View Full Version : Rodeo/Passport
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. info needed please
  2. Intermittent starting problem '98 Rodeo...
  3. Isuzu Rodeo 1995 FWD
  4. engine codes 171b 172b 174b 175b
  5. Joe Isuzu
  6. Torque Converter Clutch Solinoid
  7. Bye bye Isuzu, effective 31Jan2009...
  8. 98 Rodeo Engine Sputtering Problems
  9. 2000 Rodeo Fog Lights
  10. Rodeo hits the wall at 4,500rpm! Why?
  11. 95 Passport, vibration/noise. HELP!!!
  12. 2001 Isuzu Rodeo HELP PLZ!
  13. Transmission filter change Problem &%#&)
  14. 1997 Rodeo Transmission problems
  15. Heater light off
  16. 94 passport stutter, rough idle and accel
  17. 94 Rodeo occasionaly dies
  18. 2000 Rodeo ECM ??
  19. emerg brake lite and bat light on
  20. Back glass on 96 Rodeo compatable with 97 Passport?
  21. A Leaky Mystery
  22. remove timing belt idler pulley? 95 Rodeo
  23. P0502, P0401
  24. Word of caution for auto tranny owners....
  25. Freakin Spark Plugs!!!!
  26. 98 Rodeo Issue with Coolant/Radiator
  27. Arrghghgh! THIS is the reason I treasure
  28. 2000 izuzu rodeo
  29. Rough Running?
  30. need some input
  31. Changing the upper radiator hose
  32. 92 Rodeo Heater Core
  33. front grill guards
  34. 1995 Rodeo - replace passenger side headlamp?
  35. Question about warranties....2nd owner
  36. 4L30E Drain Plugs
  37. New Mystery
  38. Can you reset the "Check Engine" light
  39. flywheel, torque converter, or worse?
  40. which brand of spark plug - 2001 rodeo
  41. 95 Rodeo OBD-1 Scan Tool
  42. new oil leak
  43. Problems with FAQ!!
  44. Passport or Montero
  45. 97 rodeo overheated is it dead?
  46. 99 Passport rough idle then no start
  47. Surferfletch/FL 3.2......are you still
  48. Cold Idle Speed
  49. 1999 rodeo
  50. Crack in transmission housing at drain plug
  51. Rear pads for sale 99 rodeo
  52. 95 Rodeo Coolant Leak on Top
  53. Oil pan plug size?
  54. its freezing and i have no heat!!! help!!!
  55. 2000 Isuzu Rodeo Pricing
  56. 1997 Rodeo/dies when foot is off accelorator
  57. Transmission Fluid Change
  58. I Need Help With 95 Rodeo
  59. 99 Rodeo Rpm Problem
  60. Power Steering
  61. Rodeo wont start.
  62. Destination le or at??
  63. 99 Rodeo Lights Flickering
  64. coolant leak
  65. Looking for some parts.
  66. A/t Oil Change
  67. Half shaft replacement
  68. new goodies for my passport (56k beware)
  69. 1997 Cigarette Lighter Replacment
  70. 98 Passport - Alarm goes off when I open door with key
  71. Wheel Alignment How to:
  72. New shocks for an 01 passport
  73. Gas Gauge Repair Fuel Sending Unit Fuel Pump Not Needed
  74. Changing brake hose.
  75. Alignment (camber/shim pack) question?
  76. Happy Holidays
  77. front bumper for 96 rodeo
  78. 95 Rodeo Timing Belt Problems
  79. Whining / squeaky idler pulley
  80. 1995 Rodeo Leaking Radiator Fluid. Please Help
  81. 2001 Isuzu Rodeo
  82. 97 Rodeo PO118 Error (engine coolant temp curcuit high output)
  83. Cat back muffler kit:
  84. 99 Rodeo ran out of gas, now won't start
  85. check 4wd light
  86. Bad MPG
  87. Replacing '98 Rodeo Headlights
  88. The vanishing Passport catalytic converter?
  89. Relay Question
  90. 98 Passport speaker sizes?
  91. Rodeo Repair Manual
  92. Tailgate won't open....
  93. 2002 Isuzu Rodeo Rod Knocking
  94. Weird shimmy
  95. windshield wiper
  96. 1998 Isuzu Rodeo Poor Idle/Power loss/Serious backfiring
  97. Question about Seafoam and CEL
  98. 2000 Rodeo FSM
  99. Rodeo dies about 3 minutes after jump starting
  100. Questions about 2001
  101. Where to get a replacement brass bushing for the door
  102. Transfer case questions....
  103. 4WD Wont Disengage
  104. coolant system frustration
  105. 5 speed dead now I have a question
  106. Shifting into Drive or Park and close to stalling question
  107. My 1995 Rodeo Just died! :( HELP!
  108. 2002 isuzu rodeo sprt
  109. 2002 Rodeo ABS Light
  110. 99 Killed
  111. 98 passport idle shut down after 7o k of running after a computer reset
  112. Check out the inside of this 4L-30E
  113. Voltage dropping
  114. 98 Passport Engine Harness
  115. 1996 Rodeo Why does this keep happening ?
  116. Just Died 1994 rodeo
  117. steering unit
  118. Which Oxygen Sensors Impact on Smog Test
  119. fuel line
  120. 2001 Rodeo thermostat
  121. loss of power...?
  122. Valve bucket holder tool V6
  123. Oh man. My rear main seal is completely shot.
  124. Dana 44 alxe questions
  125. 94 rodeo v6 stuttering problems
  126. New Starter and still won't crank!!!
  127. HELP - '99 Rodeo won't start / has good battery
  128. Installing and a Trans Cooler on a 2001 Rodeo LSE
  129. 95 rodeo speedo question
  130. 3.2L Valve Adjusting tools
  131. Help....red light on!!
  132. fuel pump power again!
  133. Tires- need help asap!
  134. Engine Swap
  135. coolant dump
  136. Do i need new shocks?
  137. Fog light
  138. Opinions on Firestone Destination A/T's.....
  139. gas gauge? has this happend to you
  140. fuel pump power
  141. Please Help 95 rodeo fuel problems
  142. HEAVY power steering.
  143. Drivers side wiper, not wiping
  144. Left Tail Light
  145. Horn keeping honking!
  146. noise
  147. exhaust leak?
  148. A/C compressor noise
  149. Location test....for you Coloradoan's.....
  150. fule pump installation
  151. ABS Speed Sensor
  152. How long to drop fuel tank and replace sending unit?
  153. trans problem
  154. 02 Rodeo Speed Hesitation
  155. 2000 Isuzu Rodeo left signal light
  156. Here's another good mystery sound to figure out!
  157. Dash lights
  158. Overheating problem...help would be greatly appreciated. (A little lengthy)
  159. P0240: Catalyst System Efficiency Below Threshold (Bank 1): UPDATE!
  160. 03 Rodeo over revving, sounds loud, like it's stuck in gear
  161. Getting rid of my '96
  162. 97 Rear leafspring bushings
  163. Got MUD.....will travel....
  164. any comments on aftermarket egr valves
  165. 98 Alternator specs?
  166. Serpentine belt to bypass A/C
  167. Chrome pieces?????
  168. What Kind of Seats?
  169. P0240: Catalyst System Efficiency Below Threshold (Bank 1) with pictures!
  170. 2001 Rodeo brakes issue
  171. Stalls and Will Not Start???
  172. Locked my keys in my '99
  173. No Power
  174. 1998+ rodeo/passport/amigo parts for sale
  175. 2001 isuzu Rodeo 6cyl,4wd
  176. Timing belt idler bearing
  177. Water soaked floor
  178. Look familiar?
  179. hose replacement question
  180. Clicking... Valve adjustment?
  181. RKE aftermarket
  182. Widest tires for a 98 Rodeo???
  183. Flickering lights
  184. 99 Passport CEL nightmare!
  185. Replacing rear left side vent glass
  186. Lights Out
  187. 92 Rodeo loosing power at 3000 rpms
  188. How do you know when to replace shocks??
  189. wheel clearance????
  190. brakes
  191. Rodeo shifter won't go into Park or Low
  192. Have a problem..was given a company
  193. Water Dripping from Passenger Side
  194. Size of tranny cooler hoses?
  195. Which Transmission Fluid???
  196. Anyone have a passport fender flare?
  197. wiper controls i hate it
  198. high idle po 507
  199. Shifting Hard
  200. 2001 Rodeo tailgate
  201. What is that butterfly thingy
  202. Rodeo stalls only with initial acceleration
  203. List of things to do and when sticky?
  204. anybody ever troubleshoot cruise on 95 and earlier rodeo?
  205. 01 Isuzu Rodeo ABS or Computer
  206. Braker Caliper Pin/Bolt Question
  207. 99 passport CEL after IMGs
  208. What a PITA weekend!
  209. Rear Cup Holder
  210. Manual Transmission Fluid Level
  211. 1995 4X4 manual trany
  212. Computer chip in 95 rodeo?
  213. Adding Remote start/keyless entry
  214. Parking Brake Light?
  215. Timing Belt problems
  216. '92 Rodeo 3.1L V6 Erratic Idle
  217. 1995 Passport 3.2L BackFires?
  218. Rodeo/passport replacement
  219. Freeze Plugs
  220. Eeek! Friend hit 5,500 rpm's...anything to
  221. Do I REALLY need the front hub nut tool?
  222. Manual Hub Install on '01 Passport
  223. Valve Shims on 6VD1 DOHC
  224. isuzu engine runs rich
  225. wanky suspension
  226. 94 passport constant stalling problem
  227. Out Of Ideas & Money
  228. power steering hose
  229. '98 3.2 camshaft timing
  230. 98 Isuzu Rodeo Engine trouble
  231. P0753 - shift solenoid electrical
  232. lock and other issues
  233. New Alternator Installed, New Problem
  234. How do the spark plugs come out?
  235. 2000 Passport Shock recommendations
  236. 2000 Rodeo Instrument Cluster or ???
  237. Deadly Warning for dog owners in TX, FL, & CO.....
  238. 99 Passport stripped EGR pipe nut. Plz help!
  239. Passport/Rodeo rims & tires Questions
  240. 1996 Passport EX For Sale
  241. 91 2.5l Diesel engine swap
  242. 1995 Honda Passport Leaking Brake Fluid
  243. 96 Rodeo Charging Problem
  244. 96 Passport Valve covers
  245. Lifting the Green Goblin 2"
  246. Stereo Installation - problem with instrument panel lights
  247. engine stalls after rough idle
  248. 1997 Rodeo suddenly dies
  249. Fuel pump dying? '99 Rodeo - Anyone?
  250. Coolant leaking from under 1996 Rodeo 3.2L
