt
  76. Can't get rear gate to lock
  77. Trouble Code P0341
  78. Sluggish start
  79. power window problem
  80. How tight should timing belt be?
  81. Error Codes 1997 Rodeo 4ze1 efi
  82. exhaust gasket
  83. transfer case fluid fill??94 rodeo m/t
  84. 1996 Rodeo trans fluid drain fill / replace
  85. manual trans 94 rodeo transfer case???
  86. 95 rodeo/ 2000 passport engine compatibility
  87. Farewell 1998 Rodeo LS
  88. 95 rodeo
  89. 03 Rodeo replacement engine
  90. Whistling @ 2500 RPM
  91. help diagnosing sound
  92. Help! Surging and frequent stalling when A/C is on!
  93. Squeaking front end driving me nuts!!
  94. sluggish acceleration
  95. 1992 rodeo bad fuel pump
  96. transmission removal/transfer case 94 rodeo M/T
  97. 1995 Honda passport stuck in 4wd
  98. Re:Sounds like marbles in motor when I accelerate
  99. '96 Rodeo brake and ABS lights constant
  100. Running hot, AC cuts off
  101. finding a bad gas leak
  102. Lean on Both Banks
  103. How much Seafoam?
  104. '95 Rodeo 4cyl./5sp. random stalling
  105. 99 4WD Rodeo LSE ABS lights up driving over 70mph.
  106. 96 Rodeo, Won't Charge Properly
  107. P0442 code- purge solenoid need help
  108. 94 isuzu transfer case help
  109. Leaking valve cover ...
  110. Fixing it the Old Fashioned Way
  111. 1997 Left Rear Window Regulator
  112. Want to change Rodeo trans fluid?
  113. ABS sensor problems
  114. '93 Rodeo 4WD right front wheel noise
  115. CEL p0442 Can an exhaust leak cause this code?
  116. 2004 Rodeo burns 1qt oil in 3K miles
  117. Error code P1403 Rodeo 2002
  118. 92 Died and won't start
  119. Please help with my dumb transmission!
  120. 2001 Rodeo Reduced Power Light
  121. trans fluid-flush it or change it.
  122. suspension/handling recommendation
  123. brakes again.
  124. Stopped on Hwy and won't start
  125. new engine codes for me
  126. Starter??
  127. Air Conditioning
  128. Engine ig fuse keeps popping
  129. Speedometer-wacko
  130. 98 Rodeo Starter Issues
  131. Intake manifold
  132. 01 Rodeo fan belt replacement
  133. 1995 Passport sounds like a diesel
  134. map sensor
  135. 1996 Rodeo factory am-fm cassette
  136. Safety check before I try to add trans fluid
  137. Teeny Tiny light bulbs
  138. FOB Issues
  139. transfer case/transmission
  140. transfer case pull/install? 94 rodeo 3.2
  141. Stripped EGR bolt hole
  142. Radio problems
  143. 1999 Rodeo LS V6 spark plug/coil diagram?
  144. 92 with starter problems
  145. To buy or not to buy transmission
  146. Fuel Injector o-rings
  147. low compression on rebuilt 4ze1 motor
  148. 1999 Isuzu Rodeo - Won't Start After Long Distance Driving
  149. rodeo efi 4ze1 motor kicks but wont start
  150. 1996 Passport, battery crosswired
  151. rodeo 4ze1 efi kicks but wont start
  152. Fuel Gas Sending Unit Rodeo 1998-2002
  153. Thunking when turning
  154. P0440 continous -Solenoids good
  155. 1999 Isuzu Rodeo, bad knocking noise
  156. Parking/E-brake
  157. Will GM 6 lug wheels fit my 92 rodeo
  158. Crankshaft wont turn
  159. 94 Psprt 3.2L4x4 diesel swap, wasting my time?
  160. Audio help?
  161. 2000 Rodeo - Knocking, Rough idle, misfires, surging
  162. Fuel pump problem
  163. Rear cam plug leaks...
  164. Cracked block?
  165. 1997 Rodeo Suspension
  166. transfer case issues???
  167. Wix Oil Filter
  168. #6 coil
  169. Radio change question.
  170. running rough- fuel filter/pump/system?
  171. Looking to buy
  172. My "new" Rodeo is finally ready!
  173. Isuzu Rodeo and Honda Passport same?
  174. random misfire code
  175. decarbonize?
  176. Fan in front of radiator in 97 passport
  177. First time doing a larger job successful :)
  178. computer system
  179. Electrical connections to 94 Passport 5 speed
  180. 93 Rodeo cranks but won't idle. Help!
  181. Blower not working
  182. 95 Rodeo, 1st gear will not kick in....
  183. Hello friends of the rodeo isuzu engine is so noisy?
  184. hello my freinds i from guadalajara mex. I need your help to find the harness that co
  185. power steering fluid leak
  186. 1995.5 3.2L V6 Engine
  187. 1997 Honda Passport Timing Belt Issue
  188. Transmission Control Module
  189. 1999 rodeo..wobbing sound while driveing slow
  190. Can the 3.5 replace the 3.2 in a 2001 Rodeo sport?
  191. Can 3.2 replace the 2.2 in a 2001 Rodeo Sport?
  192. 2004 Rodeo with 3.5L DI CEL ALERT
  193. TIMING belt and tensioner
  194. 2001 4 cylinder dead after oil change/ flush
  195. new img: now high idle.
  196. ticking like its nearly out of oil
  197. CEL Help
  198. 01 Isuzu Rodeo, Clicks Once, Won't Start
  199. Engine noise
  200. CEL is flashing, HELP!
  201. Engine pull update.
  202. 01 Isuzu Rodeo 15a ECM Fuse
  203. accumulator Piston Cover.
  204. check engine light and reduced power light
  205. help needed-bizarre electrical short on 99 passport.
  206. Misfire causes?
  207. 2nd Gen Intake Manifold Gasket
  208. bleeding 2000 rodeo ABS modulator... Help!
  209. Code P1171
  210. WHOA. not what bucking snorting backfire
  211. Negative / Positive Speaker Wire , 01 Rodeo
  212. Rear Diff Maintenance
  213. Thanks from a lurker!
  214. Running out of ideas, 95 Rodeo
  215. what is the tank size?
  216. Axel/CV Boot
  217. '97 w/ headlights but no parking lights??
  218. 95.5 air bag
  219. 99 rodeo rear wheel lugs
  220. '99 2.2L p0301/idle help
  221. Engine Rev in Park
  222. 95.5 rodeo pcv valve / grommet 3.2
  223. Camber kit
  224. loose steering wheel.
  225. Time for a new exhaust...
  226. Engine swap possible w/ GM 4.3 V6
  227. Rodeo body lift
  228. 96 Rodeo Losing Power
  229. manually open sunroof--2003 Isuzu Rodeo
  230. where can I find a 98 rodeo relay diagram?
  231. I almost sold my Rodeo, continued....
  232. i need this A.S.A.P
  233. point me in the right direction
  234. Replacing IMG
  235. 98 3.2 4x4 engine stalls
  236. Alignment Issue
  237. another problem
  238. *UPDATE on "EGR P0401 that won't go away"
  239. 98 rodeo wiring problem
  240. Can I do these myself?
  241. 1994 passenger side door
  242. Transmission Question.
  243. After warm up
  244. Alternator
  245. 1997 Rodeo idling problem update
  246. 97 Rodeo Issues
  247. 1997 rodeo sensor problem
  248. Knocking noise at speed
  249. H e l p
  250. High output alternator?
