View Full Version : Rodeo/Passport
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. 96 Passport Valve covers
  2. Lifting the Green Goblin 2"
  3. Stereo Installation - problem with instrument panel lights
  4. engine stalls after rough idle
  5. 1997 Rodeo suddenly dies
  6. Fuel pump dying? '99 Rodeo - Anyone?
  7. Coolant leaking from under 1996 Rodeo 3.2L
  8. 1999 Passport CEL codes
  9. Special plugs for '01 Rodeo
  10. Blinking CEL, runs rough - for a friend
  11. Wanting to tackle tb and wp
  12. Rough riding 99 Rodeo
  13. Alternator Belt too tight?
  14. Where is it?
  15. Alternator Amperage Question
  16. Plane crash site trail run pics
  17. FYI - No longer using Napa Gold's on.....
  18. What size shocks needed for a 3" lift?
  19. Rodeo Sport Amigo Top Zipper Window Repair
  20. Don't call her ole' faithful for nothing....
  21. Electrical Issue: Radio (AUX) Interference
  22. Cen-Tech OBD II CODE READER
  23. 2000 Rodeo. slipping transmission
  24. 4wd light blinking, shifts into 4wd, in 4wd grinds in tight turn
  25. temp idel falure
  26. 1997 Just quit running
  27. 98 Passport condenser install instructions
  28. Dealership 2nd opinion...
  29. Interesting P0300 Code on 2001 Passport
  30. Another timing belt ???
  31. New spark plugs without new wireset?
  32. I MUST be crazy......
  33. 1998 rodeo
  34. 95 Passport hamonic balancer removal
  35. Feeler for Daily Driver
  36. Leaking tranny fluid from up top?
  37. where can i find a lift kit
  38. CEL(Check Engine Light)
  39. More Colorado scenery pics for SurferFletch
  40. 99 isuzu rodeo0(5spd-manual)question about battery?
  41. 93 borg warner 5 speed
  42. 93 2.6 rodeo ticking.
  43. 2000 Rodeo 'Slip Yolk'??
  44. will the 94 gauges fit into 91?
  45. Timing Belt--when to replace?
  46. Our 900 mile journey thru Colorado Rockies...
  47. power loss @ check light
  48. 93 Rodeo Stuck Rear (tailgate) Glass
  49. Disgusted in Colorado...tell me about Montana, WY,
  50. A/C: Air conditioning stopped working
  51. Outer CV boot
  52. 93 rodeo engine power loss
  53. 99 Rodeo (Frontera) ABS braking issues
  54. 95.5 3.2 v6 runs rough @ 2k rpms
  55. Normal Idle RPM
  56. 99 Passport Voltage Inquiry
  57. Problems putting 99 Honda into Park.
  58. 01 rodeo starter problem ?
  59. Tranny leak?
  60. Automatic trans not shifting
  61. Rodeo, rear doors will not open
  62. Squeeling noise at idle when started
  63. Removing the resin top?
  64. Power loss and red hot catalytic converter
  65. well just checked my oil
  66. is it bad gaz
  67. 2004 Rodeo Stalls Randomly
  68. Engine question...
  69. Auto tranny fluid....can I use
  70. Contemplating Rodeo purchase, some questions
  71. Tires falling apart?
  72. props for the FAQ's
  73. Out Went The Lights
  74. 1993 Isuzu Rodeo 3.2L V-6
  75. 2000 ISUZU RODEO ABS ligt on
  76. + 1 (million) for BOSCH alternator!
  77. cruise controll not working
  78. Rattle in dash - any other ideas
  79. Replacing a Transmission for a 2000 Rodeo
  80. how to remove the starter from a 2001 rodeo 4WD
  81. wiring up a condesor fan
  82. 95 blower fuse melt problem
  83. Grand Mesa pics.....
  84. Fender flares added - what are your thoughts
  85. Traced my non-4x4 actuation...
  86. mechanic labor charges, Serpentine belt & signal switch
  87. engine help
  88. FL3.2/Surfer - fender flares/pics anyone??
  89. sunk rodeo back end = now wont start
  90. what do you guys think of her
  91. honda passport grill and badges
  92. ABS an option or it comes with all rodeo's
  93. 336 & 351 Codes
  94. Electrical Problems
  95. few questions
  96. Rear Rotor
  97. Rodeo replacement: which way should i go....
  98. 98 Rodeo - ABS kicks me?
  99. Diference between passport and rodeo
  100. winter/power button
  101. 97 Passport clutch problems
  102. 4x4 question need help
  103. speedometer
  104. Hot Start Problem
  105. 1995 Rodeo sounds like a diesel
  106. 97 Rodeo AT comes out of Lockup at 60mph+
  107. 98 Passport sounds like a Harley
  108. intelligent suspension light
  109. Dome light in trunk area = DEAD
  110. Cargo Net Problems
  111. Reduced Power warning light
  112. I have your sending unit. Do you have my regs?
  113. Transmission Problem
  114. code 0405 on isuzu 2001 4wd 3.2l
  115. Speedometer
  116. Help Window Problems 98 Rodeo
  117. Y-Tail Pipe & Muffler
  118. 99 rodeo "jumping" tachometer
  119. Replacing the overdrive pan gasket
  120. 99 Honda Passport issues with parking..
  121. window up and down problems
  122. High Erratic Idle
  123. 97 Passport EX - Overheating Problems, Please Help!!
  124. Want to replace the front rotors. A couple of questions.
  125. 99 Passport intermittent wiper ( Where is it ?)
  126. 97 Passport no fan problem
  127. 98 Rodeo - Hard Starts
  128. 96 Rodeo w/p0151, p0153
  129. biggest tires
  130. Sorry, it's another alternator question...
  131. 1996 Power Window Fuse keep on Blowing
  132. I've HAD it.....help me decide on new tires....
  133. 99 Rodeo Suspension
  134. 97 isuzu rodeo m/t 4x4 won't engage
  135. Blower motor
  136. Best mileage yet!
  137. 95' Passport Blower Motor
  138. 1999 Rodeo V6 4WD
  139. sig check
  140. 4WD light blinking
  141. Parts?
  142. 99 Rodeo with Loud noise from Right front!!!
  143. 94 Rodeo Intermitent Engine Light
  144. Can't open my hood
  145. Check Trans light comes on together with Cruise Set light
  146. Power drive light question....
  147. 1993 Rodeo CODES..........
  148. Removeing cat's on 2002 rodeo-PLEASE HELP!
  149. My 99 PissPoor
  150. 2001 Rodeo Hot Start Problem
  151. 96-97 3.2L sohc Rodeo's prone to rod failure???
  152. 2000 Isuzu Rodeo Timing belt/Tranny question.
  153. Something wrong when car starts in the morning!
  154. Deer Creek / Saints John / Bill Moore run
  155. 96 Isuzu Rodeo 3.2l V6- Clutch!!!
  156. few questions on my passport
  157. Throw out bearing dilemma...
  158. 2000 Isusu Flywheel/Torque Converter
  159. Bad Flooding Yesterday.
  160. Which US dealers ship parts to Toronto Canada?
  161. Can you Reset the Speedometer?
  162. Need help!! 98 Rodeo won't start tried everything
  163. Looking for a used/rebuilt engine for 2000 Isuzu Rodeo
  164. 2001 Rodeo Muffler
  165. 1995 isuzu rodeo wont start
  166. 91 Rodeo, 3.1L w/blown head gasket...Which repair manual do you need?
  167. Giz - have you been to the grand mesa
  168. TECH 2 Scanner
  169. p0101
  170. Reand End Roaring
  171. '98 - '01 Hatch Glass O-Rings (For Sale)
  172. vent / bypass cooling hose
  173. 95, electrical problem any suggestion at all?
  174. 1993 Rodeo Overheating
  175. Surfer - here's some *mountain* pic's
  176. 95 Passport Rear ABS and Brake light on Panel
  177. rodeo crossed with pathfinder
  178. One more pic and question>>>
  179. Pics of the girl as she is today....
  180. Pics of Blue Mesa 2006 Colorado
  181. Pictures - long awaited...lets see if
  182. 2001 Texas Rodeo, 4cyl. engine
  183. Surfer/Giz - found my vibe problem....
  184. R1 concept vs Ac Delco brake rotor
  185. bad idle after head gasket replacement
  186. Problems starting 98 Rodeo
  187. 2000 Rodeo Transmission stuck in Limp mode.
  188. is it the catalitic converters
  189. 2001 Rodeo Sp-Evap Readiness-NYS Inspection FAILED
  190. 4L30E secondary clutch drum
  191. accumulator piston cover and range selector seal arrived
  192. CD player has no pwr no door panel lights
  193. ATF To change or not to change?
  194. What's it worth with a Reman Engine?
  195. Tranny leaking
  196. Overheating , Don't know why.... please help !
  197. 4 Colorado mountain passes...truck's still got
  198. Intake Air Temperature Sensor On 95 Rodeo?
  199. tailpipe bangin' into the hitch
  200. Brake Bias Problem on 2001 Passport
  201. transmission heating in rodeo 2001
  202. FIGURES! I'm like the worlds .........
  203. Engine Failed, Now What?
  204. Fuel Pump????
  205. Noise at 45-60mph
  206. 92 92 rodeo tranmission line? need help identifying
  207. need drum brake drawing or pics
  208. Rear brakes locked and ABS light on.......
  209. 97 Rodeo codes 0300 and 1133
  210. Honda Passport 2001 NOISE
  211. engine dies immediately after startup
  212. Rodeo just serviced
  213. 95 passport Fuel type
  214. Saying goodbye to an Ol' Friend
  215. Timing Belt replacement
  216. Used 98 Isuzu Parts for Sale
  217. Made it to New England!
  218. 99 Rodeo Sprung a Leak
  219. Flashing Lights
  220. Ticking!!!!!!
  221. 96 Rodeo electrical issues
  222. Pioneer stereo to Isuzu 12 disc changer?
  223. black smoke
  224. 97 rodeo chugging at low rpm
  225. Possible defective carrier bearing .... how
  226. Broken Lens
  227. Really LOUD Knocking/Timing???
  228. Axle differential fluid
  229. ABS light and codes on a 2002 Isuzu Rodeo
  230. 2000 Passport - Won't turn over, fuel pump relay buzzing/clicking
  231. Rodeo just dies while driving
  232. Spring Washers
  233. Overheating '97 Rodeo
  234. lower ball joints
  235. Automatic Trans Slippage
  236. 1997 Isuzu Rodeo Lost acceleration HELP!
  237. 98 Rodeo radio/clock/ door lock issues
  238. Transmission Problems?? Please help!
  239. Very slight vibration...now -
  240. '00 Passport - A/C or engine issue?
  241. For Sale: 1998 Rodeo Needs Work
  242. 98 Passport (Rodeo) 4x4 problems...
  243. p0758
  244. Fuel Tank for 95 Rodeo
  245. 97 Rodeo - Brake and Battery Light = No A/C
  246. 2001 Rodeo EGR removal on a 4 cylinder
  247. Front Rotor removal procedure
  248. '96 Isuzu Rodeo Belt Squeal
  249. Starting problem-97 Rodeo
  250. 95 Isuzu Rodeo Starting Problems
