View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 95.5 rodeo pcv valve / grommet 3.2
  2. Camber kit
  3. loose steering wheel.
  4. Time for a new exhaust...
  5. Engine swap possible w/ GM 4.3 V6
  6. Rodeo body lift
  7. 96 Rodeo Losing Power
  8. manually open sunroof--2003 Isuzu Rodeo
  9. where can I find a 98 rodeo relay diagram?
  10. I almost sold my Rodeo, continued....
  11. i need this A.S.A.P
  12. point me in the right direction
  13. Replacing IMG
  14. 98 3.2 4x4 engine stalls
  15. Alignment Issue
  16. another problem
  17. *UPDATE on "EGR P0401 that won't go away"
  18. 98 rodeo wiring problem
  19. Can I do these myself?
  20. 1994 passenger side door
  21. Transmission Question.
  22. After warm up
  23. Alternator
  24. 1997 Rodeo idling problem update
  25. 97 Rodeo Issues
  26. 1997 rodeo sensor problem
  27. Knocking noise at speed
  28. H e l p
  29. High output alternator?
  30. passport coolant o-ring size
  31. Rawl fuse
  32. Key stuck in ignition...again!?!
  33. '99 Passport not firing on passenger cyl bank
  34. roof rack cross bars how to install
  35. rear noise
  36. 1994 Rodeo Thermostat Housing
  37. 95' no cold start
  38. 1993 Rodeo Overheating
  39. 4X4 Light Blinking
  40. 94 passport no 3rd gear shift in 4 wheel drive?
  41. 1995 Isuzu Rodeo, Trans Problem
  42. 99 rodeo 4wd, replaced starter still no luck.
  43. exhaust question
  44. Electronic Throttle Control
  45. 2002 rodeo-tail light fuse shorts out
  46. P0172
  47. Hard Starting Blues?
  48. Hood latch problem
  49. 99 Rodeo 3.2 hunts, stalls Code P0101-0102
  50. 1998 Rodeo Started Problems
  51. abs brake light indicator - failure?
  52. axle issue
  53. 01 passport need door handle
  54. 98 Passport - 4WD Not Disengaging Consistently
  55. 98 Passport - 4WD Not Disengaging Consistently
  56. Fuel Pump Seal issue
  57. rodeo engine suddenly turns-off while driving?
  58. Rear Wiper Will Not Stop!
  59. Interior Temperatur Control Cable
  60. Drivetrain Light on
  61. '95 Rodeo 3.2L Tune-Up Questions
  62. New Owner maintenance questions
  63. side view mirror on rodeo
  64. P0116 ECT Circuit Range/Performance CEL Help
  65. Flipping upper ball joints on a lifted Passport
  66. 2000 Troubles starting
  67. 2000 Troubles starting. . .but it always starts eventually.
  68. Oil Pump replacement
  69. Rear End Shake/vibration
  70. Opinions on dipstick heaters please
  71. Replacing leaf spring bushings and engine ticking...
  72. 1997 Transmission slip in 1st gear
  73. 98 Rodeo Catyl. exhaust flange to header
  74. 1996 Rodeo interferance engine ?? yes or no
  75. Blinking 4x4 light
  76. EGR P0401 That will not go away
  77. Please Help 4cyl Rodeo.
  78. EVAP Canister Vent Solenoid
  79. Removing Transmission Pan Bolt 99 Passport
  80. '00 3.2L 6VD1 Valve Adjustment
  81. 94 Passport 3.2L starting problem
  82. 94 Passport 3.2L starting problem
  83. Coolant Crossover o-rings?
  84. 99 Isuzu 3.2 - upgrading to larger oil filter?
  85. '99 Rodeo - won't start after accident
  86. I almost sold my Rodeo
  87. EVAP Canister Vent Solenoid
  88. Shocks to replace ISC ones.....
  89. 04 rodeo workshop manual
  90. crankshaft position sensor on 99 isuzu rodeo
  91. gas gauge not working? same for 94 rodeo?
  92. 2000 Passport Rear Wiper not working
  93. New brakes and Front Bearings $1000????
  94. Wipers come on with turn signal
  95. new timing belt wearing very fast.
  96. Worn timing belt
  97. Free Cupholder for '90-'96 Rodeo!
  98. New Isuzu owner.....
  99. another oil guzzler
  100. My smoking 01 rodeo..
  101. Key won't release from ignition
  102. 98 Rodeo 3.2 4x4 code p405 help!!
  103. Really stupid problem.
  104. Harmonic balancer
  105. 97 Rodeo accelerator cable
  106. 97 Passport Timing Belt Replacement
  107. What are you buying your Zu for Xmas?
  108. 95 Rodeo Repair Manual
  109. 2001 Rodeo 6cyl - Timing Belt or chain??
  110. Anyone DIY remote start?
  111. 2004 3.5 Rodeo Will Not Start
  112. 04 Rodeo 4wd Problem
  113. still having problems with my 3.2
  114. 96 Rodeo 3.2 no power and sputtering until TPS is > 60%
  115. 98 Rodeo 3.2 4x4
  116. Red Dust? All Over Pulleys
  117. really LOST need help!!
  118. Fog light install
  119. 1999 Rodeo Manual transmission removal
  120. Name that ride
  121. Brands of Timing Belts, Water Pumps, Hoses
  122. 2000 Isuzu Rodeo Engine "stumbles"
  123. How do I post pictures?
  124. Winter mode question
  125. Which Aftermarket Air Intake for '95 Rodeo?
  126. 4x4 problem
  127. 94 Rodeo auto hub 4wd won't engage
  128. 98 rodeo coolant leaking
  129. Code 0101
  130. Cooling Fan constanly running
  131. my rodeo's
  132. what are the rust prone areas on a 2000 rodeo?
  133. 2001 isuzu rodeo 6cyl stalls but will start right up
  134. tranny slippage
  135. trailer wiring?
  136. All I want for Christmas is a flashing Check Engine Light....
  137. cooling problem
  138. Changes to my 99 Honda Passport..
  139. 99 isuzu rodeo
  140. Leaking pink stuff...
  141. Need dash button "blank"
  142. clunk noise in rear on turns
  143. CV Boots & warranty
  144. tranny problem need help
  145. 2004 rodeo idle air control location
  146. 2000 Isuzu Rodeo factory alarm
  147. Engine rev at start up
  148. Blowing fuse for reverse/signal lights....
  149. EGR 401 code and old CAT
  150. No power windows or locks from driver side
  151. '98 Rodeo overheating\pressure problem | any ideas?
  152. '94 Isuzu Rodeo TPS - What's it look like inside?
  153. Atf
  154. Antifreeze
  155. Headlights and Cornor Lamps.
  156. curious to know...
  157. Loose steering 97 rodeo - cause?
  158. Pretty much every O2 sensor code just came up NEED HELP!!!
  159. horn buzzer Defeat procedure? 1999 Rodeo
  160. Look it's magic...oil loss but no source
  161. egr valve and egr backflow transducer
  162. Changing the FSU
  163. Check engine light and Emissions
  164. My 94 Passport wont start after sitting for 3.5 months
  165. engine codes?
  166. Offroading
  167. Need transmission help 2000 Rodeo AT 4WD
  168. program for keyless remote for 2004 Rodeo
  169. Check Transmission and Cruise set light come on.
  170. 2001 Rotors
  171. Transmission slipping
  172. Wtf!!??
  173. code 0175?
  174. I know it's the alternator but...
  175. Starting Problem
  176. Misc. Problems
  177. Shifter button sticking.
  178. how big i can go?
  179. Cruise control question
  180. Shifter cable pics?
  181. Qestion on 4x4
  182. Head Gasket Replacement
  183. Insane leaking
  184. Bad Fuel Smell
  185. 92 rodeo hesitation
  186. pressing brake stops LEFT turn signal
  187. 1999 Isuzu Rodeo with some troubles - RPM flux/idle stalling/wont start
  188. O2 Sensor Part Number
  189. Sold my Rodeo
  190. Sold my Rodeo
  191. Challenging squeal
  192. disable abs on rodeo 2004
  193. Anyone Replace Muffler on 96
  194. im leaking
  195. Hood Release broke...HELP!
  196. I'm baacckkk.....had some
  197. ('00 Rodeo) Negative or Positive Ground/Siren & PA install
  198. 1995 vs 1995.5 Passport
  199. 1993 isuzu rodeo 2.6L
  200. 1995 Isuzu Rodeo wont start
  201. 99 Rodeo won'tstart no spark
  202. 97 rodeo misfire..... any suggestions?
  203. Scan tool suggestions
  204. Isuzu tf low power
  205. Nightmare body work at California shop
  206. No brake lights or cruse control & can't get out of park after the engine has starte
  207. Flex Pipe / Exhaust
  208. Starter
  209. How do you use HEAT only on windshield defrost setting
  210. 2x4 '01 Rodeo Sport owners, I'm preparing for Kansas winter
  211. Surge and stall problem.
  212. Surge and stall problem.
  213. 88 isuzu amigo o2 light on spits and sputters.
  214. 94 Rodeo Engine wiring help
  215. 2001 Rodeo EGR Valve Location?
  216. disconnect torque converter clutch connector from transmission
  217. 2000 rodeo clutch
  218. Rodeo glove compartment lock stuck
  219. Failed Emission Test. What should be my next step?
  220. Transmission rodeo 2004
  221. 01 Rodeo ABS codes
  222. 1993 Isuzu Rodeo 3.2L 4x4 -Honda Passport question
  223. 2002 4 cyl Rodeo low power and overheats
  224. Cranking the torsion bars = bad tire wear?
  225. help
  226. Timing belt/Hesitation question....
  227. Window motor - how tough to change?
  228. 1993 Rodeo... Need torque specs...
  229. 245/75/16 vs. 245/70/16?
  230. automatic hard shift sometimes
  231. P1220 code
  232. 93 rodeo PLZ HELP!!!
  233. Transfercase/4x4 Issue
  234. Key Broke off IN ignition...'97 Rodeo
  235. Can I put drive flanges on a 94?
  236. Calmini 2" lift
  237. 1998 Rodeo ABS Light
  238. 93 rodeo wont start, heres the symtoms. help please
  239. 93 rodeo ecm help. wont start
  240. I Need Help!
  241. Misfire, smoke, loud ticking, hard to start
  242. Automatic Transmission Fluid Leak
  243. isuzu Rode hood latch
  244. Isuzu Rodeo, Fuel Sending UNIT problems
  245. '01 2WD Hub to Rotor Bolts Torque Specs?
  246. 98 Rodeo starting problem
  247. obd p0452
  248. looking to buy rodeo. what to look out for
  249. anti theft alarm
  250. 95 Rodeo bucking and stalling
