View Full Version : Rodeo | Passport | MU
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Washer Fluid Tank Leaks- 1999 Rodeo
  2. 2000 Honda Passport - Poor Gas Mileage
  3. Funny sound from under the hood
  4. 99 rodeo wont hold an alignment
  5. New to forum - just bought a 97 Rodeo
  6. I miss my Rodeo - 3 years later...
  7. **survey** for DIY fuel sending unit
  8. 2004 Rodeo - Seat Belt Auto-Locking - can I disable
  9. Newbie with 98 Rodeo 4x4 questions.
  10. 94 honda passport missing
  11. 95.5 Passport loud ticking noise
  12. 2001 rodeo coolant leak??
  13. 3.2 Waterpump bolt hole won't line up.
  14. fog lights
  15. Newbie Here, No Start After Sitting 6 months
  16. 99 Rodeo wont start
  17. '01 cam idler bearing failure, how to remove?
  18. what can cause loss of power?
  19. 2000 Rodeo hesitation
  20. engine smells like gas
  21. Radiator drain petcock
  22. check engine on a full tank
  23. Exhaust smoke
  24. Is tranny completely done
  25. battery tenders? Dead battery issue.
  26. Keyless Entry for 2002 Passport?
  27. 2000 Isuzu Rodeo
  28. Trouble code P1627
  29. Miles or time after clearing codes ?
  30. 92 misfiring
  31. 2000 Honda Passport - Whine on Accel
  32. 95.5 rodeo
  33. Isuzu Rodoe timing
  34. 02 Rodeo Sluggish Accelerating
  35. 1999 rodeo
  36. 1992 Rodeo, 2WD, 4cyl, needs engine mounts, maybe clutch.
  37. Stubborn shocks
  38. A few minor, but annoying issues...
  39. Rod Knock?
  40. 96 rodeo 3.2 SOHC 2wd problems
  41. How to clean egr passage in 2000 Honda Passport
  42. Throwout bearing question
  43. 5 spd... how stout?
  44. Crank shaft position sensor
  45. Idle/ECU Problems
  46. Spindle/Knuckle axle seals? Help
  47. 1999 Rodeo V6
  48. Rebuild or replace?
  49. Isuzu Repair manual
  50. 1999 Rodeo
  51. Looks like my H2O pump is leaking at 45K
  52. 971/2 Passport
  53. Wierd issue that effects startup and Idle
  54. key will not turn in lock
  55. 1998 Isuzu Rodeo wont start
  56. Souping up?
  57. Timing Belt/Water Pump Change Out
  58. Replace Front Rotors for 97 Rodeo with 4wd
  59. 2000 Rodeo 3.2V6 blown?
  60. EGR Tube diameter?
  61. 1998 Isuzu Rodeo ECU Location ????
  62. ELECTRIC WINDOWS/ 95.5rodeo
  63. half shaft removal
  64. 93 rodeo wont restart! 23 auto shop owners are stumped!
  65. help please
  66. Manual locking hubs
  67. Truck changes lanes on its own....
  68. Blue Devil Head Gasket Sealant
  69. Thud...check trans, cruise control?
  70. RBS/BRAKE lights
  71. Help - Possible bad head gasket?
  72. Crankshaft pulley removal
  73. 96 Rodeo Auto No Reverse
  74. 94 Passport Won't Start
  75. what fluid does my rearend take? 2001
  76. 2000 Isuzu Rodeo "Hissing"
  77. Winshield Wiper Issue
  78. the horrid rodeo lifters tick!
  79. My transmission hesitates
  80. if your lookin to buy fuel pressure gauge FYI
  81. crank pulley slipping????
  82. 2001 Rodeo blower works 1, 2 and 3 only
  83. 2000 Isuzu Rodeo
  84. 1995.5 Isuzi Rodeo New Owner Needs Help ASAP PLEASE!!
  85. 2001 rodeo
  86. Anyone ever buy a Carter fuel pump?
  87. 95 rodeo cruise control
  88. Need help on fuel gauge
  89. 97 Valve Cover gasket
  90. 96 Rodeo Radio Problems
  91. 99 Rodeo will not go shift into park or reverse
  92. 95 Rodeo gas blow back when filling tank?
  93. blowing white smoke
  94. 1997 runs like crap
  95. Denso spark plug price
  96. 97 1/2 to 2000 Rodeo
  97. Is a radiator flush on an older Rodeo OK?
  98. Successful Starter Removal on '01 Passport 4WD 3.2
  99. 1997 blowing ignition fuse
  100. Help! What did I fry
  101. I am, I am new to this forum
  102. 02 sensor questions
  103. 99 RODEO Front Speaker
  104. How to tighten crankshaft bolt
  105. Can't get rear gate to lock
  106. Trouble Code P0341
  107. Sluggish start
  108. power window problem
  109. How tight should timing belt be?
  110. Error Codes 1997 Rodeo 4ze1 efi
  111. exhaust gasket
  112. transfer case fluid fill??94 rodeo m/t
  113. 1996 Rodeo trans fluid drain fill / replace
  114. manual trans 94 rodeo transfer case???
  115. 95 rodeo/ 2000 passport engine compatibility
  116. Farewell 1998 Rodeo LS
  117. 95 rodeo
  118. 03 Rodeo replacement engine
  119. Whistling @ 2500 RPM
  120. help diagnosing sound
  121. Help! Surging and frequent stalling when A/C is on!
  122. Squeaking front end driving me nuts!!
  123. sluggish acceleration
  124. 1992 rodeo bad fuel pump
  125. transmission removal/transfer case 94 rodeo M/T
  126. 1995 Honda passport stuck in 4wd
  127. Re:Sounds like marbles in motor when I accelerate
  128. '96 Rodeo brake and ABS lights constant
  129. Running hot, AC cuts off
  130. finding a bad gas leak
  131. Lean on Both Banks
  132. How much Seafoam?
  133. '95 Rodeo 4cyl./5sp. random stalling
  134. 99 4WD Rodeo LSE ABS lights up driving over 70mph.
  135. 96 Rodeo, Won't Charge Properly
  136. P0442 code- purge solenoid need help
  137. 94 isuzu transfer case help
  138. Leaking valve cover ...
  139. Fixing it the Old Fashioned Way
  140. 1997 Left Rear Window Regulator
  141. Want to change Rodeo trans fluid?
  142. ABS sensor problems
  143. '93 Rodeo 4WD right front wheel noise
  144. CEL p0442 Can an exhaust leak cause this code?
  145. 2004 Rodeo burns 1qt oil in 3K miles
  146. Error code P1403 Rodeo 2002
  147. 92 Died and won't start
  148. Please help with my dumb transmission!
  149. 2001 Rodeo Reduced Power Light
  150. trans fluid-flush it or change it.
  151. suspension/handling recommendation
  152. brakes again.
  153. Stopped on Hwy and won't start
  154. new engine codes for me
  155. Starter??
  156. Air Conditioning
  157. Engine ig fuse keeps popping
  158. Speedometer-wacko
  159. 98 Rodeo Starter Issues
  160. Intake manifold
  161. 01 Rodeo fan belt replacement
  162. 1995 Passport sounds like a diesel
  163. map sensor
  164. 1996 Rodeo factory am-fm cassette
  165. Safety check before I try to add trans fluid
  166. Teeny Tiny light bulbs
  167. FOB Issues
  168. transfer case/transmission
  169. transfer case pull/install? 94 rodeo 3.2
  170. Stripped EGR bolt hole
  171. Radio problems
  172. 1999 Rodeo LS V6 spark plug/coil diagram?
  173. 92 with starter problems
  174. To buy or not to buy transmission
  175. Fuel Injector o-rings
  176. low compression on rebuilt 4ze1 motor
  177. 1999 Isuzu Rodeo - Won't Start After Long Distance Driving
  178. rodeo efi 4ze1 motor kicks but wont start
  179. 1996 Passport, battery crosswired
  180. rodeo 4ze1 efi kicks but wont start
  181. Fuel Gas Sending Unit Rodeo 1998-2002
  182. Thunking when turning
  183. P0440 continous -Solenoids good
  184. 1999 Isuzu Rodeo, bad knocking noise
  185. Parking/E-brake
  186. Will GM 6 lug wheels fit my 92 rodeo
  187. Crankshaft wont turn
  188. 94 Psprt 3.2L4x4 diesel swap, wasting my time?
  189. Audio help?
  190. 2000 Rodeo - Knocking, Rough idle, misfires, surging
  191. Fuel pump problem
  192. Rear cam plug leaks...
  193. Cracked block?
  194. 1997 Rodeo Suspension
  195. transfer case issues???
  196. Wix Oil Filter
  197. #6 coil
  198. Radio change question.
  199. running rough- fuel filter/pump/system?
  200. Looking to buy
  201. My "new" Rodeo is finally ready!
  202. Isuzu Rodeo and Honda Passport same?
  203. random misfire code
  204. decarbonize?
  205. Fan in front of radiator in 97 passport
  206. First time doing a larger job successful :)
  207. computer system
  208. Electrical connections to 94 Passport 5 speed
  209. 93 Rodeo cranks but won't idle. Help!
  210. Blower not working
  211. 95 Rodeo, 1st gear will not kick in....
  212. Hello friends of the rodeo isuzu engine is so noisy?
  213. hello my freinds i from guadalajara mex. I need your help to find the harness that co
  214. power steering fluid leak
  215. 1995.5 3.2L V6 Engine
  216. 1997 Honda Passport Timing Belt Issue
  217. Transmission Control Module
  218. 1999 rodeo..wobbing sound while driveing slow
  219. Can the 3.5 replace the 3.2 in a 2001 Rodeo sport?
  220. Can 3.2 replace the 2.2 in a 2001 Rodeo Sport?
  221. 2004 Rodeo with 3.5L DI CEL ALERT
  222. TIMING belt and tensioner
  223. 2001 4 cylinder dead after oil change/ flush
  224. new img: now high idle.
  225. ticking like its nearly out of oil
  226. CEL Help
  227. 01 Isuzu Rodeo, Clicks Once, Won't Start
  228. Engine noise
  229. CEL is flashing, HELP!
  230. Engine pull update.
  231. 01 Isuzu Rodeo 15a ECM Fuse
  232. accumulator Piston Cover.
  233. check engine light and reduced power light
  234. help needed-bizarre electrical short on 99 passport.
  235. Misfire causes?
  236. 2nd Gen Intake Manifold Gasket
  237. bleeding 2000 rodeo ABS modulator... Help!
  238. Code P1171
  239. WHOA. not what bucking snorting backfire
  240. Negative / Positive Speaker Wire , 01 Rodeo
  241. Rear Diff Maintenance
  242. Thanks from a lurker!
  243. Running out of ideas, 95 Rodeo
  244. what is the tank size?
  245. Axel/CV Boot
  246. '97 w/ headlights but no parking lights??
  247. 95.5 air bag
  248. 99 rodeo rear wheel lugs
  249. '99 2.2L p0301/idle help
  250. Engine Rev in Park
