View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. horn does not work replaced control module . works when the alarm is turned on Help??
  2. 97 Rodeo compatibility question
  3. 1996 driver side tail light cover
  4. 93 hona passport
  5. Tapping sound
  6. Clock bulb
  7. Tansmission or VSS, 94 Passport 4X4 Auto
  8. mild but not tolerable sputter when accelerating
  9. Tricky Stereo Question... Dimmer Switch??
  10. 1996 Rodeo compatible parts
  11. 1998 rodeo #4 misfire
  12. Serpentine belt & idler pulley
  13. Giz - is it true that Dayton M/T's are the same
  14. Need Help Check engine and Power down Lights on
  15. Need new air intake tubing .....
  16. Help! I'm confused on which tires to buy for my 2000 Rodeo!
  17. Faulty dashboard lighting
  18. They don't call 'em "widow makers" for nothing...
  19. 98 Rodeo Timing
  20. Removing Rear Mounted Spare Tire?
  21. Where is the fuse for the alarm system on my 94 Rodeo?
  22. lifting a 92 rodeo LS
  23. WTB: Glass sunroof for 1st gen Rodeo/Passport
  24. 01 rodeo trans noise?
  25. Wix filters seem to make a difference
  26. 93 Izusu Rodeo front half shaft replacement
  27. over cooling rodeo
  28. 04 Rodeo Auto Transmission?
  29. Rough idle, surging, stalling
  30. Got VSV's working properly but still no 4WD??
  31. Very Noisy Belts ??
  32. Trans fluid change
  33. Trans slipping?
  34. 4Wd not working and light stuck on need help...
  35. 1994 Rodeo with surging idle, tried everything
  36. A few tips that will save you money on a "99 Rodeo V6
  37. Blower on an 3.2L
  38. no fuel after accident
  39. "Dad. The engine's smoking real bad."
  40. '04 Rodeo's temp gauge & '02 Rodeo Sport
  41. Oil Burn...
  42. 4WD does not turn off...
  43. Transission Overheating?
  44. packed snow vs. front grill
  45. Cold Start RPMS soar to over 6000???
  46. new way to refill the tranny?
  47. 94 Rodeo V6 Engine? Non-Interference?
  48. Serpentine belt and pulley's one grove off
  49. Wiper arm linkage
  50. Changing Tranny
  51. Metal noise under drivers floor
  52. Rusted Frame
  53. FAQ's for 1991-1997 Rodeo
  54. 1995 rodeo 4x4 does not engage help
  55. The Rodeo Is Back
  56. 2002 Rodeo V6 - Failing IMG symptoms?
  57. P0402 and P1404 on Honda Passport (aka Rodeo)
  58. '97 blow headgasket
  59. 99 Passport tranny makes it to 175k
  60. 1999 Passport Muffler
  61. help - Intake manifold gasket replaced and now I get a flashing CEL
  62. isuzu rodeo on lpg
  63. Jumping Tach?
  64. need to replace fuel line on 93 rodeo
  65. Bubbling sound when I turn off the truck
  66. Tire changing '02 Rodeo
  67. Need air compressor recommendations
  68. Passport trans leak
  69. WTF????!! Still waiting for parts!
  70. Tranny Problems
  71. Rear Corner Bumpers
  72. Brake Issue
  73. Fuel sending Unit - Fix Broken Gas Gauge
  74. EGR ,MAF, PCM or Intake gasket?
  75. Timing Belt
  76. Engine light
  77. Heater Problem - Any Ideas?
  78. passport idles and runs rough
  79. Check It Out
  80. 99 rodeo engine swap nite mare
  81. 96 passport passenger side window regulator replacement
  82. Either No 4WD, or no Dash Light for 4x4
  83. Somthing new last night...
  84. high carbons when trying to smog
  85. Passport wants to stall (sometimes)
  86. 99 passport issues
  87. 98 Honda Passport laundry list of things I need to fix...
  88. trans fluid change
  89. Who's got me beat? ......Anyone
  90. Strange sound
  91. Help Please
  92. 1995 passport 3.2 no spark
  93. transmission fluid
  94. Strange electrical problems
  95. 94 passport no shift
  96. Does everyone's heater suck or just mine?
  97. Should of listened...
  98. ECM Codes
  99. 96 3.2 Rodeo weird stuff
  100. Changing Oil
  101. Increase height
  102. Front Bumper Question
  103. Paint on Passport
  104. Driver power window failure
  105. High mileage Zu:
  106. Alternator compatibility...
  107. Where can I mount a tow hook.....
  108. Cat recomendations
  109. No 2wd or 4wd
  110. Trans light flasing/CEL on / Weird smell and clicking
  111. Coolent leak...
  112. 1995 Isuzu Rodeo
  113. Antifreeze in SparkPlug tube Cyl #2
  114. Lets clear some things up
  115. UOA of previous Maxlife & testiment of 3.2L
  116. rear defroster kind of not working
  117. help 3.2 liter engine idling really rough
  118. 96 rodeo power window relay
  119. 2000 honda passport
  120. 1993 3.2 V6 Engine Trouble
  121. Electrical System Problems
  122. Blower Motor No Sound
  123. 98 rodeo timing questions
  124. 1999 Isuzu Rodeo Wiper Problems
  125. acumulator piston do it yourself??
  126. P0300 code w/o cause? need help
  127. Not another alternator post...
  128. Noise/Vibration At High Speeds
  129. 89 Rodeo Transmission Prob. PLEASE HELP!
  130. Need supercharger for 2000 Trooper 3.2L V6
  131. 98 Rodeo ?'s
  132. 4th gear and code49
  133. Power Lock trouble! 1996 RODEO
  134. 1999 Rodeo 3.2L
  135. Check Engine Light on...code P0446
  136. Perfect pump for tranny
  137. Fuel sending unit
  138. Isuzu Rodeo 2000 6V 3.2L Faulty Codes
  139. FWIW - Valv Maxlife synthetic & cold temps
  140. 02 Passport
  141. How am I going to get the ABS sensor out!?
  142. Rear Brake Question
  143. Help Needed From The U.k. !
  144. 1998 Isuzu Rodeo 4X4 Updated
  145. 1995 rodeo CODE 44!
  146. clutch problem, help please
  147. 2000 Rodeo, weird idle
  148. 1996 Heater Core HELLLL!!!
  149. Anybody upgraded rear speaker size??...
  150. Newbie - Couple Questions
  151. Would bad IMG cause bad gas mileage??
  152. Sweet! $70 for 10-12HP for the 97-98 Rodeo
  153. 1990 starts,runs thens stops
  154. Ticking Right After Oil Change; Gets better with age
  155. Need some help with intake gasket issue
  156. Loose banging metal noise! Front left wheel
  157. rear wiper blade and rear defrost
  158. Do you carry tools with you?
  159. 2000 engine dead
  160. need help on 4X4
  161. 235/75/15 on a '93 Rodeo 4x4?
  162. Rear defrost stuck on....
  163. 98 rodeo coolant DISAPPEARING
  164. Engine racing
  165. Rear wiper doesn't work!
  166. Leak at tranny, small pan??
  167. Looking for Tranny interchange info
  168. I came across this video, wonder if anything broke
  169. Who says Canadian Winters are Bad?
  170. Fun thread - what's the highest RPM's you've
  171. Low oil pressure at idle, fine when driving
  172. More info on oil burning
  173. New owner with heater problem
  174. 2002 Isuzu Rodeo
  175. 30" of snow today at my place - should
  176. Fuel pressure regulator under warranty?
  177. FS 1998 Rodeo V6 5spd
  178. What to do?
  179. Power Door Lock Down
  180. Loose Steering
  181. Discount tire definitely holds up their ....
  182. Looking for hard to find part
  183. Dealer cost to replace EGR valve
  184. rear speaker pods 1995
  185. Gas tank capacity & Hitch deal
  186. came across this on youtube...
  187. Need tranny help
  188. A thank-you from a longtime lurker...
  189. 94 rodeo tranny in a 95??? HELP!!
  190. Help with a 95 Rodeo
  191. Headlight works but doen't??
  192. Bad news for Jiffy Lube customers
  193. 1998 Isuzu Rodeo Oil consumption
  194. 1998 Isuzu Rodeo Oil consumption
  195. A local tradition comes to an end.....
  196. 98 Rodeo lacks power, and misfires
  197. Engine lacks power, and misfires
  198. 2001 Rodeo CEL and RPL coming on
  199. Chevy Wheels!
  200. HELP! My mechanic doesnt know the name of this part.
  201. 2001 Sport brake job
  202. Starting issue too, no CEL
  203. Ominous sound and etc...
  204. Starting issue
  205. spectacular offroad pics
  206. Need Valve cover gasket replacement help
  207. strange gear indicator after engine rebuild.
  208. Reminder; pet lovers/owners - keep
  209. shut off using RW defog
  210. oil cooler leak
  211. Key won't turn in ignition
  212. Tried to order from St. Charles...
  213. Researching a loose PCM connection
  214. 2006 v6 CEL strangeness
  215. 96 Isuzu Rodeo Gas Mileage Problems
  216. timing belt question
  217. 97 Passport stater 3.2
  218. How do I pass emissions?
  219. New Rotor Break In??
  220. Help Replacing Damaged Rear Side Bumper
  221. Isuzu Option Codes Same As GM's Codes?
  222. Front & Rear Differential Service - 95 Rodeo
  223. 96 rodeo panel lights
  224. Anybody need a parts car?
  225. 98 Rodeo Fuel Sending Unit
  226. Turbo options ??????????????????
  227. Rear window
  228. Tire Mag sizes
  229. couple of questions
  230. 94 Rodeo squeels when accelerator mashed
  231. door lock problem
  232. 94 Rodeo security light/keyless entry?
  233. Rear Windows
  234. P401 code keeps coming back
  235. no 4x4 this morning, 96 Rodeo 3.2
  236. oil change gone bad
  237. Problems when cold
  238. easy ways to lower a rodeo... Please help!!!!
  239. How to: Fuel Filter...
  240. '98 Amigo clutch problems ?
  241. I have an idle problem!!! PLZ help me!!
  242. Oil pan
  243. Maybe a stuck EGR
  244. Timing set-up question
  245. code 0463 comes frquently on rodeo 01
  246. Rodeo won't Start! HELP!!!!!!
  247. 2001 Isuzu Rodeo rpm problem
  248. Tran pan bolts stripped
  249. rodeo 95 with transmission light on
  250. !993 Rodeo Winding noise from Rear.
