View Full Version : Rodeo/Passport
- wheel movement 96 rodeo
- WTF is this hose? ** Pics **
- 96 Passport timing
- isuzu alt part number
- FYI:Brake Rotor Sale at tirerack.com
- Fuel Sending Unit Broken Gas Gauge Fix
- 2002 Isuzu Rodeo
- need help, engine blown ?
- 1995 Isuzu Rodeo remote programming
- Upper Molding on Windshield
- isuzu
- 1997 isuzu rodio starter problems
- Timing Belt and Water Pump time...
- 97 Rodeo A/C Clutch Removal
- Help with head gasket dilemma
- Ut-oh!!...tiny hole in muffler
- boot that connects coil to spark plug...
- 99 passport electrical problems
- KN filter for rodeo 04
- Anyone Ever Have This Problem With A Rodeo?
- Engine Splash Apron: What is this?
- If I use 1 1/2" shackles, will I actually GET
- 2 new codes found after 5 minutes of idle
- 99 Rodeo electrical problems - locks, alarm and radio
- paint chips around the hood
- Axle differential fluid
- Universal or Isuzu Shackles? ...Gizmo or anyone
- t-belt change time
- 2001 Isuzu Rodeo with 7 codes read
- ABS Mayhem
- How to remove instrument cluster on a 2001 Rodeo
- Rotate tires
- 94 rodeo vss ?
- valve timing on a 95 3.2
- 98 Isuzu Rodeo Parts For sale
- Link to pics from Moab ZuZoo X
- 01 passport cell flashes only when accelerating??
- Brake and battery light on at the same time?
- 1996 Rodeo
- 96 Rodeo Starter Vs. Alternator issue
- tips on turn loose the rodeo caliper bolt
- Replacing Rear Brakes
- 2001 Rodeo Maintenance schedule?
- 1st rodeo (4wd for that matter)
- engine about to self destruct?
- Trans won't upshift, key gets stuck
- Electrical Issues.
- problem with my transmission...
- 99 Rodeo P1647 code.......need some help here
- Dashboard lights help
- 1999 Rodeo AC
- urgent stud problem
- Ac problems
- We fixed IT!! Heres the remedy...
- Little help with removing front bumper
- 97 Passport Leaking Antifreeze from Under Glove Box
- a/c line
- Help Please!!!
- brake parts recommendations
- BURNING UP!! 97 Isuzu Rodeo AC not working
- 1992 Isuzu Rodeo on Ebay $250NR (1 day left)
- 97 passport wont start
- Cruise Control blues...
- Amigo won't start
- Major issues all of a sudden
- 01 Passport muffler.
- Code P0442 in my 01 Rodeo
- No Electrical
- 2002 Rodeo (V6) not starting
- 00 Rodeo 'chugging' at low speeds - confused!!!
- 00 rodeo rear end sizes!!!????? pinion seal
- Cracked head?
- 99 Rodeo V6 Transmission upshifting problem
- Another Rodeo for sale - '93 4X4 auto V6
- ATF filler plug for AISIN Trans?
- 94 rodeo 4x4 for sale only 45,000mi
- 98 passport front end conversion to 2000passport/rodeo possible?
- Honda Passport back up light switch
- Car cover for the Rodeo??........
- New brake pads with no wear indicator?
- Need Left Cyl. Head Bolt Sequence 3.2L
- Im new hear just have a couple of questions
- No Click when Cranking
- 94 rodeo wont start
- 95 passport blows power window, turn signal fuse
- 94 Passport T-connector plug in for trailer lights
- Water pump replacement
- 95 rodeo
- burning oil
- PCV Valve: clean or replace?
- Hard to start
- Sport Convertible top rear plastic window
- 1998 rodeo 4x4
- Just bought 99 Rodeo...speaker questions
- Honda Passport 96
- Gizmo42 - you had answered a
- oil cooler return line hose
- What to do with my 98 rodeo
- Rodeo wont start- many probs.
- Clunking Noise
- CEL on and gas blinking
- Check Engine light on 1999 rodeo
- Help ID'ing Part
- Rodeo took a beating yesterday/Advise.....
- 1994 Rodeo LS 4WD Speedo Quit Working
- ?? regarding frame hole plugs.....
- fuel filter from NAPA?
- I need some help ASAP
- Window Regulator
- Got the new turn signal - rapid blinking
- 95 Rodeo Rear Defroster
- Fuel Injection???
- oil cooler lines on rodeo 2004
- cylinder block coolant drain plug
- rodeo 2004 fuel filter clamps
- Rear break rotors
- 98 Rodeo Rear Seat
- download rodeo manual
- Eng. turns off while car is being accelerated!
- It's been done
- rough idling
- Starting/running troubles....
- Rodeo has *excellent* stability..........
- '02 Rodeo 4x4 Front rotor removal?
- I need Help!
- I'm new here, does anyone know...
- Need a front fender
- Tachometer, oil pressure
- Heat shield rattling sound
- Rodeo Electric fan and pulley kit?
- Electrical Problems
- 95 Rodeo no manual, would like to know how the 4 wheel drive engages
- Keep blowing fuse
- Questions
- Please HELP 2001 Rodeo Won't Start
- Finally(new plugs,F.F,02's)
- CEL + Reduced Power Light on 01 Rodeo
- LED Lights
- auto tranny service
- 94 Passport 3.2 ticking/knock
- '99 Rodeo 3.2 - Wheel Bearings
- 2001 passport overheats
- need help trans
- passenger cam tower plug
- Fuel Problems??
- VSS Wiring
- Help With Part
- My painted air dam came...unpainted!
- Ouch!!! - What are you $$$ for gas ???
- What else can *feel* like bad rotors??.....
- check engine light/ diagnostic connector
- Trailer Hitch Questions
- Changing plugs on '01
- transfer case/trans crossmember problems
- Wacked Out Gas Gauge
- Exhaust part? Collector?
- 94 3.2L suddenly running really bad
- OBD II reader for Rodeo
- 2000 Rodeo: no codes, sputters and stalls: Trans light and Cruise light comes on
- Help me decifer emissions report......
- How to Recharge A/C 94 Rodeo
- 2001 Rodeo Radio Illuminates When Car is OFF
- 2000 rodeo at witts end
- Surferfletch - have a ??, what RPM's are
- Adding Chevron Techron to a full tank???
- Found a 95.5 Rodeo 5-spd, 4x4
- Wheel bearings - How to tighten?
- Emission Failed
- '98 Squeaky bushings?
- Resetting CEL Light
- Half shafts
- Getting a used ECU for 98 Rodeo
- Any ideas? Loud exhaust/decreased pick-up problems 96 Passport
- Wheel Stud Issue
- installing a PCM or Electronic engine comp.
- munched the front end
- Smoking/watery Exhaust
- FYI - Emissions IS still required in Colorado..
- Blinking 4x4 dash light
- Pics of 2 lifted rodeos
- Rodeo won't start
- Problem with brakes.
- check transmission light
- Throttle/Transmission/Stalling Issues
- Alternator belt tensioner...
- 99 Honda Passport fuel sending unit
- Timing Belt Tensioner
- 2000 Passport Surging,stalling,runs rough
- U/S light meaning
- 4x2 to 4x4
- 98 Honda Passport Cylinder Head
- 98' Passport serpentine belt coming off
- Low Miliage
- Determing where oil leak is from.
- Rollover protection switch (fuel pump reset switch)?
- 97 3.2 Rodeo Code P1509
- Major Oil Leak- Tons of Blowby
- 98 rodeo transmission service or fluid flush?
- How much for a T-belt change?
- Help in identifying Rodeo part
- 97 Rodeo 4x4 light will not turn off - stalling
- Looking for wiring diagram, random issues with 2k Amigo
- egr issue..help pleeeaaasssee
- 2004, 3.5L on start-up
- 2004 3.5L transmission fluid ?
- Selling a 2001 Rodeo Sport
- Passport Overheating after long idle
- fuel problems
- Selling the rodeo!
- Stuck in Hawaii! PLEASE HELP!
- Exhaust manifold Replacement
- FWIW - In JLEMOND's own words about oil...
- 2000 Passport P0300 code problems.
- Catalytic converter
- Oil and Amp gauges
- muted rear speaker sound
- please help me irgent 92 rodeo
- Where to find stereo wire harness?
- Got my Rodeo back with the new Tranny today...
- horn does not work replaced control module . works when the alarm is turned on Help??
- 97 Rodeo compatibility question
- 1996 driver side tail light cover
- 93 hona passport
- Tapping sound
- Clock bulb
- Tansmission or VSS, 94 Passport 4X4 Auto
- mild but not tolerable sputter when accelerating
- Tricky Stereo Question... Dimmer Switch??
- 1996 Rodeo compatible parts
- 1998 rodeo #4 misfire
- Serpentine belt & idler pulley
- Giz - is it true that Dayton M/T's are the same
- Need Help Check engine and Power down Lights on
- Need new air intake tubing .....
- Help! I'm confused on which tires to buy for my 2000 Rodeo!
- Faulty dashboard lighting
- They don't call 'em "widow makers" for nothing...
- 98 Rodeo Timing
- Removing Rear Mounted Spare Tire?
- Where is the fuse for the alarm system on my 94 Rodeo?
- lifting a 92 rodeo LS
- WTB: Glass sunroof for 1st gen Rodeo/Passport
- 01 rodeo trans noise?
- Wix filters seem to make a difference
- 93 Izusu Rodeo front half shaft replacement
- over cooling rodeo
- 04 Rodeo Auto Transmission?
- Rough idle, surging, stalling
- Got VSV's working properly but still no 4WD??
- Very Noisy Belts ??
