View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Isuzu Rodeo - Reduced Power
  2. 2002 2.2L 4cyl transmission
  3. Installing Cam Sensor 2002 Rodeo 4 Cylinder
  4. Transmission compatibility - 2002-2000 Rodeo
  5. where is trans ?
  6. How much is my engine worth? 2000 Rodeo, 73k, 4 cyl, 2.2L
  7. How much is my engine worth? 2000 Rodeo, 73k, 4 cyl, 2.2L
  8. Front Wiper Motor - return - or for sale
  9. ecm location??
  10. 2000 Passoprt - replaced FSU, now excessive cranking..
  11. Ignition key buzzer
  12. Wiring kits
  13. rear viper
  14. Timing Belt parts - Autozone good enough?
  15. O-Ring Replacement Under Intake Manifold.
  16. Won't start when hot - runs great otherwise
  17. Help for New users on abbrev
  18. Factory Alarm / Keyless Entry Info Needed
  19. Power Lock Relay
  20. Fuel Pump Problems
  21. gear indicater on the dash of my 2000 rodeo won't move
  22. Illumination problems.
  23. Illumination problems.
  24. Illumination problems.
  25. 1998 Passport.. Coil Problem..
  26. Horn=Off Airbag light=On
  27. Code P1406 on 97 Passport/Rodeo
  28. IMG replace this weekend.torque consensus?
  29. 2000 rodeo timing? help!
  30. Power steering only works at higher rpms
  31. P1391 G Sensor Performance
  32. Please Help! clutch problem
  33. 1994 Isuzu Rodeo - Alternator replacement
  34. Clicking coming from center console shift area?
  35. UAS (universal anchorage system) in a 01+ Rodeo
  36. Code P0154 Persistent '96 Rodeo
  37. Maintenance Questions
  38. need white fender
  39. Once again, a couple of questions from me about the isuzu. :D
  40. Headlight and grill swap
  41. Install 04 engine in my 99?
  42. Jack for 2004 Rodeo
  43. Optima Battery for a 2002 Rodeo?
  44. 1997 Honda Passport Locking Lug Nut on Spare
  45. Power windows still roll down with ignition off?
  46. Transmission fluid leak at torque converter cover plate
  47. Alternator 1997 Rodeo 3.2
  48. Intake Air Temperature Sensor 02 V6?
  49. want my rodeo back
  50. 99 Passport. Which way to turn caliper bolts?
  51. Sewing MAchine Noise
  52. 99 Rodeo- Front License plate installation
  53. antifreeze in sparkplug tube
  54. Timing Belt
  55. 95 Rodeo Overheating!!!
  56. A bunch of thoughts in one topic.
  57. Wiring Diagram 94 Isuzu Rodeo
  58. tranny question
  59. 00 Rodeo A/c Problem
  60. fuel pump
  61. 1992 rodeo hesitation
  62. Tail lights and dash lights
  63. Alternator source
  64. 2001 rodeo no power
  65. 2001 lower ball joint advice
  66. Performance Chip for 2001 Rodeo
  67. OT: firefox 3
  68. emergancy brakes useless
  69. Cooling Fan
  70. Another tranny fluid swap.
  71. 1996 Rodeo Won't Start.
  72. Rear pads lasted 4 years
  73. 1998 Rodeo starting problem
  74. AC Problem
  75. 1997 Passport Optimum AC presure
  76. Air Conditioner Charge too high?
  77. Technical service bulletins
  78. Selling a great 95 Rodeo in SoCal
  79. rodeo compressor turning on and off constanstly
  80. KN air filter
  81. 1997 Rodeo Air Compressor Question
  82. broken bolt while instaling hitch
  83. 98 Honda Passport ABS problems again!?
  84. Parts for a 2001 Sport soft top
  85. CEL is on, NEED HELP
  86. waste of time--
  87. 97 rodeo 3.2 coolant leak. Help!
  88. Cargo net '01 Rodeo Sport
  89. 1994 Rodeo Rough Idle and CEL/Fuel metering system error code
  90. recharging 2000 isuzu rodeo
  91. recharging 2000 isuzu rodeo
  92. 01 Rodeo Whistling Noise
  93. 98 Rodeo Left Turn Signal
  94. Starting with new timing belt
  95. Rodeo no more
  96. timing belt hydraulic tensioner
  97. 1997 driver door wont open from inside
  98. Timing alignment question
  99. Charging A/C
  100. Check Engine Light - PO401????
  101. 97 3.2 valve cover HELP
  102. Non INtrusive 3.2 98?
  103. 94 Rodeo A/C Not Working
  104. Question Regarding Towing Wiring Harness for 99 Rodeo
  105. New user with questions about Lift, Tires, Shocks... I searched already
  106. 1994 rodeo only starts once every 40-50 tries...
  107. Is this right?
  108. Moab zuzoo XI 2008
  109. AAMCO taking me for a ride?
  110. New Rodeo owner with a few questions....
  111. Tran Service? Pass/Rodeo/Worth it?
  112. A/t
  113. 2000 Passport AC/Heat Faulty Controls
  114. Cold Shift 98 PASS/RODEO
  115. 1993 V63.2 4WD S water leak on pass side
  116. 98 Pass/Clunk Kaboom in rear at traffic light
  117. I Wonder
  118. Major tune up order/ stereo question, new owner
  119. 94 Passport 3.2l misfire
  120. Soft Top 2001 Rodeo
  121. lock-up clutch slip control
  122. driving with tail lights stuck on
  123. Where To Add Refrigerant Oil?
  124. Help Please!!!!!
  125. any one got ideas
  126. 1999 Rodeo AC
  127. reduced power coming on
  128. Back Light for the gear shift.
  129. For Sale:
  130. Recommended repalcemant parts
  131. 99 rodeo ghost
  132. 96 Rodeo Won't Crank
  133. 98 rodeo spark plug gap
  134. 1995 passport wont crank
  135. 2000 Rodeo Gear Selector
  136. 1996 rodeo dash "gear indicator bulb #"
  137. Loud Engine Knock below 2,500 RPM
  138. smoke from engine
  139. Possible '01 Rodeo Sport owner here-help?
  140. Timing belt tensioner on a 95 Rodeo?
  141. rodeo
  142. 4low Problem
  143. How much are you paying now?
  144. suggestion to Amigo-2k: reorder table of subforums
  145. air condition filter...where is it RODEO 2002 LS
  146. 99 Passport IMG every two years!
  147. I needed new Catalytic converter...bad gas mileage!
  148. Powre Lock Fuse
  149. 97 Passport BIG PROBLEM!!
  150. *VERY* Noisy Fuel pump
  151. fuel injector clips
  152. Random Multiple Misfires.
  153. first two probs with 2002 rodeo-need advice!!
  154. 1999 rodeo head gasket replacement
  155. installing a trailer hitch for the rodeo 2004
  156. 2001 rodeo shift lock trouble
  157. Wheel size question?
  158. 95 Rodeo No Overdrive?
  159. 1999 Rodeo 2.2 4 cylinder
  160. check engine light OBD Codes
  161. Noise coming from engine area.
  162. 95 passport bleeding clutch?
  163. Abs/brake Light
  164. 2000 3.2 V6 Lse
  165. Do RS9000XL (RS999214) fit non-lifted 98+ rodeo's
  166. Bad misfire 97 Passport
  167. Tick Tick Tick Dead
  168. Help with engine timing on 99 Rodeo 2.2
  169. first real issue
  170. growling noise when applied brakes rodeo2004
  171. Need Fuel Pump Hangar/housing Asap
  172. 95 Rodeo Lower Control Arm
  173. Grinding or sort noise in engine area..
  174. Vibration
  175. Flush the rodeo trans
  176. fuel pump rodeo 2004
  177. bogging or just plain cutting out
  178. 911 with passport need help
  179. Speaker advice.
  180. yet another problem for my p.o.s...
  181. ATF fluid flow diagram for rodeo 2004
  182. 95 rodeo pitman arm
  183. brakes lifetime for Rodeo 97
  184. check trans fluid on rodeo 2004 with dipstick
  185. Replacement Seats 99 Isuzu rodeo
  186. 97 rodeo 4WD rr.abs and brake light on
  187. Compression question and valve stem seals
  188. AT filter for rodeo 2004
  189. Starter Problem 1997 Rodeo 3.2 2WD
  190. new washer for Transmission pan?
  191. 99 Rodeo V6 3.2 Manual 5 Speed Clutch Friction point a bit high???
  192. Slight to medium shimmy when braking - '99 Rodeo
  193. ghetto wheeling vid
  194. 96 Rodeo 3.2L V6
  195. I.D of oil cooler hose on rodeo 2004
  196. Passport Sensor locations
  197. 1996 Rodeo p300 error code
  198. 98+ 3.2 A/C recirc. door?
  199. Passport won't start P1311/12
  200. 95 Rodeo CV Half Shaft Assembly
  201. Help finding parts
  202. 99 rodeo has miss . need help
  203. Keyless remote programming
  204. 2000 rodeo 2.2 l will not start. Hellp
  205. new shoes
  206. 2001 rodeo please help me
  207. 93 rodeo fuel pump bad?
  208. Yet, Another Question
  209. performance parts
  210. Idle problem 1999 Rodeo 3.2 automatic 2wd
  211. Blinking gas gauge
  212. Engine Cooling Problems
  213. How do I repair tailgate latch?
  214. 1994 rodeo lossing power
  215. 1991 Rodeo Low Idle Low Oil Pressure
  216. Climate control is stuck on heat
  217. Questions about a couple of codes
  218. problem with 98 isuzu rodeo
  219. isuzu Rodeo 95.5 Blower problem
  220. Rear End Popping - Possible bushing?
  221. Need the Y pipe
  222. 1998 Passport Timing Issues
  223. Where can I find some parts.
  224. 94 passport fuel pressure regulator question
  225. Another tranny problem
  226. help tranmission problem
  227. 2000 Rodeo LS Cassette in reverse
  228. interior lights going off
  229. 2004 Rodeo high RPM when cold
  230. Rotate Crankshaft Backwards?
  231. Passport runs lean
  232. cold start transmission problems
  233. how do i get mor gas mileage?
  234. 1999 rodeo - fuel gauge
  235. Code P0171
  236. drivers side window switches
  237. New & Used 98 Isuzu Rodeo Parts for Sale
  238. Isuzu blower surging
  239. Serpentine belt wear problems
  240. Replacing the Center link on 97 Rodeo
  241. Unknown coolant leak
  242. New to Forum:99 Rodeo no heat.
  243. High output Alternator Replacement...
  244. Disk Brakes 1997 2wd
  245. Auto Transmission shifting problems w-no power/winter/checkTran indicator lights
  246. 2001 Rodeo-Rough Idle, stalls......help!
  247. 97 Rodeo - crankshaft pulley question
  248. Spark plug question
  249. service interval for timing belt. water pump etc
  250. beeps when key turned on
