View Full Version : Rodeo/Passport
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. "Dad. The engine's smoking real bad."
  2. '04 Rodeo's temp gauge & '02 Rodeo Sport
  3. Oil Burn...
  4. 4WD does not turn off...
  5. Transission Overheating?
  6. packed snow vs. front grill
  7. Cold Start RPMS soar to over 6000???
  8. new way to refill the tranny?
  9. 94 Rodeo V6 Engine? Non-Interference?
  10. Serpentine belt and pulley's one grove off
  11. Wiper arm linkage
  12. Changing Tranny
  13. Metal noise under drivers floor
  14. Rusted Frame
  15. FAQ's for 1991-1997 Rodeo
  16. 1995 rodeo 4x4 does not engage help
  17. The Rodeo Is Back
  18. 2002 Rodeo V6 - Failing IMG symptoms?
  19. P0402 and P1404 on Honda Passport (aka Rodeo)
  20. '97 blow headgasket
  21. 99 Passport tranny makes it to 175k
  22. 1999 Passport Muffler
  23. help - Intake manifold gasket replaced and now I get a flashing CEL
  24. isuzu rodeo on lpg
  25. Jumping Tach?
  26. need to replace fuel line on 93 rodeo
  27. Bubbling sound when I turn off the truck
  28. Tire changing '02 Rodeo
  29. Need air compressor recommendations
  30. Passport trans leak
  31. WTF????!! Still waiting for parts!
  32. Tranny Problems
  33. Rear Corner Bumpers
  34. Brake Issue
  35. Fuel sending Unit - Fix Broken Gas Gauge
  36. EGR ,MAF, PCM or Intake gasket?
  37. Timing Belt
  38. Engine light
  39. Heater Problem - Any Ideas?
  40. passport idles and runs rough
  41. Check It Out
  42. 99 rodeo engine swap nite mare
  43. 96 passport passenger side window regulator replacement
  44. Either No 4WD, or no Dash Light for 4x4
  45. Somthing new last night...
  46. high carbons when trying to smog
  47. Passport wants to stall (sometimes)
  48. 99 passport issues
  49. 98 Honda Passport laundry list of things I need to fix...
  50. trans fluid change
  51. Who's got me beat? ......Anyone
  52. Strange sound
  53. Help Please
  54. 1995 passport 3.2 no spark
  55. transmission fluid
  56. Strange electrical problems
  57. 94 passport no shift
  58. Does everyone's heater suck or just mine?
  59. Should of listened...
  60. ECM Codes
  61. 96 3.2 Rodeo weird stuff
  62. Changing Oil
  63. Increase height
  64. Front Bumper Question
  65. Paint on Passport
  66. Driver power window failure
  67. High mileage Zu:
  68. Alternator compatibility...
  69. Where can I mount a tow hook.....
  70. Cat recomendations
  71. No 2wd or 4wd
  72. Trans light flasing/CEL on / Weird smell and clicking
  73. Coolent leak...
  74. 1995 Isuzu Rodeo
  75. Antifreeze in SparkPlug tube Cyl #2
  76. Lets clear some things up
  77. UOA of previous Maxlife & testiment of 3.2L
  78. rear defroster kind of not working
  79. help 3.2 liter engine idling really rough
  80. 96 rodeo power window relay
  81. 2000 honda passport
  82. 1993 3.2 V6 Engine Trouble
  83. Electrical System Problems
  84. Blower Motor No Sound
  85. 98 rodeo timing questions
  86. 1999 Isuzu Rodeo Wiper Problems
  87. acumulator piston do it yourself??
  88. P0300 code w/o cause? need help
  89. Not another alternator post...
  90. Noise/Vibration At High Speeds
  91. 89 Rodeo Transmission Prob. PLEASE HELP!
  92. Need supercharger for 2000 Trooper 3.2L V6
  93. 98 Rodeo ?'s
  94. 4th gear and code49
  95. Power Lock trouble! 1996 RODEO
  96. 1999 Rodeo 3.2L
  97. Check Engine Light on...code P0446
  98. Perfect pump for tranny
  99. Fuel sending unit
  100. Isuzu Rodeo 2000 6V 3.2L Faulty Codes
  101. FWIW - Valv Maxlife synthetic & cold temps
  102. 02 Passport
  103. How am I going to get the ABS sensor out!?
  104. Rear Brake Question
  105. Help Needed From The U.k. !
  106. 1998 Isuzu Rodeo 4X4 Updated
  107. 1995 rodeo CODE 44!
  108. clutch problem, help please
  109. 2000 Rodeo, weird idle
  110. 1996 Heater Core HELLLL!!!
  111. Anybody upgraded rear speaker size??...
  112. Newbie - Couple Questions
  113. Would bad IMG cause bad gas mileage??
  114. Sweet! $70 for 10-12HP for the 97-98 Rodeo
  115. 1990 starts,runs thens stops
  116. Ticking Right After Oil Change; Gets better with age
  117. Need some help with intake gasket issue
  118. Loose banging metal noise! Front left wheel
  119. rear wiper blade and rear defrost
  120. Do you carry tools with you?
  121. 2000 engine dead
  122. need help on 4X4
  123. 235/75/15 on a '93 Rodeo 4x4?
  124. Rear defrost stuck on....
  125. 98 rodeo coolant DISAPPEARING
  126. Engine racing
  127. Rear wiper doesn't work!
  128. Leak at tranny, small pan??
  129. Looking for Tranny interchange info
  130. I came across this video, wonder if anything broke
  131. Who says Canadian Winters are Bad?
  132. Fun thread - what's the highest RPM's you've
  133. Low oil pressure at idle, fine when driving
  134. More info on oil burning
  135. New owner with heater problem
  136. 2002 Isuzu Rodeo
  137. 30" of snow today at my place - should
  138. Fuel pressure regulator under warranty?
  139. FS 1998 Rodeo V6 5spd
  140. What to do?
  141. Power Door Lock Down
  142. Loose Steering
  143. Discount tire definitely holds up their ....
  144. Looking for hard to find part
  145. Dealer cost to replace EGR valve
  146. rear speaker pods 1995
  147. Gas tank capacity & Hitch deal
  148. came across this on youtube...
  149. Need tranny help
  150. A thank-you from a longtime lurker...
  151. 94 rodeo tranny in a 95??? HELP!!
  152. Help with a 95 Rodeo
  153. Headlight works but doen't??
  154. Bad news for Jiffy Lube customers
  155. 1998 Isuzu Rodeo Oil consumption
  156. 1998 Isuzu Rodeo Oil consumption
  157. A local tradition comes to an end.....
  158. 98 Rodeo lacks power, and misfires
  159. Engine lacks power, and misfires
  160. 2001 Rodeo CEL and RPL coming on
  161. Chevy Wheels!
  162. HELP! My mechanic doesnt know the name of this part.
  163. 2001 Sport brake job
  164. Starting issue too, no CEL
  165. Ominous sound and etc...
  166. Starting issue
  167. spectacular offroad pics
  168. Need Valve cover gasket replacement help
  169. strange gear indicator after engine rebuild.
  170. Reminder; pet lovers/owners - keep
  171. shut off using RW defog
  172. oil cooler leak
  173. Key won't turn in ignition
  174. Tried to order from St. Charles...
  175. Researching a loose PCM connection
  176. 2006 v6 CEL strangeness
  177. 96 Isuzu Rodeo Gas Mileage Problems
  178. timing belt question
  179. 97 Passport stater 3.2
  180. How do I pass emissions?
  181. New Rotor Break In??
  182. Help Replacing Damaged Rear Side Bumper
  183. Isuzu Option Codes Same As GM's Codes?
  184. Front & Rear Differential Service - 95 Rodeo
  185. 96 rodeo panel lights
  186. Anybody need a parts car?
  187. 98 Rodeo Fuel Sending Unit
  188. Turbo options ??????????????????
  189. Rear window
  190. Tire Mag sizes
  191. couple of questions
  192. 94 Rodeo squeels when accelerator mashed
  193. door lock problem
  194. 94 Rodeo security light/keyless entry?
  195. Rear Windows
  196. P401 code keeps coming back
  197. no 4x4 this morning, 96 Rodeo 3.2
  198. oil change gone bad
  199. Problems when cold
  200. easy ways to lower a rodeo... Please help!!!!
  201. How to: Fuel Filter...
  202. '98 Amigo clutch problems ?
  203. I have an idle problem!!! PLZ help me!!
  204. Oil pan
  205. Maybe a stuck EGR
  206. Timing set-up question
  207. code 0463 comes frquently on rodeo 01
  208. Rodeo won't Start! HELP!!!!!!
  209. 2001 Isuzu Rodeo rpm problem
  210. Tran pan bolts stripped
  211. rodeo 95 with transmission light on
  212. !993 Rodeo Winding noise from Rear.
  213. Gizmo going offline.. for a little bit
  214. DPFE sensor - anyone heard of this IN
  215. d44 question
  216. Aftermarket stereo recommendation & any
  217. Radio Display - dimming then comes back, then repeats.
  218. Rear Wiper none stop! Need Help!
  219. Need Parts For A Rodeo??
  220. 2002 V6 codes P0171, P0174, P0507
  221. Beware the Serpent!
  222. Noob needs help with 91 Amigo starting problem
  223. 1998 Rodeo Transfer case????
  224. 95' 2.6L Rodeo Overheating....HELP!
  225. Grill Guard ?????
  226. 98 Rodeo Fuel gauge again
  227. MAP - any particular brand? Anyone else
  228. Timing Belt
  229. better mpg?
  230. 94 audio?
  231. hey guys, new guy here
  232. I don't need these parts anymore - do you?
  233. 91 engine codes
  234. Pics of my lifted Rodeo
  235. FS 1998 Isuzu Rodeo V6 5spd
  236. Maintenance day
  237. 1994 passport rear size?
  238. Transmission Help...Please!
  239. Hard Shift in Transmission.
  240. 2002 V6 cleaning the Idle Air Control Valve
  241. Classifieds/ Parting out ?
  242. Exhaust
  243. 2002 Rodeo won't start/fuel related
  244. Idle air control - know about them?
  245. HELP!! Trying to track down the pinging source.
  246. Tranny problem...
  247. A horrible end to my Rodeo - this shouldn't have happened.
  248. Towing With 01 Passport
  249. New EGR Valve didn't help ...
  250. 96 Rodeo deal or no deal?
