View Full Version : Rodeo/Passport
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Maintenance Questions
  2. need white fender
  3. Once again, a couple of questions from me about the isuzu. :D
  4. Headlight and grill swap
  5. Install 04 engine in my 99?
  6. Jack for 2004 Rodeo
  7. Optima Battery for a 2002 Rodeo?
  8. 1997 Honda Passport Locking Lug Nut on Spare
  9. Power windows still roll down with ignition off?
  10. Transmission fluid leak at torque converter cover plate
  11. Alternator 1997 Rodeo 3.2
  12. Intake Air Temperature Sensor 02 V6?
  13. want my rodeo back
  14. 99 Passport. Which way to turn caliper bolts?
  15. Sewing MAchine Noise
  16. 99 Rodeo- Front License plate installation
  17. antifreeze in sparkplug tube
  18. Timing Belt
  19. 95 Rodeo Overheating!!!
  20. A bunch of thoughts in one topic.
  21. Wiring Diagram 94 Isuzu Rodeo
  22. tranny question
  23. 00 Rodeo A/c Problem
  24. fuel pump
  25. 1992 rodeo hesitation
  26. Tail lights and dash lights
  27. Alternator source
  28. 2001 rodeo no power
  29. 2001 lower ball joint advice
  30. Performance Chip for 2001 Rodeo
  31. OT: firefox 3
  32. emergancy brakes useless
  33. Cooling Fan
  34. Another tranny fluid swap.
  35. 1996 Rodeo Won't Start.
  36. Rear pads lasted 4 years
  37. 1998 Rodeo starting problem
  38. AC Problem
  39. 1997 Passport Optimum AC presure
  40. Air Conditioner Charge too high?
  41. Technical service bulletins
  42. Selling a great 95 Rodeo in SoCal
  43. rodeo compressor turning on and off constanstly
  44. KN air filter
  45. 1997 Rodeo Air Compressor Question
  46. broken bolt while instaling hitch
  47. 98 Honda Passport ABS problems again!?
  48. Parts for a 2001 Sport soft top
  49. CEL is on, NEED HELP
  50. waste of time--
  51. 97 rodeo 3.2 coolant leak. Help!
  52. Cargo net '01 Rodeo Sport
  53. 1994 Rodeo Rough Idle and CEL/Fuel metering system error code
  54. recharging 2000 isuzu rodeo
  55. recharging 2000 isuzu rodeo
  56. 01 Rodeo Whistling Noise
  57. 98 Rodeo Left Turn Signal
  58. Starting with new timing belt
  59. Rodeo no more
  60. timing belt hydraulic tensioner
  61. 1997 driver door wont open from inside
  62. Timing alignment question
  63. Charging A/C
  64. Check Engine Light - PO401????
  65. 97 3.2 valve cover HELP
  66. Non INtrusive 3.2 98?
  67. 94 Rodeo A/C Not Working
  68. Question Regarding Towing Wiring Harness for 99 Rodeo
  69. New user with questions about Lift, Tires, Shocks... I searched already
  70. 1994 rodeo only starts once every 40-50 tries...
  71. Is this right?
  72. Moab zuzoo XI 2008
  73. AAMCO taking me for a ride?
  74. New Rodeo owner with a few questions....
  75. Tran Service? Pass/Rodeo/Worth it?
  76. A/t
  77. 2000 Passport AC/Heat Faulty Controls
  78. Cold Shift 98 PASS/RODEO
  79. 1993 V63.2 4WD S water leak on pass side
  80. 98 Pass/Clunk Kaboom in rear at traffic light
  81. I Wonder
  82. Major tune up order/ stereo question, new owner
  83. 94 Passport 3.2l misfire
  84. Soft Top 2001 Rodeo
  85. lock-up clutch slip control
  86. driving with tail lights stuck on
  87. Where To Add Refrigerant Oil?
  88. Help Please!!!!!
  89. any one got ideas
  90. 1999 Rodeo AC
  91. reduced power coming on
  92. Back Light for the gear shift.
  93. For Sale:
  94. Recommended repalcemant parts
  95. 99 rodeo ghost
  96. 96 Rodeo Won't Crank
  97. 98 rodeo spark plug gap
  98. 1995 passport wont crank
  99. 2000 Rodeo Gear Selector
  100. 1996 rodeo dash "gear indicator bulb #"
  101. Loud Engine Knock below 2,500 RPM
  102. smoke from engine
  103. Possible '01 Rodeo Sport owner here-help?
  104. Timing belt tensioner on a 95 Rodeo?
  105. rodeo
  106. 4low Problem
  107. How much are you paying now?
  108. suggestion to Amigo-2k: reorder table of subforums
  109. air condition filter...where is it RODEO 2002 LS
  110. 99 Passport IMG every two years!
  111. I needed new Catalytic converter...bad gas mileage!
  112. Powre Lock Fuse
  113. 97 Passport BIG PROBLEM!!
  114. *VERY* Noisy Fuel pump
  115. fuel injector clips
  116. Random Multiple Misfires.
  117. first two probs with 2002 rodeo-need advice!!
  118. 1999 rodeo head gasket replacement
  119. installing a trailer hitch for the rodeo 2004
  120. 2001 rodeo shift lock trouble
  121. Wheel size question?
  122. 95 Rodeo No Overdrive?
  123. 1999 Rodeo 2.2 4 cylinder
  124. check engine light OBD Codes
  125. Noise coming from engine area.
  126. 95 passport bleeding clutch?
  127. Abs/brake Light
  128. 2000 3.2 V6 Lse
  129. Do RS9000XL (RS999214) fit non-lifted 98+ rodeo's
  130. Bad misfire 97 Passport
  131. Tick Tick Tick Dead
  132. Help with engine timing on 99 Rodeo 2.2
  133. first real issue
  134. growling noise when applied brakes rodeo2004
  135. Need Fuel Pump Hangar/housing Asap
  136. 95 Rodeo Lower Control Arm
  137. Grinding or sort noise in engine area..
  138. Vibration
  139. Flush the rodeo trans
  140. fuel pump rodeo 2004
  141. bogging or just plain cutting out
  142. 911 with passport need help
  143. Speaker advice.
  144. yet another problem for my p.o.s...
  145. ATF fluid flow diagram for rodeo 2004
  146. 95 rodeo pitman arm
  147. brakes lifetime for Rodeo 97
  148. check trans fluid on rodeo 2004 with dipstick
  149. Replacement Seats 99 Isuzu rodeo
  150. 97 rodeo 4WD rr.abs and brake light on
  151. Compression question and valve stem seals
  152. AT filter for rodeo 2004
  153. Starter Problem 1997 Rodeo 3.2 2WD
  154. new washer for Transmission pan?
  155. 99 Rodeo V6 3.2 Manual 5 Speed Clutch Friction point a bit high???
  156. Slight to medium shimmy when braking - '99 Rodeo
  157. ghetto wheeling vid
  158. 96 Rodeo 3.2L V6
  159. I.D of oil cooler hose on rodeo 2004
  160. Passport Sensor locations
  161. 1996 Rodeo p300 error code
  162. 98+ 3.2 A/C recirc. door?
  163. Passport won't start P1311/12
  164. 95 Rodeo CV Half Shaft Assembly
  165. Help finding parts
  166. 99 rodeo has miss . need help
  167. Keyless remote programming
  168. 2000 rodeo 2.2 l will not start. Hellp
  169. new shoes
  170. 2001 rodeo please help me
  171. 93 rodeo fuel pump bad?
  172. Yet, Another Question
  173. performance parts
  174. Idle problem 1999 Rodeo 3.2 automatic 2wd
  175. Blinking gas gauge
  176. Engine Cooling Problems
  177. How do I repair tailgate latch?
  178. 1994 rodeo lossing power
  179. 1991 Rodeo Low Idle Low Oil Pressure
  180. Climate control is stuck on heat
  181. Questions about a couple of codes
  182. problem with 98 isuzu rodeo
  183. isuzu Rodeo 95.5 Blower problem
  184. Rear End Popping - Possible bushing?
  185. Need the Y pipe
  186. 1998 Passport Timing Issues
  187. Where can I find some parts.
  188. 94 passport fuel pressure regulator question
  189. Another tranny problem
  190. help tranmission problem
  191. 2000 Rodeo LS Cassette in reverse
  192. interior lights going off
  193. 2004 Rodeo high RPM when cold
  194. Rotate Crankshaft Backwards?
  195. Passport runs lean
  196. cold start transmission problems
  197. how do i get mor gas mileage?
  198. 1999 rodeo - fuel gauge
  199. Code P0171
  200. drivers side window switches
  201. New & Used 98 Isuzu Rodeo Parts for Sale
  202. Isuzu blower surging
  203. Serpentine belt wear problems
  204. Replacing the Center link on 97 Rodeo
  205. Unknown coolant leak
  206. New to Forum:99 Rodeo no heat.
  207. High output Alternator Replacement...
  208. Disk Brakes 1997 2wd
  209. Auto Transmission shifting problems w-no power/winter/checkTran indicator lights
  210. 2001 Rodeo-Rough Idle, stalls......help!
  211. 97 Rodeo - crankshaft pulley question
  212. Spark plug question
  213. service interval for timing belt. water pump etc
  214. beeps when key turned on
  215. another engine knock
  216. Lost mpg, Need Help!
  217. 1997 Rodeo Brake Issues
  218. Tips on 4wd starter replacement...
  219. Tranny Fluid Along Rear Cross Bar
  220. Vacuum leak or replace Part?
  221. Need some advice....transmission I think
  222. Trouble with crankshaft pulley
  223. transmission fluid maybe ??
  224. need an administrator...
  225. 99 Rodeo Steel Rims
  226. Timing belt tensioner, spun bearing or ??
  227. tranny question?
  228. Range sensor? help!
  229. 4wd ingaged green light always on -Help!
  230. Grinding in rear end...
  231. How to remove serp belt tensioner?
  232. Thank you
  233. Tire size up
  234. Replacing Head Gasket on 99 Rodeo
  235. Rodeo Alternator for sale
  236. Thermostat
  237. Transmission service - advice needed
  238. 1997 isuzu rodeo will not run
  239. R&R oil pump on 97 v6 Anyone done this?
  240. My 1994 isuzu rodeo shutters while maintain a speed
  241. 99 Rodeo racing and stumbling/stalling
  242. Changing water pump- info please
  243. Speed sensor replacement
  244. 92 isuzu v6 won't start
  245. Pulley Noise
  246. 120K Maintenance
  247. 1999 Rodeo tranny
  248. P0122 and P1406 codes
  249. 1999 Rodeo need tranny info
  250. 1999 rodeo surging
