View Full Version : Rodeo/Passport
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Tire/Rim question
  2. Idle air control valve
  3. A/C expansion valve location on 99 rodeo v6
  4. 1998 Rodeo Isuzu Window and Cruise won't work
  5. engine swap
  6. 2000 Rodeo Door Popping
  7. Strange Transmission issues- 99 rodeo
  8. Small Gas Tank Issue
  9. Window washer question
  10. Where do you folks get parts?
  11. 94 rodeo engine problems
  12. 95 rodeo 3.2L 4WD 5 speed gas mileage?
  13. 1993 V63.2 4WD wheel bearing
  14. Fan Clutch - how many of you have had
  15. Timing belt, plugs & hoses
  16. 96 Rodeo Gas Pedal Sticking Pictures!
  17. Yankee Hill / Loch Lomond trails run pics
  18. 2001 Rodeo brake light problem
  19. Repairs Cost: Front Brakes, T-Belt, water pump etc
  20. Air Conditioning Myth !?!?!?
  21. '99 Passport trans filter change
  22. Found an engine for a '97
  23. Extended warranty
  24. 1998 Isuzu Rodeo 4X4 problem
  25. 01' Rodeo p300 code/Randm mtpl cylndr msfire, HELP!!!!
  26. Low Mileage 96 Rodeo on Ebay:
  27. What Is Better?
  28. off-topic help
  29. 94 Rodeo ATF coolant lines
  30. 94 Rodeo is gutless til "Check Engine" light comes on
  31. rodeo shocks..
  32. Cross country road trip chcklist; have I
  33. 1998 Isuzu Rodeo AC not engaging
  34. Surferfletch - can you advise me
  35. Rodeo Gas Pedal Sticking and Brake Fluid Light on HELP!!
  36. Rodeo problem.
  37. '95 Rodeo... no Instrument Lights
  38. Starter?
  39. Rodeo Alt OEM New on Ebay:
  40. dirty egr stealership$$
  41. proud of my battery
  42. 2000 Isuzu Rodeo - Electrical
  43. thermostat
  44. Heavy duty radiator replacement?? ......
  45. '98 Rodeo A/C Compressor Won't Engage
  46. 1998 Isuzu Rodeo Rear Axle
  47. Back to smaller tires - anyone interested ...
  48. 97 Passport- Not getting enough charge
  49. Alternator Again!!?!?
  50. Problems never end
  51. '94 Rodeo overheating issues
  52. Parts/ classifieds
  53. 95 Passport engine troubles
  54. Bosch, PIAA, Rain-X, Michelin, : Which is the best wiper-blade?
  55. 1998 Rodeo miss-fire
  56. Best place to buy Brake Rotors and Pads???
  57. Oil weights
  58. Tranny techs, come inside (99 Rodeo V6)
  59. Need auto transmission for a 1996 Rodeo
  60. Look what I found.....
  61. +98 hard top
  62. trailer attachement 7 pins for Rodeo 2001 3.2l
  63. 1996 Rodeo 3.2, 4x4, 125k - throttle surge
  64. Crazy Dash Lights...
  65. Cel???
  66. Fan Clutch? Slipping Belt? SUPER LOUD screeching at cold startup!!!
  67. Diffy Cover Questions
  68. Curious: what's your gas bill up to??
  69. Rear bearing? Or just brakes?
  70. Tensioner Question
  71. Saints John / Deer Creek Trail this weekend - mostly scenery
  72. CTS questions
  73. power window in/op
  74. Idle Problem Solved - IACV Cleaned (99 Passport)
  75. 1998 Isuzu Rodeo rear brakes
  76. 1998 Isuzu Rodeo timing belt replacement?
  77. Interior Lighting/ parking lights
  78. 1995 Rodeo 3.2l MAF?
  79. RwABS and Brake Dashboard Lights
  80. Ok, since my Rodeo is the oil tester dummy
  81. Check engine light on 2000 Rodeo
  82. 1998 Isuzu Rodeo
  83. 1998 Isuzu Rodeo AC not working
  84. Fuseable Link
  85. Easy Cruise Control?
  86. 99' rodeo cylinder head bolts
  87. Need center caps?
  88. Range mode sensor
  89. 1995 Isuzu rodeo no spark
  90. where is fuel filter located?
  91. 99 rodeo fuel pump noise
  92. No power in cab
  93. isuzufaq.com
  94. Passport objections?
  95. Fuel gauge floats...
  96. 1991 Rodeo Performance Exhaust???
  97. code P300- randum multiple cylender mis-fire
  98. Steering Wheel Cover Removal
  99. Front Driveshaft Stuck!!
  100. 97 Isuzu Rodeo no fuel no fire
  101. Overheating! water missing, but where?
  102. If you could design your own Isuzu?
  103. Curious - if you could do it over again,....
  104. Has Anyone Changed A Clutch?
  105. Rear Main Seal
  106. Oil Burning Problems? 2001 Rodeo
  107. P0430 code represent which sensor?
  108. Hawaii Rodeo Owners? Having trouble climbing hills (97 Rodeo 3.2)
  109. clunking in front suspension
  110. 2 problems with 01 Rodeo P0430 code & water leak
  111. 99 Passport hesitating to shift into reverse
  112. Torque specs on alloy wheels??
  113. egr valve replacement
  114. FYI - future reference for wheel/rim info....
  115. Pre 98 bumper swap
  116. FAQ Problems
  117. ’98 Rodeo Alarm Problems
  118. 96 Rodeo - Problems are piling, what is the cause?
  119. Temporary FAQ'S page until they get the real one up and running again.
  120. Wheels - don't have much choice but to
  121. When will the FAQ'S page work again???
  122. Replacing engine on 2000 Isuzu
  123. CD Player shorted a fuse in link?
  124. Exsessivly high idle 2000-2500 rpms
  125. rattling noise under the hood
  126. Speedometer gear source???
  127. source for '97 chrome bumper end cap
  128. 01 rodeo wont go into gear
  129. auto tranny question
  130. moon roof
  131. OEM rear brake pad set.
  132. to all off roaders... true story..
  133. help 99' rodeo won't start
  134. my rodeo has low power at low end
  135. colorado trail run this weekend
  136. When replacing rotors?
  137. 1995 Rodeo, OBD 2 connector whereabouts
  138. Coolant Problem.
  139. Help with frozen track bar and shock nuts!
  140. Well got some great news...& sad news...
  141. pcv valve doesn't fit 3.2L v6 93 Rodeo
  142. 01 rodeo trans range sensor?
  143. 1993 Rodeo Oxygen Sensor light at 180,000 miles
  144. threw a rod
  145. Passport Timing Belt
  146. Need help withfor my 1996 Izusu Rodeo!
  147. 2001 Rodeo ABS Light
  148. Is 2007 the final year for Isuzu???
  149. Cheap fix for tailgate net in rodeo
  150. Trail run to Bill Moore Lake - lots of pics
  151. 4WD Light will Not come on.
  152. ABS and brake lights on?
  153. 02 Rodeo cooling fan
  154. 99 rodeo shift knob button will not push in
  155. another exteneded drive and...
  156. Going Crazy over this!
  157. 97 rodeo rear glass won't open!
  158. Idler Arm
  159. engine for a 95 Trooper - $500
  160. Stuck Spark Plugs
  161. Freon?
  162. Anybody know about KYB GR2 Shocks?
  163. 1995 Passport V6 Crank No Start
  164. RrABS and BRAKE light illuminated tonight
  165. Code P0430 on my 01 Rodeo?
  166. Tranny fluid question
  167. 01 Rodeo steady cel went off
  168. Overheating - Bypass Hose Coolant Leaking
  169. Multi-Port Injector Question and a few others
  170. Alarm problems with 99 Isuzu Rodeo
  171. 2001 Rodeo Check Engine Light Stays On
  172. 99 Rodeo ECM gets very hot....
  173. Rancho or Sensa-Trac?
  174. Will They Pay ?
  175. Please help!!! power loss
  176. Gotta check this out... what an embarrasement for mercedes
  177. Rodeo 4 wheel drive
  178. New alternator chewed through belt < 1 month
  179. GREAT - Now the tranny fill plug ...
  180. Timing Belt Parts and Bad Auto Parts Staff
  181. CEL problems
  182. Yet another question about cleaning the EGR valve
  183. here's a question that will stump you
  184. Hatch glass
  185. Tranny problems
  186. Standing oil in common chamber / intake plenum!
  187. Power steering problems...
  188. Engaging 4WD - HOW TO on-the-fly-shift for my Honda Passport 1996, Please help
  189. Speedometer on 92' Rodeo
  190. Transmission
  191. Is the tranny relearning??........
  192. rodeo turbo
  193. Clutch Replacement
  194. clean engine compartment
  195. Test drove an '02 Trooper; can't say
  196. 2002 Rodeo V6 oil filter wrench
  197. Spark plug question:
  198. '95 Rodeo 2WD LSD
  199. To Rodeo or not to Rodeo - that's my question
  200. 2 quick questions
  201. Size of ATF coolant hoses?.........
  202. Getting ready for timing belt and water pump swap.. need some advice please...
  203. Rodeo Alarm Buzzer
  204. Sorry a few more auto ??
  205. GM THM 200-4R does our 4L30-E have
  206. Keyless locking and alarm setting problem
  207. cable routing on 94 roedo power windows
  208. Camshaft Position Sensor & Valve Cover Gasket
  209. High mileage ATF for high mileage auto??
  210. Knock in steering
  211. Suspension Questions
  212. 93 Rodeo stalls when its put into gear.. Help
  213. In over my head
  214. My 95.5 Rodeo is totalled
  215. 93 Rodeo Clutch Problem
  216. Random harness in center console
  217. Rodeo02 - need your help in regards
  218. Thermostat only opens after engine is off -- Why????
  219. Replace Mirror
  220. FAQ Maintenance
  221. Changing 99 Passport serpentine belt (visable).
  222. Cracked Cylinder Head 99 Rodeo
  223. Replaced Timing Belt
  224. Replaced Timing Belt
  225. Keyless entry question
  226. 97 Rodeo Starter removal?
  227. '95 rodeo shifts without key in ingnition.
  228. 100 Amp main fuse blowing 98 rodeo V6
  229. Electrical Problems
  230. Puchasing manual hubs
  231. Hissing from passenger side
  232. A few questions abou my 95
  233. 9 1/2 or 10 1/4 clutch?
  234. coolant disposal
  235. Replace Engine?
  236. Replacing rotors on 01 Rodeo
  237. need new shocks
  238. leak soaking my rear flooring
  239. Transmision shifting hard??
  240. Brake Question Help Please!
  241. CEL code P0440
  242. Alternator change on a 95
  243. 95 Rodeo tranny, no 4th/ just overreevs?
  244. P0131 &P0137 O2 Sensors
  245. Good thing we ain't driving our Rodeo's in Scotland
  246. cracked radiator
  247. 1998 Rodeo
  248. '97 Rodeo for sale.....
  249. Transmission
  250. popping noise
