View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. another engine knock
  2. Lost mpg, Need Help!
  3. 1997 Rodeo Brake Issues
  4. Tips on 4wd starter replacement...
  5. Tranny Fluid Along Rear Cross Bar
  6. Vacuum leak or replace Part?
  7. Need some advice....transmission I think
  8. Trouble with crankshaft pulley
  9. transmission fluid maybe ??
  10. need an administrator...
  11. 99 Rodeo Steel Rims
  12. Timing belt tensioner, spun bearing or ??
  13. tranny question?
  14. Range sensor? help!
  15. 4wd ingaged green light always on -Help!
  16. Grinding in rear end...
  17. How to remove serp belt tensioner?
  18. Thank you
  19. Tire size up
  20. Replacing Head Gasket on 99 Rodeo
  21. Rodeo Alternator for sale
  22. Thermostat
  23. Transmission service - advice needed
  24. 1997 isuzu rodeo will not run
  25. R&R oil pump on 97 v6 Anyone done this?
  26. My 1994 isuzu rodeo shutters while maintain a speed
  27. 99 Rodeo racing and stumbling/stalling
  28. Changing water pump- info please
  29. Speed sensor replacement
  30. 92 isuzu v6 won't start
  31. Pulley Noise
  32. 120K Maintenance
  33. 1999 Rodeo tranny
  34. P0122 and P1406 codes
  35. 1999 Rodeo need tranny info
  36. 1999 rodeo surging
  37. info needed please
  38. Intermittent starting problem '98 Rodeo...
  39. Isuzu Rodeo 1995 FWD
  40. engine codes 171b 172b 174b 175b
  41. Joe Isuzu
  42. Torque Converter Clutch Solinoid
  43. Bye bye Isuzu, effective 31Jan2009...
  44. 98 Rodeo Engine Sputtering Problems
  45. 2000 Rodeo Fog Lights
  46. Rodeo hits the wall at 4,500rpm! Why?
  47. 95 Passport, vibration/noise. HELP!!!
  48. 2001 Isuzu Rodeo HELP PLZ!
  49. Transmission filter change Problem &%#&)
  50. 1997 Rodeo Transmission problems
  51. Heater light off
  52. 94 passport stutter, rough idle and accel
  53. 94 Rodeo occasionaly dies
  54. 2000 Rodeo ECM ??
  55. emerg brake lite and bat light on
  56. Back glass on 96 Rodeo compatable with 97 Passport?
  57. A Leaky Mystery
  58. remove timing belt idler pulley? 95 Rodeo
  59. P0502, P0401
  60. Word of caution for auto tranny owners....
  61. Freakin Spark Plugs!!!!
  62. 98 Rodeo Issue with Coolant/Radiator
  63. Arrghghgh! THIS is the reason I treasure
  64. 2000 izuzu rodeo
  65. Rough Running?
  66. need some input
  67. Changing the upper radiator hose
  68. 92 Rodeo Heater Core
  69. front grill guards
  70. 1995 Rodeo - replace passenger side headlamp?
  71. Question about warranties....2nd owner
  72. 4L30E Drain Plugs
  73. New Mystery
  74. Can you reset the "Check Engine" light
  75. flywheel, torque converter, or worse?
  76. which brand of spark plug - 2001 rodeo
  77. 95 Rodeo OBD-1 Scan Tool
  78. new oil leak
  79. Problems with FAQ!!
  80. Passport or Montero
  81. 97 rodeo overheated is it dead?
  82. 99 Passport rough idle then no start
  83. Surferfletch/FL 3.2......are you still
  84. Cold Idle Speed
  85. 1999 rodeo
  86. Crack in transmission housing at drain plug
  87. Rear pads for sale 99 rodeo
  88. 95 Rodeo Coolant Leak on Top
  89. Oil pan plug size?
  90. its freezing and i have no heat!!! help!!!
  91. 2000 Isuzu Rodeo Pricing
  92. 1997 Rodeo/dies when foot is off accelorator
  93. Transmission Fluid Change
  94. I Need Help With 95 Rodeo
  95. 99 Rodeo Rpm Problem
  96. Power Steering
  97. Rodeo wont start.
  98. Destination le or at??
  99. 99 Rodeo Lights Flickering
  100. coolant leak
  101. Looking for some parts.
  102. A/t Oil Change
  103. Half shaft replacement
  104. new goodies for my passport (56k beware)
  105. 1997 Cigarette Lighter Replacment
  106. 98 Passport - Alarm goes off when I open door with key
  107. Wheel Alignment How to:
  108. New shocks for an 01 passport
  109. Gas Gauge Repair Fuel Sending Unit Fuel Pump Not Needed
  110. Changing brake hose.
  111. Alignment (camber/shim pack) question?
  112. Happy Holidays
  113. front bumper for 96 rodeo
  114. 95 Rodeo Timing Belt Problems
  115. Whining / squeaky idler pulley
  116. 1995 Rodeo Leaking Radiator Fluid. Please Help
  117. 2001 Isuzu Rodeo
  118. 97 Rodeo PO118 Error (engine coolant temp curcuit high output)
  119. Cat back muffler kit:
  120. 99 Rodeo ran out of gas, now won't start
  121. check 4wd light
  122. Bad MPG
  123. Replacing '98 Rodeo Headlights
  124. The vanishing Passport catalytic converter?
  125. Relay Question
  126. 98 Passport speaker sizes?
  127. Rodeo Repair Manual
  128. Tailgate won't open....
  129. 2002 Isuzu Rodeo Rod Knocking
  130. Weird shimmy
  131. windshield wiper
  132. 1998 Isuzu Rodeo Poor Idle/Power loss/Serious backfiring
  133. Question about Seafoam and CEL
  134. 2000 Rodeo FSM
  135. Rodeo dies about 3 minutes after jump starting
  136. Questions about 2001
  137. Where to get a replacement brass bushing for the door
  138. Transfer case questions....
  139. 4WD Wont Disengage
  140. coolant system frustration
  141. 5 speed dead now I have a question
  142. Shifting into Drive or Park and close to stalling question
  143. My 1995 Rodeo Just died! :( HELP!
  144. 2002 isuzu rodeo sprt
  145. 2002 Rodeo ABS Light
  146. 99 Killed
  147. 98 passport idle shut down after 7o k of running after a computer reset
  148. Check out the inside of this 4L-30E
  149. Voltage dropping
  150. 98 Passport Engine Harness
  151. 1996 Rodeo Why does this keep happening ?
  152. Just Died 1994 rodeo
  153. steering unit
  154. Which Oxygen Sensors Impact on Smog Test
  155. fuel line
  156. 2001 Rodeo thermostat
  157. loss of power...?
  158. Valve bucket holder tool V6
  159. Oh man. My rear main seal is completely shot.
  160. Dana 44 alxe questions
  161. 94 rodeo v6 stuttering problems
  162. New Starter and still won't crank!!!
  163. HELP - '99 Rodeo won't start / has good battery
  164. Installing and a Trans Cooler on a 2001 Rodeo LSE
  165. 95 rodeo speedo question
  166. 3.2L Valve Adjusting tools
  167. Help....red light on!!
  168. fuel pump power again!
  169. Tires- need help asap!
  170. Engine Swap
  171. coolant dump
  172. Do i need new shocks?
  173. Fog light
  174. Opinions on Firestone Destination A/T's.....
  175. gas gauge? has this happend to you
  176. fuel pump power
  177. Please Help 95 rodeo fuel problems
  178. HEAVY power steering.
  179. Drivers side wiper, not wiping
  180. Left Tail Light
  181. Horn keeping honking!
  182. noise
  183. exhaust leak?
  184. A/C compressor noise
  185. Location test....for you Coloradoan's.....
  186. fule pump installation
  187. ABS Speed Sensor
  188. How long to drop fuel tank and replace sending unit?
  189. trans problem
  190. 02 Rodeo Speed Hesitation
  191. 2000 Isuzu Rodeo left signal light
  192. Here's another good mystery sound to figure out!
  193. Dash lights
  194. Overheating problem...help would be greatly appreciated. (A little lengthy)
  195. P0240: Catalyst System Efficiency Below Threshold (Bank 1): UPDATE!
  196. 03 Rodeo over revving, sounds loud, like it's stuck in gear
  197. Getting rid of my '96
  198. 97 Rear leafspring bushings
  199. Got MUD.....will travel....
  200. any comments on aftermarket egr valves
  201. 98 Alternator specs?
  202. Serpentine belt to bypass A/C
  203. Chrome pieces?????
  204. What Kind of Seats?
  205. P0240: Catalyst System Efficiency Below Threshold (Bank 1) with pictures!
  206. 2001 Rodeo brakes issue
  207. Stalls and Will Not Start???
  208. Locked my keys in my '99
  209. No Power
  210. 1998+ rodeo/passport/amigo parts for sale
  211. 2001 isuzu Rodeo 6cyl,4wd
  212. Timing belt idler bearing
  213. Water soaked floor
  214. Look familiar?
  215. hose replacement question
  216. Clicking... Valve adjustment?
  217. RKE aftermarket
  218. Widest tires for a 98 Rodeo???
  219. Flickering lights
  220. 99 Passport CEL nightmare!
  221. Replacing rear left side vent glass
  222. Lights Out
  223. 92 Rodeo loosing power at 3000 rpms
  224. How do you know when to replace shocks??
  225. wheel clearance????
  226. brakes
  227. Rodeo shifter won't go into Park or Low
  228. Have a problem..was given a company
  229. Water Dripping from Passenger Side
  230. Size of tranny cooler hoses?
  231. Which Transmission Fluid???
  232. Anyone have a passport fender flare?
  233. wiper controls i hate it
  234. high idle po 507
  235. Shifting Hard
  236. 2001 Rodeo tailgate
  237. What is that butterfly thingy
  238. Rodeo stalls only with initial acceleration
  239. List of things to do and when sticky?
  240. anybody ever troubleshoot cruise on 95 and earlier rodeo?
  241. 01 Isuzu Rodeo ABS or Computer
  242. Braker Caliper Pin/Bolt Question
  243. 99 passport CEL after IMGs
  244. What a PITA weekend!
  245. Rear Cup Holder
  246. Manual Transmission Fluid Level
  247. 1995 4X4 manual trany
  248. Computer chip in 95 rodeo?
  249. Adding Remote start/keyless entry
  250. Parking Brake Light?
