Our Community is 662,000 Strong. Join Us.
View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Which Oxygen Sensors Impact on Smog Test
  2. fuel line
  3. 2001 Rodeo thermostat
  4. loss of power...?
  5. Valve bucket holder tool V6
  6. Oh man. My rear main seal is completely shot.
  7. Dana 44 alxe questions
  8. 94 rodeo v6 stuttering problems
  9. New Starter and still won't crank!!!
  10. HELP - '99 Rodeo won't start / has good battery
  11. Installing and a Trans Cooler on a 2001 Rodeo LSE
  12. 95 rodeo speedo question
  13. 3.2L Valve Adjusting tools
  14. Help....red light on!!
  15. fuel pump power again!
  16. Tires- need help asap!
  17. Engine Swap
  18. coolant dump
  19. Do i need new shocks?
  20. Fog light
  21. Opinions on Firestone Destination A/T's.....
  22. gas gauge? has this happend to you
  23. fuel pump power
  24. Please Help 95 rodeo fuel problems
  25. HEAVY power steering.
  26. Drivers side wiper, not wiping
  27. Left Tail Light
  28. Horn keeping honking!
  29. noise
  30. exhaust leak?
  31. A/C compressor noise
  32. Location test....for you Coloradoan's.....
  33. fule pump installation
  34. ABS Speed Sensor
  35. How long to drop fuel tank and replace sending unit?
  36. trans problem
  37. 02 Rodeo Speed Hesitation
  38. 2000 Isuzu Rodeo left signal light
  39. Here's another good mystery sound to figure out!
  40. Dash lights
  41. Overheating problem...help would be greatly appreciated. (A little lengthy)
  42. P0240: Catalyst System Efficiency Below Threshold (Bank 1): UPDATE!
  43. 03 Rodeo over revving, sounds loud, like it's stuck in gear
  44. Getting rid of my '96
  45. 97 Rear leafspring bushings
  46. Got MUD.....will travel....
  47. any comments on aftermarket egr valves
  48. 98 Alternator specs?
  49. Serpentine belt to bypass A/C
  50. Chrome pieces?????
  51. What Kind of Seats?
  52. P0240: Catalyst System Efficiency Below Threshold (Bank 1) with pictures!
  53. 2001 Rodeo brakes issue
  54. Stalls and Will Not Start???
  55. Locked my keys in my '99
  56. No Power
  57. 1998+ rodeo/passport/amigo parts for sale
  58. 2001 isuzu Rodeo 6cyl,4wd
  59. Timing belt idler bearing
  60. Water soaked floor
  61. Look familiar?
  62. hose replacement question
  63. Clicking... Valve adjustment?
  64. RKE aftermarket
  65. Widest tires for a 98 Rodeo???
  66. Flickering lights
  67. 99 Passport CEL nightmare!
  68. Replacing rear left side vent glass
  69. Lights Out
  70. 92 Rodeo loosing power at 3000 rpms
  71. How do you know when to replace shocks??
  72. wheel clearance????
  73. brakes
  74. Rodeo shifter won't go into Park or Low
  75. Have a problem..was given a company
  76. Water Dripping from Passenger Side
  77. Size of tranny cooler hoses?
  78. Which Transmission Fluid???
  79. Anyone have a passport fender flare?
  80. wiper controls i hate it
  81. high idle po 507
  82. Shifting Hard
  83. 2001 Rodeo tailgate
  84. What is that butterfly thingy
  85. Rodeo stalls only with initial acceleration
  86. List of things to do and when sticky?
  87. anybody ever troubleshoot cruise on 95 and earlier rodeo?
  88. 01 Isuzu Rodeo ABS or Computer
  89. Braker Caliper Pin/Bolt Question
  90. 99 passport CEL after IMGs
  91. What a PITA weekend!
  92. Rear Cup Holder
  93. Manual Transmission Fluid Level
  94. 1995 4X4 manual trany
  95. Computer chip in 95 rodeo?
  96. Adding Remote start/keyless entry
  97. Parking Brake Light?
  98. Timing Belt problems
  99. '92 Rodeo 3.1L V6 Erratic Idle
  100. 1995 Passport 3.2L BackFires?
  101. Rodeo/passport replacement
  102. Freeze Plugs
  103. Eeek! Friend hit 5,500 rpm's...anything to
  104. Do I REALLY need the front hub nut tool?
  105. Manual Hub Install on '01 Passport
  106. Valve Shims on 6VD1 DOHC
  107. isuzu engine runs rich
  108. wanky suspension
  109. 94 passport constant stalling problem
  110. Out Of Ideas & Money
  111. power steering hose
  112. '98 3.2 camshaft timing
  113. 98 Isuzu Rodeo Engine trouble
  114. P0753 - shift solenoid electrical
  115. lock and other issues
  116. New Alternator Installed, New Problem
  117. How do the spark plugs come out?
  118. 2000 Passport Shock recommendations
  119. 2000 Rodeo Instrument Cluster or ???
  120. Deadly Warning for dog owners in TX, FL, & CO.....
  121. 99 Passport stripped EGR pipe nut. Plz help!
  122. Passport/Rodeo rims & tires Questions
  123. 1996 Passport EX For Sale
  124. 91 2.5l Diesel engine swap
  125. 1995 Honda Passport Leaking Brake Fluid
  126. 96 Rodeo Charging Problem
  127. 96 Passport Valve covers
  128. Lifting the Green Goblin 2"
  129. Stereo Installation - problem with instrument panel lights
  130. engine stalls after rough idle
  131. 1997 Rodeo suddenly dies
  132. Fuel pump dying? '99 Rodeo - Anyone?
  133. Coolant leaking from under 1996 Rodeo 3.2L
  134. 1999 Passport CEL codes
  135. Special plugs for '01 Rodeo
  136. Blinking CEL, runs rough - for a friend
  137. Wanting to tackle tb and wp
  138. Rough riding 99 Rodeo
  139. Alternator Belt too tight?
  140. Where is it?
  141. Alternator Amperage Question
  142. Plane crash site trail run pics
  143. FYI - No longer using Napa Gold's on.....
  144. What size shocks needed for a 3" lift?
  145. Rodeo Sport Amigo Top Zipper Window Repair
  146. Don't call her ole' faithful for nothing....
  147. Electrical Issue: Radio (AUX) Interference
  148. Cen-Tech OBD II CODE READER
  149. 2000 Rodeo. slipping transmission
  150. 4wd light blinking, shifts into 4wd, in 4wd grinds in tight turn
  151. temp idel falure
  152. 1997 Just quit running
  153. 98 Passport condenser install instructions
  154. Dealership 2nd opinion...
  155. Interesting P0300 Code on 2001 Passport
  156. Another timing belt ???
  157. New spark plugs without new wireset?
  158. I MUST be crazy......
  159. 1998 rodeo
  160. 95 Passport hamonic balancer removal
  161. Feeler for Daily Driver
  162. Leaking tranny fluid from up top?
  163. where can i find a lift kit
  164. CEL(Check Engine Light)
  165. More Colorado scenery pics for SurferFletch
  166. 99 isuzu rodeo0(5spd-manual)question about battery?
  167. 93 borg warner 5 speed
  168. 93 2.6 rodeo ticking.
  169. 2000 Rodeo 'Slip Yolk'??
  170. will the 94 gauges fit into 91?
  171. Timing Belt--when to replace?
  172. Our 900 mile journey thru Colorado Rockies...
  173. power loss @ check light
  174. 93 Rodeo Stuck Rear (tailgate) Glass
  175. Disgusted in Colorado...tell me about Montana, WY,
  176. A/C: Air conditioning stopped working
  177. Outer CV boot
  178. 93 rodeo engine power loss
  179. 99 Rodeo (Frontera) ABS braking issues
  180. 95.5 3.2 v6 runs rough @ 2k rpms
  181. Normal Idle RPM
  182. 99 Passport Voltage Inquiry
  183. Problems putting 99 Honda into Park.
  184. 01 rodeo starter problem ?
  185. Tranny leak?
  186. Automatic trans not shifting
  187. Rodeo, rear doors will not open
  188. Squeeling noise at idle when started
  189. Removing the resin top?
  190. Power loss and red hot catalytic converter
  191. well just checked my oil
  192. is it bad gaz
  193. 2004 Rodeo Stalls Randomly
  194. Engine question...
  195. Auto tranny fluid....can I use
  196. Contemplating Rodeo purchase, some questions
  197. Tires falling apart?
  198. props for the FAQ's
  199. Out Went The Lights
  200. 1993 Isuzu Rodeo 3.2L V-6
  201. 2000 ISUZU RODEO ABS ligt on
  202. + 1 (million) for BOSCH alternator!
  203. cruise controll not working
  204. Rattle in dash - any other ideas
  205. Replacing a Transmission for a 2000 Rodeo
  206. how to remove the starter from a 2001 rodeo 4WD
  207. wiring up a condesor fan
  208. 95 blower fuse melt problem
  209. Grand Mesa pics.....
  210. Fender flares added - what are your thoughts
  211. Traced my non-4x4 actuation...
  212. mechanic labor charges, Serpentine belt & signal switch
  213. engine help
  214. FL3.2/Surfer - fender flares/pics anyone??
  215. sunk rodeo back end = now wont start
  216. what do you guys think of her
  217. honda passport grill and badges
  218. ABS an option or it comes with all rodeo's
  219. 336 & 351 Codes
  220. Electrical Problems
  221. few questions
  222. Rear Rotor
  223. Rodeo replacement: which way should i go....
  224. 98 Rodeo - ABS kicks me?
  225. Diference between passport and rodeo
  226. winter/power button
  227. 97 Passport clutch problems
  228. 4x4 question need help
  229. speedometer
  230. Hot Start Problem
  231. 1995 Rodeo sounds like a diesel
  232. 97 Rodeo AT comes out of Lockup at 60mph+
  233. 98 Passport sounds like a Harley
  234. intelligent suspension light
  235. Dome light in trunk area = DEAD
  236. Cargo Net Problems
  237. Reduced Power warning light
  238. I have your sending unit. Do you have my regs?
  239. Transmission Problem
  240. code 0405 on isuzu 2001 4wd 3.2l
  241. Speedometer
  242. Help Window Problems 98 Rodeo
  243. Y-Tail Pipe & Muffler
  244. 99 rodeo "jumping" tachometer
  245. Replacing the overdrive pan gasket
  246. 99 Honda Passport issues with parking..
  247. window up and down problems
  248. High Erratic Idle
  249. 97 Passport EX - Overheating Problems, Please Help!!
  250. Want to replace the front rotors. A couple of questions.
